How to build your own Above Unity Machine
  • 5.5K Views
  • Last Post 23 February 2019
Chris posted this 01 December 2018
You Will need:
  1. One Input Coil
  2. Two Output Coils
  3. Patience
  4. Support
You need to follow the basic plan laid out here:
NOTE: Partnered Output Coils can be wound either CW / CCW or CW / CW Flipped.
  • CW is Clockwise.
  • CCW is Counter Clockwise.
I prefer CW / CCW.
You will need to make sure your Output Coils have Opposing Magnetic Fields, thus Opposing Currents!
This is a Critical and Required Component!
The Operation to start with is as follows:
  1. Input Coil ( Green Coil ) brings up the Potential, then is switched Off.
  2. One Output Coil then Conducts Current ( Gold Coils ).
  3. The Second Output Coil then also conducts Current, a split second after the first, Equal and Opposite, to the First Output Coil ( Gold Coils ).
INPUT: Go for 2 Volts DC and around 320Hz or so, a Duty of around 10% or so. Slowly turn the Voltage up until you see things start to happen.
You will need to make sure the turns are greater on the Output Coils, per Coil by a factor of at least 1 : 3, so for every 1 turn on the Input Coil, you will need 3 Turns on the Output Coil and then that again for the Second Output Coil.
NOTE: Sometimes dropping a few turns on one Partnered Output Coil can be of benefit.
A small Gap between the Cored Partnered Output Coils to delay the Magnetic Field Mutual Coupling between the Coils. Circuitry can also be employed to delay Conduction on the second Partnered Output Coil.
Monitoring Currents in the Partnered Output Coils, you will see the Partnered Output Coils, like The Mr Preva Experiment, will Oppose, Magnetic Fields will Oppose! The Machine works because the Fields Buck, a Bucking Oscillator!
NOTE: When you have Bucking Output Coils, you will see a Sawtooth Waveform! Look for it, its the sign you need to see to know you're getting results.
Now, its up to you, arrangement, how you Construct it. I suggest Small Cheap and easy to work with!
On your Input Coil, perhaps use 12 turns 1mm wire or slightly larger. This means your Partnered Output Coils will be approximately 36 Turns each give or take.
NOTE: Don Smith suggested 1 : 4 Ratio.
I have suggested a few Circuits already:
Of course, this is what I have found, and the Output Circuit is not limited to these Circuits specifically!
Look at the Independent Replications, for some inspiration:
  1. Bill Alek
  2. TinMan, Bradley Richard Atherton.
  3. Graham Gunderson.
Basic and up Front, No Bucking, then your machine does not work and you need to re-arrange your Machine.
This is an Asymmetrical Machine, all this I have covered here on my website. We have:
  1. Amplified Voltage. Turns Step up.
  2. Amplified Current. Bucking Magnetic Fields as in The Mr Preva Experiment.
For all we have covered, all of it, and if you've followed, then this task should be easy!
I Promise You, if you follow the rules, make your Machine do what I have said above and on my Websites, it will work. You will have an Above Unity Energy Machine! You have my word on it!
NOTE: I expect you are experienced enough to competently work with Electrical Energy! This device can be dangerous, High Voltage and Current can very easily be achieved! I am not responsible for harm to person, and or equipment! I give you this very simple Guide as is and without warranty or guarantee. I have given a promise, and if you follow the instructions, this will work as I have stated! Making Changes will result in Failure.
Atti posted this 01 December 2018
   Hi.
 I fully confirm Chris's writing!  Chris has perfectly summed up the building criteria, the opportunities to find work in the work of others.
 But!!
How much energy do I spend and how much can I get out of it? Are there any measurements in and out of this? How much is the difference?  Did anyone make a similar measurement? Just out of curiosity.
Hey Atti,
COP > 1.0 when one has Tuned Frequency and Duty. Also with good Gapping and any Switching.
Crazy thing is, many here could build for $20.00 and an hours work if they know what they are doing.
Again for the readers: Critical Point is, Partnered Output Coils MUST Buck, this is the Current Amplification part. Greater turns on the Output Coils steps up Voltage, this is Voltage Amplification.
Very simply: Power ( P ) = Voltage ( V ) x Current ( I )
P.S: Lets see, what we see, from those that have waited for this for an eternity?
alohalaoha posted this 01 December 2018
   Hi.
 But!!
Hey Atti
It is not important how much input power you will inject in circuit 10Wt or 100Wt. You will get as much energy as you need at output once process was started.
Aboveunity power comes from charge injector pump, or from ferrite core charges.Sources of charges could be different. High potential - high frequency devices like Tesla transformer, Vladimir Brovin's Katchers (with HV bipolar or HV mosfets or IGBTs), Ground, Indepenent mass of high conductivity metals, salt water, highly ionised air, plasma sources etc.etc.
Charges only need to be sucked by Bucking Magnetic Fields and boost their initialy field strenght. Process is autosync once has achived. As low impendance is your load as much charge injecting would occur. This device make with easy infinite rise of power. So you need to sink additional power or to lower injection rate.
ps: The most important thing here is a TIMING. All must be balanced and coordinated. Maybe Chris should start with design electronic logic control for all kind of assymetric devices ?
Reg.
I want to share these Tesla's words which have a great importance to all aboveunity researchers and inventors.
They were from the lecture delivered by Nikola Tesla to the American Institute of Electrical Engineers at Columbia College, New York 20 May 1891. Lecture was firstly posted in the electrical engineer, a weekly journal of electrical engineering, volume viii, from 3 July, 1891.
Quote Tesla"
I would call attention to the fact, that in an alternating electrostatic field, a conductor, such as an exhausted tube for instance (or any resonant coil, waveguide, any conductor my addition), tends to take up most of the energy, whereas, in an electromagnetic alternating field the conductor tends to take up the least energy, the waves being reflected with but little loss. This is one reason why it is difficult to excite an exhausted tube, at a distance, by electromagnetic induction. I have wound coils of very large diameter and of many turns of wire, and connected a Geissler tube to the ends of the coil with the object of exciting the tube at a distance; but even with the powerful inductive effects producible by Leyden jar discharges, the tube could not be excited unless at a very small distance, although some judgment was used as to the dimensions of the coil. I have also found that even the most powerful Leyden jar discharges are capable of exciting only feeble luminous effects in a closed exhausted tube, and even these effects upon thorough examination I have been forced to consider of an electrostatic nature.  How, then, can we hope to produce the required effects at a distance by means of electromagnetic action, when even in the closest proximity to the source of disturbance, under the most advantageous conditions, we can excite but faint luminosity ? "
End of quote
Aloha,
This is a key Patent: TESLA PATENT 336,961 REGULATOR FOR DYNAMO-ELECTRIC MACHINES.
If, for instance, the commutator-space between the brushes a and c, when the latter is at the neutral point, is diminished, a current will flow from the point Y over the shunt C to the brush b, thus strengthening the current in the part M', and partly neutralizing the current in the part M; but if the space between the brushes a and c is increased, the current will flow over the auxiliary brush in an opposite direction, and the current in M will be strengthened, and in M' partly neutralized.
More than 100 Years old! dated March 2, 1886!
We already know this is specifically related to the Amplification of Current:
The Greatest man that ever lived, Nikola Tesla, the Mr Preva Experiment with Don's video, is undisputable.
Jagau posted this 01 December 2018
I confirm what Chris quotes above for experimentation.
In my last experience with two coils partnered Output coils (POC) and one input coil  that transmits at the resonant frequency
with only 0.300 millivolt p/p, I got 60 volts p/p. Make yours you will see, easy and cheap to make.
It's reality.
The model to use is very simple Aloha, everyone can do it.
Take a pot core with 3 cables twister set of gauge 24 or what you have on hand, 2 cables are in mode P.O.C. and the third in Rx
With a signal generator injects about 5 volts p / p in order to
find the frequency of resonance when you have found injected into your POC and look at the exit you will be surprised at the result.
Adjust the voltage of the S.G. up to 300 mv p / p and you will still have a lot of voltage present. It is a (C.E). cold electricity, .but with an avramenko plug I turn on up to 5 leds without extra consumption.
P.O.C. configuration is the name of the game it is a must
alohalaoha posted this 02 December 2018
Hey Jagau
What about current output? Have you did some meassurements ?
I need hundred of Amps at the output not some uA or mA. Also voltage must be in hundreds of volts not mV or V.
Need overunity heater to warm house and garage.
If you have concrete project let me know. Wish to bild one and improve if possible.
ps: I have not much possibilities to try thousands of experiments, simply because have no cash for all to realise. For all of this i need highly professonal and expensive lab and highend equipment and tools. This is only reason why do asking you and not only you but all the others for just one concrete working overunity device. Can make one but not thousands....
ps: my newest e-mail is sergvdrag@yandex.ru. Fell free to contact me if you have real ou device to share with me.
Thank you
Best regards to all - Aloha
Jagau posted this 02 December 2018
Hello Aloha
I am in this forum to learn, and with my latest research I share with you the little things that I find
because this is the purpose of this forum.
share what would be interesting
learn to share it
help those whom we can help.
No I have not found the rosetta pearl yet but I'm working on it.
I hope I did not disappoint you, but you bring me ideas that sometimes move me forward.
  • alohalaoha
  • glennmr2018
Thank for your support and many clever ideas Jagau.
You are a good american man, in same free energy problems like all honest people in america.
If you belive in my words, same situdation is at russia, and very probably 99,9999% in other parts of the world.
I know from my life way , only experiement is a supreme judge of all possible and impossible theories because he always present and show us a truth. This is the only reason why we need to listen him and analyse what he always tell us. No other way in total darkness of this parasitic world.
Best wishes
  • glennmr2018
hi aloha
I'm 100% agree with you, it's very good,
just do not let go we'll have it.
Just a clarification I am Canadian
  • alohalaoha
Chris posted this 02 December 2018
Hey Aloha,
Have you built the above layout I gave?
If so please post a picture.
Also, would you mind, please do not post material with my site addresses or my name that is not mine. What you posted above ( Now Removed ) is misleading for others. Its not my work, its yours. I hope you understand.
I would like to quote:
Useful energy occurs as the result of imbalances in the ambient background energy, which is a transient phenomena. In the electrical field, it is a closed system subject to heat death, which severely limits it's utility. The flip side of the electron, produces magnetic waves which are an open system, not subject to heat death. These waves, being unrestricted, are the universal source of energy when unlimited resonate duplicates from this one source are available. Therefore, the key to unlimited energy, is Magnetic Resonance. In order to understand this, requires putting a stake through the Heart of Antique Physics. Non-linear and Open Systems are universally available in Magnetic Resonance Systems, Explosions of any sort [including Atomic Explosions] and Combustibles of any type. Mechanical equivalents would be levers, pulleys and hydraulics. A highly obvious example is the Piano where the Key impacts the one note giving one sound level, which resonates with it's two side keys providing a much higher sound level. Magnetic Resonance Energy clearly amplifies itself, demonstrating more energy out, than in.
Ohmic resistance does not apply to Magnetic Resonance which travels unrestricted for great distances, therefore multitudes of electrons are disturbed, and their back-spin translates magnetic into usable electric energy. The right angle component which the magnetic flux provides, translates into useful electrical energy. Taken at right angles, the Magnetic Dipole provides an unlimited source of electrical energy.
Don Smith - Resonant Energy Systems
Don't forget what we learnt in The Mr Preva Experiment! Magnetic Resonance, we know what it is already and already achieved it! We must get the voltage up, and this is how you do it!
Monitor your Currents! Like I showed you in the thread: Some Coils Buck and some Coils Dont
The Frequency and Duty you need to find, I believe you will find, is a harmonic of the Partnered Output Coils natural Resonant Frequency - Now I have said to much!
Now the Numpty Club will beat us to the Gold Nugget. Comon people, we have to be first!
  • alohalaoha
  • mrblobby
Vidura posted this 02 December 2018
Chris, Check the schematic s you posted in the beginning of the thread. For opposed like magnetic poles the load should be connected to the center tap with CW/CW coils (eventually con diodes) and at the ends between two coils for CW/CCW coils. Regards Vidura
Yes, many output circuits can be arranged. Yes Diodes can be of benefit. Also other conduction circuitry.
The Circuits I posted are a guide and depends on the Partnered Output Coils and how they are arranged. I published this circuits some 4 odd years ago now. Without looking it up exactly.
Yes, the Center Tap can also be used.
Really, the point is, the Partnered Output Coils must Buck and also produce usable Electrical Energy.
  • Two Output Coils - Must.
  • Electrical Energy - Must
For example, a single output coil will never work.
How's progress Vidura?
alohalaoha posted this 03 December 2018
You Will need:
  1. One Input Coil
  2. Two Output Coils
  3. Patience
  4. Support
  • CW is Clockwise.
I prefer CW / CCW.
Hey Chris
If you think it's needed for all members here rearrange your picture according to Donald Smith reference. He had told - RIGHT WOUNDED SPIRAL (CW) MADE CURRENT or precise CHARGES MOVEMENT FROM + TO -, LEFT WOUNDED SPITAL (CCW) MADE VOLTAGE or precise CHARGES MOVEMENT FROM - TO +.
Lenght of CW wire bring us CURRENT RESONANCE, lenght of CCW bring us VOLTAGE RESONANCE.
What are in fact bucking coils or better formulation PARTENRED COILS ?
We simply obtain RESONANCE IN RESONANCE !!
However geometry of excitation coil is very important in respect to output partnered coils. Any advice here ?
Also type of excitation envelope, sinus, cosinus, triangle, square, nano-pulse, pulse trains or some mixed envelope ? Any advice here ?
Excitation on lambda resonance or lamba/4 resonance ? Or on free LC resonance, or on geometric mean of two LC resonances if we have full asymmetric configuration for example CW{C1=1nf}, CCW{C2=100nf}. Or maybe is best to tune free LC resonance to intersection point with Standing Wave Resonance ?
If somebody can explain, will be excellent reference for all people here.
ps: Chris i dont like this simple fact. From 163 members only members you can count on your fingers make posts and share experience and knowledge, other 153 simply STEAL HARD WORK OF those 10. I think it is very very bad !!!! That way went alsways to blind-alley. !!!!!!!!!!!!
Reg.
Chris posted this 03 December 2018
Hi Aloha,
I think, think Simple.
Follow the first post, don't change anything, make the goals and there will be no confusion.
Yes, we do have a small few here, waiting to thieve the good bits.
He shot out of here like a scolded cat when he saw the thread I left him!
Note: Some members here, English is not their first language, and they wish to stay quiet readers. They would never have trouble here! But I understand their position.
  • alohalaoha
Hey Chris it is Ok my friend.
I knew you have told all the truth about partnered coils. I knew man called himself on one russian free energy forum Tank who first said MR.Preva how to make current boost. Btw I don't know Mr.Preva personaly and its not important.
All my thoughts are about the role of electrostatic field here. As many time has went i am prety sure that partnered phenomenon has electrostatic nature, nor electric, nor magnetic, nor electromagnetic !! As great Tesla once said "Pulsation of charges".
Remember Donald's board, why he had used HF HV electrostatic field ?
ps: I should repair my two oscillographs C-112A and PM3208. Simple rule: There is no free (not lunch) but experiment !
Free lunch could be at many places, but free experiment nowhere !
Hey Aloha,
I have read many of Tanks posts.
Yes, one path forward, experiment, is knowledge gained for repeatability. Of course this is except for Brad, he can no longer make a machine work. Thus the reason he comes here.
@All - Keep in mind the very important concepts we have covered!
I have given a few hints on this thread!
There is no Wrong or Right, there are many ways this works!
  • alohalaoha
I kept the term "Magnetic Resonance" for many reasons. But most of all, Floyd Sweet used it, Don Smith used it. Others have used it.
Before to long Bradley will no doubt use it. He was last here, reading our pages yesterday.
I would recommend you adopt it also if you haven't already.
Now, a small tip, I mentioned the Partnered Output Coil time delay, or offset. Many ways to achieve it, but how did Don Smith do it? Three hints here on this Thread about it now!
Remember, Partnered Output Coils must Buck, Currents and Fields must oppose. Monitor your Current!
  • alohalaoha
Vidura posted this 03 December 2018
Yesterday I have lost a detailed post, so i have to edit in another program and paste.Maybe i should have formulated my last post as a question, i am aware that you have tested this for many years. So yesterday i had made some experiments using your guidelines , where i tried different configurations, like in the posted schematics and reversed with and without airgap, diodes and so on. I found it actually easier to get a significant output connecting the way like in the schematic, but using the right hand rule the fields are not opposed like poles. Neither they are in the Mr Preva experiment, in this cases the fields are allowed to align as unlike poles, and they are forcing the current to flow from the lower to the higher potential side. In my test setup i got this way a exponential current curve, not a sawtooth. With a airgap the interaction least much longer. Also the diode helps in this case, without it the pulses become very short and sharp, and the input power increases.
Anyway i think the diode is not strictly necessary when the coils are tuned correctly in resonance. When connected the other way , so that fields are forced for opposing like poles there is a very notable reduced impedance as expected, but i still could not get out a significant power level on the output. The spikes are very sharp and short and don't make lit a bulb. This could be due the small nr of turns of the coils, so i rewound one with more turns-more inductance, which i still have not tested. Regarding your question: thanks for asking, sincerely i have not much progress lately. Maybe due to problems in daily live I hardly can concentrate well in the investigations. Such is life sometimes , then it will change for better again certainly.
Vidura.
Hey Vidura
On which frequency you have pulsed your partnere coils ? Free LC resonance or something different ?
Reg.
In this setup i sweeped frequency from 180hz to 700hz. 1 —2% duty without capacitor attached.at lower frequency ther was better output power.
  • alohalaoha
Setup was like Chris have done or you have changed something ?
How many windings you have wound for CW/CCW coils?
Sorry about the loss of your post. The session of your login timed out. There is an App Pool issue I am still trying to resolve.
My life is full at the moment also, problems unexpected. You're right, better it can only get.
Yes, Yes, the exponential curve is right, that's good!
Voltage will be the Sawtooth wave, it is a linear reduction, fall to zero, due to the opposing Currents.
Diode is good, it creates a delay, ever so small, some are in the nanoseconds, but it can be enough in some situations.
You could always load each coil separately?
The same result will occur.
Also, sometimes, stay safe doing so, but increase input voltage just a little.
Excellent Vidura! You're on the right track! Like the Mr Preva Experiment, there is no difference except we are using a low impedance Coil to drive this arrangement to increase Voltage, to test the result, hook the Coils in Series and see if the Current has doubled? If not, the Currents are not Bucking.
This was the device that I shared with everyone here: Bucking Experiment Way back on April 16, 2014
It was the next step, driving with a separate Coil. Sorry for the mess in the video. It was a very busy day.
Remember where Floyd Sweet started:
The BIG sponge trying to damp vibrations!
Remember, we must have Bucking. At the right power level, with cores, you should hear or feel a definite vibration!
Zanzal posted this 03 December 2018
Hey Chris, I wish I understood what you meant by this, but I am finding it elusive. From your scope shot, you use a single current pulse to trigger a double current pulse. The single DC pulse, results in a non-sinusoidal wave that is effectively two current pulses travelling against each other but the second one is staggered (out of phase).
By magnetic resonance, you just mean that the two pulses do not occur simultaneously, that the reverse pulse is delayed or do you mean something else?
The term "magnetic resonance" in this context just means "staggered so that you get two distinct pulses instead of one?" So its as if you made a transformer that receives a single phase and produces two equal phases of output, but only when it is 1) driven at the correct frequency (as determined by ???) and 2) that the second coil is loosely coupled so as to not to load the primary.
If I am understanding for this to work each pulse must carry the same energy as the total input pulse or somewhat less with losses, but the second pulse as your additional energy. Honestly I am surprised this system doesn't generate reducing oscillations, the system looks from the scope shot to be self-damped... Sorry in advance if none of these questions are coherent, I'm trying to establish a theory of operation which unfortunately, may only make sense to me...
Hey Zanzal,
Apologies, I wish to be direct, not rude.
Magnetic Resonance:
Magnetic Resonance is where the Currents in both Partnered Output Coils are 180 degrees out of phase. Equal in magnitude and opposite.
We learnt this in The Mr Preva Experiment.
The Coils must Buck each other. There is no complication to the operation, but is some fiddling to the optimum output.
We have thieves that visit us, we must be careful to avoid putting to much information out. If people have read what I have laid out on my pages, done the experiments as I have laid out, there is zero complication to this.
We have had Above Unity Machines for a long time, I am not the first person. But I am the first person ever, to show you, how to do it.
I have laid out, very carefully, a path of discovery.
It only need be followed.
  • alohalaoha
Listen carefully, what do you hear?
Jagau posted this 04 December 2018
Yes we hear a strong vibration
Chris posted this 04 December 2018
@All,
Start small FIRST! Learn the workings First! As Vidura has.
Remember, the Core material can hold only so much flux.
Increasing the Core Size, the Cross Sectional Area, CSA, increases the Flux carrying capabilities.
You need to lower, to decrease, the turns as you go up in Core CSA. Of course, thicker wire may be required also.
Please be careful, this is very dangerous as you move up in size.
Atti posted this 04 December 2018
"Remember, the Core material can hold only so much flux.
Increasing the Core Size, the Cross Sectional Area, CSA, increases the Flux carrying capabilities"
Chris,  With the above statements I completely agree, but! This is true. I have tried some layouts already. But the question is still open:
-what is the input power requirement?
-what is the output power requirement?
In some variations I tried and measured the Mr Preva layout.
Has anyone weighed curiosity?  Not the amper but the power. (P = UxIxcos fí )  output power/input power.
Hey Atti,
Sorry, all I wish to say on measurements is Output > Input with some work.
The Mr Preva Experiment as it stands, is Input > Output. It must be changed accordingly.
I would say, it is entirely up to the experimenter as to weather they post Measurements.
To  prevent the circling of vultures, I recommend keeping some information quiet. we do not want people here that are not genuine, here to thieve our hard work.
For, all humanity can not benefit, if the top 1% have everything!
 "Do some information remain silent? "
let it be ...............................
Hi Atti,
The choice is yours. You can post if you want to.
Posting negative material toward others will not help. We are learning. Dont make judgment.
  • Atti
Atti posted this 05 December 2018
Do not misunderstand Chris !! I do not want to deny her work! It has invested immense energy in these experiments, which I fully reaffirm. As can be seen in shared videos.
But energy balance is a bit different. Yes, obviously it is not a good idea for others to share information with fars because they are misleading.
So I do not judge just sharing my helpful opinion. Please understand that.
Chris posted this 05 December 2018
Hi Atti,
Understand, and thank you.
Energy balance comes with a set of circumstances, extra effects will be seen, but only at a specific point in the interactions of the two Partnered Output Coils.
Magnetic Field magnitude plays a role. Frequency and Duty Cycle play a role. Timing plays a role.
There must be a specific point where input is off, and Partnered Output Coils have a Magnetic Resonance occurring.
This Magnetic Resonance is where extra Energy comes from. Bucking Magnetic Fields.
When Current in one Partnered Output Coil has reached a point where it is at its maximum, the second Partnered Output Coil must then Conduct, this creates the opposing Magnetic Field, the Current doubles as a response of the Bucking, the same as we saw in The Mr Preva Experiment. Currents equal and Opposite, 180 degrees out of phase.
Remember what Floyd Sweet said:
I ask, we are learning, so please, let us not make judgement on others work! We must nurture and guide the progress, of those that are working hard to learn. Lets respect each other as we would expect for ourselves. I am generalising, for all here.
Chris posted this 07 December 2018
When you get the Required Bucking of the Partnered Output Coils, an effect like is shown in the following video:
You will see, once the point is reached, a greater Bucking, louder noise, is reached. At this point you have maximum output. This action is entirely an Interaction between the Partnered Output Coils.
I showed this here:
The Input is reduced, because we have an additive Magnetic Field.
  • alohalaoha
alohalaoha posted this 07 December 2018
Self Resonance in Coils
Aloha is exactly right! Often an Earth Ground may be needed.
  • alohalaoha
Quadrature Bucking Coils  = Self Running Motor - based on Tesla patent 511916 titled as Electric Generator by Tesla
Aloha is correct, however the Four Coil Structure is not necessary. The same effect is present.
I would ask, keep it simple, low frequency, a small pulse can give a large result.
  • AETHERIC_MIND
Chris posted this 08 December 2018
A long time ago, I shared a bit of work, it holds relevance today: What's it going to take to Get OU?  ( Date Created: 10/01/2014 1:10:58 PM )
It is true, what I started working on then, although not worded perfectly, it does outline the basics. It turned out, the reference to introducing an Iron Core, is simply Bucking Coils at the right time! I also shared that in my initial release of Partnered Output Coils.
This is simply the: Reduced Impedance Effect.
We have all the answers! Its just a case of getting the right order of the answers in our heads.
  • alohalaoha
Jagau posted this 09 December 2018
You're full of resource Chris
I reread your article, very explicit that all should read, excellent.
Chris posted this 09 December 2018
Thanks Jagau!
Those that read these pages will notice some similarity in the ideas presented. There is some base level items presented in the 'What's it going to take to get OU' that we have seen in other devices.
Graham Gunderson used Permanent Magnets to try to Bias the Core of his MIT to get up to close to the Knee of the BH Curve, Ironically, I used this requirement in my document. Ironically, Bucking Coils I have been presenting for many years, since 2011, Graham Gunderson used Bucking Coils.
Thanks to Reiyuki
Graham deserves full credit, he did an awesome job, and an awesome demonstration! I could not have ever done such a professional demonstration. Even though he did use all my work. Only a few years earlier, stating he did not look into interactions of Coils and had only investigated Floyd Sweets Permanent Magnet Conditioning, which was a Hoax and a Lie.
Yes I have had some communications with Graham and his team members over the years. I did share Floyd Sweets Transcribed Lab Notes with the Aseop Institute and we had some communications as a result. All readers should research this story.
Mark Goldes never released any documentation on Floyd Sweet. I asked a few times, he told me he had none.
Graham Gunderson worked for Mark Goldes for many years.
Mark Goldes had on the order of 50 companies, all going either bankrupt or closing. Companies including: ASEOP, MPI, Chava… and others. Mark Goldes, then ASEOP Institute, funded Floyd Sweet, some of the equipment in images of Floyd Sweets demonstrations was funded by Mark Goldes, but not all:
Mark Goldes, Co-founder of Chava Energy and Chairman of Magnetic Power Inc. and its synergistic subsidiary company, Room Temperature Superconductors Inc. Chava is acquiring assets of both the earlier firms.
Magnetic Power Inc. Company assets are being acquired by Chava Energy. The new website is http://www.chavaenergy.com/ Devices formerly called Magnetic Power Modules(tm)are now called MagGen(tm).
Chava is developing these modules as well as other breakthrough technologies.
As of the Summer of 2009, Mark Goldes claims to have achieved several over-unity protypes, and hopes to have commercial 1 kW units ready next year. The company claims that those with an EE background and with an open mind will agree that the concept (disclosed under NDA) is workable.
For those who do not have access to proprietary photos, videos, and other evidence due to the proprietary nature of this technology, confidence is borrowed from CEO, Mark Goldes' reputation with Ultraconductors, a known and proven technology.
Some well known names worked for Mark Goldes:
  • Cyril Smith ( Smudge )
  • Partzman
  • Graham Gunderson
  • Others I cant think of at the moment.
If my research is correct, Mark Goldes never once produced any Product, no Product ever went to market.
Suppression comes in many forms, sometimes suppression of technologies, appears in the form of business Failures. Those working for the System, not realising they are part of the problem.
Note: Almost every page out on the Internet, when Searching Mark Goldes, contains the word: "Swindle". Mark Goldes has earned a somewhat dubious reputation.
Thank Chris for sharing those information
We understand better now.
cheors posted this 09 December 2018
Chris,
I am new here and english is not my native language.
Could explain (once more probably) what "buck" means when you say "coils must buck, a bucking oscillator" ?
Hi Cheors,
Welcome!
Buck means to Oppose Magnetically, and as a result, the Current from one Coil to the next must also Oppose, or run in the other direction.
The following experiment shows the meaning:
OK thanks, i understand.
In that video, the 12V source is not disconnected, so we don't see the self sustain aspect.
But we get 5.2 A output and 2.8 A input : not so bad !!!
When i have time i will try something like that.
Hi Cheors,
The Mr Preva Experiment is a learning tool. It is not a self running Energy machine. It is very valuable experiment to replicate.
To Double Voltage from V to 2 V, and also double Current from I to 2 I means a total Power increase of 2 P from P.
We know how to achieve both methods.
Atti posted this 10 December 2018
Hello everyone.
cheors. It's best to study your own small experiments. Just as Chris suggested it. Look at the work of others, then compare it with yours. Finally, withdraw your own conclusions from it. You can learn from everything, even from a bad experiment. It's really good if you can look at other work but do not replace yours. Mr Preva's experiment is very useful, but not mixed with your partner's output coils.
Observe winding directions. Now let's look at a magnetic test.
I've already done some research on this topic.
It can be seen that induction is induced by higher inductance. Do not expect a miracle from him, but keep in mind! This is a good game, I recommend it to you as well. If you like to share the results with us.
Chris posted this 10 December 2018
Atti is right!
There is only one path forward! You must:
  • Set your Goal, know your objective.
  • Learn the base requirements.
  • Experiment and observe, ensuring your experiments are progressing toward your Goal.
Using the basic procedure above, in the first post, you will succeed. It does take some fiddling.
alohalaoha posted this 11 December 2018
Hey Atti
Take one toroidal core for example from old pc power supply, which was used there as output choke. It is a big yellow ferrite.
Than make full bucking configuration like Mr.Preva did. Look from the aspect of cross-section of toroid. Wind two windings in opposite directions. It means one going from outer circumference of toroid through the toroid hole, while other going first from hole and end up on outer circumference.
Make it fully symmetrical with same number of both coil windings or if you like make asymmetrical. Then short both coils, add parallel resonant capacitor, two current sense resistors 1ohm or 0,1ohm (non inductive) and excite it with signal generator to catch parallel resonance. When you hit it, meassure RMS currents and voltages across both resistors. You will get the same like Mr.Preva have.
I can advice you to use litz wire for both windings. You should distinguish between 3 modes you could get.
1st. Partnered bucking effect.
2. Parametric resonance effect and
3. Acoustic resonance effect.
Our goal is to examine experimental conditions for obtaining 1st effect. According to experiments there is C.O.P = 37 or 3700% amplification of voltage and current. Both depend of lenght of coils or precisely lenght of wire wounded coils. Also if you use HF you need ferrite with low magnetic permeability, if low freq with high magnetic permeability. You can eaither pump the coils with the spark from your power supply or with mosfet or bipolar transistor. Anomaly bucking effect exist 100500%, only you need to catch it up. Also you may try with two air gaps in toroid to avoid satuaration of the core.
Best regards
Chris posted this 11 December 2018
Hey Aloha,
From what I can see, you have it right. Have you built a working Machine?
alohalaoha posted this 12 December 2018
Hey Chris
Still not yet. Squeezed like a wedge into wood with global sync of HV.
For you information we need 4 things.
1. HV (range betwen 3,5-7KV)
2. Partnered resonator
3. Multiplexed Partnered Output
and the most important
4. Sinchronization or timing. Lot of variables , hard to tune. This is the hardest part and mandatory.
Reg.
Chris posted this 12 December 2018
Hey Aloha,
No, no, no, no, High Voltage ( HV ) is not a requirement!
In some machines, as little as 3 volts is all that's required!
The rest you have mostly right. Timing, we must have the Partnered Output Coils interact at the right Time. Remembering, we have the already known Magnetic Isolation at this time in the Cycle:
The Primary Coil see's no Negative effects from Lenz's Law, but only at the right time. Of course each Partnered Output Coil is its own Battery, Voltage is produced by the Input Coils Pulse, but Current is a function of Loading the Coils at the right time, the Opposition of Magnetic Fields increases the rate at which Current can flow to the load.
The following video shows some techniques for the timing:
Those that have been reading and following would already know all this.
I see, we are in for a work load of avoiding Confusion. We must, absolutely eliminate these statements that introduce elements of confusion for readers.
Aloha and others reading, I want to make a point of saying; Please do not make statements unless you are sure of the correctness of the statements!
Thank You,
Atti posted this 12 December 2018
Hey Aloa, a schematic drawing would be good for avoiding misunderstandings. With my time, I'll do the experiment. Just for clarification.
What circuit should the COP 37 say? Can this video be seen from this measurement? Thanks.
On January 23, 2015, I gave an encounter with a Vacuum Cleaner:
About three years ago I got the Vacuum Cleaner out to do some Vacuuming around the house. (Yes I do it regularly )
I plugged it in, went to turn it on, and POP! I thought this was very strange!
Pulled the Cleaner down and tried to find what was going on. I found that one of the Field Coils had blown itself to bits, approximately 1 cm of wire gone. Minimal Burn Marks!
The Rotor was stuck in one position, it could move but not freely like normal!
With my work I was doing (Related topic) I could only come to one conclusion why this happened.
I believe that the same situation as we are looking at right now had presented itself in the Motor! Magnetic Field's Build, some in opposition, and because the Rotor was stuck, we got Max Fields!
On collapsing with the sine of the mains I believe this Magnetic field went to Max Current and as a result the wire could not handle this huge current and it blew to bits.
I have of course assumed that this was the situation! I have no proof that this is what happened.
So, the point of me posting this, is that we need to Maximise the Magnetic Field Interactions! Get the highest Magnetic Fields in the device that are possible.
Ref: Partnered Output Coils - Free Energy
June 19, 2015 Bradley Richard Atherton demonstrated exactly this, a Vacuum Cleaner motor using Partnered Output Coils producing excess energy.
Study closely the Coil Interactions, there in lays the secret.
  • Atti
Hi. Some things have already been said here, like Mr Preva's experiment. Or the associated output coils. How are the currents there? Power and voltage products? Another additive to the flow of currents.
It can be seen that the current of the freewheeling diode of a D.C motor driven by PWM is possibly higher than the input current. Is this now extra energy? No! This is Mr Preva's circuit. But note it.
Vidura posted this 12 December 2018
Hi Atti, This is of course a normal behaviour for any Buckconverter, the currents on the freewheeling diode can exeed the input current by a mayor factor when the duty cycle is low, but also the voltage on the load dropping proportional, so there is no energy gains in this. But if we can use the increased current on this branch of the circuit to induce a MMF, by means of a feedback loop there could likely be a energy gain. Regards Vidura.
Hey Aloha,
Thank You,
Hey Chris
In my setup HV is one of main requirements, because i dont use mag.flux.routing technique to extract free energy from the ferrite.
You know Tesla's used HV, Don Smith, Edwin Gray, Stenly Mayer, Kapanadze, Akula, Roman Karnouhov, Nnail, Tiger2007, Lithuania 1KWt generator, Fabrice Andre, Joseph Newman etc etc.
On the other hand other devices based on ferrites or soft iron no need for HV. VTA Floyd Sweet, Markov transformer, Vladimir Pantuhov ferrite reactor, also Akula in his ferrite devices.
We must distinguish between these two classes FE devices, because they are using different principles, but in many cases there exist many interconnection points between. One is mandatory for both and that one is synchronisation of timings. This is kind of different processes "Glue".
If all is so simple how that nobody have (or have had) working free energy generator. I think everything is much complex as we have thought, on the first glance.
Hey Atii
I have already posted here:
http://www.aboveunity.com/thread/let-s-sparking/
ps: Excitation could be with low or high voltages. Anomaly effect exist in both cases. You have all you need in the schematic.
Best regards
Apologies Aloha,
I miss read.
  • alohalaoha
Chris ,
you mentioned in this post the importance of getting the strongest possible magnetic field in our devices, I completely agree with that and want to remark the importance of the coils design for this purpose. Sometimes we want to make it easy , use small nr of turns for our coils, which sometimes might be correct, specially for HF applications, But regarding the Ampere turns and field strength it is good to keep in mind the following investigation results from Joseph Newman:
Quote from Patrik Kellys book:
Consider an air-cored coil with an interior diameter of 10 feet, a height of 8.32 feet and would with 1,000 feet
of 40-gauge copper wire. That length of wire has a resistance of 1,049 ohms and weighs 0.02993 pounds.
If 100 volts DC is connected across it, then a current of about 95 milliamps will flow, which is a power input of
9.5 watts. With just 31.8 turns, it will produce a weak magnetic field of 0,012 Gauss, with a mere 0.000014
Joules of energy stored in it. With a tiny inductance of just 0.003 Henries, if the current is stopped and the
ends of the coil shorted together, only an insignificant current would flow.
Now, repeat the experiment, but this time, use 5-gauge copper wire. As it has a resistance of 0.3133 ohms
per 1,000 foot length. To equal the same resistance and match the previous current flow, a massive length
of 3,348,000 feet needs to be used. This length of wire will weigh 335,469.6 pounds which is 16.77 tons.
The 10-foot interior diameter coil, 8.32 feet tall, wound with this wire will have about 90,000 turns. If 100
volts DC is now connected across the coil, the same 95 milliamp current will flow with an input power of 9.5
watts, the same as before. But due to the massively larger coil, it has a magnetic field of 23.7 Gauss, which
is 1,905 times larger than the previous coil, and with 116 Joules of energy stored in the magnetic field. This
is a phenomenal 8,000,000 times more energy than in the 40-gauge coil of the previous example. A
phenomenally larger current flow would now occur if the current input was stopped and the coil shorted out,
as that would generate an inductance of 25,700 Henries which is more than eight million times the
inductance of the previous coil.
The values in this comparison are extreme, but Joseph built then a prototype motor with "only about 2 tons " of copper and run a 600 pound PM rotor with 1.5 W of power consumption and a huge excess energy and strongest BEMF spikes.
The point I want to remark: we certainly will not be able to spend money in this amount of copper, but increasing the wiregauge and nr. of turns by a reasonable factor might increment the performance of our devices very notably.
Regards VIDURA.
Chris posted this 13 December 2018
Yes, keep your machine small, easy to work with, keep the costs down while learning.
There is no need for huge field strengths like that, anywhere from 1 gauss to 1000 gauss should be more than enough. That is a very good example of how one can increase the Field, the Inductance.
  • alohalaoha
Atti posted this 13 December 2018
Aloha,if you say so, of course. But millions of times it is easier to say something or like to push than to show it. There is a difference between the two.
alohalaoha posted this 13 December 2018
Atti there are many methods to excite the Ether. But he always respond on our excitations at his own way.
As much as i examine Ether, i start to think about him, like some kind of living essence.
Absurd is in that, we are living in the infinite ocean of energy, while in same time we don't know nothing about. As a result we are stll warming our houses with wood, gas, oil, drivng our cars on petrol and spining around ourselves, like a dog trying to catch his own tail.
Stick to the outline I laid out in the first post!
Don't let complication creep in! Simplicity:
Pay special attention to the Terminals of the Coil, Pay special attention to the Terminals of the Coil, Pay special attention to the Terminals of the Coil, this is where you learn.
Introduce one Coil at a time.
Focus on the Voltage and also the Current! Learn how Interactions between the Coils can increase quantity's, eg The Mr Preva Experiment.
In-front of you is your goal should you choose to learn and take on this task. Ignore all outside distractions, focus on the task at hand.
For you, another replication, back in 2011: Sergey Dobrozhansky
  • alohalaoha
Thanks Chris for pointing us on this great experiment by Sergey Dobrozhansky.
https://sites.google.com/site/dobrojanskij/soobseniebezzagolovka-2
Chris this is amazing. He take out 840W (1200V, 07A) at output coil loalded with 30K 2Wt resistance, while his input have had only 20Wt. It is C.O.P = 42. And all of this with small toroidal ferrite.
He has wwo pairs of bucking partnered coils on a torodial core with magnetic permeablity 6000.
Low voltage direct current to alternating current with further high direct current output. All of this with small battery. This is how he has called his setup.
Two primary coils from 15-30 windings - optimal number of turns 16-20.
Two secondary coils each 10m long. Maximal lengh depend only of toroidal core size.
He also sais that his primary coils were in bucking configuration Picture had not drawn correctly. One primary should be CCW (from core's hole to outer circumference and other vice versa CW.
So he had 2 pairs of bucking coils in his HV generator. Output of two partnered secondary is very high 1200V, 700mA, with only 10m of wire each. This is extremely dangerous voltage and could rise in several KV if you plan to use higher magnetic permeability core. For example some with 100 000 permeability
Reg.
Hey Aloha, I ask again. You made a statement on COP 37. Where do you see this measurement? Where is it proven?
Zanzal posted this 13 December 2018
Thank you for translating the important details Aloha, it looks too simple to be true, just the kind of thing I like investigating.
alohalaoha posted this 14 December 2018
HET ATTI.
HAVE BEEN PROVEN IN EXPERIMENT SEVERAL YEARS AGO.
Excitation pulse was 3KV in amplitude, pulse envelope monopolar, or gausian HV pulse, or sinx/x pulse. Output pulse was more 110KV , very near 111KV. I am talking about effective value of pulse amplitude not peak value. This worth only for one pulse comparison. Goal was to examine - does effect exist with HV pulsing. Our friend Chris was right. Experiments with partnered bucking coils are dangerous due to very high voltage generated in circuit. If you want to try just make a setup like i was drawing. Excitation 12V or 24V depend what you have in your lab. By the way effect exist also without ferrite core but output amplitude is much smaller with low voltage excitation
You can give a try or not. Everything is about your will.
Chris posted this 14 December 2018
I would remind you, all the information you need is in the first post.
Following the instructions, with a little persistence, you will learn amazing things.
Chris posted this 16 December 2018
In the thread: Energy Machine Operation I made a comparison to the human heart, the Energy Machine is a Pump. It is a Mechanical Pump and has similarity's to other mechanical pumps. The Hydraulic Ram Pump is one example.
The Magnetic Field is our Force Field, our Conductors, the Insulated Copper Wire, Artery's or Water Pipes.
We must think, as we saw in The Mr Preva Experiment, about the interactions between our Conductors, we must think about the pumping of Current.
You truly have the knowledge, you truly do! We have covered all here in our pages, everything is there. All that needs be done is applying this knowledge! In the first post of this thread, all the instructions are given.
I want to give you an example, but I don't want to confuse you, so please, use this information sparingly. Akula worked on several machines, in his schematic, the 30 Watt Lantern, he shows 15 Turns on the input Coil, 45 Turns on the Secondary Coil:
Akula in his 60 Watt Lantern shows, 12 Turns on the Input Coil, and 60 Turns on his Secondary Coil:
  • I1 = 15
  • S1 = 45
  • R1 = 1 : 3
  • I2 = 12
  • S2 = 60
  • R2 = 1 : 5
Akula's step up turns ratio, from the 30 watt lantern to the 60 watt lantern, was increased by a factor of two.
So, Akula was stepping up the Turns, in turn stepping up the Voltage! As a result, the Current also increasing as Ohms Law states: I = V / R, summing with the Voltage, remember Ohms Law: P = V x I
Because we have a PUMP, we have more instantaneous Power! We must have Magnetic Resonance, we are best to use a harmonic to excite this arrangement, 8% duty Cycle low frequency, approximately. Tune for the best result. Magnetic Resonance:
Kapanadze uses the exact same technique:
The answers you already have, focus on the Coils, the interactions, the Magnetic Resonance, the Voltage. Remember, a Pump!
Vidura posted this 17 December 2018
Chris, the shape of the wire terminals should be important for the reflection of a longitudinal wave, a flat surface at 90° should give a strong reflection on the coil ends and produce a kind of Laser effect releasing more charge carriers in each reflection, if I am wrong please correct me. When I was working with teslacoils I could see the effects of different shapes of objects attached to the coil ends, and that longitudinal waves have a different behavor in propagation.
Chris posted this 20 December 2018
Like anything, experiment proves points. The shape, the geometry, yeah a role is played, but the shape of the Copper Conductor, as long as it is coiled, a helix, then the shape is not all that important.
History proves standard coils with standard Copper conducting wire is all that's needed.
Atti posted this 21 December 2018
Hi.
Árpád Bóday's device has given more energy when I loaded it in its own arrangement. This resulted in asymmetry within the transformer. Only then did the permanent magnet refuse to operate. But within the transformer columns, not only your partner output coil is located, but the Mr Preva layout too. (for easier understanding) Due to the two transformers, parametric excitation can be imagined.
So you can see that others have used these effects.
Even if they did not deliberately make it so. But that's just my speculation. One picture about it.
Partner output coil operation in this old device also justifies Cris's explanations. Just think about it:
-asimmetric operation
- voltage excitation without any effect
This coil detects the magnetic field generated by the telephone student. It's so weird
monk, I mean there are two coils (bottom and top) because they are knock-offs.
If it were just a coil, it would not only take the student's changing magnetic field,
but would be collected from the environment by all other electrical equipment
also a disturbance, which is mostly a knock.
  To eliminate the knock, two coils were queued
bound but contradictory beginning - ending.
With this solution, the remote network
the whirlwind is extinguished. Conversely, the "top coil is closer to the student of the phone"
so his sign is not extinguished by the reverse coil. Very neat!
http://oldradio.tesla.hu/szetszedtem/433kihangosito/cb55hoz.htm
Chris posted this 21 December 2018
Hey Atti,
This is a great example of what we are trying to present! It follows all the same basic outlines as you have pointed out!
Thanks for sharing!
Chris posted this 27 December 2018
For those that don't already know this, another way of thinking about the Partnered Output Coils, how they work and interact together, is:
You can see, L1, your Input Coil is pulsed at Frequency and Duty Cycle X, which is a sub harmonic of the actual Magnetic Resonance, It has coupling to L2, but not L3. L1 is switched off. The Magnetic Field created now moves from X to zero. At the point of induced voltage of about 0.5 volts, the diode: D1 will conduct and the bulb BL 1 will light.
Now, importantly, the close proximity of L3 to L2 means the two coils will interact together. The two Coils buck, simply because their reactions together invoke Faraday's Law of Electromagnetic Induction. This geometry will add, the Current as we have already learned in The Mr Preva Experiment, will double the Current in L2, and gives us L2 + L3 Current in total, remember, Floyd Sweet told us the same thing:
These interactions on the Input cost us very little. A short sharp pulse brings up the Potential on L2. That's all that's needed, the potential to be bought up! Nothing else.
Then, the pumping action, the pressure, forces the Charged Particles as current down the Insulated Copper Conductor and out to the load.
Its not all that complicated, but a definite way of thinking is required! A clear mind is required.
Some things should be burnt in, these words are the most important:
Don Smith 2006 Tesla Tech (17:42)
Ok this is, something which I have a patent on, it relates to getting a huge amount of energy out when you put a few milliamps of energy in, you end up with like a hundred kilowatts of Energy out.
That won’t make sense for someone who thinks of an electrical system, you have to think in terms of Magnetic Flux, because, if you’re using electrical flux, everything is dying a heat death and you lose the energy almost immediately, in electrical flux, but in magnetic Flux you can make as many copies of the original as you want, without depleting the original at all, so if you’re chasing electrical flux, you’re chasing the wrong rabbit, you need to be chasing magnetic flux.
You need to build it, make your path straight, if you want it!
Chris posted this 28 December 2018
Something to keep in mind, Input power can be wasted and is often wasted, because the machine control is not quite as ideal as we may like.
The best example is in Brads Rotary Transformer. Remember, you need to catch the wave, Frequency and Duty Cycle is required to get the correct Subharmonic:
You can see, all the spikes in there, the spikes after the first peak at the top of the Sawtooth Waveform, all the spikes are wasted energy after the wave for has been caught. On the other side of the diode:
We see, the Sawtooth Waveform is not clean, its all over the place. We really need to aim for a clean evenly distributed Sawtooth Waveform. Graham Gunderson was one of the best I have seen:
Seen in red, the Sawtooth waveform is the Asymmetrical Regauging. We have covered this in some detail in my thread: Asymmetrical Regauging
This is Electrical Energy "Generation" at ZERO COST to your Input. It is entirely between the two output, the Partnered Output Coils.
Atti posted this 28 December 2018
Chris and everyone else.
   (  Fix me if I'm wrong , criticism is not a problem
Everyone has seen this arrangement many times. Still, it doesn't matter how we do it.
A drawing helps a lot in understanding the theory.But we confess.
In practice, however, we can learn more than producing only theories.
Many years ago I did a similar experiment that Chris presented to us. The essence of this is that all four columns of the transformer had the same basic circuit diagram. The effect is very interesting.Just a detail of the wiring diagram.
I have implemented many other similar schematic diagrams.
All in all here.
http://www.vems.hu/freeenergy/pajert/index.htm?FoAblak=../pajert64/MEGKiserl_Attila.html
But what's the point!
The following video shows the following.
Practical implementation doesn't matter at all !!! It can be seen that at tight coupling, the increase in voltage or the decrease in current gives a different value than in the case of loose coupling. The value is completely different if it is controlled by H bridge. There is no significant drop in power there. The value is completely different if the added voltage or associated output coil is diode.
Has anyone else done similar measurements?
Hey Atti,
If I may suggest, go back and do The Mr Preva Experiment again.
I see you were using 50% Duty Cycle in your diagrams. You need to go back and follow the instructions. The Timing cycles are important and need to be followed! The description of how the Coils are excited - It is important to be followed!
Our Input is NOT the Source of our Output! Our Output is a "Generation", an Induction event! Not related to out Input. This was shown in The Mr Preva Experiment. Like I have said, our Input is for Potential Only.
A Transformer is very well engineered piece of electrical apparatus. We are not building a Transformer!
I apologize, my efforts to share, my efforts are great, but I grow wary.
Hey Chris
I'll read it all right.
Please ask again. Has anyone already dealt with the layout? Could you share your experience?
Thanks.
Hi Atti, @All,
Yes, when people follow exactly, what I have laid out, the same exact instructions with "no improvements" from those that are not in the know, you will have an Above Unity Machine!
Some have had successes of varying different degrees.
cd_sharp posted this 28 December 2018
Hey, friend,
Not exactly, but if L3 would be reversed it would become very interesting. I add it to my todo list.
Zanzal posted this 28 December 2018
I've already built my transformer according to Chris' specification, 20awg, 2x12 turn primaries (2 just in case I need to swap polarity), 2x36 turn secondaries. Armed with additional knowledge from my simulations I have on hand a slew of diodes I can switch between. In early testing with a Joule Thief configuration, I was able to elicit what I believe was a ferromagnetic resonance reaction my core. That's a good sign, but I know most ferromagnetic resonance reactions do not cause OU, but simply waste power while causing massive over voltages. Finding the island of stability can be challenging. I'll share what I find.
Jagau posted this 28 December 2018
I have no doubt in my mind that what Chris teaches is exactly what we have to do. It is up to us to develop from this concept.
You must not wait to have everything cooked in your mouth and simply copy the result.
I am a little surprised by your reactions, lets go at work. Magnetic resonance is what we have to work on, let the electric resonance drop.
I am making a very explicit video to prove what Chris taught me to do.
You will understand then that he was right.
Chris posted this 29 December 2018
Jagau posted this 29 December 2018
Me too i have a lot of fun with logic
Atti posted this 29 December 2018
Thank you for your comment.
Wistiti posted this 29 December 2018
Excellent !!😁
fer123 posted this 08 January 2019
Hello to all I found this video Chris if is not appropriate remove please, I think It can help. Thanks.
Chris posted this 08 January 2019
Hi Fer123,
Excellent example! Yes, there is a component here that is the same! Andrey Melnichenko is one of my hero's! Remember what he went onto:
The last video is with Arthur Trankle from now Steho Energy showing the works of Andrey. Pin 5 on the 34063 IC is of very short Duty Cycle but many of them. this is in attempt to catch the wave.
When building your Machines, remember you must account for a Inductive, Inductive Time Constant.
The Time it takes for the Bucking Fields to move from maximum value to zero is accounted for, the same as the Time it takes for the Magnet to fall through the Copper Tube:
Remember, what we are aiming for is exactly the same effect! Asymmetrical Regauging:
If you do not leave enough Time, after your Input Pulse, your Output Pulse will be insignificant, Asymmetrical Regauging, shown above requires a short On Time and a Long Off Time. You also must get your Timing correct so as to Catch the Wave down to Equilibrium or Zero. A Sawtooth Wave Form. Floyd Sweet showed a Sine Wave, but look how straight is sine edges were:
Ref: 25 : 51 - Floyd Sweet Secrets - Remastered - 13-06-2006 - 6.05 AM
Compared to a standard Sine Wave:
A visible round edge difference seen. The Straight edge shown in Floyd Sweets Scope Shot is the Asymmetrical Regauging. A DC Cycle each Half AC Sine Cycle.
Vidura posted this 08 January 2019
A good point Chris, I have observed this waveform in some transformer tests, sometimes almost a triangular shape.
Jagau posted this 09 January 2019
Yes a very good point
Don Smith suggested this fact in one of his lectures in 1994,
we must have this kind of waveform
alohalaoha posted this 09 January 2019
Hey Chris - check these new topics from Vyacheslav Gorchilin site
Slow drift magnetic waves in Partnered Coils Configuration
http://gorchilin.com/articles/coil/magnetic_wave?lang=en
and this one
2nd order magnetic wave resonance math in PC configuration
http://gorchilin.com/articles/coil/magnetic_wave_resonance
The Trure Partnered Asymetric Buck configuration
  1. Two coils conf., parallel winding
  2. Choke conf. - high voltage, low current
  3. Bifilar conf, - low voltage, high current
  4. Asymmetric Partnered Buck conf. - high voltage, high current. Remark. Coils need different wire lenght.!
Vidura posted this 10 January 2019
The information from Gorchilin is very recomendable to read for understanding  of the magnetic resonance.
Regards Vidura.
mrblobby posted this 12 January 2019
Copied and saved to the 'aboveunity' folder on my laptop.
Chris posted this 12 January 2019
It is amazing how the world has changed in recent years!
Some years ago, this would have been laughed at, criticised, and disregarded. Now we know better! I am so proud of you all, and what we as a team, have, and are achieving! It is you that's actively changing the world!
Our Charge is Magnetic in Nature! Because it has an electric charge, this charge carries a Magnetic Field!
Each Ball Bearing / Magnet ( Cyan Ball ), can be made to move:
Remember, the Copper Wire, the Insulated Copper Wire must be bared on the ends to access the Charge! Insulation is not a fundamental instrument of "Generating" Energy.
Conductivity is!
The Insulation acts as a Guide, to direct your Charge that you have under pressure, to induce Velocity of the Charge.
Build your Pump my Friends! Show us how your pump is designed and we can compare!
Zanzal posted this 13 January 2019
Hey glennmr2018,
Welcome back. A couple of suggestions from experience:
I recommend avoid sharing ideas that you haven't built in someone elses thread. Its white noise that most experienced replicators have learned to simply ignore but it can be annoying to the thread owner who is trying to convey an important concept and doesn't want their thread filled with unproven attempts to innovate. Proven innovation is always welcome.
From experience I can tell you that if you haven't already built a working POC any innovation on the idea is a waste of time. There is an order to things in life, first you must learn the working principle, then you can expand upon that principle and integrate other principles.
Start simple with Mr Preva replication. If you can replicate the concept behind MrPreva then feel free to share your replication of that experiment (if you have not already.) Its sort of a right of passage and its the very important principle behind what Chris teaches here. Its not a concept you can skip and expect to be successful.
You should look back and delete any duplicate posts you may have made. Chris may do this for you.
Anyway, that's just some advice, you can do as you wish. Feel free to update us on how your idea works out.
Chris posted this 13 January 2019
Zanzal is right,
That many posts of that nature should have their own dedicated thread. We are seeing a White Noise problem now. I urge new comers to start thinking about others, existing members.
I have moved Glenmr2018's posts.
glennmr2018 posted this 14 January 2019
hallo guys~i have only just worked out how to actually view the latest posts here ~ by clicking on 'view latest posts' down below and scrolling down to the bottom!~ Chris , is there any easier way? this is why i posted the same thing 3 times last night~i could not even find what i had posted. While i apologize for this nontechsavy mistake.. i didn't expect you would delete the whole...lot! sigh!~i suppose this is 1 of the penalties i pay for having Aspergers Syndrome!
Visualize the Shape of Things Not Yet Seen with Eyes !! ... .. .
Vidura posted this 14 January 2019
HEY GLENNMR2018,
YOUR POST HAS BEEN MOVED INTO A NEW THREAD, YOU CAN FIND INDICATIONS ABOUT HOW TO USE THE FORUM SITE  IN THE LINK:HELP WITH USING THE FORUM AT THE TOP RIGHT SIDE
REGARDS VIDURA
Gravitation posted this 29 January 2019
Hi Chris and all !
First, thanks to all to share and making this forum very interesting ! I will be happy to share also my experiences here !
I'm working on this subject and it is very surprising that there is nothing new from 3 weeks ago. This topic is named "How to build you own above unity machine" and newer posts are on other topics on this forum. Everybody should be here no ??
Ok I've first replicated the Mr Preva experiment (success) and now trying to get above unity. Working for now with diode and bucking coils. With various configurations of putting diodes in the output, i'm now near the 1:1 for power input/output (1:0.85 in real). I don't have put capacitor to reach the resonance with coils. Is capacitor needed for above unity ? (Looking at Akula's schematic,  the answer seems yes)
Chris you are talking like a man that he has found and done a above unity machine. Is it true that you have done an over-unity machine ?
I put also here a screenshot of the current monitoring on the output bucking coils showing a sawtooth (1 ohm/5watt ceramic resistors). Chris, is this sawtooth that you are talking about in the beginning of the post ? I was here at 2 Khz on the bucking coil (10% Duty).
Thanks in advance for your help !
sawtooth current
Vidura posted this 29 January 2019
Hi Gravitation and welcome. It's good to see new members joining and doing practical experience. The sawtooth wave is inverted in your screen shot. The current have to be at maximum value in the beginning of the work cycle and fall linearly or exponential depending of parameters. Check if your coils are actually opposing magnetically. Regards Vidura.
Chris posted this 29 January 2019
Hi Gravitation,
Thanks for sharing! Welcome!
If I may point out, your Current is correct but in reverse. When one Pushes a Ball Up a Hill, One does not want any Resistance, one wants a task that is easy as possible.
We must not interfere with the Magnetic Field on the Up Hill journey! We must allow the Magnetic Field to build to maximum value with Zero Interference.
Where we want to use the Magnetic Field is on the Down Hill Journey:
Excess Electrical Energy can only be "Generated" by a Changing Magnetic Field! A Changing Electric Field burns a Heat Death - See Don Smith Quotes.
So, when a system is transforming from Electric to Magnetic, one must not allow any interference!
When a system is Transforming from Magnetic to Electric one can use the Changing Magnetic Field to "Generate" an Excess. Only using Partnered Output Coils however, not possible using a Single Coil.
The Partnered Output Coils must have sufficient Voltage and as a result Magnetic Fields ( Opposing Currents ) to see gains. Some work is required here to maximise your systems Energy "Generation". Some threads that may help: Asymmetrical Regauging, Magnetic ResonanceImpulse Pressure Wave, Non-Linear Inductance, Electromagnetic Waves, Increasing the Rate of Kinetic Energy, E=mc^2, Nano Second Pulses, Charge Separation, Resonance, Force, Parallel Wire or Bifilar Coil Experiment, Lenz's Law Experiment, Reduced Impedance Effect, Timing, Parametric Excitations of Electric Oscillations, Some Coils Buck and some Coils DONT, Accelerating Electrons, Electrical Energy...
Two Magnetic Fields ( Partnered Output Coils ) Slapping together very fast "Generates" a Voltage higher than two Magnetic Fields Slapping together Slower:
Ref: https://www.youtube.com /watch?v=xvNNTc6ZPtQ
Magnetic Fields Stand the same as Ocean Waves Stand:
Ref: https://www.youtube.com /watch?v=EUXOZAinUPk
A Vertical Wall of Water, huge Force.
NOTE: This Wall of Water is the Amplitude of the Voltage Peak! Voltage is bought high, because of the Magnetic Field Change! This is the Regauging part, seen here:
You are on the right track, but just have the Currents on the wrong side of the Cycle.
Gravitation posted this 30 January 2019
Many thanks for the super precise answer ! Very good idea to have listed all the threads that can help ! Vidura, yes i confirm to you that my coils were opposing magnetically in this screenshot.
It is very clear for me now, i will continue on the way that you said and post some news later
Gravitation posted this 01 February 2019
Ok from what i see, it seems to be good to have diode in reverse at the output branch of the Mr Preva experiment to force current to flow only in the center of the coils. When diodes are there, the sound of the transformer is deafening. And i am very suprised that the current in the center is almost pure DC without capacitors. Watch pictures
The frequency on the scope is wrong, i was at 2500Hz on both shot. Notice that the current monitored in A & B (on the scope) were negative DC and the 1 ohm resistor (R3) was positive DC.
With diodes :
Without diodes : (the transformer makes a little sound, nothing compared as before)
Next step is going to put some capacitors to reach resonance and see what's will happens
Chris posted this 01 February 2019
Nice Gravitation!
The Mr Preva Experiment is a step towards a working Above Unity Machine! Very nice waveforms there!
Chris posted this 05 February 2019
@All,
I wish to share some fantastic results!
Zanzal has replicated YoElMiCrO's Circuit and got some very good results!
Zanzal's Thread: Zanzal's Easy BCFT Circuit
YoElMiCrO's Circuit.
Zanzal's Circuit.
You see now, together we can change the world! We can! We have much more power than you think! You, here working toward the future will be remembered forever as the ones that led the Driving Force to make a Change!
Its all just a way of thinking, no Magic involved!
EDIT: Zanzal has reported an error in his result, please check the Thread listed above.
Zanzal posted this 16 February 2019
I went back and looked at the CW/CCW Coils circuit and did a quick retest. Using a 20W 12V DC 0.6 ohm bulb as the load I noticed that the current appeared to be under reported by my meter. The bulb seemed brighter than the current would have suggested. I did need to feed in a decent amount of power before I saw a noticeable reversal. It is not a sawtooth exactly, but a dip followed by an exponential slope in my case. Sawtooth might be how really good ones appear. Diodes were unnecessary, all that was needed was sufficient input power. It is impossible to know if it is underunity or overunity without accurate power measurements, so that is going to be a problem. I am not used to dealing with AC current, so I am not sure if my meter reported it accurately and the bulb simply looks brighter because it is AC.
Using the RMS AC voltage over a 1 ohm resistor and trying to maximize that number relative to the input power is probably the best approach I can think of for now. Will hopefully get some time to play with it this weekend.
Chris posted this 16 February 2019
The Numbers come with the birth of the effects I have described on this forum. Yes, its like:
The Scientist put the work in, followed the outline for the birth, and then came the moment of euphoria.
Paying attention, learning the outline and following the rules, simple rules, will bring success.
Your machine is a Pump, you must make it pump! Some details here: Parallel Wire or Bifilar Coil Experiment
This is a scope shot from a recent test using the CW/CCW coils circuit taken across the load:
Chris, is this what we are supposed to see for that circuit or does the waveform indicate something done incorrectly?
Edit: The circuit is the CW/CCW coils circuit in the original post and the load is a 1ohm resistor.
Hey Zanzal,
What's the Circuit, are you measuring Current or Voltage?
In my thread: Some Coils Buck and some Coils DONT I show Current scope shots that have a similar shape. Seen again here:
I should point out, this waveform is a constant, the basic shape is seen throughout: Akula, Graham Gunderson:
The very sharp change in Current is explained here.
One Current Up-Hill and one Current Down-Hill. In a parallel configured situation:
Equivalent to:
However, I have diodes eliminating the overshoot.
Maybe a little more info and I might be able to give you a little better information.
YoElMiCrO posted this 16 February 2019
hi Zanzal.
If the measurement occurs in the drain of the mosfet, that waveform is normal, seems to have saturation?
The positive peak is due to the back emf, which has a high value for having no load.
For that reason flyback topologies can not remain without load and is a normal behavior for an inductor.
I used the circuit CW/CCW coils:
The wave form is captured on a hand held oscillscope with the probe and probe ground where the blue dots are on the above. Load is a 1ohm resistor.
Chris posted this 17 February 2019
Hey Zanzal,
Excellent, so Voltage is what you're seeing. You're using a DC Pulse on the Input Coil, its being Loaded and Current increases when your load is connected, so you have Lenz's Law between Input and Output. I am guessing this is right, yeah?
If so, I would look toward the replication of: Some Coils Buck and some Coils DONT to see how Input to Output Isolation techniques can be used.
Also, the Voltage induced on your Output Coils can be increased dramatically by using information in this thread:  Parallel Wire or Bifilar Coil Experiment - at very little cost.
When you catch the wave, you will know. Jagau posted some good information on 'ferroresonance', I pointed out, that the Effects I am sharing with you are very similar:
The Thread: Impulse Pressure Wave, particularly Jagau's post in the pdf document on Ferro-Resonance, also describes these effects.
Ref: My Post Here.
Catch the Wave, get your Voltage up, not to high, but high enough to make a difference, use Conduction delay techniques through Timing to get these effects. But remember, this is not the only way. Other ways exist, but they are harder. I recommend sticking to this when learning.
P.S: Monitor your Currents, its important to monitor your progress!
I have shown this in the thread:  Some Coils Buck and some Coils DONT - It is very easy to see, once one learns enough, that the Voltage is important, as the Voltage increases, the Current must also increase!
Really simple EE facts.
Forelle posted this 22 February 2019
Hi all,
this is a short info how it goes on with my first bucking coil experiments,i did take 12 turns on the inputcoil,1,1mm dia,and 1 x 36 and 1x 33 turns on the buckingcoils,i was very impressed that i get with 2,8V and 0,8A a 1200 Vpp,accidently my load (lamp) was damaged and i was wondering why it did not light up and instead i saw about 5mm long sparks inside the lamp and very high spikes on the scope .This is not compareable with the regular spike that you  get with like for a Bedini system,if you imagine with only 2,8V and such few windings 1200 Vpp.
I would like to build a little bigger device where i can adjust the gap when it is running and where you can adjust the position of the coils.Chris,you never mentioned the wire size for the bucking coils is there a size that works better than an other?I forget, i had 10% dutycycle and 270Hz.
Oliver
Chris posted this 22 February 2019
Hi Oliver,
You can play with turns and wire size, as the Load is increased , larger wire Gauge is needed.
Turn down your input, and your duty Cycle. use less current.
Maybe use a resistive load, 10 Ohm 100 watt Resistor or something similar.
Then work on the Conduction Delay, pointed out in: Parallel Wire or Bifilar Coil Experiment
Be very careful of your equipment, large spikes like that can very easily damage scopes. Equipment normally does not like large spikes.
i was lucky that my scope was not damaged,it was by accident that i get this spikes on the scope,i should buy a differential probe.Is there a possibility that i can upload pictures with more than 2Mb?
Thank you.
Hi Oliver,
Sorry, 2Mb is currently the global limit.
Shrinking down Images is easy, only a little quality loss is seen and you can still get pretty good resolution.
http://www.simpleimageresizer.com/
That might be worth trying?
Thank you i will try.
Jagau posted this 22 February 2019
Hi Forelle
Very good job, believe that we have something interesting with the configuration you use. Excellent.
I got about the same effects as you but I use only a few milliamps for almost the same result.
The source I use limits this current in order to study this effect more deeply,
let's experiment.
Forelle posted this 23 February 2019
Hi Jagau
i thought this is common behavior  of the bucking coils.The spike comes on the outputcoils when you switch the inputcoil off like in a "normal" coil and you see it of course  only when no load is applied on the outputcoils.I have a small flyback transformer core like Chris or Akula.
