Parametric Excitations of Electric Oscillations
  • 1.8K Views
  • Last Post 12 May 2020
Chris posted this 09 August 2017
This thread is based entirely around the very old document, 1934, from Russian Researchers: "ON THE PARAMETRIC EXCITATION OF ELECTRIC OSCILLATIONS"
This document is attached below, in two pdf's, the original and a Translated OCR'ed by myself document also.
I want to include a snippet from the document, it is an example used in the document: Page.3, second paragraph.
Suppose that a current i is flowing in an oscillatory system consisting of a capacitance C, ohmic resistance R, and self-inductance L, at some instant of time which we shall take as the starting instant.
At this moment we change L, by, ΔL, which is equivalent to increasing the energy by 1/2  ΔLi2 The system is now left to itself.
After a time equal to 1/4 of the period of the tuned frequency of the system, all the energy transforms from magnetic into electrostatic.
At this moment, when the current falls to zero, we return the self-induction to its original value, which can evidently be done without expending work and again we leave the system alone.
After the next 1/4 period of resonance oscillations the electrostatic energy transforms fully into magnetic and we can begin a new cycle of variation in L.
If the energy put in at the beginning of the cycle exceeds that lost during the cycle, i.e. if
where ε is the logarithmic decrement of the natural oscillations of the system, then the current will be larger at the end of each cycle than at the beginning. Thus, repeating these cycles, i.e. changing I with a frequency twice the mean resonance frequency of the system in such a way that
we can excite oscillations in the system without any emf acting on it, no matter how small the initial charge.
I think we have seen now, many times, the importance of such Timing. The Timing Thread, we cover such phenomena! This with the MrPreva Experiment, it is a key component in the steps forward.
Energy is changing in time! Energy is entirely Electrostatic Energy (Red), Charge from the Capacitor discharges into the Coil for 1/4 of the Cycle, and then, Magnetic Energy (Green) is converted by the Coil back into Electrostatic Energy filling the Capacitor, on the second 1/4 Cycle:
So, the Capacitor discharges its potential Charge, entirely into the Coil, then the Coil, because it reverses polarity, discharges its Magnetic Field back into the Capacitor. Thus the opposite Sine for the Charge Polarity. I have covered this in some detail in the: A Coil, the Current and the Voltage Thread.
Below, an example of how Energy is added to the system by changing a parameter:
Parametric Oscillations can have two forms:
  • autoparametric excitation
  • heteroparametric excitation
Each with Regeneration (an external Voltage/Current Source) and without Regeneration.
Its very interesting to read the documents provided, it is a job to absorb it however! Much is complex, but not all of it needs to be understood!
Its worth noting: 1/2 the Resonant Frequency, or Twice the Resonant frequency is one of the optimum point. This could be seen as:
You can see, at 1/4 cycle, the sine of the second harmonic changes. Thus the Opposing Coils, Opposing Magnetic Fields.
Dynamic Magnetic Field Interactions, it is mentioned in the same document:
Thus a linear system cannot serve as an A-C generator.
Thus, as we have covered, this is the reason a "Common-Mode Choke" is good at its job, but nothing else.
We need a Dynamic System, Non-Linear in its operation, or Asymmetrical in its operation, not the same at the same time!
This is why we see Graham Gunderson's switching at near peak Current (Green Trace):
Because, this is where we need to change the Inductance, as he has.
  • John12
  • mrblobby
Chris posted this 28 August 2017
For those that don't know already, way back on: 10/01/2014 I published an article:
and even earlier: 17/12/2013 an Experiment:
I have researched this technology for many years.
This is very closely related, as stated above, to an AC "Generator". The AC "Generator" is a dynamic System, changing in Time, not Static.
Some simple work to try to make simple the requirements:
"***   Arduino Uni-Polar Parametric Switch V 1.0   ***"
I have moved this post and the project contents to: Arduino Uni-Polar Parametric Switch
Chris posted this 30 August 2017
The definition of the word Parametric is interesting:
adjective: parametric
  1. relating to or expressed in terms of a parameter or parameters.
    • Statistics assuming the value of a parameter for the purpose of analysis. "variables with normal distribution were compared by means of parametric tests"
    • Electronics relating to or denoting a process in which amplification or frequency conversion is obtained using a device modulated by a pumping frequency, which enables power to be transferred from the pumping frequency to the signal.
The definition one is able to deduce by means of reading the above paper is more so:
Non linear change in Time of one or more dependant Parameters.
With little work, one could modify the above "Arduino Uni-Polar Parametric Switch", into an "Arduino Bi-Polar Parametric Switch".
Please remember, all this is not necessary if one gets the correct Wave Lengths in the Coils. This is a way to force the Action without having to make lots of modifications and mistakes. The 1/4 Wavelength is the key.
I hope, with the examples I have provided, that everyone can see that this is critical, it is key to understanding how Energy Machines and also AC "Generators" actually work! Without knowing this, or at least the basics of the process described, then there is a large gap.
Where the Green "Magnetic" area in the Cycle enables us to "Generate" an excess of Electrical Energy!
Zanzal posted this 31 August 2017
Hey Chris, Regarding the 1/4th wavelength.. I never really understood this, can you give a laymen's explanation of the basics for determining the relative "wavelengths" of a wire?
Chris posted this 31 August 2017
Some of my friends say Wave Theory is incomplete, or incorrect. So what I say may not ring true for some people. Experiment proves critical to understanding.
Study this:
Then as time goes on, a better understanding will become clear in conjunction with the above data.
No worries Chris, just trying to understand how you see it. Radio theory isn't really on my radar right now. But, the problem with the antenna video is it is EM propagation (photons). Its not clear that this can be applied to systems involving transformers or even electrons unless those electrons are moving at speeds near the speed of light.. Unfortunately, I don't know enough to unify the two concepts.
Let's say I have two cables, each nearly identical, one cable is 4 feet long, the other is 1 foot long. I wrap them both around my transformer in whatever configuration. I am assuming for this concept coil configuration is not relevant (or maybe this only works with POC). Are you saying that for any such transformer with a 1 to 4 ratio, there is some frequency where the AC signal through the 4 feet cable can be called "1" wavelength and the transformer at this frequency will produce an overunity effect in the secondary because it is exactly 1/4 the length of that cable?
Hi Zanzal - Some notes to ponder:
  • The first requirement for Energy "Generation" is Magnetic Fields in Opposition.
  • The Change in Magnetic Field Invokes an EMF, faster the change the greater the EMF.
  • If the Primary has one wave length applied across it, then the Secondaries can only have Opposing Magnetic Fields in certain configurations.
  • A Standard Conventional Transformer can never go over unity, not unless a Third Magnetic Field is introduced.
  • Where are the Electrons in the Wire at 1/4 Wavelength? What direction are they traveling? Think MrPreva Experiment... Not all the Electrons are induced from the Primary!
  • Look at the Experiments I have shown:
WHY?
Why is the Input completely Reactive at Resonance? What is Reactance? What changes the Voltage to Current Phase Angle making for a Reactive Input?
When one Magnetic Field Influences another, loading the Magnetic Field, Lenz's law, then another Magnetic Field in opposition to the Second will Counter Balance the Loaded Magnetic Field! We are Counter Balancing Lenz's Law!
Study the Coil, why is it that the Grenade is wound like it is, 1/3 counter wound back on itself?
Because it "Generates" Electrical Energy. The KapaGen becomes "Regenerative" at Resonance!
Why does a Standalone Coil/Inductor exhibit a Self Resonance:
The Distributed Capacitance of the Coil and the Inductance, but why? What is Coil Resonance?
The trick is to make the Electrons flow efficiently. To Efficiently run these devices, like the MrPreva Experiment, we needed to find RLC Resonance!
In RLC Resonance, what happens? What are the Unique Characteristics that happen at RLC Resonance?
"Regenerative", "Must be in Phase" Exactly what we have seen! We see the Regenerative Current, In the MrPreva Experiment. Yet we have Magnetic Fields in Opposition!
Exactly what we were told by Floyd Sweet and so many others!
Zanzal posted this 01 September 2017
I hope you didn't intend these questions to all be rhetorical. But, since I asked, and you countered my question with a bunch of questions, I'll give an answer as to my opinion.
The direction of electron movement is always towards the positive emf, except at a time representing 1/4 cycle if the frequency of oscillation is not in resonance its entirely possible the electrons will only have begun to move since they may be lagging behind or will have already ceased moving.
WHY?
Half of this question I've wondered myself. Though I think overall I would say that I probably don't really understand it. I know that inductive reactance increases with increasing frequency and capacitive reactance decreases.. or maybe i got it backwards, anyway, depending on frequency current will either lead or lag as a result of of capacitive and inductive reactance. At resonance these effects are balanced so current is in phase with voltage. But the why, well, that would probably because of voltage drop while charging the capacitor, causes current to lead and counter emf for lag in inductance would be my guess..
I know people have this great skill to look at some youtube video and instantly know how the coil is wound, or to see a circuit print and be able to reverse engineer it into a schematic.. but yeah, I'm not one of those people. I personally attribute this to a complete lack of experience.. I'm like a toddler in this field, trying to run before I've figured out how to crawl.
Anytime you have two parallel conductors there will be a capacitance, so the coil turns act as very small capacitors.
I am not sure if those were the answers you expected, but I still don't understand the 1/4th wavelength thing. No worries though, you are not responsible for what I cannot understand.
You know it just dawned on me, resonance causes the capacitor to charge twice as fast as it should and it also causes it to discharge twice as fast as it should?
Chris posted this 01 September 2017
Hi Zanzal - I meant to spur thought processes. Rhetorical, no, to try to help only. Great answers! At Ideal Resonance, V and I are 90 degrees, out of phase.
We saw in the Wave Propagation, or Antenna Video that when in resonance, the optimum wavelength across the antenna is 1/2 Wavelength. The reasons are explained in the video: avoid Reflection and not waste Energy:
Please visit Here for animated Gif's
Note: Each Polarity, to the above depicted Antenna is 1/4 Wavelength - Positive and Negative! We learned in the Mr Preva experiment  that Positive Current and Negative Current Add to the Total Current.
Again from Floyd Sweet:
However, the output power sees a constant load impedance, that of the matched antenna system. If this changes, the input to the antenna is mismatched, and standing waves are generated resulting in a loss of power. The frequency is a forced response and remains constant. Power is lost and efficiency becomes less and less, depending on the degree of mismatch. Let’s assume the Jensen amplifying transformer is in a resonating condition. Its output is connected to a transmission line which is X number of miles long
Yes, you are right.
A Capacitor changes Polarity, two times per Cycle! However, there are four Actions Per Cycle!
  • Cap Charges Coil.
  • Coil Charges Cap.
  • Cap Charges Coil.
  • and lastly Coil Charges Cap.
This is a critical aspect to what we are looking at! Why?
Because in the Coil, at Resonant Frequency X, One Half the Wavelength is across the Coil! The Coil Converts Electrical Energy into Magnetic Energy, then, Magnetic Energy back into Electrical Energy, charging the Capacitor for the next Half Cycle.
However the Coil changes Polarity Four Times per Cycle, but only has two Actions per Cycle.
  • Magnetic Field in one Direction
  • Magnetic Field in the opposite Direction.
However, one could say, Four Actions exist, Magnetic Field Expansion and Contraction for each One Half Cycle. My point being the Coil see's One Half Electromagnetic Wave each One Half Cycle.
Wave propagation, Invokes an E.M.F, or moves other Charges at One Half the Wavelength, but we want to be tricky, and induce Opposite Magnetic Fields with the Charges in motion... Then how will we do this? Knowing we can invoke more Charge motion via Electromagnetic Induction! E.G: Mr Preva Experiment.
Reactance
Reactance is Capacitive XC and Inductive XL, these two values are part of the Impedance (Z).
The Magnetic Field has a Resistance, like the Electric Field (Current) has a Resistance. Perhaps not the best analogy. A Magnetic Field influences another Magnetic Field by changing the internal properties of the Coils.
Yes, you're right, XL Inductive Reactance is Frequency driven, it is the "Generation" of Current in Opposition to the Source Frequency's Current, it impedes the increase of Frequency - Why? Electromagnetic Induction!!!
Experiment
Take a small Audio Transformer, not loaded, measure the input, phase angle, voltage and Current.
Now load the Transformer, the Phase angle will change along with the Current, the input voltage shouldn't change much if at all depending on your source impedance.
Result
The Phase angle will be larger, a greater difference when the Transformer is not loaded compared to when it is loaded. Why? The Magnetic Fields, the Secondary in opposition to the Primary, changes the Coils Impedance, allowing more current to flow the stronger the Magnetic Fields become.
I have not covered all of it, Answers are all throughout my pages, but like I said, as time goes on, more becomes clear. Also, I am still learning, I am trying to make sense of and also best describe what I have learned. Sometimes I am not always right, or pick the best analogy's.
I think this is cool:
I hope this helps some!
  • alohalaoha
Chris posted this 13 June 2018
Hey Mrblobby,
I do not know about documents as such, but yes he did refer to the Russian Parametric Oscillator.
cd_sharp posted this 12 May 2020
Graham Gunderson also talks about changing the inductance:
