Chris's Non-Inductive Coil Experiment
  • 10K Views
  • Last Post 43 minutes ago
Chris posted this 08 October 2019
I am going to show a small experiment, one that follows the works of Andrey Melnichenko and even Tariel Kapanadze's works and as we know many others.
We have discussed here before, the fact that H3 is H3 simply because H1 and H2 cancel out: H1 + H2 + H3 = H3, why is this so, because H1 is Positive and H2 is Negative! We have seen this equation before: 1 + -1 + 1 = 1.
I think with Fighter's success recently, its time for some hands on!
  • First Layer: 88 Turns.
  • Second Layer: 43 Turns.
Layer One:
Layer Two:
Turns Direction:
Layer One Inductance:
Layer Two Inductance:
Non-Inductive Connected:
Layer One Resistance:
Layer Two Resistance:
Closed Loop Resistance:
My Coil, like Andrey Melnichenko's, is 0.33 + -0.33 + 0.33 = 0.33.
Two thirds of my Coil is canceled out. My Circuit looking like this:
  • L1 and L2 are Non Inductive.
  • L3 is Inductive.
If this Coil is carrying 1 Ampere of Current, and exactly one half of the Coil is Non-Inductive, then Turn for Turn, only 45 Turns will create an M.M.F, which is considered as 45 Turns x 1 Ampere = 45 Ampere Turns or 45At.
Science tells us, that Turn for Turn, where we have Non-Inductive part of the Coil, this part of the Coil does nothing! Creates no Magnetic Field, therefore does nothing.
However, from Experiment, we know that this part of the Coil DOES do something! Remember Floyd Sweets paper: Nothing is Something, this is the same!
At Resonance, we have a perfect Standing Wave! We know this as Magnetic Resonance! Where each Magnetic Field is 180 Degrees out of phase:
Now, straight away, we should see a problem! Why? Kirchhoff's Current Law says the Current must be equal at every node, but we have Turn for Turn, one Coil that is Inductively Zero, and another Coil that has only a part of the Induction canceled!
In the specific case of positive charges moving to the right and negative charges to the left, the effect of both actions is positive charge moving to the right. Current to the right is:
I = da+ / dt + da- / dt
Each node does not equal the other, so the Circuit must balance out, Current is Increased as the Standing wave shows us.
Remember what Induction is? See here: Non-Linear Inductance
Induction gives us an approximation on the Coils ability to carry a Current: L = ε / di / dt
By Bringing a Coil arrangement like this into Resonance is our task.
Where each Electromagnetic Wave travels in opposite directions. One through the other in the same space.
THE NATURE OF SPACE
Space itself is the ability to accommodate energy. Consider for a moment the following illustration:
A signal (energy) is transmitted from point A to point B. A and B are separated by a finite distance. Consider three periods of time:
  • The signal is launched from A.
  • 2) The signal resides in the space between A and B.
  • 3) The signal arrives at B.
If (3) occurs simultaneously with (1) we say that the signal has traveled at infinite velocity. The signal has never resided in the intervening space and therefore there exists no space between A and B. A is virtually at the same point in space as B. For real space to exist between A and B it is necessary that a signal travelling between them be "lost" with reference to both points for a finite period of time.
Now we know that for real space to exist between two points a signal travelling between them will propagate at a finite velocity c, ( c = 1 / √με )
If a signal will not travel between two points, as in the case when c = 0, then we can also conclude that there is no link or intervening space between them.
Ref: Floyd Sweet - Nothing is Something.
Floyd Sweet tried very hard to make c = 0! What does this mean? It is simply a Standing Wave, a Team Wave was used:
It is a simple matter using the equations E / H = √με and c = 1 / √με for a team wave to get rid of H and c and so convert the first equation into the well known equation for energy density in the so-called electrostatic field.
I have pointed out: Why 'C' is equal to One in these Devices.
We have a lot of data!
I am going to show Transformer Coupling, to drive my Experiment.
Input Coil Turns: 2 Layers 37 + 39 = 76 Turns.
The Input Coil:
Input Coil Inductance:
Input Coil Resistance:
You can see, I have less turns than the single Layer on my Output Coil, first layer, but the Inductance is higher:
  • 84 Turns compared to 76
  • Inductance of 395 compared to 412
Geometry, the Length of the Coil plays a role here.
The Resistance is almost the same: 0.4 compared to 0.4, no visible difference.
Next, I will show the drive on the Coil, from my Switching Unit.
Jagau posted this 09 October 2019
Excellent Chris
I think the junction between L2 and L3 will give you double the input power?
Chris posted this 09 October 2019
When you say:
I think the Current will double, but double from what to what, I will show more soon.
Best wishes
Sorry I thought it was a replication of melnichenko when he said this
Since the current in the coils of the same, we believe the resulting voltage in the time T2 is twice to the accumulation of energy
expended at the time t1.
Yes, you are correct in this situation! As we have 2x the turns on the First Layer and the Capacitor is directly connected through the Diode, then 2X the Voltage will be present at the terminals.
This is of course only true when the Coil: L2 is shorted in the above diagram. When L2 is un-shorted, then the Circuit will only have the Voltage of a Single Coil.
I have a little more to add soon.
I was called away, sorry.
We have some open doors with the above circuit, it is not clear, and in-fact it is confusing as to its operation. I want to specifically show something. The Circuit above compared to this circuit:
We are looking at some circuit differences! In fact, we have several different Circuits in the document here: Генератор на нелинейной индуктивности
What we know to be true, is the Circuit used is more like this:
Which as we know was the working model, when it was stated:
A working model by Valery, free-energy@list.ru.
Improving the coach, you can create the perfect coach, but first-class car - barely. (Edward de Bono)
Energy generator in the nonlinear inductance
Developed and assembled the unit with an efficiency of greater than 1. Working in self-maintaining, with the releasing enormous amounts of energy it takes to glow lamps. Valery.
We know this to be in-accurate! We know from research the circuit was the Circuit pointed out above, and again here:
You can find a lot of data here: Akula's circuits- is this the principle?
The quote:
The essence of the research: obtain convincing theoretical, computational and experimental evidence for the possibility transgeneratsii electricity from non-additive (non-linear) properties of the energy of electromagnetic fields and waves. The experiments are quite simple and easily reproducible in any special laboratory. This work is the development of some interesting ideas about the physics of Tesla radio and the possibility of generating energy from non-linearity of the energy field. The work is not contrary to modern physics, electrodynamics, well grounded in theory.
Ref: Andrey Melnichenko - Common-mode interference of electromagnetic waves and transgeneratsiya energies.
The point, I am trying to make is, we must follow the path of proof. Proof, hard data is going to be where we make huge leaps forward like we already have!
The document: Transgeneratsiya electromagnetic field energy, make a huge effort to deal with Electromagnetic Waves and specifically:
So we see that for the addition of two opposite-traveling electromagnetic waves resulting electromagnetic wave power increases by four times.
The method of operation is Electromagnetic Waves in Opposition.
I hope this research helps some!
Chris posted this 11 October 2019
Its taken a while, I have been pulled away a few times and also had a few other problems to deal with.
The following Video is Long, so beware. Its also a video aimed for beginners!
I hope these experiments prove to be useful to others!
Another Video, this time a bit of understanding on what we saw in the Experiment in the first video.
I hope this video is useful for all!
Vidura posted this 11 October 2019
Very well done this video, really good and simple explanation of the principles, I recommend to all to watch it, it is also good for those with advanced understanding to keep in mind the basic mode of operation, the goal to reach. Vidura.
Chris posted this 13 October 2019
As I said in the last video, I needed to drop my turns down on my Input Coil. This is an Image:
So now I have an input Coil of: 12 Turns.
This is a difference of: 76 - 12 = 64 Turns. Also because, as was also stated, we have whats called Unity Coupling now, we should get much better Coupling from Input to Output.
Remembering, we do only have an effective 45 turn to 12 turn Coupling. So that's a step up of: 3.75
A video is currently being processed.
Chris posted this 16 October 2019
Hey guys,
Well, the last week has been very busy!
I must Apologise. This video is very bits and piecy! Many distractions and a few technical problems has led to a video that may hold value, but will require a patient viewing.
A lot of info in this video, much of it is known, some is to try to encourage forward thinking.
The next video will be more helpful!
I ask you the question: "Whats the biggest problem we have seen in my videos"?
I let you ponder this...
Jagau posted this 16 October 2019
excellent video to make our brain work.
One of the recurring problems that I see is taking measurements with the right tools and the right technique.
when you say:
Would you mind expanding what you mean?
In the thread of Vidura ''measures'' we talk about it extensively but it is good to refresh our memory.
A good link for the technique:
https://www.electronics-tutorials.ws/accircuits/average-voltage.html
For measuring devices, some voltmeters are not at all effective and often can be misleading depending on how they are built.
Towards the end of your video we see it at 31:50 the oscilloscope is more accurate than the multimeter.
Chris posted this 17 October 2019
Yes, Digital Multi-meters ( DMM's ) are a very rough estimation and should not be considered accurate if one is working at reasonable frequencies.
in the mean time, how about:
Any ideas on what the biggest problem is?
Vidura posted this 17 October 2019
Hey Chris, I like the accuracy in your coil build. Regarding the question I would say it is not resonant still, that is the difficulty. Note that the formula for the antenna resonance references to longitudinal waves, I would guess in your experiment the waves are transverse, maybe the energy level is too low to setup predominantly longitudinal oscillation? Vidura
Zanzal posted this 17 October 2019
You asked, what is the problem with your videos? That's a very subjective question. The most generic answer is that you need to identify your audience - those who you think will or who you want to benefit from seeing your video - then you need to tailor your content to convey the message you want that audience to receive. Not everyone can appreciate every video, some videos will be more helpful to those at a certain level of experience. People may complain, but those people who complain may not be your audience anyway.
I personally would recommend you just focus on producing what you want to produce and not worry about what anyone thinks, but since you asked, regarding your video for me it spends a lot of time showing what could be shown in a much shorter video. If you wanted to demonstrate 3 different configurations to show which had better results, it could be done in much less time. For me it was 1 minute of new information, spread across 40 minutes. Don't feel bad though, I watch a lot of videos on 2X play speed because it is common for people to be long-winded. That's just me. I think it is nice of you to share your experiments and no need to worry about what anyone thinks.
Thank You wink
Excellent answer, yes, you are right. However I was thinking a little closer to the operation of the system.
We know in the last video, video three, we could not get the Voltage up, even with a 1 : 3.75 ratio, that there was a choking effect. This was evident on all the coils and in this video, I show a little more, a problem that we could say The Conservation of Energy Law is Invoking at its last possible chance:
This is a very important effect, one that produces failures in experiments and gives some a final conclusion, e.g: "it cant be done"... cry
As far as I know, never been shown before, new and previously not noted or documented.
I hope this video is much better received than the last, the last was such a problem to get finished!
Hey Zanzal,
I think you have misunderstood the question I asked?
I meant the Technical problem, identifying technical problems is the goal... not so much the "long winded" problem, but thank you for pointing that out!
I apologize Chris. I don't think I understand your question. Since you asked the question multiple times today I figured you must really want someone to try to answer. Maybe you could elaborate on the kinds of answers you are looking for by giving some examples of what you expect we might say?
If you are asking something along the lines of what might we have done differently? I think for me it looked like your secondaries are both wound the same direction. I might have been tempted to wind one of them in the opposite direction. Not sure if that is what you are getting at or not.
The video: "Non-Inductive Coil Experiment - Video Four" gives us a specialized effect related to a years long problem!
Please, for all members, what might be the techniques we could use to over come the worst of the problem we are seeing? To remove the effect from our system, so we can by-pass The Second Law of Thermodynamics, Energy can not be Created nor Destroyed?
Of course, technically, we never create or Destroy, we Pump from the Source!
I don't expect the establishment to ever understand that, not this decade anyway!
Hopeful1 posted this 17 October 2019
G'day Chris,
Thanks for the video.What I got out of it was a good lesson in reading  an oscilloscope. I have bought a good one but need some lessons in how to decipher what the wave forms mean.So thanks again for spending the time and sharing your hard earned knowledge.
Tony
Hey Hopeful1,
Yes, for sure there is a bit of a learning curve on scopes. Perhaps we start a new thread on learning the oscilloscope, it is certainly a good idea!
I am certainly not an expert, however we have many experts here!
I am happy to help when I can!
The Magnetic Fields in the Core and the Coils all Interact together, there is a battle, and we need to get the Coils Voltage up so they can carry a good Current!
Jagau posted this 18 October 2019
hi Chris
You probably meant that we consume and return to the source of energy used?
Chris posted this 18 October 2019
Hey Jagau
Yes, exactly, there is only ever a Transformation Process.
This Transformation Process only ever Transforms one Energy to another, then a huge circle occurs, from one Transformation to another and so on...
Tom Bearden's Source Charge shows this:
I hope we all realise this.
patrick1 posted this 23 October 2019
i like your recent video series chris. good late night viewing ;=D.  - finally i finished the replication today. successful of course, but thats because it isnt OU. something i am still chasing via many means.    magnets and wire. i have working.  but transformers are a litttle out of my reach sadly ...  although every month im becoming more and more comfortable with the fact our planet does not have free energy products.  - because its really bloody difficult.
nice work with your scope too buddy.
Fighter posted this 23 October 2019
Not entirely true, Patrick. Our planet have free energy products, it's just those products are kept in military black projects and people are not allowed to have that. Yet. That's why we all are here, to change that.
Every time I see some news about UFOs flying in our planet's sky or in orbit it's a motivation to continue on this way, I'm telling myself "Those guys, no matter if they are our military or if they are just visitors, are powering their ships with free energy and have anti-gravity engines. It's everything right under our nose, they're showing us these technologies and the path we must follow...". 'Cause I'm 100% sure those ships don't have immense reservoirs with fuel on board to get the energy they need to do all the incredible things they do in our skies.
So no, the only reasons we civilians don't have free energy (yet) it's not because this planet don't have the technology, it's just because some greedy morons want to keep that technology just for themselves even if they obtained it in black projects using trillions of dollars took from our civilian pockets.
Chris posted this 24 October 2019
A learning video, making discoveries and working toward Magnetic Resonance:
I show many problems, and give some answers! We have a new video coming soon and the next one will be just a little better again!
We must do the small experiments to move forward!
Chris posted this 25 October 2019
Solutions to problems come from our intellect. What is our intellect?
the faculty of reasoning and understanding objectively, especially with regard to abstract matters.
Ref: Oxford Dictionary - Lexico
Our experience gives us the ability to use our Intellect to solve the problems we face! Today's video is about solving the very simple problems we have seen in previous videos!
With an average view time of: 8.46 minutes, I think my videos are too long?
We believe in the systematic understanding of the physical world through observation and experimentation, through argument and debate, but, most of all, freedom of will.
Ref: Stargate - The Ark of Truth - Alteran woman
I enjoy wise quotes...
Coming in video Seven, Asymmetrical Regauging:
On another note: over at one of the other forums we are seeing them copy our work to a tee, exactly, almost word for word. You can see here: I wish them luck, even though they are not giving anyone credit for the work they copy!
Fighter posted this 27 October 2019
Yep, they're talking directly about bucking-coils and I recognize a ZPM schematics there. It's funny how that guy "remembers" about a paper he "wrote" few years ago about bucking-coils. Sure, buddy, whatever you say... laughing
(link to larger image here)
And this guy Smudge reminds me of someone we had here who refused to share his work but was very ironic and acted like know-it-all, don't say who Sure buddy, you "did" a lot of research and put a lot of "effort" in renaming from "Romanian ZPM" to "Magnetic Delay Transformer", congrats ! laughing
Let them copy, there is a higher-purpose in what we do here, don't care if these copycats give us credits or not...
Chris posted this 27 October 2019
@Fighter,
My Friend, your'e right, there is a "Higher Purpose"!
@All Readers,
Asymmetrical Regauging is a CRITICAL aspect to Energy Generation, We always have a Regauge Period, then a Work Period. This is Critical, and also, this needs to be Asymmetrical!
I am thinking this video might be too early to share, perhaps we might not yet understand it. I feel previous Videos may not yet be understood properly?
In the following Video I show Asymmetrical Regauging: 10% On Time and 90% Off Time
This is it gals and guys, this is the Lollie!
IMPORTANT: Now, please understand, one can have Asymmetrical Regauging and still be Below-Unity! Some Fiddling is required! The Coils Slapping together Creates a Voltage, then the Current can be calculated: I = V / R
Jagau posted this 27 October 2019
WOW I just watched your last video, impressive is the word.
I look forward to trying to reproduce that.
Thank you very interesting video
In order to replicate, in your last experiment i would like to know
if the output of your H-bridge is AC square wave or pulsed DC wave?
Just a single DC Pulse, 10% Duty Cycle of 3000 Cycles per Second.
Its very easy to replicate, only getting the Diodes in the right polarity is the important thing. Worth using a Re-settable Fuse just in-case.
What I have shown is just the start!
It is the beginning of a new world of Machines!
Patience and some very serious thinking will be required to further what I have shared. I know we here have all done the reading, got the background, we already understand what I have shared, we all know the importance and what exactly to look for! So, I am here, any questions please post here or PM Me.
I would prefer to keep technical questions here on this thread so they can help everyone!
My Friends, we begin! A journey to the future!
Chris posted this 28 October 2019
An Asymmetrical System is critical to making this work!
I think we need to start thinking about the Magnetic Field, particularly the Magnetic A Vector Potential, or here, and how far past, what we think of as a Boundary, the Magnetic Field can really extend!
I posted HERE some information about this many yeas ago:
Does a Magnetic Field extend past the Repulsive Force of another? Where is it that interaction of Fields are Really Occurring?
What we see today, in Experiment, shows that more than one Magnetic Field can Propagate through a Core at any one time!
This is so very important!
What we have learnt in this thread, and of course in preceding threads, here at aboveunity.com, give us the very basis of the future technologies to come! We are truly Light Years ahead of the other forums!
Other forums are actively coping our work!
The point of this post: Stick to Facts and hard data!
Soon, if not already in progress, we will see misleading information released by other prominent members of Other Forums! They will happily Mislead you if you let them! Don't let them!
We must turn a Symmetrical Transformer into an Asymmetrical Transformer!
Facts:
To make this work, all you need is:
  1. Three Coils, two can be used but this method is not my preferred method.
  2. Two Diodes.
  3. A Core that you have enough room to move the Coils around.
BS:
They may tell you that you need:
  • Magic Magnets.
  • Magic Diodes.
  • Magic Wire.
  • Magic Input.
  • Magic Core.
  • Magic touch...
Of course we all know what BS Stands for! Don't listen to them! Ignore everything except the facts I have laid out!
My Input is like so:
The Circuit in the Video:
Which is this:
This is the other Coil, some of the data is off screen:
This is Asymmetrical Regauging:
The Input was DC 12V @400ma. Above is the Output, some data off screen, my 10x probes are not enough to accurately grab all this data.
This is just a very simple, successful experiment! Andrey Melnichenko was right, but just had the implementation wrong in the pdf he shared. I have implemented: How to build your own Above Unity Machine using the knowledge I have gained in this Thread and others. This works as I have shared for many years!
Is science and the world going to move forward and learn from these simple experiments on this and other threads? I hope so!
I hope this helps! Its easy and Simple, no need for any complication!
Jagau posted this 30 October 2019
The primary is L1
L2 is the small coil of 25 turns and it is on the primary L1
L3 is up, is it good?
Chris posted this 30 October 2019
Hi Jagau,
No, L1 is the Primary, this coil is approximately 25 turns.
L2 and L3 are both approximately 250 Turns, these are the Partnered Output Coils.
I hope this helps some wink
Ok Chris
Well understood, thank you
On the site of metglass there is a document that will probably interest you
it's about handling and maintenance to avoid rust on this type of core.
cd_sharp posted this 30 October 2019
Guys, let's pay attention, 250 / 25 = 10. Duty cycle is 10 percents. Inductances ratio is very important in making them talk to each other. In my previous investigation, if the inductances are random values without an integer ratio between them, the current did not want to flow during the off time.
dewetw posted this 30 October 2019
I love the work that you guys do, but I don't always have the time to experiment myself. However, this time I did and I got the effect that you are talking about - the saw tooth. I played around with it lots and got mere perfect saw tooth on both output coils. Other setting made output coil 1 way deliver more than output coil 2 and I can also go slightly to the other side. I even got to settings where one output coil ramps up during the off part of the applied pulse.
Now, I never saw any result where I am getting more than about 0.82 COP. How important is the core material? - I am using a high frequency ferrite transformer core, N87 material I think. Output coils are about 35m of 0.5mm enamel copper wire each. Input coil is about 12m of the same wire to give that 1 to 3 ratio that you mention. I have played around with gaps between the core halves and even removing them altogether, one side and the other and both. Those cores stick together when in contact and powered up.
My driver is based on the CREE Wolfspeed and supplies a negative going pulse very efficiently. I can easily switch into the megahetz range while only costing about 15mA at 15V to drive the mosfet - I use ZXGD3005 after the mosfet driver to drive the gate even harder/more quickly, works beautiful. Shortest pulse I can generate is about 30nS. I am using non-inductive resistors as loads. Diodes: UF5405
Is there something I am missing?
What direction should I head in next?
Core material?
Coil setup:
Driver circuit:
Output coil 1 giving more then coil 2 giving more:
Some saw-tooth under different settings:
Hey Dewetw,
Nice! Excellent documentation! Good images and also good textual description.
Let me ask you a question: In a single sentence, how would you explain the operation?
Hi, I would say:
"The input pulse charges the electrical field in the coils and as it collapses magnetically so the coils oppose one another causing the current to flow longer."
I am close?
Hi Dewetw,
I would say pretty close wink
The Time Rate of Change of the Magnetic Field of the Primary Coil ( 25 turns on mine ), Induces a Voltage ( V ), and because we have a Load, a Current ( I ) in one Secondary Coil.
The Time Rate of Change of the Magnetic Field ( Current ( I ) in this secondary ) creates a Voltage ( V ) in the Tertiary Coil and because we have Loaded Conditions, we have a Current ( I ). Both Secondary Currents Oppose each other, however one Current assists the Primary.
The time, I marked in the video @ 38 : 18:
Is Important!
This is where the Input Coil can bring the two Output Coils to maximum Amplitude as quickly as possible! This means we must look for this optimum point, Magnetic Resonance. Magnetic Resonance, where each Coil's Current is 180 Degrees out of phase, like we saw in The Mr Preva Experiment.
This point is where the two Coils reach Maximum Amplitude in the shortest possible time, the slap together, we have no Impedance of the Coils!
Here is one Cycle, marked in Red:
You can see the Ramp Up, or the Slap Together, this is important, it must be short, fast and have a good amplitude.
Compare to Tom Bearden's Asymmetrical Regauging:
We see a match.
Vidura posted this 31 October 2019
Good experiment dewetw, as you asked for improvement I would suggest to reduce the primary turns and use a thicker wire gauge, so you can take better advantage of your fast Switching circuit, and get the voltage higher. Regards Vidura.
Chris posted this 05 November 2019
I was hoping this thread would spur more work on. I get that everyone is busy these days, but it is work that must be done.
What I have shown is just the start wink
cd_sharp posted this 06 November 2019
Hey, man I put 15 minutes in it last night. No results so far. Stay tuned.
Chris posted this 07 November 2019
The evolution of the human race, is paramount! The first most important thing, over and above all else!
Some of the greatest minds have come and gone, left our small planet with tall dreams, giving the young hope and inspiration, these people have changed the world:
The problem is, there is far too much procrastination! To many do not believe in our future.
We humans, MUST start pushing greater boundaries. We must release the Limits we place on ourselves, and we must evolve.
Electrical Energy is at the forefront of our evolution! Manufacturing costs are detriment to Electrical Energy Costs.
We have some answers, we have already removed some Limits. Many breakthroughs have already been made. I cant do this by myself, I need you all to do it with me! To help me, to assist, to break through the Limits we must not let ourselves be bound to!
This and other threads here on this forum and material on my site: www.hyiq.org is here to help all.
Please, we must evolve!
Chris posted this 08 November 2019
In the first post we saw this Image:
After a few experiments, we saw in Video Six, we got H1 + H2 = 0.
In Video Seven we changed the entire equation, we got exactly: H1 + H2 + H3 = H3.
As Tariel Kapanadze said, pointed out here, Andrey Melnichenko was on the right track:
@ 37 : 07 in video: www.youtube.com / watch?v=3utQUdGDMmU
From a computer has pulled out the information about such person... Its surname is Melnichenko. The unique person, unique material with which I have had time to familiarise for the last years, who decided exactly this question. It speaks: hold a resonance and all will turn out.
As he said, it has not reached transformer Tesla. and has already begun work, to make this installation. he will make this device, to my mind, still it is not fast, but... he is very close.
We have it my friends, we have it, all we need do is further it.
The future is ours! But only if we do this together.
Chris posted this 09 November 2019
A small review:
Many experiments shared, Seven Videos in total on this thread, one with a successful result. I need you all to help me do this, I cant do it for everyone else.
Jagau posted this 09 November 2019
Another good video my friend
I can feel your concern and it is legitimate.
We are fortunate to have here a clean website with polite exchanges
and since I have been on this forum, I have made a lot of progress.
Thank you Chris for everything you bring us.
cd_sharp posted this 09 November 2019
Hey, man, I'm by your side, you know that.
Jagau, CD, My Friends, Thank You!
Vidura posted this 09 November 2019
Hey Chris, Sometimes I feel like you that there should be more responsive actions. But the universe has it's own timing, every now and then the things stuck and all seems to be difficult and all the efforts we put seems to be in vane. But then in the next moment everything changes, and without doing anything all begins to flow again . I know the effort you put to keep the forum running and sharing your experience. By the way i had a very busy time as well , so it was not possible to continue contributing . When ever I can i do it with all my love and dedication. So be patient my Friend, certainly all the efforts will bring their fruits on time, and it will help to make the world a better place. Vidura
My Friend, you are very wise! I have said a few times now wink
Thank You!
@All I have a new video, just a look at what we got in Video Seven:
I hope this helps some!
Chris posted this 11 November 2019
A new video, one with a little history. Some close ups of scope shots.
Atti, excellent replication! Nice work!
A few things to think about:
  • The input Coil Turns and Wire Gauge.
    • The input Coil will create the Signal for the POC's to Interact Together at the best Frequency / Duty Cycle.
  • Coils Coupling Factor to each other.
    • As you pointed out, the location and so on can play a role. Also what Coil is doing what to the other Coil is important.
You've done a good job at getting Effects! Well done! This is only the start, this can lead to a much better machine.
Jagau posted this 12 November 2019
Hi Atti
 I really appreciate your experiment
Chris posted this 12 November 2019
In The Mr Preva Experiment, we learned the importance of Equal and Opposite Currents in the Coils. We defined this as Magnetic Resonance.
Take our Partnered Output Coils, two Output Coils, opposing each other.
Our task: Bring these Coils into Magnetic Resonance.
Important: The Time Rate of Change one POC see's compared to the other, is Important, because E.M.F = -N dPhi/dt
POC2 sees POC1 as the Source, remember? So, the Time the Coil takes to Change its Magnetic Field, is important, very important. Because POC1's Magnetic Field, changing in Time, creates the Voltage, or E.M.F on POC2.
POC1 sees POC2 as the Source. So, the Time the Coil takes to Change its Magnetic Field, is important, very important. Because POC2's Magnetic Field, changing in Time, creates the Voltage, or E.M.F on POC1.
We have seen these potentials can be manipulated, tricked, but this is the basic rule.
Resonant inductive coupling,
another term that is apparent to magnetic resonance.
A very good article here from wikipedia explains it in another way.
https://en.wikipedia.org/wiki/Resonant_inductive_coupling
Yes you're right, but a word of hesitation, the circuits / schematics on Wikipedia are far from what we are doing, although the idea is there.
From Don Smith:
He said the same thing as few times. Remembering Don Smith used Magnetic Resonance as Floyd Sweet did, the reason I use Magnetic Resonance.
As you say Chris the schema is far from what we do, it was only to demonstrate where they are.
More often we heard MRI (imaging) or another NMR (nucelar) that refers to nuclear
.A lot of terms very confusing talking about magnetic resonance.
Chris posted this 13 November 2019
I hate to say it, a day will come, when the young, that have this technology, know it, will say;
Those dumb bastards before us, they were so dumb they could not work this out!
They paid huge Electricity Bills, and Energy so is simple and so cheap.
They will coin us as the absolute dumbest, generation of all.
I already look back, I look at the very smart people I have come across, and think to myself, surely they must know and they are hiding it. Surely this super smart person is not that dumb...
Like I said, the US Military were testing the Hendershot Motor in the 20's:
I want the next generation to know I tried, to know I made a difference.
Jagau posted this 13 November 2019
First test of Chris replication.
I think it will be better when I finish making my H brige.
With only one mosfet that's what Iget
have try with a half bridge is already better, with full bridge mabe it willbe ok
 as youcan see with 11% DTC ,2.54khz withChris schematic
others Photo to come
Nice!
One Mosfet is all you need. Or Half Bridge, but remember, you need a path back to your Input supply. Power will come back through the input Coil.
Are you getting a nice Sawtooth waveform? Asymmetrical Regauging?
Very nice!
Yes i get a sawtooth waveform but at input coil.
What do you mean by return to input a diode maybe?
Sounds like the Coils and the Diodes may not yet be correct. Sawtooth Waveform should be best on L3, with the Diode and current sense resistor.
The Sawtooth waveform is directly related to Lenz's Law and the Current that Follows.
I showed data on that in the thread: Some Coils Buck and some Coils DONT
Yes, as long as there is a reverse path, a diode via Fet, D1 via Q1 or something, one can see the Input drop as one finds better and better results.
As you know, this is for others, as L1 sees a reverse EMF, Current will flow back to the 3V Source if there is a Diode, or internal Diode on the Fet.
Thank you Atti
I will read it carefully
@Chris
Indeed an inverted diode, corrected the error on L3
Others better photo to come
Okfor the input i understand what you mean.
Remember, Don Smith, Floyd Sweet, many before us, the lessons they taught us: Use the Right Hand Grip Rule to see what Don is Saying!!!
Dont let this slip by, you may never get the chance again!
The input Coil:
I ask you, remember what we were told:
Remember what we found in the video series we have just gone through, we saw that the Change in Current is what produced an E.M.F, I have described this as Rise over Run, Tom Bearden describes it as Rise Time and Decay Time.
Why is this important?
E.M.F = -NdPhi/dt this is Electromagnetic Induction!
A very sharp Rise Time is the Change in Magnetic Field.
Our Partnered Output Coils is where the E.M.F is required.
I have provided an Electromagnetic induction Calculator:
Chris posted this 14 November 2019
A video to help explain the processes:
Jagau posted this 15 November 2019
Second trial
The frequency is lower about 2.7khz and I am getting closer.
Chris posted this 15 November 2019
A new video with some info:
Hope this helps!
Atti posted this 26 November 2019
Hi.
I would ask you.Only for information. Were you looking at input and output power ratios?
Chris posted this 26 November 2019
Hi.
Atti, Its a very simple build, you should build and test yourself.
Prove to yourself that its easy and simple to get More Energy Out than In!
Its just a way of thinking.
Chris posted this 27 November 2019
Hey Atti,
Everyone that has done the reading and Viewing of my Videos is getting the results, some better results than others. But everyone is getting the Effects necessary! The Effects can be improved upon!
It is simple, its not hard! We must force ourselves to not over complicate this!
The only way to understand this is to build and replicate this as I have shown you.
AMCC320 Equivalent Core, Two Former's, Three Coils, 250, 250 and 22 approximately. Then this Circuit:
I have advised against using Cores too small, I have given you the data, all you need do is follow it! You have one of these core, I have seen in your videos!
I do not want to listen to Non-Believers complain about measurements and others abilities! Some here are very skilled in what they do! With greater abilities than myself!
Either do it or don't do it, there is no try! This is easily achievable if one puts their mind to it!
Chris posted this 01 December 2019
On the 16th January 2020, I would have been sharing what I have learned for five years, publically. I have shared from 2005, my experiments on my website: hyiq.org, but as a figure, supporting what I have learned, sharing with others, and making myself available for questions and support, it will be five years.
We have had some successes! We have faced many battles, with Non-Believers, or Skeptics. Not that I want to battle with them at all, I just want them to stay on their side of the fence and let us be! Let us work and progress, as we so desperately need to!
After some lengthy planning, by changing the Game, we have managed to isolate Trolls from our progress!
We no longer suffer the Trolls, they have lost their war. Now out of a Job!
The other forums still suffer from Trolling, simply because they are not properly Moderated!
Aboveunity.com is unique, we are Light Years Ahead of the other forums! We have technology they have not yet even dreamed of!
They copy our work, simply because we have forced their hand! We have played a game of Catch Up or be Left Behind, and made a mockery of, as time progresses!
I have released this series of videos to commemorate this Five Year Anniversary, to show all Readers and Followers what I have been telling you is True and Correct!
Now, all of you, the ones that have Read, and Followed my work, are getting results!
After saying this, its not me making this work, its you! All of you, working to make this world a better place! Those of you working hard to understand something as simple as it is, to make progress and share their work, its you making a difference.
Please, all Readers, join us, make a Difference, Be part of something Better! Share your work here, you are SAFE HERE, I promise, just ask our other Members.
Dont forget, what I am showing you is exactly the same as an Electrical "Generator". There is no difference, except we have gone to an Asymmetrical configuration!
Chris posted this 05 December 2019
Hey Atti,
Re:
The physical direction of the L2 winding is how it is wound.
The Partnered Output Coils are CW-CCW.
The Primary, L1, was one layer over the top, same direction.
Yes you have the definitions of L1, 2 and 3 the same as I put them on the Circuit:
L1 wound on to of L2 and L3 on the other side. BUT, you can do it other ways...
I have shown before the difference between CW-CCW Coils, how one combination can be so much better than the other. Can you remember what Thread I posted this to?
Atti posted this 06 December 2019
Hey Chris.
Okay. Thanks.
I don't know what you're thinking right now. In which thread did you write?
Chris posted this 06 December 2019
Hey Atti,
Winding Partnered Output Coils CW-CW or CW-CCW can make a difference to the Output of the Machine.
I showed this on my thread: Some Coils Buck and some Coils DONT
I think most here ignored that thread, its one of the most important, showing the Interactions between the Coils, an extremely important concept, it was a lead up to this thread and its partner thread: Chris's Non-Inductive Coil Experiment
One day, there will be more interest. People only look for figures and that achieves nothing, zero learnt by focusing on the numbers. Numbers come afterward. When one has learnt the necessary effects I have shown.
  • Atti
We need to be smart about this whole concept.
An Asymmetrical Transformer is not a common concept, but the ideas are the same! We only need to expand these ideas! Its not rocket Science, its simple!
Never forget, Partnered Output Coil Two, is an Open System, An Energy input to the System that is not related in any way to the Input, it is only an assist to the Input.
I am very keen to get people working on this, its is very important!
Its all simple concepts for those that have been following!
For new comers, it may not be so simple, but never let it get complicated! Because its not complicated!
The other forums are so far behind, they are not even close to the mark!
We are LIGHT YEARS AHEAD of the other forums!
Chris posted this 07 December 2019
Hey Atti,
My Hat is off to you sir! Well Done!
Now, in all your experiments, have you had such results, and have you had such results from something as simple and as cheap as what I have given you?
You have one Input,
You have two Outputs, one is Opposite to the Input and one is Assisting the Input.
Well done, I am very pleased to see your successful results!
Yes there is always room for improvement wink
Hey Atti,
I see you have a good heart! You are an asset to our team! As are all our Members!
Re:
I've already received similar measurement data, but it's the easiest way to start. Simple and cheap.
I am glad to hear!
Its just a case of Learn Build and Share, you would agree, yes?
You could increase your Frequency, as there is some dead time at the end of your scope shot, in the waveform:
Jagau posted this 08 December 2019
Hello Atti
I wish I could use the google translator to know what is being said
in your last video,
but the button is not there.
Atti posted this 08 December 2019
Hey Jagau.
You can read the context in the other thread.
but the point of translation in the video is:
Boday: The phenomena is exceptionally interesting. Input voltage is zero now and here these electric bulbs are lit.
Reporter: At first you switched something and  a number 7 could be seen?
B: yes, there is a given voltage to start with, then the setup gets excited and the input voltage can be switched off, for instance you see I unplug the connection and the bulbs continue lighting. So this is a completely new phenomena  which now I would not like to talk about.
R:  But I would have one more question: In your setup there are still two 4.5V dry batteries?
B: The two 4.5V dry batteries feed the control electronics only.  If you consider there are 8 light bulbs of 10W power each, altogether they are 80W, and you cannot take out 80W power from two 4.5V dry batteries. I could show you the current coming out from these batteries, it is about 30mA the control circuit consumes.
R: Basically, you change the Law of Energy Conversation with this setup by showing you gain energy from nothing?
B: Well, not from nothing but from permanent magnets: their magnetostatic energy is converted into magnetodynamic energy.  This is all I wished to tell you because this setup needs further experiments and developments to get an extremely well useable and useful device for everybody.
Chris posted this 08 December 2019
Again I wish to reinforce the importance of Simplicity!
We must not allow complication!
No Magnets are necessary, no special anything, there is nothing complex, or secret to this at all!
Strictly, it is Three Magnetic Fields, an Asymmetrical Transformer, Three Magnetic Fields, or Magneto-motive Force, One Positive, One Negative and One Positive.
Please, do not allow, do not introduce any complication! It is entirely unnecessary!
Chris posted this 09 December 2019
Independent Replications have been done, some are above-unity, some on the verge. None the less, what I have shown has also been successfully replicated by other Members of this forum! With a little more work, Members will improve their Machines!
Please join in, help us change the world!
CaptainLoz last experiment is a taste of what you can achieve:
We are here to help you, join us, and we can help!
Fighters work, The Romanian ZPM,  is also another way to use the same technology, its also an excellent example of above-unity.
Please understand, this is only the start, its a taste of whats achievable!
The other forums are so far behind, We are Light Years Ahead!
You are Safe Here, we have Zero Trolls!
Chris posted this 12 December 2019
How close can people get without realising what they actually have?
I read an article the other day, just by coincidence, I came across the image, so i read the article: The Buck Regulator – Power Supply Design Tutorial Part 2-1
Look how close they get without realising the next step in the Earths most Important Problem: Energy "Generation"
His circuit is not far from ours:
If this guy saw our work, he would say I was so close!
Ask yourself, what can this Coil do:
If it had a Partner, what could they do? What could they do if they were both bought into Magnetic Resonance?
Chris posted this 15 December 2019
Wisdom, Logic and simplicity, all important doctrine's!
We need more than that, we need a code to complete our task:
We have the Technology, we need the strength!
We must push forward, share our experiments, share our experiences.
P.S: Don't forget, we don't want to many turns on our Partnered Output Coils, they must react in a timely manner. Too many turns, the Reactance is too high, then the wont work properly. 40 - 200 or so turns.
Noise is a bit of a problem on the oscilloscopes. Even at 6 million points!
Input:
Output:
If my measurements are correct, we are seeing:
17.7 / 5.37 = COP = 3.296
I have a big problem with all this noise however. Not normal in my experiments. I have checked many times the measurements, the 0.1 Ohm resistor has been checked and the Scope setup for 1 x 0.1 x 10 = 1 Ohm for a Current measurement of 1 : 1.
Perhaps I have a bad switch or something.
Please note, these figures are just an experiment I have put together for learning purposes. Much better results can be achieved as more experience is gained.
Are these results to be trusted?
cd_sharp posted this 15 December 2019
Hey, man
No, the signals need to be clean. Otherwise, the MATH function computes noise.
Chris posted this 16 December 2019
Noise on each line shows something I wanted to put out there. To say look at whats on each line!
Of course, noise does not mean real power!
I want to say, I want to be clear, what I am showing you does not create noise! It creates real Power! Pure power!
Many of us replicating this technology have already seen this, real power. Voltage and Current in phase and available like a Tap has Water.
Some mistakes to avoid:
  • Too many turns on the Partnered Output Coils, aim for around 40 to 200 of at least 20 gauge.
  • Too many turns on the Primary Coil. Aim for around 10 to 30. 22 Gauge or more.
  • Make sure you use enough Input Power to get our Output Power doing work!
  • Cross Section to small.
  • Core Composition to slow. Sluggish Core.
  • Bad Switching on the Input Coil.
  • Bad Coupling between all Coils.
  • Aim to get the Magnetic Fields Pumping, if they are not pumping, they are choked off, then its not working.
  • Feel the machine! Its a baby and you have to nurture it, bring it to life!
Each Magnetic Field, all three, has a job to do! They all have to work together, in unison, with a time frame that they must start interacting together. This machine is an Action Reaction and Counter-Reaction machine.
cd_sharp posted this 16 December 2019
Guys, for the input, the noise is symmetrical, so it averages out close to the real value (about 5V x 1A).
But looking at the output traces I realize I don't remember seeing such mostly negative noise like in the yellow trace:
With 20V per division I don't think that's noise.
Energy is always considered the Total Area Under the Curve. An example of this Area Under the Curve is:
No matter how you do it, the more Area Under the Curve you can achieve, then the More power you have, and if your'e smart enough, you can do it for free!
In a standard transformer, if the Secondary is loaded, then the Secondary carry's a Current that changes in time!
This Current Changing in Time, is equivalent to a Magnetic Field changing in Time!
I want to quote:
An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields.
Ref: A Free-Energy Device by Paul Raymond Jensen
Most of you are likely tired of me repeating myself! Please understand, I am also doing this for the new comers.
Much work to do, much to learn, much achieve...
Chris posted this 08 January 2020
A Current in a Wire is the same thing as a Magnetic Field. The Magnetic Field Changing in Time is the Source for Electromagnetic Induction.
The Magnetic Field Changing in Time is the same as a Current Changing in Time in an Inductor.
Electromagnetic induction requires several things:
  1. Turns ( N ).
  2. Cross Sectional Area ( CSA ).
  3. Time Rate of Change of the Magnetic Field ( B ).
With these three things, we can achieve Electromagnetic Induction!
What happens if we have too many turns?
  • The Magnetic Field ( B ) changes slowly in Time ( t )!
What happens if we have too small Wire Gauge?
  • Current ( I ) is restricted, slow change in time, a reduced Current Output.
What happens if our Input Coil has too much Inductance?
  • The Partnered Output Coils do not interact sufficiently to produce an Output that we require.
Balance is important in everything in life. Not too much of one thing, but too little either.
Why do we see lots of spikes in this Tech?
  • Because there is a lot of very fast transitions of Magnetic Fields ( B ) around Turns ( N ).
  • Lots of extra Electromagnetic Induction.
Noise does not always mean Power!
Whats required for power?
  • Voltage ( V ) and Current ( I ) must be in Phase! This is real power.
We have many answers, the right questions must be presented for these answers to be come obvious however.
Chris posted this 11 January 2020
We are a step ahead. We have a greater knowledge in the area of Energy and soon to come EM Propulsion. So we are lucky.
I would like you to take a few minutes to watch this video:
Energy is critical in the advancement in the Human Race! We must take time to understand these simple cheap Energy Technologies.
Please, work hard, think hard, be strong, use logical thinking. look for the effects and work to improve the effects. Before you know it, you will have output much greater than the Input and its so absolutely easy!
We are Light Years ahead of the other forums!
Chris posted this 14 January 2020
So many people tell me not to share, I get mysterious messages all the time from people I dont know!
Here is a message I got today: youtu.be /2BrGejedJyU
Why are others not sharing, and telling me not to share? Whats the problem with sharing?
We need good people, here, sharing their work! We can only do this together! As a united force demanding change!
Some may say I am an activist, I only want a better future for our Children! A Free Future.
cd_sharp posted this 15 January 2020
Hey, man
I'd say one thing to this guy:
The world becomes very dangerous? What do you know, it has already. There is no greater danger than destroying the Earth that keeps us alive. Watch the Amazon forest, Australia, active volcanoes, ice in Antarctica, .. This threat is against everyone, whether it's terrorist, soldier, president, head of oil company, .. Time is about up.
Chris posted this 18 January 2020
Someone is preaching to me! The latest message:
Some people are so narrow minded!
Why is some person I do not even know preaching nonsense? Oxygen is one of the worlds most deadly Gasses, however we need it to breath! Without Oxygen a Match Stick could not light! What is wrong with people?
Jagau posted this 18 January 2020
They write this because they know we are close, so it tires a lot of people.
Mikkoli posted this 18 January 2020
Iam new here.
My knowledge in components is wery limited but i know physics.
Isnt this similair to the mr prevda experiment.
I Saw a video with the second coil beeing a tank curcuit rewinding the polarity isnt that electron field friction?
Friction energize the electron and speeds it up? It should be related to spinn no?
Ive seen alot of free energy methods but i think its wery relevant a easy to make pdf is made and spread across the net with partslist including.
Even if we all use money to survive its beeing used more and more against humanity with debt based constallations goverments seem to gone mad overpopulation overconsumtion became a issue. There is no competence to create biocirculat economys becouse everything is beeing monopolised to a few and they wont let go of their monopolys.
As its written i guess judge the wicked by their fruits they profit from suffering and by poisening earth. I Cant say anything else have been the consequence of opressing free energy tech.
I Do think this tech can be boosted using sparkgaps tank curcuits and the casmir effect.
Can i ask if the output needs to be recified?
il go trough all posts as soon as i got time to get more into the methods.
Bless you all for trying to free humanity.
The truth shall set you free, i do think that everyone working within this area knows the meaning of the phrase and its deepth probably on a whole new level better than most.
Zanzal posted this 18 January 2020
@Chris, I don't think the person who expressed concerns is wrong to have concerns, but I disagree with the idea of keeping it a secret. If there are problems with a particular approach then those problems can be studied and solved like other problems. We can't solve the problems we don't understand. If AU research is not allowed, then that means our understanding can not advance.
Sure those that know might claim its for the best we don't know, but why should we listen? It is just as plausible they don't want us know for their own selfish reasons (worried their stock prices might drop or their bitcoin will not have any value). And if it were true that there are real dangers we as a society must face them. I do think caution and study are good and it is very reasonable to think some approaches might have undesirable side effects, but promoting ignorance or obfuscation is not good.
Vidura posted this 18 January 2020
Hey Friends, Just a small example: Someone invented a knife, it can be used for various purposes, it can be very helpful or it can be dangerous. Possible that it can be used to hurt or kill someone. Hence would it be a solution to stop fabrication of knifes? To keep the fabrication process secret? Only a sick or scared mind would think to take it to harm someone else. And of course only people that get a personal profit or have made agreement with the mighty ones would try to keep this technology secret. Actually there exists so many weapons of different types, enough to extinguish all humanity. So I don't think that a still more Powerful weapon would change the situation, it depends on the evolution of people, to learn to take care for each other and the planet. In a peaceful society nobody would want to damage or hurt anyone, so the most powerful technology would not present any danger. Sorry the off topic 😀 Regards Vidura.
Chris posted this 19 January 2020
Mikkoli, Welcome!
Mr John.K1 introduced The Mr Preva Experiment to our cause here. I agreed that is is a good learning tool, but was never Above Unity as it was:
Hi Chris, Guys,
I have a question for you. I watched some Russian video (
) and it inspired me to replicate the setup.
I have made one as seen on the picture below. The picture is self explaining.
You only do not see a 1 Ohm resistor I used on the AC source to read the input current.
2 partnered coils on the ferrite torroid core, (CW & CCW).
I know kirchhoff law is used mainly for DC circuits. How is it with the AC circuit as on my picture below??
Cheers,
Ref: John.K1 - Partnered Output Coils - Free Energy
I replicated and verified the effects and asked everyone wanting to learn to replicate and verify the effects also:
Hey Utopia Now - Electromagnetic Induction only requires a Change of Flux over time.
But, I have found a Sinusoidal Wave is best - This is a gradual change over time. Easy to control and easy to use.
DC Pulsing I do not prefer, sharp peaks, which can be nasty on your equipment. This is unless a Resonance can be established.
I have shown many times the basic steps that are required, we even saw some experiments. Don Smith also tells us as do many other famous experimenters.
Quote from: Floyd Sweet - The Space-Flux Coupled Alternator
Current is deemed as a quantity or number of charged particles moving from P1 to P2 in time t, or as the charge transferred in one second by a current of one ampere. The coulomb is the charge on 6.24 x 1018 electrons. Electric fields are due to the presence of charges. Magnetic field effects are due to the motion of charges. Current is the net rate of flow of positive charges. This is a scalar quantity.
In the specific case of positive charges moving to the right and negative charges to the left, the effect of both actions is positive charge moving to the right. Current to the right is: I = + da+/dt + da-/dt. Negative electrons flowing to the left contribute to the current flowing to the right.
Superposition is Key:
See: My MRPreva Experiment - Image below
See: Don Smith - How to Generate Energy - Use the Right Hand Rule to see what Don is Saying!!!
As I have pointed out, these concepts are the start, there is a little work and a lot of understanding to this. But if you want it, then you will be more than happy to work for it.
The current and potential windings require relatively little power, and are applied in such a manner that rate of flow of moving charges may be accelerated beyond 1 ampere = 6.24 x 1018 electrons⁄second. Thus the duty factor of the copper changes.
I2 Losses diminish and more charges drawn from the now coherent space field flow at a faster rate as current to the load.
This means as more current is required by varying loads more feedback magnetomotive forces free more electrons from binding forces complimented by potential magnetic forces of the orientated, coherent space field.
Thus a conductor that formerly had a temperature rise above ambient labelled as a factor of 10 would now operate at a temperature of 1.0. Thus the same gauge wire would carry 10 times more current at the same temperature.
An example: Tariel Kapanadze, the Grenade Coil as you pointed out, this Coil is inherently non inductive as we would call it. Having little to no effect on the surrounding resonant circuitry in the form of Lenz's Law, Magnetic Reflection.
But a sharp spike does what? Injects a very fast, Magnetic Field, Time Rate of Change, inducing an EMF in the Grenade Coil, but this is too fast for any negative action. So the Coil has no choice to Engineer Current, because the Current is dependent on the Voltage. No Voltage (EMF) no Current
Of course there is more to it than this, Earthing and so on...
Chris Sykes
hyiq.org
P.S: Voltage Transformation is Free, Step Up, Current Transformation is not, we must Engineer the Magnetic Field for Current. MrPreva Circuit, aka Partnered Output Coils do exactly this!
Ref: Chris, Me - Partnered Output Coils - Free Energy
I would like Mr John.K1 to join us, but he has not.
A rectification on the Output makes it easier, gives better results for less work. Yes Governments are Corrupt, not all, but most! We have a world of problems! But we can make change:
We can only do this together! I cant do it by myself, nor can anyone else! There is no 'I' in Team!
@Zanzal - I agree! I see a world of problems, but nothing is ever going to get better if we do not push forward! We just MUST DO IT! There are WAY more positives than Negatives! I have only touched on the Energy side, not gone into other things, there are other things that we Humans desperately need! Floyd Sweet reported Anti-Gravity Effects! Well watch this:
You will see a correlation if you have been following close enough!
@Vidura - Exactly right! We must push forward! We, human beings have no choice! Most study's show crime would decrease if everyone had enough to be well off! A trend of Crime can be attributed to desperation! Those that are desperate do desperate things!
It angers me that we have been held back for so long, that we must fight for Freedom:
Tyranny has conquered us! The oligarchs using puppets as front men, we call them politicians. Humanity has many problems! Many! To solve problems and solve problems properly, hiding Truth is not an option!
And the truth shall set you free.
Ref: John 8 : 32 and above by Mikkoli
The only thing that matters is what we leave behind! We must not condemn our Children! Truth is Freedom and Freedom is to make good and bad choices. As long as we learn from our mistakes!
Fighter posted this 19 January 2020
There are only two possible scenarios:
  1. The guy is sent to stop what we're doing; they know we already have the key for overunity but this time it's not only one guy working in secret which can be threated and eventually annihilated, this time is a bunch of people experimenting and sharing to hundreds of people (lurkers); this doesn't match any known scenario from their book so they have no standard approach; so threatening doesn't help, they try to use the reason we're doing this (for the good/future of humankind) against us; therefore the "concern" expressed by the guy about how the ZPE technologies can harm the humankind. Let's see, every year is a record on temperature, extreme typhoons, the entire Earth is on fire, countries are fighting each other for controlling and getting fossil fuel resources, the air is more and more unbreathable, the oceans acidity is increasing killing the aquatic life and soon the oceans will not be able to absorb CO2 anymore, the arctic ice is melting releasing more CO2 captured during millions of years and I can continue with all these; actually it's a chain reaction already in progress, a perfect storm (search the meaning of "perfect storm"). And the guy's concern is that giving clean, unlimited free energy to the humankind will be more harmful than what's actually already happening on the planet ? Right...
  2. The guy is not sent by anyone, he discovered overunity tech in 2008 as he says and since then he preferred to stay on his own ass watching his own planet going to hell just because he has concerns about how ZPE can be used to damage the humankind; that means he's just a coward and will not make any difference.
In both scenarios I would just ignore the guy, he's just trying to stop or at least delay our research.
I agree Fighter, you are wise my friend!
Both scenarios are possible! We are a lot further ahead than what he thinks anyway, so either way, we still win!
Chris posted this 25 January 2020
Many times I have posted on how Partnered output Coils work. Today I tried to post to the 8Kun boards. Many do not believe. Feeling the water, its easy to see that many distrust something so simple.
We, those of us that have done the work know better. I have said it before, smart people are often the dumbest! There is a deeper meaning to this statement.
It appears the promises that our old mate TinmanPower now known as OzSolarPower, have flopped as usual. A bit sad, this is what Tinman has come to, never ending broken promises! These tactics are why others do not believe those of us telling the truth!
Perhaps today we should look at the laws of Electromagnetic induction again. The series I have shared with you:
In the video's above, I have laid out a lot of information! Video Seven shows a functioning Above-Unity machine. What we have learnt in the videos, shows how the manipulation of Magnetic Fields can induce a Solid State Generator, the only thing moving is the Magnetic Fields in time!
Many others here have replicated these effects and some have gained the results we have shown.
What have we done?
There is two processes occurring in Time:
  1. Accelerate Charge down the Wires - Green part of the Triangle.
  2. Decelerate the Charges in the Wire - Red part of the Triangle.
The Green part of the Triangle shows what I call: Reduced Impedance Effect
This is a very important part in the process! The Reduced Impedance Effect allows for the Coils to get to maximum amplitude very fast! You may remember the experiment I did, showing how much faster the Currents and there fore the Magnetic Fields can grow to maximum amplitude:
TO:
From 75 milliseconds approx, to 500 microseconds, a factor of: 0.075 / 0.0005 = ‭150‬ times faster. This is the same reason we see the Triangle get to maximum Amplitude fast, but when our Input turns off, the Output Coils change their Impedance / Reactance, and they don't allow the Current to decay immediately. The Current is forced to decay linearly over time. We have referenced this before:
Again we show the Triangle:
Remember, this is Asymmetrical Regauging:
How the Oscilloscope measures the Waveform:
Remember, we have two things we must take into account:
  1. Amplitude ( Y Axis ) = Value of the Potential Measured.
  2. Time ( X Axis ) = the time the Amplitude is non Zero during the measured time frame.
So if we have more area under the curve on the Scope when our Input is off, compared to when our Input is On, then the area shows more Power, Voltage x Current x Cos( θ ), is being measured.
Our machine has become a Charge Pump, a system that requires Regauging every X seconds, the Frequency and Duty Cycle of Operation. We have invoked the use of Magnetic Fields to pump Current in the Wires exactly the same as our old reference video, the Hydraulic Ram Pump: Energy Machine Operation
We have offset the Forces of Magnetism ( M.M.F ) so our Input is not negatively effected as much as we would normally see in a normal Transformer.
Chris posted this 27 January 2020
If you want Free Energy, then you need to study and replicate the above work! My last post has video information and other posts have a huge amount of information! If you study and learn what I have shared, then you can build Free Energy Machines!
It is very simple!
It is very Cheap!
Once you have the experience you can build it very quickly!
Please, share your work here! Please replicate this Technology I have shared with you! Its easy and cheap, whats a few hours out of your day? Please join us:
Be Part of Something Better!
We have many successful replications already:
  • CD_Sharp Here.
  • Vidura - under another project name - Here.
  • Jagau Here.
  • CaptainLoz Here.
  • Atti Here.
Please everyone, we MUST do this together, we cant do it by ourselves!
It is so Simple and Cheap that Science should be so absolutely embarrassed to come forward and join the Cause! The cause; to solve the worlds Energy Problems!
Chris posted this 01 February 2020
I just love Coincidence! It appears others are waking up! The thread I started is top of the list right now, again. One Troll is not liking the attention it is getting!
I would like to ask you all of a favor: Would you mind going to the thread Partnered Output Coils - Free Energy and directing others, willing to learn here, to this forum?
Please don't put your accounts at risk by getting into arguments / debates with the Trolls!
People that are waking up, need to know the truth! We need to do our part and help where we can. wink
Captainloz posted this 02 February 2020
Done!  I just posted on the thread over there!  I was going to post a link to one of my videos, but they'll have to join this forum to see it. Hahah! smile
Cheers,
Loz
Chris posted this 02 February 2020
Thank You mate, I appreciate it!
I agree, let them do the work themselves, if they want to move forward they will do the work, if not then we don't really want to deal with the non-sense. wink
Thanks Loz!
EDIT: Wow the responses...
cd_sharp posted this 02 February 2020
Hey, man, it's done,
I hope good people will see our small links in the massive non-sense they are producing there.
Yes, there is a ton of non-sense there! Huge amount of wasted space! Still if we can get the few that wish to move forward join us, then we become stronger everyday! We can only do this together! You and the others here working hard to move forward are inspiration my friend!
P.S: As Loz pointed out, those that wish to move forward and do the work will succeed! You guys and gals already know that! There is a steep learning curve if those that come have not dome their homework. But we as a Team, a Family, here, can help those that need help.
Chris posted this 04 February 2020
I am dissapointed!
It appears Atti, the one yelling from the top of the roof for measurements, after getting close, he drop's the truth like a hot potato, has gone ahead and deleted his prior Successful replication of this experiment, Asymmetrical Regauging! Only having the Image left I got for a screenshot:
Now, I see this as deceitful! I see this as an act of trolling! Especially after his last rant! Atti, I almost banned you because of your last rant!
Atti has deleted his post:
  • CD_Sharp Here.
  • Jagau Here.
  • CaptainLoz Here.
  • Atti Here.
Atti's link no longer works! I am very disappointed Atti has attempted to mislead us and others by his upsetting behavior! His Videos posted are now made private... No doubt a Patent Pending!
What is very clear to me now, is you had no intention to progress! Most likely a Paid dissinformationist here only to cause trouble! I should have gone with my gut feeling! You have bought a world of bad Karma down on yourself!
You are now Banned! I am disappointed for what you have done!
Sadly,
cd_sharp posted this 04 February 2020
Hey, man, I know you had suspicions, I did also, we talked about it. But still, this is surprising me. You did the right thing.
Wistiti posted this 04 February 2020
Really sad yes... We have seen this in the past and unfortunately will see it again in the future... some people just dont care abouts other and at the end they realize they are alone ...
With that said, I believe they are a minority and most of us have good intentions.
Anyways creating this forum with the strict rules you maintain was one of your best moves my freind!
Thank you for that!
thaelin posted this 04 February 2020
@Chris:
    No matter Chris, stand by your convictions. Never relax your rules here and this will always be the place to share and prosper.
I have since left most of the other places available due to the fighting and mis-info things going on. I still have a version of linux that was made strictly for research purposes and it had a strong set of rules to belong to it. They were always open to other ideas and versions but would not tolerate any indiscretions towards any other member. It worked well and that is how a research place should be run. Voice your opinions and then discuss it with your peers. Keep it sane and proper and you will always be in good standings with the rest.
Bravo
I have since started working on a type of motor-generator system with added goodies and as it starts to come together, I will start posting progress here. Not sure if non-members will be able to see it, but will hope they can and share it on the other places that I will not go back to.
CD, Wistiti, Thay,
Thank You Guys! I will maintain the Rules, it is important as you point out.
Wistiti, re:
You are wise my friend! We have many more good than bad here!
Thank You Thay! It is good to hear! We do have the best community here, all of us have the same hearts! All have similar goals! All of us are tired of Trolls!
Best Wishes to all, even Atti now banned for being a Troll!
Jagau posted this 05 February 2020
A lot has happened in the past few days, I just got back from my trip.
Chris I think we are all behind you,
I agree perfectly with the way you manage this forum, thank you.
We feel confident.
Chris posted this 05 February 2020
Thank You Jagau!
That means a lot to me! Hope you had a great trip!
  • Fighter
Captainloz posted this 05 February 2020
Hi Chris and all,
I wish I had more results I could share.  I know I haven't been contributing.  It is so hard to stay focused on one thing! I tried many different experiments with the ferrite toroid cores I had set up, but none of them worked out as well. So I bit the bullet and invested in a Metglas core from Mouser.  It arrives tomorrow! I'm looking forward doing a MEG replication.  However it will be a few weeks because I'll be away.  I hope to be contributing again soon!
Sorry to hear about Atti
Loz
Hey Loz,
All of us have good and bad results. Its normal. Even now sometimes I have to work at it for a while before I get a machine working. Its hard to pin down the exact causes! Sometimes too many turns, sometimes not enough, sometimes tuning is hard, sometimes easy.
Sometimes getting the best result is a lot of fiddling. But, when the Machine is ideal, for example when the wave form is optimum, and one does not have too much dead time and so on, then normally this means your'e going to get good numbers.
Above, the dead time, we saw some examples:
From here.
I pointed this out to Atti also:
The post Here.
Sometimes this is a sign you have too many turns on your Partnered Output Coils also. When we have good waveform, like this:
We get much better results!
As we know Wave Amplitude is an indication of Energy, V x I x Cos( Theta ), and so by increasing the Amplitude, is beneficial. The old: Current ( I ) = Voltage ( V ) / Resistance ( R ). Increasing V increases I.
All of us can help, no matter what! Let us know how your'e going and we can share our experiences. You have had a taste and know what its about, so if you follow the same rules as before, you wont have any trouble.
Best Wishes, have an excellent holiday!
Chris posted this 06 February 2020
Mohamed asked me for specifics, I have covered in detail in the videos if you watch, which I recommend, but following is a list:
To start:
  1. Three Coils, One Input Coil, 22 Turns 1.6mm, Two Output Coils, 0.8mm I recommend around 180 Turns.
  2. I have provided Circuits, see below.
  3. Frequency 3,000 Hz @ 10% Duty Cycle.
Circuits:
Putting a Diode on your Input, blocking Energy coming back to your Input is not a good idea! Try different Load's, the Load Resistance can make a difference! This is another reason this can be a bit fiddly. I used a 12V 300ma globe. This load is one of my better ones.
Make sure your Input Switching is clean and sharp.
Use a Core that has a reasonable Cross Sectional Area, CSA, remember it's the Magnetic Field, the Volume of it and how fast it changes in time that is important here! My Core, in the video is:
Length x Width is Area of a Rectangle, so: 49 x 23 = 1,127‬ square mm's. Your Coils Impedance, and the less it is the better, but remember, you need Voltage, get it up! Don't go to high though, its far to dangerous other wise!
This is info that's already available on this and other threads.
Ourbobby posted this 09 February 2020
Hello Chris,
I am slowly working my way through your tutorial videos' on non-inductive coils. Towards the end of video four , you state that that bifilar coil had enough charge to run a small city.
Could you please elaborate on that comment?
Thank you
ourbobby
Chris posted this 09 February 2020
Hey Ourbobby,
If you need help with the videos / replication, please let me know.
Please note: I have replied to your Energy question here.
I am sorry, I have to be tough on off topic posts, otherwise the forum will turn into a mess, nothing will be organised.
baerndorfer posted this 09 February 2020
hello chris,
i started to watch your videos and build some coils for testing.
when i do the measurement with the lcr meter on the opposing coils it gave me a reading far away from zero.
is it incorrect to expect zero inductance on a coil which is wound that way?
i use 1mm wire for the coil which have a diameter of 50mm. 56 CW and 56 CCW with center-tap.
thank you for the brillant videos and explanation!
regards from austria
rené
Hello and welcome Baerndorfer,
Please don't get hung up on the term: "Non-Inductive" its important we think broadly about this and apply the right thinking and concepts to the experiments I have shared.
It is impossible to cancel all the Inductance in Coils, even with the best wound Coils, there will always be some Inductance.
So, the meter will never read Zero, some Inductance, stray, or parasitic Inductance will always be present.
It may be of benefit to read over a document I put together some time back: Does Science truly understand Electromagnetic Induction
Many of us here can help if you need us, so please ask, please create your own thread if you wish, the best way to move forward is to experiment, prove and dis-prove the simplest things.
Chris posted this 11 February 2020
This post is a specific post about the broadness of the technology I am sharing with you.
In the old days when Akula was sharing information, his comments on Bucking Coils and Standing Waves and so on were hard to decipher but were there if one took the time to observe!
What I am sharing is broad!
Fighter has shown how broad this technology is!
Don't limit yourselves to one narrow path! The concepts are all the same, yes the same! The same ideas, same concepts. I will explain:
Akula tuned the Frequency and Duty Cycle to maximise the Magnetic Resonance, increase the Potential in the Coils and as we learnt in The Mr Preva Experiment, the Currents are Equal and Opposite. The Input to Output ratio is achieved by Tuning the Frequency and Duty Cycle, this video shows a similar device, but uses the same concepts:
The same basic idea, Coils, as the Mr Preva Experiment:
The Asymmetrical Regauging process is the same. Its all the same processes! Same concepts! A short pulse, Duty Cycle at a particular Frequency, when the Coils are Magnetically Resonant is where we gain Energy, Excessive Electromagnetic Induction occurs, well beyond the Unity Boundary!
Timing is a difficult task in these circuits, but others have achieved success, its not beyond reach, but be prepared for a difficult task. Working with the Coils, Partnered Output Coils, learning them first and then moving forward after learning how they work is the best path forward.
My Advice: Get the Coils working, then build the Circuitry around the Coils! Stick to the basic concept here, Electromagnetic Induction, to amplify both Voltage and also Current, don't let any complication creep in!
Chris posted this 14 February 2020
Sometimes I cant help but smile!
Some years back when I introduced this technology, I had some communications with Partzman. I believe Partzman has an account here as Prometheus. I am speculating and do not know this for sure.
Let it be known, I like Partzman, he seems like a good person.
This is a re-visitation of a particular ferrite toroid core that I had demonstrated years ago that had anomalous voltage levels. The two pdfs below explain my findings back then and this is an application of that core within an operating circuit.
The schematic of the test is shown below and a scope pix is also shown.
The frequency is 50kHz and the measurements are shown with statistical analysis of many measurement cycles. The vertical deflection is adjusted for near full screen and at this frequency the resolution is ~12 bits. Also note the horizontal sampling at 1Meg points.
Using the mean values, the output power is 2.151^2/500 = 9.25mw. Therefore, the apparent COP = 9.25/4.372 = 2.12.
The question is, what is the cause of this core's anomaly?
Pm
Ref: Anomalous CMC Tests started on: 2016-04-11
I started sharing my work on: January 16, 2015 and well before, 2011 on hyiq.org.
Isn't it funny how easy it is to guide others, but others still think they came up with the ideas themselves? We have many pages here and forum posts else where that show I was well before everyone else in sharing this tech! Still its part of evolution as they say:
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident.
Ref: Arthur Schopenhauer
Ourbobby posted this 15 February 2020
Hello Chris,
I hope that I am in the correct thread this time. I am not sure if this is a Partnered Output Coil test.
I have been spending my evening going through your thorough set of video tutorials on Non inductive coils. Assimmilating all the information is difficult and needs time! Especially understanding the unique differences that can appear.
I have started a test sequence using the two coils with an extra drive coil. Video 7 I think. I do not have a lot of time at the present, however, I have found some time this weekend. I think my early results might be fruitful: you can be the judge. The test set up is not complete as I have to get some 0.1ohm resistors for the current sensing. I have only been working to get resonance, which the attached photo shows, might be close?
My pulse circuit has an adjustable pulse width and adjustable frequency. In the set-up, I am using an amorphous core AMCC100. There are three coils 2 coils are 300 turns #23 guage and 1 drive coil 75 turns #17 guage which is wound over one of the other coils. The large coils are CW and CCW wound. The drive coil is CCW wound on top of the large CCW. I do not know why, but, the outputs are difficult to understand. Yellow Trace is primary CCW coil wound over Blue trace which is large CCW coil. Puple trace is CW coil on adjacent side of the core. I might have expected the output from Trace purple, CW coil to have been a larger voltage or similar output voltage to the other coils. Also, Where as the CCW coils show similarities of output,
the CW coil- purple- is a little bit unruly!
I am hoping to make a donation for you soon, as I can see that your effort in recording these videos has been tremendous.
ourbobby
Chris posted this 15 February 2020
Hey Ourbobby,
Looking really good! Well done.
What you have is a really good start! A few things to try to help,
  • Input needs to be a very short DC Pulse.
  • You could drop your Input Coil down to say 20 turns or even less.
  • You have a lot of AC signal, which is fine if that's what your'e aiming for, but aiming for DC might be a better path forward. That means you need some Diodes on your Partnered Output Coils. See below Circuit.
Sorry about my off topic complain a while back.
Good work, Thank You for sharing. Please PM me if you need any help!
              Thanks for the heads up. From your video comments, I take it to mean that optimum output comes with resonance. The scope shot it an expanded pulse, looking for symmetry of pulse waveforms. My input pulses are approximately 10 % as you recommend. I'll get some resistors next week and do some further work to look at the current.
Edit: I have found a couple of 5W .1ohm resistors, or I should say, rescued. I am wondering if I should have special settings enabled on me Rigol. No matter what I do, I am unable to get the waveforms or conditions that you show in videos 5,6 and 7. Each time I get a scope image of a pulse that crosses the median, as one would expect when pulsing a coil. No rise or fall or delays. Just a ringing effect when expanded.
ourbobby
Hey Ourbobby,
Yes, I used 3,000 Hz at a 10% Duty Cycle. Your Frequency and Duty Cycle might be very different. The Output should be DC, after the Diodes.
You will see a very Triangle Waveform on the Output:
Loading the Output, the Input should go down in Current Consumption, meaning Energy is sent back to the Input.
Vidura posted this 15 February 2020
Hey Ourbobby your scope shots look like if the output coils are not loaded, check if you have amps flowing, maybe change the load device, to mach the impedance better, or maybe a failure in the diodes? Regards Vidura.
Jagau posted this 15 February 2020
Hi ourbobby
I think Vidura is right.
Just a very simple little trick to check a mosfet if it is good.
If it could help
              I can see what my issue is!. I am not understanding the calculation for winding for inductance. I do not recall you giving any inductance figures. Of course your core is three time the size of mine. I am showing an inductance of 1.77mH. I am thinking that I should be looking for low inductance and low resistance in the coil. On a side note, the Figueras device uses non inductive partnered coils?
ourbobby
ourbobby
Hey Ourbobby,
This is really to everyone, Keep it simple, don't over complicate it. Its really important you keep it simple!
Yes there are some complicated stuff in there, but treat it like an experiment. Drop Turns, test... Add turns, test... Adjust Frequency and Duty Cycle and then test...
From what we can see Ourbobby, the Input Switching is not right. Your Output Signals are wrong. You have AC wave form and that's not right. By working on that, moving one step at a time, forget about Inductance and all that, just go by Turns, you will get it working better.
We can help, we will help, but work on your Input Switching first. We have lots of info here about Switching:
I am sorry, perhaps I am a bit too blunt, but I am being honest and to the point, I am only trying to help. wink
So PLEASE don't take this the wrong way!
Ourbobby posted this 16 February 2020
Nope! no offence taken. I just want to understand what I am doing!
My last test until I can spend some more time on it. Maybe a window next weekend. No matter what I do this is the output I get. I have uploaded a couple of shots to show the connections as per the bucking circuit with diodes and resistors. Yellow is input, Blue is asymmetric coil, purple is coil beneath input coil. The coils are wound CCW input coil 1.5mm wire 20 turns, CCW main coil 1.06mm wire #17, 164 turns, asymmetric coil CW #17 164 turns.. Probes across the resistors.
also, thanks for the heads up on the mosfet switching. I am aware of some of the issues related to switching. I use a TC4427 which will switch efficiently at high frequencies. The mosfets I am using are IRFP 260n and IRFP 460, both with low rds. What I am not picking up is the sawtooth we are seeking. That confounds me!
ourbobby
Vidura posted this 16 February 2020
Ourbobby, I see your wave forms, Chris was correct, the switching is the problem. You have to get a clean rectangular pulse at the Inputcoil. Avoid using the alligator clips for the power path, better screw connectors, a bad contact sometimes causes issues. Vidura
Hello,
          I have found the problem. Bought five mosfets a while back, cheap! Each one is breaking down when pulsed!
Have ordered some replacements from Mouser!
Thanks for the help
ourbobby
Chris posted this 16 February 2020
Hey Ourbobby,
Lots of things can make a Mosfet fail. One common problem I have seen, is the Mosfet is not switched off properly. If you follow the guides above I gave. This should help!
PM Me if you need help.
Chris posted this 18 February 2020
Perhaps this needs a new thread?
I want to say something that is obvious to some, but perhaps not obvious to others. The big reason I put so much effort into my Mosfet Switching Technology, shared on the thread: Reliable and Flexible Switching System is the very fact that I realised early on that very detailed specific control of a Mosfet is critical!
Take for example the Akula days, in all Akula' Circuits, he has one thing in common in all of his circuits, a detailed control of Switching. Take for example the following two circuits:
Great detail, a huge amount of effort is concentrated on the Switching Circuits! Akula used many IC's even Phase Locked Loop PLL Circuits in there to hold Frequency and Duty Cycle.
So I also spent a lot of time and effort on full control of the Mosfet. This is why I have shared so much on Circuits and the best of what I know about the Technology behind driving Mosfets.
Chris posted this 26 February 2020
I have shared this today with other readers:
This is a general post for all interested parties.
What exactly are Bucking Coils? What is the Purpose by applying this very simple technique? This is important, its important that this is thought about in the right way!
I want to quote:
CLEMENTE FIGUERA
The thought processes of Clemente is important to think about, simply he is investigating Electromagnetic Induction!
Each Coil in Partnered Output Coil's is a Rotor Coil and a Stator Coil of an Electric "Generator" - Does this make sense?
Electromagnetic Induction is encouraged by an Input Coil, but the Partnered Output Coils are the Primary and Secondary Coils in what we would normally think of as a "Generator". I have been through this many time in many different places.
The Mr Preva Experiment shows some basic, elementary principles so one can learn how the Interactions between Two Coils occur at Resonance.
We can only do this together, I am one man, I can not do it for everyone!
Chris Sykes
Ourbobby posted this 29 February 2020
Well I have discovered that the fets were not faulty, but, blown up! The issue was too much current flowing upon start up. Got that sorted out and here is a photo confirming the sawtooth and subsequent current flow. I have a 12 volt globe connected. I only have to reduce the mark space for 10% to say 15% and globe becomes much brighter. This is the obvious photo.
The other photo is me changing the connections and which might bring me into new territory. The yellow trace is 12v input coil magnified by induction of bifilar coupled secondary coils. The Blue trace is the one I am unable to work out. I tried the 3000hz, but, have backed the frequency down to the low hundreds. Frequency does not seem to influence output? Globe rightness does not appear to change when increasing frequency. I have a 240v 60w incandescent connected to output, but, I have to increase 10% pulse width to get to full brightness increase. Also, where you are using special powersupply, I am using 12v pulsed input. Seeing the outcome of the bifilar connection, I am wondering how best to capture this output? Anyway, it is reassuring to be able to replicate to some degree your demonstrations.
The output is making me cautious! As you see on the scope the bifilar out put is reading very high voltage. Is this Radiant or standard electricity?
Yellow trace input coil. Blue is secondary before bifilar connection to test for current flow. Bifilar if the Globe output.
ourbobby
Chris posted this 29 February 2020
Hey Outbobby,
Very nice, well done. Please forgive me, sometimes I cover things others may already know?
A Coil has a Current Ramp Up and a Ramp Down which looks something like this:
The Voltage, something like this:
Something similar to those wave forms for Voltage and Current is a normal DC Switching waveform. When I say normal, this is normal Coil to Magnetic Field Interactions from Switch On to Switch Off during the cycle.
If we have anything other than these waveform's, then we must have different interactions occurring in our machines! Meaning, the Magnetic Interactions in the Coils, Electromagnetic Induction has been changed from what we would normally see.
This is the key, we are using Geometry and specific Action Reaction and Counter-Reaction's to change the overall operation of the Coils and Magnetic Fields changing in time. By changing our System, we get:
You are close, your waveform is on the way! Well done! Working toward the improvement of the waveform will be of benefit.
Well done Ourbobby, nice work! Thank You for sharing!
Ourbobby posted this 04 March 2020
              Thanks for the comments. I can see why you are using a constant current during the experiments! I have rewound my test coils to search for the resonance. My primary seems to be getting too much feedback from the secondary coils. I blow a mosfet within a few seconds of switching the pulse on. And I am using much less than a 10% pulse width. So either I am drawing too much current or my voltages are peaking. I will say that the flyback diode I have in place goes off with bang too. What I have done is what seems to be similar to Don Smiths metglass device. I have wound the primary around coils L2 and L3. Too much do you think?
ourbobby
Chris posted this 04 March 2020
Hey Ourbobby,
My Input Current is 10% @ 3000 Hertz, so its a Pulsed DC that is used, we have Current being returned back to my Power Supply from my Machine, so this current is not being supplied, rather returned, we can not count this Current as used, because it is not.
I am happy to hear you are seeing some results! Feed back from your secondary Coils is what you want, this is power coming back to your Input, Negative Power and as a result drops your Input Power consumption.
Mosfets are normally pretty sturdy devices.
As long as they are Turned On and Turned Off correctly they are solid within their ratings. For example:
The Datasheet for you mosfet will have your Ratings. The Ratings need to be observed and need to be adhered to.
Its worth looking up your datasheet and familiarising yourself with the ratings, and finding out what exactly is making your Mosfets pop. Its a great learning curve!
We have many threads here to help with Mosfet driving:
Protect your Mosfet with a Diode from Drain to Source, like so:
Where: D1 is an extra Diode, Ultra Fast is always nice but not necessary, to protect your Mosfet.
I also have a PCB soon for-sale that can be bought and you can purchase parts I have listed and build if you wish. I only recommend this for those that have an electronics background already as there is some work and some knowledge to building this PCB from the ground up.
Don't give up, it sounds like you are doing better than it actually sounds, with blowing up a few mosfets and that's probably a good sign! With some work, you will get it! It can be done!
Good work and Thank You for sharing!
Thanks Chris! incidentally, i had an ultra fast diode across the IRFP460 for the last burst. It blew it in half. A UF 5408. 3 amp i think. Because of the damage, I had the duty cycle at around 5%, so I suspect that even then too much current was being drawn. I am looking at two options to drive my coils. One is similar to what you are using. the other is a low voltage solid state Marx where I can adjust the output to accommodate the coils' output. At the moment, I am unable to confirm the sawtooth!
Ourbobby
Hey Ourbobby,
WOW what sort of Input power are you using? Voltage and Current?
It sounds to me that your'e going over the ratings for the Mosfet and also the Diode. Maybe do a YouTube video and post, lets see whats going on.
raivope posted this 04 March 2020
If you are using this circuit (above), 3V source and single rail mosfet with parallel diode you still have problem with collapsing field (high voltage) that attacks mosfet or diode. (Mosfets have always diodes inside because of the design "parasitics", but usually they are not fast - so yes, adding a parallel UF diode is good.)
Energy may cycle in coils and then during the second cycle it will go back thru the diode, but in first cycle it has nowhere to go.
3V is low and usually many circuits survive the CEMF, but I would recommend to pulse the circuit with double rail circuit (or half bridge, or full bridge with single direction pulses) where you direct CEMF further away or back to source. Then later you can go higher voltage.
Best,
Raivo
I think the problem might be twofold. One i need to use a current limiter in the pulse circuit. Two, I am using 12v battery, and I am only getting 10v pulse, so mosfet is not switching properly. Likely 15v better at the gate, so need to redevelop power supply. It is also possible that my configuration of coils with primary wrapped over both secondary coils is giving me some feedback  issues, that because of the fet blowing so early i cannot see what is happening.
The non-inductive videos have been great, cleared up some issues I have had with constant differences with other system confusing me. it is most likely, on reflection, that I should first just put a power source together with current limiting, to consolidate my understanding.
Haven't made a youtube video, will have to look into process!!
Edit: on the circuit above you must be driving the mosfet with two separate voltages. The gate would require minimum 10v, you are showing 3v at Drain. i have missed that!!
oubobby
Vidura posted this 04 March 2020
Hi Ourbobby, Would you like to post a schematic of your experiment, with component values, so it would be easier to isolate the issue and find a solution. Vidura.
                here are a few shots of current layout. This is modified coil, to test for resonance. Previous coil was wound as per video 6 with primary on top of L2. I have used more turns on this winding. Hope you can make out my quick drawing!
Edit: I have drawn the duty cycle configuration incorrectly. diode goes to pot adjustment, pot goes between 16 and 9. It works on the board!
ourbobby
Hey Guys, awesome! You guys are all awesome!
Ourbobby, I would keep your setup as is, don't change anything.
Test your Circuit and Mosfet on a Resistive Load, maybe the light you have as a load there, see if you have any trouble driving a Restive load. If you don't, then your Coils are likely the Feed Back problem.
Vidura and Raivope have excellent suggestions!
The Coil does have considerable inductance, you could load your input Coil, yes this sounds silly, but you could try this circuit:
Of course, this is not ideal, but if it saves your Mosfet, then that's a practical start.
Like I said, your'e on the right track, don't change anything yet, I always say, learn as much as you can on the experiment you have right there on the bench, its the simplest things that lead to the biggest discoveries!
Well done! Thank You for sharing!
Hey ourbobby,
Thanks for the Info, now Yes we got the issue: the Mosfetdriver 4427 has to be connected to the gate, via a resistor 10-20ohm. The mosfetdriver is intended to deliver considerable current pulses for properly driving the mosfet, the optoisolater do not have likely the capability to drive it(unless it is a combined opto isolated driver IC ). The opto in your circuit would be placed between the PWM IC and the driver IC. But it is not strictly needed in your circuit, as you use a low side switch with common ground connection you could leave it away. I hope this helps.
Vidura.
Ourbobby posted this 05 March 2020
Thanks guys, very helpful. Have to wait until week end for some time!!
Ourbobby
Hi guys,
             Before I retire for the night, did not want to dream on this all night! Two photos, showing current rise and delay. Have not captured the sawtooth yet. Will look for that next. OK, what have I learned? 10% is borderline for delay to commence. A wider delay on the tips will readily show up with say 7% - approximately in photo. The problems I am having with mosfets' is too much current. As soon as I increase width of duty cycle - Boom! Thats it for now. Living below 10%. Have to start thinking again.
ourbobby
Chris posted this 05 March 2020
Hey Ourbobby,
You should be very proud! We all have to start at the start, and your enthusiasm and dedication is something to be admired! Stick at it, you will get there.
The Sawtooth Waveform comes from the magnetic Interactions:
Each Coil has a job to do. Each Coil produces a series of Action Reaction Pairs.
The Actions are:
Action, Reaction and Counter-Reaction
So, the Input Coil Induces a Voltage on the Partnered Output Coil One, POne, POne then carry's a Current because it is Loaded. This is the Action, Input Coil, and the Reaction Secondary Coil.
The instant POne starts to Carry a Current, Partnered Output Coil Two, PTwo has an Induced Voltage because of this change in Current on POne, the Diode starts to Conduct and a Current Flows. This is the Counter-Reaction. The Current in PTwo must assist the Primary Current and also must Oppose POne.
This process occurs in this period:
During this period, the Coils have very little Impedance, because each Coil this process occurs when the Coils Resonance point is found, and has the same effect as my experiment Reduced Impedance Effect.
Once this is done, we achieve a very Slapping together of the Magnetic Fields, we see a Voltage gained and Both Coils carry a Current. This is seen as a very slow Decay, a Sawtooth wave, because out Input is off, and the Partnered Output Coils now Pump Current for the remainder of the period:
Ref: Chris - Aetheric_Mind bucking coil experiment
Be proud my friend, hold you head high, you are like everyone else here, a part of History!
   Chris Sykes
  • Fighter
Chris posted this 07 March 2020
We have covered this before, in many different places, but I am getting to a point here, soon.
Every Transformer has a perceived Flux Direction, normally indicated by arrows:
The Arrows in the Flux is given by the Right Hand Grip Rule and the Applied Conventional Current. It is never pointed out, that the Secondary Flux, from 0 to 90 degrees, is Equal and Opposite, North Pole Opposing North Pole. So Magnetic Flux is equal and opposite.
Flux Leakage in a Non Unity Coupled Transformer indicates this Opposition:
If you observe the arrows, you can see the arrows Oppose. The Secondary Flux, this is important so please pay attention, but the Secondary Flux, Changing in Time, is a critical aspect of a Transformer! This Flux is what regulates and determines the Conservation of Energy Law. Its the "Your'e not going Above Unity", regulator!
This Secondary Flux, Changing in Time, is what gives us the opportunity to "Generate" a Voltage and therefore a Current, in a Tertiary Coil.
Please think about this, its really important!
A Tertiary Coil will Assist the Primary Coil but will Oppose the Secondary Coil, so we have a total Assist, M.M.F is Positive in the System.
Recently I posted this, to help Aetheric_Mind:
The Actions are:
During this period, the Coils have very little Impedance, because each Coil, this process occurs when the Coils Resonance point is found, and has the same effect as my experiment Reduced Impedance Effect.
Once this is done, we achieve a very hard Slapping together of the Magnetic Fields, we see a Voltage gained and Both Coils carry a Current. This is seen as a very slow Decay, a Sawtooth wave, because our Input is off, and the Partnered Output Coils now Pump Current for the remainder of the period:
Ref: Aetheric_Mind bucking coil experiment
Working with, and modifying the Transformer Force, as M.M.F, or Ampere Turns, NI, the Force directed back on the Primary Coil is critical to think about in the form I am trying to point out.
You can probably understand why we need a Load on the System to make this all work.
cd_sharp posted this 07 March 2020
Hey, my friend
The load prevents the secondary flux choke off the primary. If we have a "bad guy" (Lenz's law) in society, we won't let him kill people. We need to put him to good use and make him work for the good of the society.
Ourbobby posted this 08 March 2020
hi guys,
             Got part of the way today. Setting up dual voltage points, set up simple current limiter for mosfet current, got current showing  on scope but no sawtooth yet. I have blown my 3524 too. I think the  10%- delay should help to give me sawtooth, have a couple of 3524's on order. Have rewound the whole set of coils. using 76,76,19!. I wonder if I have wound the primary wrong direction over L2? Have 2 Cw wound coils.
ourbobby
direction?
Chris posted this 08 March 2020
Hey Ourbobby,
Can you please draw a Circuit and show where your'e Probing in the Circuit. I can only guess.
Your switching does look much better, is it reliable now?
Thanks for sharing!
               I am probing where you are probing in Video 7. On my scope photo, yellow is input and violet is across 0.1 resistor of the L3 coil. Although, I am showing less than 10% duty cycle above, I just adjusted the screen to get a clear picture. Unlike previous attempt, same set up different outcome! I might try Don's reduction by a couple of turns on one of the coils to see if that helps. With L2 and L3 wound oppositely, I cannot see how winding direction of primary would make a difference, it would just mean left or right through the core? As you say the emphasis is between the slapping of two coils slightly out of phase with each other.
ourbobby
Hey Ourbobby,
Re:
Ah ok, cool. perhaps we should all try to get into the habit of posting a Circuit with Test Points marked. This is a very Scientific approach to what we are doing and also helps to avoid Confusion.
Re:
My Thread: Some Coils Buck and some Coils DONT, will help you understand the difference between Coil Direction and also output Differences.
Re:
Yes, this, I call Delayed Conduction, it is to help get the Voltage Up in the Coils. Other methods also exist, I hope to cover them soon also.
Ourbobby, excellent work, and Thank You for sharing! However, your waveform's are still not right. We need to help you a little more, to maximise the effects of the Coils Slapping together, then the long, Linear Decay Period:
Now, Load is Important, make sure you don't load down your machine too much! Make sure you have Voltage and Current on the Output. If you load your machine too much, it also chokes off the machine. The Coil / Magnetic Field Interactions are reduced, the Machine becomes a simple Transformer. Below Unity will be all you can get.
Best wishes, and Thank You for sharing!
Have just reduced the turns on L3 to 74. What appears clearly is a shift in outputs. I made a mistake in previous post. Yellow, very messy feedback, is across L3 and Blue is input! Getting there slowly. very small sawtooth! Losing the current  somehow.
ourbobby
Hey Ourbobby,
The Circuit is not right.
I would keep the turns you have, not make any turns adjustments, but check the Circuit. Youre not getting the right Magnetic Field Interactions.
This circuit, making sure L1 opposes L2, and L3 Opposes L2, which must mean L3 Assists L1.
Ourbobby posted this 09 March 2020
Well I have a result of sorts! And as you say on the videos, its all about the current. In your test you use a constant current of 100ma. At 3v this is 90mW, and at 12v you are 1.44W. So I have emulated those figures and get a sawtooth of sorts. as the scope shows at 12v, a sawtooth of sorts. And a shining bulb. I had to increase my constant current to 15v 200ma to get this result. This is a new wind! 1 coil 220turns 18awg, 1 coil 224 turns 18 awg and 1 primary using speaker wire 12 guage 16 turns - all I could fit onto the spool! So my resonance is well out with at 1/12.5 wave input. I need to understand what is going on and will have to think about the best approach, and considering how best to extract the energy. One interesting observation. The unit had been running for a few minute when all of a sudden, the globe "popped" on!!!
I had changed to the configuration you show above without any change to my outputs. This is when i decided to increase the coil sizes.
thanks for the encouragement
ourbobby
. I think I can see
Chris posted this 09 March 2020
Hey Ourbobby,
Starting to look much better! Thanks for Sharing!
As you increase the operation, improve your Machine, you should get a more Linear Sawtooth Waveform:
How Sawtooth your waveform is shows how much Opposition you have between the Coils, its Lenz's Law, we saw this here. Pardon the pun!
This stuff is Important, redirecting the Magnetic Fields like this, it the first step to making your Machine do work, well outside your Machines Input Period! When you can have 10% on time, then 90% work outside your Input, then that's plenty of time to "Generate" excess Energy when your Input is Off, a critical feature for Energy Machines!
  • Fighter
raivope posted this 09 March 2020
You have 10% ON and 90% OFF in input. I have seen this power triangle explanation, but don't you think that in 10% you have already paid for what is happening in the rest of 90%?
Someone tested some Melnichenko patent (some LCR circuit) and figured out that 1/4 (quarter) pulsing was beautiful - looks like you have 3 rising waves during ON and the rest 10+ are at decline. Measuring input and output (on resistor R) - revealed that there was nothing there.
resonance-illusion
You have to measure input and output on resistive load, wave shape does not give you full info. Of course - wave shape shows you if you have ferro/wave/accousting/stochastic/whatever resonance.
(If you find this msg inappropriate for this topic here you can delete, no prob)
Raivo
              I am a little perplexed with the use of the term asymmetry. Asymmetric implies an unbalanced state. with the current topic, when using the three coils we have a primary and then L2 and L3. If we take the 4:1 Tesla ratio, as say per Don Smith, this implies that primary and say L2 are paired. To get to the equation, visualised with the slapping waves, L3 has to be a different ratio again. In the wave video, the returning wave would have depleted energy, but is the resistive force against the incoming charged wave. Therefore creating the clash.  Obviously, the returning wave has to be in the correct position returning for the slapping to be amplified. Therefore, in terms of the coils, which one is the returning wave? L3? if L2 is wound with primary. Is L3 wound with different number of turns?
The coils in the tests shown in the set of non-inductive coils, other than video 1, all others would seem to be equally wound.
ourbobby
Hi Ravio, My Friends,
This post is very Important! Please read and understand!
What you bring up has valid points!
In all conventional Transformers, Energy is Transformed, Input is Transformed to Magnetic Force to Output Force, the M.M.F, or Ampere turn is equal and opposite less losses. Input M.M.F is Equal and Opposite to the Output M.M.F less Losses! Any time you offset the M.M.F, force, then you have more work in the System.
This is the point of the Machine we build, to Offset the Input to Output M.M.F, to add M.M.F via the Third Coil!
Yes, it can be that these Waveform's can have Conventional Transformer Transformations, but we are not building a Conventional Transformer, that's the point of what we are doing.
A great deal of experiments performed by others are invalid, until one understands the Subject matter and thus the foll operation of a machine, experiments can be completely inconclusive! I have done many experiments that I look back on and think to my self, there is no way that could have worked, I did not understand the machine, if the slightest deviation in the Experiment you are performing from the original experiment, then the experiment is wrong. So we really can not compare unless we have everything 100% Correct and can verify that.
Th waveform you show, is not like any Andrey Melnichenko Experiment Waveform I have ever seen and thus can not comment on its validity or verification.
I always use Resistive Loads, an Incandescent lamp is largely a Resistive Load, this means Power is real, Voltage and Current are in phase - Yes.
It is correct to ask questions! No one should believe what might be ramblings of a crazy person! I expect all members to question everything, after all that's our job, in Research, is to question everything, until we understand it, totally and fully!
The Sawtooth waveform can be both Below Unity and Above Unity! Some examples I have given here on this forum, Don Smith, The MEG Team, Graham Gunderson, Tinman aka Bradley Richard Atherton:
The Sawtooth Waveform is the Defining Lenz's Law Waveform!
I pointed out in my thread: Some Coils Buck and some Coils DONT why the Sawtooth Waveform is so important:
The Sawtooth Waveform is the Result of Lenz's Law, the very fact that Two Magnetic Fields are working together! This Magnetic Field Interaction is CRITICAL to understand! It is the EXACT Same effect as dropping the Neo Magnet down the Copper Tube:
This is the reason the waveform has a Linear Decay, not an exponential decay! A Critical fact to observe and understand!
The Sawtooth Waveform is the Defining Waveform for Energy "Generation"!
Ourbobby posted this 10 March 2020
              Let me see if I understand what you are saying about the Lenz. We are not concerned with cancellation of energy due to symmetrical impact of L2 and L3 output. We are concerned with seeking the point the Lenz kicks in almost simultaneously on L2 and L3. The slapping effect we are looking for is joining two current and two voltage conditions using a very small window of delay between the outputs of the two coils. What Don Smith states is just a couple of turns on one of his pairs of coils.
Thanks for the explanation
ourbobby
Chris posted this 10 March 2020
Hey Ourbobby,
Technically, Lenz's Law predicts the Direction of, or Polarity of the Voltage that is "Generated". However, as we think of, and deem Lenz's Law, as the Drag on the Rotor, of Back E.M.F in the Transformer, which is technically incorrect.
The Magnetic Field, implied by the Voltage Polarity, is the Problem!
What constitutes a magnetic Field? Current! Yes, for example, no Current Flow in a Coil, the Coil produces no Magnetic Field!
This means, we need, we must have Current Flow, therefore we Must have an associated Magnetic Field! There is no way around this, one is the other! The answer is, what we do with this Magnetic Field! So we now know, each and every Coil that has a Current, must have its own associated Magnetic Field. We have covered this here many times!
IMAGINE: We have a Transformer, it has 2 INPUTS, 1 Output. Inputs are both in phase, they add together! Our Output is loaded, it has 100 Watts Loaded. One Input we pay for, one we don't, one Input is 50 Watts and this costs us! The other Input is not, its powered from a Solar panel, or any other form of Power, but it to is supplying 50 Watts! Point being we are ONLY paying 50 Watts, the other 50 Watts is Free, we are not paying for that 50 Watts! Yet, at the Output, we have 100 Watts!
The above scenario is, we have a Energy Input to our System that we ourselves are not paying for! We have an Input we are paying for! We have more Output because we have this extra Energy Input to the System. Our Third Coil is an Input to the System, adding Energy, Watts, Joules per second! It is seen as a Magnetic Force or M.M.F.
In our machine, we have 1 Input, 2 Outputs.
We Engineer Lenz's Law, so the Law itself, when used Asymmetrically, can give us a Gain in Energy.
Call me a Lenz's Law Engineer!
Ref: Partnered Output Coils - Free Energy
Thanks for being patient with me! This is a good concise explanation.
ourbobby
Hey Ourbobby,
We can only do this together my friend!
I often over look things, not realising others may not see things the way I do. We are all filled with the same colour blood, the same DNA!
Together we can achieve unlimited possibilities!
Divided, we are very limited!
Power, Electrical Energy is the most basic fundamental aspect to a life free of unnecessary poverty and discomfort! Most discomfort and poverty is by design, so the top 1% can soar over every one else. I will be happy when the top 1% are in Jail for their crimes against Humanity!
Apologies, going way off topic now.
Chris posted this 12 March 2020
I really want to get more moving on the idea of Action, Reaction and Counter-Reaction of Coils. Aka Partnered Output Coils.
We Human Beings can become so much more! We only need make our mind up, put some effort in, and do the Experiments.
Please remember what Floyd Sweet said:
The source of energy is unlimited, the virtual vacuum of space itself structured by a motional electromagnetic field is the powerhouse.
Ref: Floyd "Sparky" Sweet Nothing is Something.
What is our machine doing? Yes it is Modulating the Magnetic Fields Asymmetrically.
I have had help, I can not explain it, but I can say I have had a hand guide me in the right direction. I ask that hand also guide others in the right direction, please.
I love this world, I love the life on it, I desperately yearn for Change, for every Human on the planet to become who we are supposed to become, we have so much more potential, we only need reach for it!
Thank You My Friends, both above and here.
Chris posted this 13 March 2020
For the sake of completeness, and accuracy, I want to share a little more data on my Last Asymmetrical System. My Inductance of each Partnered Output Coil:
Coil Turns: 254
You can see, each Coil is nearly Identical. Turn for turn, they should be the same, the Inductance just being localised differences. The DC Resistance is significant.
For most, this will not mean much, nor should it. What this information does say to us, is, to increase the Output, we need to reduce the Resistance, of course, the Coils Impedance will be even higher again, from tens of Ohms to several Hundreds of Ohms, the AC Resistance. Now you will see why we can not have too many turns!
Equations:
XL = 2 * pi * f * L, where L is the inductance in Henrys
XC = 1 / (2 * pi * f * C), where f is the frequency and C is the capacitance in Farads
This means, the Reactance is: 8749.7143Ω, now as far as I am aware, I understand this is for a Sinusoidal Waveform, we are not using a Sinusoidal Waveform, Its Pulsed DC.
Please do not over complicate this, it is so simple, and could not have more far reaching consequences!
Please everyone, we MUST Do this, we must ban together, the future of our race depends on us making changes right now, not tomorrow, but today, for what we do today can change tomorrow!
  • chocolate blanco
Chris posted this 14 March 2020
An Important Post today. Today, a Paradox, only explained in Experiment.
Any Electrical Engineer will tell you: "The way a Coil is wound does not make any difference to the System." This statement is not true. In my thread: Some Coils Buck and some Coils DONT, I gave experimental proof, the Winding Direction is important!
In this particular Circuit, Configuration Two in bucking mode appears to be the most beneficial! CW/CCW Coils.
  • 0.680 volts RMS
  • 192.1 ma mean
  • 196.4 ma mean
Compared to where Bucking does not Work, not very well anyway:
  • 0.587 volts RMS
  • 55.18 ma mean
  • -19.97 ma mean
and the next best configuration after Configuration Two, Configuration One:
  • 0.624 volts RMS
  • 150.9 ma mean
  • 172.2 ma mean
There are three configurations:
  1. Coils wound in a single direction in the same Axis.
  2. Coils wound in a single direction in the same Axis, but one Coil flipped End for End.
  3. Coils wound Clock Wise and Counter Clock Wise respectively in the same Axis.
NOTE: We have detailed Tariel Kapanadze's Grenade Coil and how part of the Coil is Non-Inductive by Definition, yet it Amplifies Voltage and Current many times! COP = ∞
The experiments I have shown, show the same basic things as others before me have:
@9 : 46 in the following Video, Listen, the Noise is a giveaway!
The most simple experiments are the most important! Every single machine I have ever seen, the Inventors all started with studding the Electrical "Generator", all of them!
Akula, just before he got the Lanterns working: "ТПУ от акулы 0083 часть 2"
CLEMENTE FIGUERA
The induced voltage in the winding obeys Faraday’s law as quantified by Neumann
Ref: Floyd Sweet - The Space-Flux Coupled Alternator.
Many others also! We have been told:
I am trying to tell you the same thing, I use reference to show I am only re-sharing something that others have already tried to share, at least in part.
The point here is the Curl of the known Fields and how this Curl can be represented! To get some idea, about the Curl:
The Right Hand Grip Rule can be applied in a few different ways, to predict Current, or Magnetic Field and even the Magnetic A Vector Potential.We must move down the the Core Level, pretend we are standing on the Core and can see the Curl.
If we are smart, and we are, then we can apply Electromagnetic Induction to every single Changing Magnetic Field, the Primary and the Secondary, where normally the Secondary is ignored.
Remember what we were told:
That is such an important statement!
The Coils each have a Current, and if we work the Currents such, that the Currents themselves make for a greater Primary Assist, also meaning the Primary magnetic Field is Greater, then we have exactly as Floyd Sweet Told us:
The current and potential windings require relatively little power, and are applied in such a manner
that rate of flow of moving charges may be accelerated beyond 1 ampere = 6.24 x 1018 electrons per second. Thus the duty factor of the copper changes.
I2R losses diminish and more charges drawn from the now coherent space field flow at a faster rate as current to the load. This means as more current is required by varying loads more feedback magnetomotive forces free more electrons from binding forces complimented by potential magnetic forces of the orientated, coherent space field. Thus a conductor that formerly had a temperature rise above ambient labelled as a factor of 10 would now operate at a temperature of 1.0. Thus the same gauge wire would carry 10 times more current at the same temperature.
Even better results may be forthcoming. The energy conversion conservation is fantastic.
Your Input Coil only brings the Potential, or Voltage up, The Partnered Output Coils do all the work themselves! One Partnered Output Coil being the Coil on the Stator and One Partnered Output Coil being the Coil on the Rotor, each Coil only being excited by the Action, in our case we are replacing the Rotation of the Rotor with a small Changing Magnetic Field initially.
We have built a Solid State Electrical "Generator" - This is the best way to think of it.
Your Core can only hold so much Magnetic Field, your Coils can only have so much Current through them.
Ourbobby posted this 14 March 2020
              i am suffering a bit from information overload! Arthur or Martha? Just help me out here please. Above you show measurments for two coils.  What I don't get is your meter showing 80+ ohms for impedance. How did you do that?
ourbobby
Morning Ourbobby,
I have a feeling my Digital Multi Meter is faulty, I am about to get another Meter and re-check the measurements.
For now, please disregard the DC Resistance of the Coil, I do believe, and Vidura as you have, has also pointed out this seems wrong.
"Little steps for little feet", please, the information will always be here, so don't worry, your experiments will give you answers.
Really, there is only three things you need to keep in mind:
  1. You need at minimum 2 Output Coils.
  2. Your Output Coils must Buck, or Oppose.
  3. Your Input is only a tickler, to get your Potentials, or Voltages Up.
All here can help so please try not to feel overwhelmed. I know its hard.
  • chocolate blanco
Ourbobby posted this 15 March 2020
As you say, KISS is the acronym. I realise why I am having difficulty establishing, I need a controlled current power supply with an independent voltage adjustment to hold the set current. Without this, I cannot see a way forwards. I am able to get to see the current rise, but as soon as I raise the input power, I lose it. As soon as I overload the POC unit, I lose any semblence of current rise. That is, the window disappears. No sawtooth!! Also, I am getting a tremendous amount of noise and random looking waveforms. Again, I would suppose, correctly balanced coils, with the correct power input, and its happy days are here again!
There ia s lot of information on your Hyiq site. Constant refences and examples contribute to the difficulty of a successful build. in the short term at least. I am mindful oj John Bedini's approach which although implying"free Energy", did not seem to be threatening. People out ther clammered to his site and workshops. His working model, the SG for example would have enabled many hundreds, if not thousands of afficionado's!.
Anyway, I have to have a rest, the constant interrogation of your links and threads has exhausted me. until I can a solution I shall have to become a theoretical builder.
ourbobby
Vidura posted this 15 March 2020
Hey Ourbobby, It happens to all sometimes that we become saturated by a lot of information, anyway, the most valuable knowledge is that gained by experience. Regarding the inconvenience with your actual setup, if I may suggest: Try a simple experiment like the Mr Preva or the coils like in Chris' tread some coils buck and some coils don't, so you can evaluate if your switching unit is working correctly. A regulable lab power supply is useful, but not indispensable. Most experiments can be performed using batteries as well. Adjustment of voltage on some cases is needed, while the current limiting feature is mostly for protection of the equipment. If I can help with something just let me know. Vidura.
Ourbobby posted this 18 March 2020
Hello,
I do not have a variable AC supply to drive the Mr Preva or the non-inductive coils. I am not sure how to interpret the pulsed outputs due to obvious jittering or excess interference. I have tried tuning the non-inductive coils I have already wound. Approx 3000hz I get with a 105 capacitor. This is my output. Nice big sawtooth.
However, it seems I shall have to get a lab power supply of sorts so that I am able to control the inputs. At present, with a resistive load as the current control, my pulse at the mosfet changes in frequency as I increase voltage. As the power ratio changes. So although I set the pulse to 10%, at the mosfet output, it changes to relfect the power to the coils. Anyway, understanding this is good.
! can get a sawtooth this way!
ourbobby
Chris posted this 18 March 2020
Hey Ourbobby,
Awesome work! Much better than last waveform! There you have it, excellent progress! Improvement comes from work, with work, we see gains in Energy as the effects are improved! Very nice! Thank You for sharing!
I believe it is your turn to be added to the list, well done!
  • chocolate blanco
Hello Chris,
                  I am yet to have the magic eureka moment! But, thanks for the comment. I must look for the output or energy input next.
ourbobby
Hi , just before I head off to bed, I also have a primary winding on the core, so that I can look for differences between core winding and on top of L2 winding! Here is the difference for me. Which is the better route?
ourbobby
Hey Ourbobby, Can you explain this further, I do not understand. Perhaps a diagram, might help me understand what you mean.
Re:
You have the interactions there to led you to a much greater understanding Ourbobby! Don't forget the waveform is a precursor:
I urge all here, study this video:
What does Graham show at minute:  4 : 54 on.
Ref: @ 10 : 27
NOTICE: The Scope is 100 Volts per division.When Graham removed the Capacitors, the pulse was around: 200 Volts, when the Capacitors were removed, the Voltage was around 240 Volts. The sharper the Spike, the more E.M.F was Generated, thus the machine went Above Unity when more E.M.F was generated.
For this experiment, I added, a capacitor on each one of the Output Coils.
instead of a pulse width of about a micro second we have about 2 and a half microseconds.
Cop is about 1.3
Remember the difference:
The difference: 0.5 Watts Input 9.5 Watts Out vs 8.0 Watts Input 10.8 Watts Out
Now, remember, Ohms Law: I = V / R, Increase the Voltage, the Current is also increased for the same Resistance. The Potential Problem also pointed out by Tom Bearden:
Don't forget guys, methods exist to get the Voltage up! I started a thread, to get others looking at this: Voltage I hope we can all come together to work on the best methods to solve the Voltage Problem!
Ourbobby posted this 19 March 2020
Chris,
Here is a drawing that I hope explains the different outcomes, sawtooth and curved outcome, and L2 and L3  connection.
ourbobby
Chris posted this 19 March 2020
Thanks Ourbobby,
Not enough Coffee, I got you now, although the placement of the Coils should have little effect to the overall operation, only the Coupling and therefore the losses through un-coupled Flux.
When the secondary Coil is directly over top the Primary Coil, this is called Unity-Coupling. Transformers are both Unity Coupled and non-unity Coupled, they work the same either way.
Thank You for sharing, I appreciate your efforts as I do everyone here!
  • chocolate blanco
Ourbobby posted this 23 March 2020
               I think I have it. 10% is the charge time, which terminates as the alternate lenz kicks in and combined with the discharge gives us the sawtooth?
ourbobby
Chris posted this 23 March 2020
Hey Ourbobby,
My Friend, it sounds like you have it.
The Opposition of Force is Re-Directed, from the Secondary Coil to the Tertiary Coil. Essentially, the Primary pushes the Tertiary Coil, they work together, in unison, to push the Current, to Maximise the Electromagnetic Induction well beyond the current limit or Input = Output - Losses.
We target Electromagnetic Induction and the advancement of it.
I get impatient sometimes, I would really like to see more progress, I realise we all are so busy! The Virus, our Families, daily lives are so busy! Why are we all kept so busy?
Time is only a reflection of change. From change, our brains construct a sense of time as if it were flowing. As he puts it, all the "evidence we have for time is encoded in static configurations, which we see or experience subjectively, all of them fitting together to make time seem linear."
Ref: https://www.space.com/29859-the-illusion-of-time.html
So we are so busy because things change so fast, we are seeing so much change from minute to minute!
Our Partnered Output Coils must mirror our Daily Lives! We need Change, fast change, we need turns, but not too many!
I would like to share an analogy:
Ref: http://www.hyiq.org/Updates/Update?Name=Update%2018-07-11
IMPORTANT:
I had to tune this machine, find the best frequency, to observe effects. Each Coil has Capacity, Inductance and Resistance.
Each Coil is subject to Electromagnetic Induction!
The Time Rate of Change of the Primary Magnetic Field "Generates" an E.M.F, then a Current can Flow. Each Coil sees the Other Coil as a Load! Each Coil attempts to Drive the other Coil! This situation becomes by definition, a Triode:
An electron tube used mostly for signal amplification, consisting of a cathode and anode (or plate) as in a diode, and an intervening wire mesh called the control grid. With little voltage on the grid, large currents can flow between the cathode and plate, but small variations in the voltage on the grid cause large variations in this current, allowing for large amplification of a signal applied to the control grid.
A type of vacuum tube that is used in audio and radio amplifiers and oscillator circuits. It is like a diode with the addition of a wire mesh control grid between the cathode and plate (anode) that controls current flow. A filament heats the cathode enabling it to release electrons. When a small voltage is applied to the grid, the current flow between the cathode and plate is changed accordingly. In some triodes, the filament is the cathode.
Ref: https://www.yourdictionary.com/triode
Each Coil squeezes off the Vacuum Flux, or the Magnetic Flux of its Neighbor! So, Current flows between the Cathode and the Plate! The Control Grid, controls the Flow, between the Cathode and Plate, simple a squeezing off of the Flow of Current.
In this analogy, if Magnetic Flux was to replace the Current, then simply, squeezing off the Magnetic Flux, if you like a Controlled Electromagnetic Induction Pump, then the Grid becomes the Action / Reaction Pair of the Partnered Output Coils, the Input Coil is the Supply of Current to the Grid. So Tom Bearden's analogy was right, if one looks at the VTA, Vacuum Triode Amplifier in the correct sense! Floyd Sweet allowed Tom Bearden to rename the VTA from the SQM The Space Quanta Modulator, or Space Flux Coupled Alternator. The term Alternator implying Electrical "Generator", by its very definition!
You see, Electromagnetic Induction is simple:
  1. Conductors!
  2. Magnetic Field Changing in Time!
  3. Right combination of Proximity and Turns.
Electromagnetic Induction is Incomplete! There is more to learn! They stopped back in the 60's because they knew there was more here, more to learn, but it threatened their status quo! They shut it down and tole everyone, nothing more to learn here, its a finished now obsolete topic, when they knew it was not!
Remember:
When the current in one half of the conductors in the coils (i.e., one of the bifilar elements in each coil) of the device is moving up, both the current and the magnetic field follow the right-hand rule.
The resultant motional E-field would be vertical to both and inwardly directed.
At the same time the current in the other half of the conductors in the coils is moving down and both the current and magnetic field follow the right-hand rule.
Thus, the resultant field intensity is double the intensity attributable to either one of the set of coil conductors taken singularly.
Expressed mathematically:
E = ( B x V ) + ( -B x -V ) = 2 B x V
NOTE: The Coil Winding Direction as I have shown can play a role in the success you have.
Chris posted this 25 March 2020
I need to say to all readers; On regular occurrences I get PM's Emails or other correspondence saying:
I want to build a machine that gives about 500 Watts for free...
Now I have to say, all readers MUST start at the start! That way of thinking is unrealistic, at least when first starting!
I strongly urge all members set small realistic goals, aim for 2 - 3 watts first!
Floyd Sweet his first unit was reported to be Six Watts! Although there is no documented evidence for this figure, there is a documented figure of: 19.1544 Watts on one of Floyd Sweets First Machines. You can read that here: Floyd Sweet Lab Notes.
Please, everyone, I urge you all, this is important! Be realistic, aim for a few Watts first, you can improve as you learn more!
But don't set your goals too high, where they become un-reachable! This will be Negative and you will quickly loose interest and not learn anything! We all have to start at the start! We have to! Its how Life works!
If you set small realistic Goals, then before you know it, you will have 500 Watts Output, but you must be realistic!
Chris posted this 26 March 2020
A Video to help understand What the requirements are for Energy:
I hope this helps others! A Milestone also!
I love Humanity and wish for so much more for all of Humanity and the World as a whole!
  • Fighter
At this stage, for some of you, this is already well known, we have already touched on this before, but:
Now let us consider the losses. Copper or Cu I2R losses remain but may be minimized by using wire of larger than usual cross-sectional area.
What are the I2R Losses? DC Resistance Losses! We already know this, but this is verification from Floyd Sweet, hidden in the middle of the texts.
Using our Above Unity Member Calculator we can run a comparison:
By increasing the Cross Sectional Area by a factor of 10, we gain an output factor of: 49.5 / 0.495 = 100, thats a hundred times more for only 10 times Cross Sectional Area Increase!
Floyd Sweet was right! Again we have covered this before, but with a little more data this time.
Chris posted this 27 March 2020
A friendly reminder of an age old technology, we only need expand on a little:
Ourbobby posted this 29 March 2020
    Am looking at the Meg as an initial stage to understand the induction complement of the set-up of POC's. Looking at the JL Naudin build. So, I first have to rationalise the L2 windings over the middle of the C cores! For anyone looking at this. Here is my magnetic clamp solution, not perfect, but, OK for winding small number of cores. It uses two round neo magnets sold often with 6mm screw hooks.. My coupling iuses two long extention nuts 10mm to connect to winding machine and adjacent magnet.. I have drilled out two 10 mm bolts and tapped for 6mm threaded rod insert, then cut off the heads. It works!
Enjoy
ourbobby
Chris posted this 29 March 2020
Hey Ourbobby,
Very nice! If I may suggest, wind your POC Coils, x Turns of nice gauge wire, but wind one layer, say around 10 turns on the top of each coils also.
Then apply what we have learned. Find the Sawtooth Waveform, then you can go ahead and maximise the effects to get the best possible output.
Nice work, Thank You for sharing!
A Video for all:
Apologies, I said Excitation Coils, the Diagram labels the Coils I meant as Excitation Coils, earlier in the video as Power Coils. You may need this:
NOTE:
Checks still not in – 13 days late – Sparky explains that there is a little part in the Generator that he
has withheld from disclosure – A $1.50 part from Radio Shack that could be gotten at 30c in quantity
that is not a capacitor (no resonance effects) that divides the current somehow into the circuit being
Spherical
With light bulb filament
parallel, that puts a small µa current into the Power Coil as well as the Excitation Coil, that works with the Magnets in such a way that there is halved A Vector Complementarity (he calls this unit a ( “Vector Oscillator" )
Ref: Floyd Sparky Sweet Lab Notes.
Lets not forget, this is not the first time we have heard this, its not rocket science:
I hope this helps some!
Ourbobby posted this 30 March 2020
              Lets see if I have it! I wind two secondary coils and then on top of each secondary I wind a linked centre tap primary of ten turns. So what happens to the 100 turns primary on the MEG? What is nice wire?
regards
ourbobby
EdiT; I am stupid, I see it now!!!!!!!!!!!
Chris posted this 30 March 2020
Hey Ourbobby,
Yes, but the 10 turn coil as a separate Coil, not electrically connected. No Center Tap, not yet, learn first then later you can try all that stuff.
Wind them as I have shown in my POC Image, you can have 4 Coils if you like? Its up to you, use one as a sensing Coil. So, Output Coils will be X Turns, Input, one Coil, 10 or so turns.
Don't forget, Delayed Conduction to get the Voltage Up. Current ( I ) = Voltage ( V ) / Resistance ( R ), as the Voltage increases, as does the Output Current.
I have given everything, When I said you have to get the Voltage up, I gave it to you all, You see a large Voltage spike here:
Fighter has shown you the same, and done the same, given you all of his work:
There are different methods to get to the same end goal, many of us have shown this technology work.
My Friends, I fear many are here reading for their own selfish benefit! Some out there claim the invention for themselves! I read a post on another forum the other day, claiming the Invention, I said something, and they got all upset.
I fear the world is still not ready for this!
Although this means the majority miss-out, the minority is all it takes to spoil the whole thing. There is still too much Selfishness, Greed, and to be honest, some days I feel like shutting the whole lot down! The only reason I don't, is I know we have such a good bunch of people here, hard working, all sharing! It is those of you that keep this all going!
I posted this to the other forum today:
Well, looks like I am going to have to ignore your comments: "MY INVENTION"
In reality, Partnered Output Coils is the subject of this Thread and were around well before you came on the scene Seychelles.
@kolbacict - I worry for you! Your posts show many problems, are you OK?
Now, I am going to put this plainly, Go Replicate my series: Non-Inductive Coil Experiment - in Video Seven you will find information that will help you the most! All videos prior are important and a buildup to Video Seven.
Video Seven:
I get tired of trying to help everyone when others are either out for themselves or not willing to help themselves! I wont be doing this for ever! You have little time left! I suggest you do a lot more to help your Fellow Brothers and Sisters!
Your Greed, your Self Service, will be your DESTRUCTION!
You have a glorious Future if only you were to Evolve!
   Chris Sykes
My Friends, this is all for you and because of you! Please support this effort, make this what it should be!
We have broken Ground, this should move like a Roller Coaster, growing and Growing, getting faster and faster, but I do still see problems! Be Safe and be Well My Friends!
Wistiti posted this 30 March 2020
Chris, my freind, dont lose your time and optimist by following this forum.
On my side i see great difference between the first forum you start and what we are now!
Thank you to be there, do not worry it,s more than apreciate!
Thank You Wistiti!
My Friend, you have been with me from the start! Your experiments are excellent! First Class! You have machines Charging both Batteries, Input and Output! I am extremely please you have seen what Humanity has to come! It is just the start! We have doors wide open once we have made those initial steps!
I very much appreciate your contributions!
Thank You My Friend!
Jagau posted this 30 March 2020
I join Wistiti for the same words, I think that says it all,
in these difficult times for all i believe the best is yet to come.
You even see google can change you got the proof this week.
A big thank you for what you bring to this forum, as a founder and for having the patience to support us.
It will be fine
Thank You Jagau!
I agree, the best is yet to come! We have come a long way, already, but yes, the Future will be Glorious! We only need work hard for it!
So many Good People here! I thank You All! Humanity is on difficult times and we are getting through it much better than what we have in time past!
Best wishes My Friend!
Chris posted this 01 April 2020
I am sorry, this may be a little off topic, but I have re-watched the old Star Trek Movies and Series.
I guess you could say I have tried to base my work on the way Mr Spock has shared his effort, trying to be Logical as possible! I would like to share some quotes, in remembrance of the great man and the roll he played:
Logic is the beginning of wisdom, not the end.
The miracle is this: the more we share the more we have.
In reference to Leonard Nimoy. Also another of my favorite, James Doohan, truly, all of them are legendary! All the way up to our current Movies...
thaelin posted this 01 April 2020
Aye and Scottie knew it well. One of his sayings stays with me forever. "Fool me once, shame on you. Fool me twice, shame on me." Hope that is taken in the correct context. Don't fall for it twice, just move on.
Hey Thaelin,
Yes I remember that one also!
If you have spare time due to the Virus, watch "For the love of Spock" - Its good!
I would like to make some more examples obvious.
We have a reasonable good historical record! I have shares all my research here: Reference and here on my two websites, hyiq.org and aboveunity.com. I have done many thousands of experiments over the years, most not any real value, some very valuable! I always learnt lots by experimenting!
Recently, in other threads, we have covered again some more on the thread: Non-Linear Inductance
Inductance ( L ) is the Rate at which Amperes can flow through the Coil in Time, this is defined as:
L = di / dt
One Henry is where One Ampere transitions the Coil in One Second. With Back E.M.F:
L = ε / di / dt
Where ε is the Back E.M.F, restricting the Current Flow, created by the change in Current  that produced the E.M.F.
We know, Faraday's Law of Electromagnetic Induction, as a Magnetic Field Changes in the Proximity of a Conductor, this creates a Voltage! Well the same if true of the Inductance, the Inductance changes with the Magnetic Field!
This means, you could say as the Inductance changes, a Voltage will also be Created / Changed. Thus, simply, because the Magnetic Field is Changing.
Remembering Inductance is the ability for a Coil to pass Current. The BH Curve being a function of the Current to the Voltage, the Primary Current to the Output Voltage. Sites out there help you measure the BH Curve, sometimes known as the Hysteresis Curve, using a similar Circuit:
Note: You need to plot X and Y on your scope!
Most here will know, an Air Core does not Saturate, having no BH Curve, there is still an Inductance however!
What does it take to Saturate a Core? Well there are Core Values, specified on the Manufacturer Datasheet, under Bh or AL or something similar that tell you what the Core is rated to.
Magnetic Field if as we have learnt, the Turns carrying Current vs the length of the Inductor. Our AboveUnity.com Member Calculator has a small calculator in there to help you with this:
This will help you see what the Magnetic Field is at Core Saturation. How can one find Saturation, the sharp peaks on Current Waveform is one indication:
We must remember, at Saturation, we can have very bad Burnouts:
So please be careful!
What occurs, the Inductance is lost, the Inductor becomes a straight DC Resistance, loosing all its AC Resistance, or Reactance, and the Input Current goes very High! The Transformer can Burnout as a result.
Chris posted this 02 April 2020
I cant recommend this more! A very good documentary!
0.56 + 0.82 + -0.59 + 0.56 = 1.35
I don't get why the negative is ignored?
Electricity and Light, how they are related.
In regards to the above post, not the last one, but one before that, I would like to add, if anyone has gone and read the link investigated the image, read the posts, and remembered what was said, this perhaps this line may have stuck out at you:
You can see, an external Magnetic Field added to a System, and Moving this Magnetic Field, in the System, can, and does, add energy to the System. Thus the "Generation" of electrical Energy.
What was I showing? Well lets look again: Partnered Output Coils - Free Energy
Any and all Permanent Magnets work, to imply otherwise is just foolish. Magnetic Fulx when moving, no matter from what ever source, Invokes Electromagnetic Induction:
Quote from: Floyd Sweet
Rather, what happens is that the individual packets of quanta are polarized by the initiating and sustaining coherent force the field of the primary magnets or in special cases, electromagnets.
Floyd "Sparky" Sweet - The Space-Quanta Modulated Mark 1 Static Alternator
Maybe its time to repost this image:
Please ask the question, what are the Magnets actually doing in the Core, it is not just the Movement which I have stated! It does other things also!
I am a Student in the School of Life, always will be, my entire life, never an Expert!!!
We have many very smart members here on this forum, some helping me understand more every day! I have said, it requires a bit of work, fiddling is required to make this work! But one day soon, maybe this wont be quite as tough of a learning curve? I cant predict the future, not yet anyway, but I know the now.
I want to thank: Zanzal, YoElMiCrO, Vidura and Jagau for their recent contributions. I hope we can share more soon.
Chris posted this 03 April 2020
The following Documentary is very good! Many good relevant points in this Documentary, think Nothing is Something by Floyd Spark Sweet:
What is nothing? It is Everything!
I don't want to hijack others threads, and without creating a new thread, this is the next best thread.
Recent work focuses some, on Permeability. Now documentation for Permeability is poor at best. The definition of Permeability is:
1: the quality or state of being permeable
2: the property of a magnetizable substance that determines the degree in which it modifies the magnetic flux in the region occupied by it in a magnetic field
Ref: Merriam-Webster - Permeability
I would like to speculate some.
I am thinking in terms of Coil and a Core having Mass and distorting Space Time, thus the Toroid.
I want to Visualise Permeability in a 3D Space, a localised Space Time Distortion. I believe the best way to Visualise Saturation and Permeability as a Toroid:
Note: This is a localised area of distorted Space Time due to the Mass.
Inside the Toroid, we have a region of Space, if you like Space Time, that can change, it has a Curve to it.
Here you can see the Curve I am getting to, please excuse my terrible art:
The BH Curve, or Hysteresis Curve are related to the Permeability:
Ref: Datasheet on Magnetic Cores.
We know, as the Magnetic Field Density ( B ) increases, the Plot starts to Curve, in Red. When the line flattens out, this is Saturation, no more Magnetic Field can fit inside the Core! The Core Material is Saturated! Thus the BH Curve:
We know Space Time can be Flat and also can be Curved. Mass distorts Space Time!
Mass is not a property of space (or space-time itself), but of physical objects in classical physics. In General relativity, it is difficult to speak about mass clearly, there is no good general definitions. Now, there are two naive metaphysics about space-time. The substantivalists think that space-time exists by itself, even if its not "made" out of something, and that if you remove all matter from it it is still here (but empty). The relationalists on the other hands, think that space-time is emerging from the relations between matter and that it does not make sense to speak of space-time itself without matter. For substantivalists, space-time has points that "really" do exists, while for relationalists it does not.
Ref: physics.stackexchange.com - Does spacetime have a "mass" value? or What is "Spacetime ...
The E = mc2 equation which we know to be Energy ( E ), Mass ( m ) and the Speed of Light2 ( c2 ) is a form of Energy ( Mass–energy equivalence ). Energy distorts Space Time:
Since matter carries energy (via Einstein's famous relation that energy is mass times the speed of light squared), such objects will have a gravitational field and so they will distort space-time. So one way in which a charge or a magnet will distort space-time is by virtue of its matter.
Ref: Do electric charges and magnets distort space, in the way that a source of gravity does?
If I understand this correctly, then Permeability must be related to Energy, or at least to the Flow of Energy! This is the Green Curve above.
Space Time is Permeable, known as Vacuum Permeability: μ₀ = 1.25663706 × 10-6 m kg s-2 A-2
The physical constant μ₀, commonly called the vacuum permeability, permeability of free space, permeability of vacuum, or magnetic constant, is the magnetic permeability in a classical vacuum.
Engineering the Vacuum:
After a brief review of the foundations of (pre-metric) electromagnetism, we explore some physical consequences of electrodynamics in curved spacetime. In general, new electromagnetic couplings and related phenomena are induced by the spacetime curvature. The applications of astrophysical interest considered here correspond essentially to the following geometries: the Schwarzschild spacetime and the spacetime around a rotating spherical mass in the weak field and slow rotation regime. In the latter, we use the Parameterised Post-Newtonian (PPN) formalism. We also explore the hypothesis that the electric and magnetic properties of vacuum reflect the spacetime isometries. Therefore, the permittivity and permeability tensors should not be considered homogeneous and isotropic a priori. For spherical geometries we consider the effect of relaxing the homogeneity assumption in the constitutive relations between the fields and excitations. This affects the generalized Gauss and Maxwell-Ampère laws where the electric permittivity and magnetic permeability in vacuum depend on the radial coordinate in accordance with the local isometries of space. For the axially symmetric geometries we relax both the assumptions of homogeneity and isotropy. We explore simple solutions and discuss the physical implications related to different phenomena such as: the decay of electromagnetic fields in the presence of gravity, magnetic terms in Gauss law due to the gravitomagnetism of the spacetime around rotating objects, a frame-dragging effect on electric fields and the possibility of a spatial (radial) variability of the velocity of light in vacuum around spherical astrophysical objects for strong gravitational fields.
Ref: Electrodynamics and spacetime geometry: Astrophysical applications
Again, I want to mention: Zanzal, YoElMiCrO, Vidura and Jagau, as much of this thinking has been spurred on by them! I have not thought about Coils quite like this before.
Good video, but this guy is super skeptical! The video in the last post, from Professor Jim Al-Khalili, disputes some data in the PBS Videos, Dr Matt O'Dowd. Please beware of this!
Please remember I am still learning this stuff!
  • YoElMiCrO
Chris posted this 05 April 2020
I want to recommend the Videos done by PBS, the YouTube Channel: PBS Space Time ( https://www.youtube.com /channel/UC7_gcs09iThXybpVgjHZ_7g )
This Video is another very good one!
What is dark energy? And could we tap into it?
Before scientists could even attempt to assess the possibility of harnessing dark energy as a source of electricity, we'd have to find it.
If we were able to harness the power of dark energy, however, we'd be using it for a lot more than simply powering our iPhone. Instead, tapping into dark energy could usher in a whole new era of human spaceflight.
Theoretically, a spacecraft that runs on dark energy is possible. According to a paper published in 2008 on arXiv.org, a dark-energy-powered spacecraft may be able to travel faster than the speed of light. The spaceship would actually stay in place while space-time around it was affected.
Sci-fi fans will recognize this as the basic concept of a "warp drive." In fact, one scientist has even created a design for what such a ship capable of traveling warp speeds would even look like.
That, however, is an application we likely won't see in our lifetimes. And dark-energy-powered electronics, cars or buildings aren't coming along anytime soon, either.
Ref: https://science.howstuffworks.com/
Also:
Dark Matter as a Possible New Energy Source for Future Rocket Technology
Current rocket technology can not send the spaceship very far, because the amount of the chemical fuel it can take is limited. We try to use dark matter (DM) as fuel to solve this problem. In this work, we give an example of DM engine using dark matter annihilation products as propulsion. The acceleration is proportional to the velocity, which makes the velocity increase exponentially with time in non-relativistic region. The important points for the acceleration are how dense is the DM density and how large is the saturation region. The parameters of the spaceship may also have great influence on the results. We show that the (sub)halos can accelerate the spaceship to velocity 10−5c∼10−3c. Moreover, in case there is a central black hole in the halo, like the galactic center, the radius of the dense spike can be large enough to accelerate the spaceship close to the speed of light.
Ref: arxiv.org
Amazing Science! But please, as I always try to say, Reference and cross reference. We all make mistakes and PBS may not have it all 100% spot on! So Cross Check!
dale morgan posted this 05 April 2020
Hello,
There are problems with the terminology that Classical scientists use. Dark Energy and Dark Matter are actually called Dark because they cannot be observed. You can't measure them directly. Bearden covers this in several of his papers. He states that Dark Energy is actually the Virtual Particles that we are immersed in, from the nucleus on out into space on the other side of the universe. Can't see it or measure it so it's called Dark as a way to talk about it as a specific entity. I've been re-reading all of his papers to bring it back to the top of the brain so at this moment I can't say specifically which paper has what. Bearden repeats the same thing in many of his papers to get the info out there to those that are interested.
What he says about the function of magnets, how they work, is pretty straight forward. So is Howard Johnson's description. The field lines that can be shown with Magna View are an ordered Steady State flow of Virtual Particles as in Van Flandern's waterfall. NESS, non equilibrium steady state flow.  The formation of a magnet creates an ordering of the atoms within the material. Several billions of little dipoles, (magnets), aligned and fixed in mostly the same direction. Kind of like a magnifying glass. Concentrated in a small space.  I think of it as a Vacuum Tap, like tapping a keg of beer. Can't get the beer out without it, (a coil is basically the same thing).
But we don't see the keg... Virtual Particles are not single particles as they are most commonly thought of. They are EPO's. Electron/Positron Pairs which do not have enough energy to pop into our 3-Space on their own. They need to hit some mass. So the visible magnetic field we can 'see' has to come from someplace... can't create or destroy energy. The Bloch Wall is a boundary layer between domains of orientation within the magnet. This is a sort of filter which separates the EPO's into discrete units. Positive and negative moving in opposite directions. Normally most of this happens near the center of the magnet between the poles. It is an inflow of energy into the magnet that we cannot see or measure. This action is the power behind the magnets field. The strength of a magnet is determined by the strength of the applied magnetic field that created the magnet in the first place. As is normal a large coil is used to make magnets, however the field in the magnet is only paid for once during it's creation. The field from a coil has to be paid for continously. Generally the same effects can be gotten from either. It's a matter of economics or complexity. I like to use both. Something From Nothing is a very good title as the magnetic field has to come from somewhere. No magic here.
In my own opinion, Spacetime Distortion is being misrepresented by that terrible graphic which looks like a funnel. That shape may represent a path that an object might follow upon being captured by the gravitational field. I believe that a more accurate representation would be like the layers of an onion. If anyone is familiar with Optics then the refraction of a beam of light through the surface of a layer of glass is a good way to see it. A fishing pond is a good way to visualize it also. The fish is not actually where it looks like it is. So relating it to an onion we have multiple layers, multiple surfaces of refraction. As the strength of the gravitational field increases, getting closer to the surface of the mass, the number of layers increases, the path becomes steeper. Thus at any point of 'capture' in any direction the path will 'follow' the shape of the funnel, generally.
I have spoken loosely here to try to paint a picture that isn't highly technical in nature. The point is that the terminology can be misleading in some cases. It can screw with your perspective enough to have you going in circles, not gaining a clear understanding. Certainly in some of the videos clear understanding is not what they want to teach. The electron is called negative because Ben Franklin flipped a coin, an arbitrary choice. In some cases it's easier to think of it as being positive....
Hopefully I haven't sounded like an arrogant ass here. I do not want to offend anyone and I certainly do not know everything! However I will have nothing to do with the Box or the limits that Classical Science try's to impose upon us.
Have a great day,
Dale
Hey Dale,
Nice Post, thanks!
I agree, dont be bound by someone elses box!
I read this, its also helpful:
Ref: Modern Nonlinear Optics, Part 2 - edited by Myron W. Evans
Although, this theory and background is useful, we must realise, as Vidura has said, we are currently working in areas that may not have anything to do with this field. I am interested in attempting to know more so I can understand more.
An analogy:
A New Tesla forms right in front of you, its beautiful, drives like a dream and you are very grateful! But you cant stop wondering how and why it formed right in front of you and this bugs you. You need to investigate more and more! It becomes an obcession and you hardly drive that beautiful Tesla because your'e busy attempting to find the reason for its appearance!
I tried to join Twitter today - It wont let me! Keeps sending me around in endless circles... I guess the @elonmusk bit was not really an acceptable thing in their opinion!
Note: This is on Account signup, not even doing any posting at all, before I posted anything.
I see this sort of thing a lot more now that ever before!
  • AETHERIC_MIND
thaelin posted this 06 April 2020
You do not need that forum Chris. They would never allow you to post the truths on what we are about anyhow. If you post anything that is contrary to the system of things, it will be edited out or your account seized or the likes. We come here to seek the truths on things being investigated. To thine  own self be true. And then share the truth with others as you have already been doing.
Many things will come to light soon.
Chris posted this 06 April 2020
Thanks Thaelin!
I was going to send Elon Musk a message, he is perhaps one of the few wealthy that may listen to reason. As you say, the message will likely be destroyed before he receives anyway.
Conventional Science does not understand the Electrical "Generator"!
Shaft Torque is not the Cause of the Volumetric Flow we know of as Watt Seconds ( V x I ). Shaft Torque is the Effect, only occurring after the Volumetric Flow is achieved.
Simple Experiments give us a lot of real data, if we take the time to study what we are shown. Voltage is Free, Science agrees on this point! Current is not Free, at least according to Science. However, NI, the Ampere Turns, is equivalent to the M.M.F, and the Magnetomotive Force is a fundamental Force that must be dealt with!
CD's recent experiments show a working Machine, a DUT that is obviously Above-Unity, showing all the effects we need to observe. Current is sent back to the Power Supply, the Input, or Consumption Current, is Reduced, when in operation, which is required, the machine powers a Load for less energy that the machine required just to operate. The Load reducing the Input power, not increasing it like we have been brain washed into expecting!
We really cant make the machines any more simple, its Three Coils, One Input Coil, Two Output Coils, Partnered Output Coils, configured correctly gives Above Unity!
The start to this understanding comes in this Video: @ 30 : 14
NOTE: The whole series is important, containing lots of information.
CD has worked very hard to obtain this result! I congratulate him! From here on, improvements will be colossal!
I am happy to help anyone wanting to work toward this goal! As long as they are willing to work hard to achieve it. I have a great deal of respect for my fellow Brothers and Sisters, our Future is going to be Glorious!
We do have to work hard for it though!
Thank You Thaelin, you have been with us from the very early days! I very much appreciate everyone's support!
dale morgan posted this 06 April 2020
Thank you Chris!
I'm thinking that everyone already knows that the Heavyside flow is the Magnetic Vector Potential A, the uncurled 'half' of it that is. I found a way to separate them but cannot open up my boxes yet. Very anxious to do so.
Don't waste you time with Musk. I sent him an equation and asked if he'd ever seen it, dA/dT = -E. No response at all. He must like having to plug the car in to charge the batteries...
Myron Evans is one of my favorites to read. He's the whip! Oh, in the US that means one of the best.
Good days,
Dale
Chris posted this 08 April 2020
The Word, in a public effort to educate, I joined Twitter, never thought I would. Initially I had problems. After a lot of messing around, and changing some things, I got my account working. I made several tweets already:
Will this help our cause? Will it hinder us? Time will tell.
Ourbobby posted this 08 April 2020
Hi Guys,
                Have eventually got my Meg replication built!!. Winding the secondarys' took a bit of time getting them wound smoothly with the fine wire. Anyway, these are my first photos and first connection! Have not looked to see if my coils might need swapping yet. The Yellow trace is a 100:1 probe the Blue trace is 10x probe. The yellow trace is on the CCW coil. At least i think it is CCW, always get a bit confused with the winding direction. Showing just over 1kv.
Incidentally, i have put a thin plastic separator between the C sections.
So this works!  I shall look at it for a short while to see what it tells me. Reassuring that I can build something that works!.
ourbobby
chocolate blanco posted this 08 April 2020
very good, could you pass the circuit and how many turns on each coil? You say that with a better cable, like coax, would it improve?
Ourbobby posted this 09 April 2020
Hi Chocolate blanco,
                                  I am using the coil dynamics of JL Naudin's replication of the MEG. http://jnaudin.free.fr/meg/meg4cf.htm
for the driver I am using the circuit outline as postrd above using a 3524 and 4227 driver. I have been looking at my coil connections and something unusual has occurred. I have found that general pulsing with my circuit will not provide sufficient oomph for the bucking to occur. I think I have a tricky potentiometer! Because, when I get to a certain point of the wiper, I get very good pulse to the coils! As it is a tricky circumstance, it is very difficult to maintain the pulse outcome. This has indicated to me that I must reassess the drive for the coils in the unit. I am not sure if the pulse output is what I might be looking for. The globes in the attached photo are the mains voltage LED's. So they will light with Radiant output. Incandescent Globe does not light up! So i am still not doing it correctly. The voltage i am using is 12v battery.
Regatrds
ourbobby
Chris posted this 09 April 2020
Hey Ourbobby,
We have a The MEG Thread. Its worth watching the Video if you have not already:
Notice the waveform shown:
Of course the bottom waveform is upside down.
I hope this is useful!
  • Fighter
              Thanks for that Timing link. I 'll order some MOV's tomorrow with different voltages, so i can see what my outputs are. I think i have the correct waveform but wrong control process. I get funny buzzing sound from within the core when i get the tricky bit stabilised. Although in reality I likely have just fluked the right potentiometer resistance to switch the coils?  That's what can happen when experimenting.
Will take a few days to arrive i think, even a week or more. Then sanitising! Strange times are here.
I built the MEG to see if it would help me understand the process we are sharing on overunity. Incidentally, if I hold one of my mains voltage LED globes towards the MEG, it will attempt to light up!
ourbobby
Hey Ourbobby - No no, just use diodes as we have been.
We are getting the same result, we only need improve on it.
Good work keep it up.
