Tinman's Magnetic Diode?
  • 1K Views
  • Last Post 09 October 2019
Chris posted this 15 August 2019
Hopeful1 bought to my attention this video:
Thanks Hopeful1!
I want to ask all here that is only now getting up to speed, this is exactly how my technology works! Its exactly how the RT V3 worked.
Brad has done a very good job of explaining the importance of:
Action, Reaction and Counter-Reaction.
Its worth noting, tinman does tell you in the image attached to this post, of Action, Reaction and Counter-Reaction!
This breaks down to: Primary = 1, Secondary = -1, Tertiary = 1 which equals: 1 + -1 + 1 = 1.
The Coils doing, exactly this:
All new comer's should make this experiment a priority along with The Mr Preva Experiment!
Jagau posted this 16 August 2019
If I understand well
1+ = source coil (primary coil)
-1 = second coil on the left
+1 = third coil in the center
so 1+ -1 + 1 = 1
Chris posted this 16 August 2019
Yes exactly.
In a Transformer, or a "Generator" we have:
  •  Primary = 1.
  • Secondary = -1.
  • 1 + -1 = 0.
So there we see a Symmetrical System, 1 + -1 = 0, however we need to use an Asymmetrical System, 1 + -1 + 1 = 1.
We have a Force that is not used up, we are left with the same force we started with but still have the Output. So the Primary is not negated! We have:
Lenz’s Law Free Power Extraction.
Ref: Guidelines to Bucking Coils.
What is interesting to observe,
is that the third coil also produces a BEMF
but in reverse polarity and can not return to the source. (anti lenz coil)
That's why, I think the 2 LEDs light up a little stronger
I give a lot of information and also complain about brad steeling my tech and again claiming it as his own:
Also, look who is visiting us right now: ( Brad, aka tinman )
Vidura posted this 16 August 2019
Really good experiment, so simple demonstrated that effect. I'm quite sure that I have seen this in my tests with POC and diodes, without realising what was going on. Vidura.
Wistiti posted this 16 August 2019
Not the first time he play with your POC concepts and for sure not the last time!!!
Atti posted this 16 August 2019
Although I guessed what the outcome would be, I did try it out of curiosity with lower frequencies and more powerful LEDs. Iron core with open coils. I was not impressed with the result. Has anyone tried it before?
Atti - try harder, look at: RT V3
Study the MIT, Graham Gunderson's machine.
Ask yourself, what is the cause of this wave height?
Wistiti, My Friend - Thank You!
You are very wise! It is evident tinman will always circle back to the very same concepts we have learnt in depth!
Partnered Output Coils are Humanity's ONLY Change forward! He know's this!
Hey Friends, For those who want to experiment on this pay attention that in first place the coils can be displaced for tuning , and the other thing that it is an open core in this case, which makes it a little bit easier to follow the directions of the magnets waves. In a closed core we have to deal with bidirectional waves and might need different techniques. I believe that Wistitis battery charger works on this exact same principal. Vidura.
Chris posted this 18 August 2019
I was expecting a few replications already, no one?
For those looking for more answers, the bench is the only way!
Atti posted this 18 August 2019
Talking is always easier than acting.
Vidura posted this 18 August 2019
Hey Chris and Atti You are so right with this, I have a couple of experiments prepared, hopefully I will find the time to perform them soon. Also I made a video of a test lately but it came out too bad, so I didn't post it, now I have to clean up the phone first, no more memory available for videos,😓. Sorry about that, will try to catch up soon.Vidura.
patrick1 posted this 18 August 2019
Hello Friends, Much love from Perth, Western Australia.
HOME OF THE MIGHTy PENDULUM and me2
Rocking it all night long,
Patrick
getreal156 posted this 18 August 2019
Very interesting experiment that might be obvious for some but made some bells ring with me.
I have limited time but definitely going to replicated this one soon.
Just watched some Thane Heins video's where he also talks about a " diode " effect of the magnetic fields.
His cores where designed to let the 'trigger' flux through in one direction only.
Hey Getreal156,
Tinman, aka brad uses no core.
Vidura posted this 19 August 2019
Hello Friends, Here a video of a "magnetic diode" replication. I found this effect on a coreless setup, more prominent at around 150khz with my coils, but also with a powdered iron core @10khz and most difficult with the ferrite block but also present at 4khz, it also depends on duty cycle and the distance between the coils. For the moment I could not reproduce it with incandescent bulbs, only with led.
getreal156 posted this 19 August 2019
Hi Cris,
I was referring to the working principle of the bi-torroid device from Thane Heins. In one of his video's he is explaining that the magnetic field of the trigger coil only works in 1 direction. As he explains, the fields generated by the secondary coils don't flow back into the primary and thus doesn't influence the impedance of the primary.
I'm currently making some 3d prints for a replication. I will post my results this week.
  • Atti
Atti posted this 19 August 2019
Hi Vidura!
Great work! It perfectly shows where I made a mistake. Distance between rolls. For me, all three rolls fit tightly together. So I didn't see the effect. Unfortunately, it does not work with light bulbs and diodes. We need to keep thinking.
Hi getreal.
Can you tell me which setting this is? Or about video.
Hi Atti,
Sorry. I should have included the video before. Thane describes his transformer as being a magnetic diode.
At 7:00 in the video
Chris posted this 19 August 2019
I should bring up our Don Smith thread again.
What tinman has shown we have been through many times, on the above thread and also many others. What's the basic Circuit?
What should be the Goal: Input Coil, remove turns and tune for ideal frequency...
Vidura is exactly on the right track! Excellent work Vidura!
@Getreal156 sorry, not paying enough attention - I see what you meant now.
patrick1 posted this 20 August 2019
tickle tickle, truly Chris, that is a magnificent table
getreal156 posted this 02 September 2019
I promised it last week so I'm sorry for my late update.
Chris posted this 02 September 2019
Hey GR,
You need to use a Mosfet, DC to the Coil. Uni Polar Magnetic Field.
You need to look for: Action, Reaction and then Counter-Reaction. 1, 2 and 3...
Youre right, Tinman's theory and ideas are somewhat flawed, but the ideas presented do work if you get the polaritys and setup right. I know, because he stole "his" ideas from me!
CD has done the same experiment, with a slightly different setup and got the results I have been trying to convey. This does work if one gets the right configuration...
WOW your voice sounds very much like Itsu, are you also known as Itsu?
Please, you have come so far, try a little longer, I can help you with this! It does work!
Hi Cris,
I just was listening back my audio and noticed exactly the same ! Amazing ! haha .
Actually, I find listening to my own accent very enoying. I tried to improve when I was younger but obviously didn't try hard enough
I didn't show it in this video but I did use a Mosfet before. I repeated the the experiment a few times with different configurations. Mosfet, NPN transistor and without any thing, directly coupled to the function generator.
The results that I got do match with Tinman's experiment but I was specifically interested in if there is any truth to the ' magnetic blocking' theory.
ps. I didn't found a lot of difference between using a mosfet or directly coupling to the function generator.
Thanks a lot for offering your support again! Really appriciated
I'm following your leads and I'm working on some new and old experiments. I definitely will come back to you later with some questions. Although I have limited time for experimenting my brain is working over time ALL day, every day. I don't post a lot of results but I think I'm getting close.
Hey GR,
Your accent is very cool! I enjoy listning to all accents except my own, sounds a bit hypocritical, I dont know why embarassed
Also, I should have pointed you to Vidura's excellent replication also. Its above, the Video:
You are right in your observations, the term Diode is perhaps confusing, but if you take the Vector of each Magnetic Field, you do get a better way of thinking about it:
1 + -1 + 1 = 1
Or:
Remember: Typically we have Symmetrical Systems, only having two Vectors:
Or:
1 + -1 = 0
Chris posted this 09 October 2019
Its been two months and not a squeak from Tinman!
@Tinman,
Publically I invite you, and only you, from your band of merry men, to join our Forum. Come and be part of something Better! I will stop my critique of your claims.
You could become a valuable member here, as are all the current members here!
I leave the choice up to you.
Kind Regards
   Chris Sykes
There we go, a Public Invite, addressed directly to Tinman.
His work and understanding is valuable, he does have a good way of looking at things. His video above is valuable to learners.
