Microcontroller PWM cheap and easy start to getting something working
  • 528 Views
  • Last Post 22 August 2020
Chris posted this 28 June 2020
Many years now I have been super interested in PWM. Years ago I wrote a PWM project for Arduino, it was terrible, but it was a good start. Since then, I have written many more...
Today I want to share something of a bit more value than my first project, A PWM Project that has a lot more value:
The Code:
// PWM Software written by Chris Sykes.                                                           //
// NOTE: 16 bit Timers currently used. 32 Bit Timers need all shorts changed to longs!            //
// Software written and shared as is, no warrantys are given. Use at your own risk.               //
// Your MCU Clock Frequency: 16000000 or 16e6, retrieved by F_CPU.                                //
long fclock = F_CPU;
// Most MCU's have:        //
//   0,        //
//   8,        //
//   64,        //
//   256,        //
//   1024        //
// as Prescaler Values:        //
short Prescaler = 1024;
// The MCU Setup Method:        //
void setup() {//////////////////////////////////////////////////////////////////////////////////////
  // Init Serial:
  Serial.begin(115200);
  // Confgure Timer:
  ConfgureTimer(1.275, 21.525);
// Configure Timer:        //
void ConfgureTimer(double frequency, double dutycycle){/////////////////////////////////////////////
  // The counter simply overruns when it passes its maximum 16-bit value
  // (MAX = 0xFFFF (65535)) and then restarts from the BOTTOM (0x0000).
  // Timer One PWM Pin:
  // Check your Datasheet!
  pinMode(10, OUTPUT);
  // Reset Timer One:
  TCCR1A = 0;
  TCCR1B = 0;
  // ComA and B need to be set for Compare Match Pins:
  TCCR1A |= (1 << COM1A1) | (1 << COM1B1);
  // Configure Prescaler (CSX):
  SetPrescaler(Prescaler);
  // Set PWM Mode:
  SetPWMMode();
  // Set Frequency:
  OCR1A = CalculateFrequency(frequency);
  // Set Duty Cycle:
  OCR1B = CalculateDutyCycle(OCR1A, dutycycle);
// Set Prescaler:        //
void SetPrescaler(short prescaler){/////////////////////////////////////////////////////////////////
  // See your Datasheet! See: Clock Select Bit Description                                                 //
  // CS02     CS01     CS00     Description        //
  //  0        0        0        No clock source (Timer/Counter stopped)                                   //
  //  0        0        1        clkI/O/(No prescaling)                                                    //
  //  0        1        0        clkI/O/8 (From prescaler)                                                 //
  //  0        1        1        clkI/O/64 (From prescaler)                                                //
  //  1        0        0        clkI/O/256 (From prescaler)                                               //
  //  1        0        1        clkI/O/1024 (From prescaler)                                              //
  //  1        1        0        External clock source on T0 pin. Clock on falling edge.                   //
  //  1        1        1        External clock source on T0 pin. Clock on rising edge.                    //
  switch (prescaler) {
    case 0:
      //  Set 0: clkI/O/(No prescaling)
      TCCR1B |= (0 << CS12) | (0 << CS11) | (1 << CS10);
      break;
    case 8:
      // Set 8: clkI/O/8 (From prescaler)
      TCCR1B |= (0 << CS12) | (1 << CS11) | (0 << CS10);
      break;
    case 64:
      // Set 64: clkI/O/64 (From prescaler)
      TCCR1B |= (0 << CS12) | (1 << CS11) | (1 << CS10);
      break;
    case 256:
      // Set 256: clkI/O/256 (From prescaler)
      TCCR1B |= (1 << CS12) | (0 << CS11) | (0 << CS10);
      break;
    case 1024:
      // Set 1024: clkI/O/1024 (From prescaler)
      TCCR1B |= (1 << CS12) | (0 << CS11) | (1 << CS10);
      break;
    default:
      // Set Off: No clock source (Timer/Counter stopped)
      TCCR1B |= (0 << CS12) | (0 << CS11) | (0 << CS10);
      break;
// Set PWM Mode:        //
void SetPWMMode(){//////////////////////////////////////////////////////////////////////////////////
  // See your Datasheet!        //
  // Waveform Generation Mode Bit Description        //
  //                                     Timer/Counter Mode of                    Update of       TOV Flag (1)(2)   //
  // Mode    WGM3   WGM2   WGM1   WGM0   Operation                     TOP        OCRx at         Set on            //
  //  0      0      0      0      0      Normal                        0xFFFF     Immediate       MAX               //
  //  1      0      0      0      1      PWM, Phase Correct, 8-bit     0x00FF     TOP             BOTTOM            //
  //  2      0      0      1      0      PWM, Phase Correct, 9-bit     0x01FF     TOP             BOTTOM            //
  //  3      0      0      1      1      PWM, Phase Correct, 10-bit    0x03FF     TOP             BOTTOM            //
  //  4      0      1      0      0      CTC                           OCRnA      Immediate       MAX               //
  //  5      0      1      0      1      Fast PWM, 8-bit               0x00FF     TOP             TOP               //
  //  6      0      1      1      0      Fast PWM, 9-bit               0x01FF     TOP             TOP               //
  //  7      0      1      1      1      Fast PWM, 10-bit              0x03FF     TOP             TOP               //
  //  8      1      0      0      0      PWM, PnFC                     ICRn       BOTTOM          BOTTOM            //
  //  9      1      0      0      1      PWM, PnFC                     OCRnA      BOTTOM          BOTTOM            //
  //  10     1      0      1      0      PWM, Phase Correct            ICRn       TOP             BOTTOM            //
  //  11     1      0      1      1      PWM, Phase Correct            OCRnA      TOP             BOTTOM            //
  //  12     1      1      0      0      CTC                           ICRn       Immediate       MAX               //
  //  13     1      1      0      1      (Reserved)                    –          –               –                 //
  //  14     1      1      1      0      Fast PWM                      ICRn       TOP             TOP               //
  //  15     1      1      1      1      Fast PWM                      OCRnA      TOP             TOP               //
  // NOTE: PnFC = Phase and Frequency Correct.
  // Fast PWM needs bits (WGM10 & WGM12) set to One:
  TCCR1A |= (1 << WGM10) | (1 << WGM11);
  // Configure Fast PWM Mode (WGM12 and 13):
  TCCR1B |= (1 << WGM12) | (1 << WGM13);
// The MCU Loop Method:        //
void loop() {///////////////////////////////////////////////////////////////////////////////////////
  // Print Output:
  PrintOutput();
  // Delay:
  delay(3000);
// Calculate the Frequency:        //
short CalculateFrequency(double frequency){/////////////////////////////////////////////////////////
  // Calculate OCR1A from specified Frequency:
  return (short)(fclock / (frequency * Prescaler)) - 1L;
// Calculate the DutyCycle:        //
short CalculateDutyCycle(int period, double duty){//////////////////////////////////////////////////
  // Calculate OCR1B from OCR1A and specified Duty Cycle:
  return (short)(period * (duty / 100L));
// Calculate Register Resolution:        //
double CalculateResolution(short ocrx){////////////////////////////////////////////////////////////
  return (log((double)ocrx + 1.0D)/log(2.0D));
// Print Output Data:        //
void PrintOutput(){/////////////////////////////////////////////////////////////////////////////////
  // Shorts, Longs and other variable's dont mix well, convert to Double:
  double Frequency = ((double)fclock / (((double)OCR1A + 1.0) * (double)Prescaler));
  short Period = (short)((double)fclock / (Frequency * (double)Prescaler)) - 1.0;
  // Display Output:
  Serial.print("Frequency: ");
  Serial.print(Frequency);
  Serial.print("Hz. Resolution: ");
  Serial.print(CalculateResolution(OCR1A));
  Serial.print(" bits. Period: ");
  Serial.print(Period);
  Serial.print("==");
  Serial.print(OCR1A);
  Serial.println(" comboblets");
Of course this is just the start, to get you started! You can use many Arduino Microcontrollers with this, from the Arduino Mega, Pin 12, to the Arduino Pro Micro, Pin 10, currently testing the Code on the Pro Micro:
Of course, the Mega has different Pin Outs. This Code is very adaptable! Please post here if you need help changing the Code to suit your Microcontroller.
PWM can be used to drive any Mosfet, Transistor, SCR, Triac, Relay and many more Switching Options! For about $6.00 one of these can be purchased: MOSFET High Power
Of course, some sort of interface to update your Microsontroller can be used, USB Serial, WiFi or anything like this can be used to change the Frequency and Duty Cycle, but more Code will be required.
For less than $10.00 this is a great option to get started!
@Zanzal and other Dev's, please feel free to add Code or suggestions to improve the Code.
The above example is a super cheap and fun example of getting PWM Working for your projects!
I want to share an example, Serial Communications, that you can look at to get your Frequency and Duty Cycle updated from your Computer. The Arduino Page gives a good starting example: https://www.arduino.cc/en/tutorial/SoftwareSerialExample
  Software serial multple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 The circuit:
 * RX is digital pin 2 (connect to TX of other device)
 * TX is digital pin 3 (connect to RX of other device)
 Note:
 Not all pins on the Mega and Mega 2560 support change interrupts,
 so only the following can be used for RX:
 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
 Not all pins on the Leonardo support change interrupts,
 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
 created back in the mists of time
 modified 25 May 2012
 by Tom Igoe
 based on Mikal Hart's example
 This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
void setup()
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Native USB only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(38400);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
Of course, you will need a Client and Server sort of setup, Software listening to commands on your MCU, the Server, and software issuing Commands, Client, on your computer.
Devs, anyone willing to put your info in to help come up with a solution?
C# is one of my preferred Languages, although I know a few, not as well as C# however, here is some C# Code for Serial Communication:
using System.IO.Ports;
/// <summary>
/// Configure the Baud Rate and Setup in the ComboBox...
/// </summary>
private void BaudRateComboBoxConfig()
    // Clear all existing Items...
    this.baudRateComboBox.Items.Clear();
    // Add an empty line...
   this.baudRateComboBox.Items.Add("");
    // Baud Rates Available....
    this.baudRateComboBox.Items.AddRange(BaudRates);
/// <summary>
/// Get the selected Baud Rate...
/// </summary>
/// <param name="sender"></param>
/// <param name="e"></param>
private void BaudRateComboBox_SelectedIndexChanged(object sender, EventArgs e)
    if (this.baudRateComboBox.Text != "")
    // Sets Baudrate....
    this.serialPort.BaudRate = Convert.ToInt32(this.baudRateComboBox.Text);
    this.portNameComboBox.Items.Clear();
    this.portNameComboBox.Items.Add("");
    // Gets Availabe COM ports...
    foreach (string str in SerialPort.GetPortNames())
        SerialPort tmp = new SerialPort(str);
        if (tmp.IsOpen == false)
            this.portNameComboBox.Items.Add(str);
    if (this.portNameComboBox.Items.Count > 0)
    // Set the Port ComboBox to Enabled=true now a Baudrate is selected....
    this.portNameComboBox.Enabled = true;
    else
    // Display Error Message - No Device Found....
    if (this.notificationLabel.Text == noDeviceFoundMessage)
        String message = noDeviceFoundMessage;
        String caption = "Error - No Device Found...";
        MessageBoxButtons buttons = MessageBoxButtons.OK;
        MessageBoxIcon icon = MessageBoxIcon.Error;
        MessageBox.Show(message, caption, buttons, icon);
    this.notificationLabel.Text = noDeviceFoundMessage;
    // Clear Baud Rates....
    this.BaudRateComboBoxConfig();
    return;
/// <summary>
/// Connect/Disconnect...
/// </summary>
private void ConnectButton_Click(object sender, EventArgs e)
    #region this.connectButton.Text == "Disconnect"..
    if (portNameComboBox.Text.Length >= 3 && this.connectButton.Text == "Disconnect")
        if (this.serialPort.IsOpen)
        try
            this.serialPort.Close();
            this.baudRateComboBox.Enabled = true;
            this.baudRateComboBox.SelectedIndex = this.BaudRate;
            this.portNameComboBox.SelectedIndex = this.COMPort;
            // Set the Connect Button Text to Disconenct...
            this.connectButton.Text = "Connect";
        catch (Exception exc)
            MessageBox.Show("Error: " + exc.Message);
            // Return and dont go any further...
            return;
        #endregion
        #region this.connectButton.Text == "Connect"...
        if (portNameComboBox.Text.Length >= 3 && this.connectButton.Text == "Connect")
            // Set the Port Name....
            this.serialPort.PortName = portNameComboBox.Text;
            this.serialPort.Parity = Parity.None;
            this.serialPort.StopBits = StopBits.One;
            this.serialPort.DataBits = 8;
            try
                this.BaudRate = this.baudRateComboBox.SelectedIndex;
                this.COMPort = this.portNameComboBox.SelectedIndex;
                // Open Serial Ports and disable Buttons....
                this.serialPort.Open();
                this.portNameComboBox.Enabled = false;
                this.baudRateComboBox.Enabled = false;
                this.notificationLabel.Text = "Connected to : " +                 portNameComboBox.SelectedItem.ToString() + " , with a baudrate of : " + baudRateComboBox.SelectedItem.ToString() + "...";
                this.connectButton.Text = "Disconnect";
            catch (Exception ex)
                MessageBox.Show(ex.Message, "ERROR: " + ex.Message, MessageBoxButtons.OK, MessageBoxIcon.Error);
            if (serialPort.IsOpen)
                this.Center();
                // Dont go any further...
                return;
            else { notificationLabel.Text = "Please select Baud Rate then select Com Port..."; }
            #endregion
My opinion is, comming up with a good smart Serial Communication Scheme is more difficult than the Code itself.
I came up with a string like this: <1|0002000|050|100|1>
The Code:
// Our Serial Data String should look something like this : <1|0002000|050|100|1>
this.TXDString = String.Format("<{0}|{1:0000000}|{2:000}|{3}|{4}>", CPU.ConvertPortToInt(Port.ToString()), Frequency, Duty, divider, Output.ConvertModeToInt(Mode.ToString()));
I think this could be done a lot better and more efficient. All that we need is 2 numbers, each up to 16 bits for:
  • OCR1A
  • OCR1B
Something like this:  <OCR1A|OCR1B>
Chris posted this 29 June 2020
I spent five minutes on the Serial Receive:
  // Print Output:
  PrintOutput();
  // Look for Serial Data:
  if(Serial.available()){
    // Read Serial String:
    String data = Serial.readString();
    // Check Data and Process:
    if(data.length() > 0 && data.startsWith("<"))
      ProcessSerialData(data);
// Process the Serial Data:        //
void ProcessSerialData(String data){////////////////////////////////////////////////////////////////
  // Get Frequency (F) and DutyCycle (D) from: <65535|32767>
  long F = data.substring(1, data.indexOf('|')).toInt();
  long D = data.substring(data.indexOf('|') + 1, data.indexOf('>')).toInt();
  // Set Frequency:
  OCR1A = F;
  // Set Duty Cycle:
  OCR1B = D;
A simple bit of Software is now needed for the PC, just a .NET App to send via Serial, the Commands.
I couldn't help myself, I have written a very simple, extremely simply, not pretty looking controller:
namespace SerialPWMController
    #region Using Statements:
    using System;
    using System.Windows.Forms;
    #endregion
    public partial class Form1 : Form
        #region Fields:
        /// <summary>
        /// The Microcontroller Clock Frequency:
        /// </summary>
        int fclock = 16000000;
        /// <summary>
        /// The Clock Frequency Prescaler:
        /// </summary>
        int Prescaler = 1024;
        /// <summary>
        /// Create a new SerialPort Reference.
        /// <para>
        ///     See: https://docs.microsoft.com/en-us/dotnet/api/system.io.ports.serialport?view=dotnet-plat-ext-3.1
        /// </para>
        /// </summary>
        SerialPort serialPort = new SerialPort();
        #endregion
        #region Properties:
        /// <summary>
        /// Serial Port Name:
        /// </summary>
        public string PortName
            get { return serialPort.PortName; }
            internal set { serialPort.PortName = value; }
        /// <summary>
        /// Serial Port BaudRate:
        /// </summary>
        public int BaudRate
            get { return serialPort.BaudRate; }
            internal set { serialPort.BaudRate = value; }
        /// <summary>
        /// Serial Port Parity:
        /// </summary>
        public Parity Parity
            get { return serialPort.Parity; }
            internal set { serialPort.Parity = value; }
        /// <summary>
        /// Serial Port DataBits:
        /// </summary>
        public int DataBits
            get { return serialPort.DataBits; }
            internal set { serialPort.DataBits = value; }
        /// <summary>
        /// Serial Port StopBits:
        /// </summary>
        public StopBits StopBits
            get { return serialPort.StopBits; }
            internal set { serialPort.StopBits = value; }
        /// <summary>
        /// Serial Port Handshake:
        /// </summary>
        public Handshake Handshake
            get { return serialPort.Handshake; }
            internal set { serialPort.Handshake = value; }
        #endregion
        /// <summary>
        /// Form Constructor.
        /// </summary>
        public Form1()
            // Form Init:
            InitializeComponent();
            // Add Port Names:
            foreach (string PortName in SerialPort.GetPortNames())
                if (!PortNameComboBox.Items.Contains(PortName))
                    PortNameComboBox.Items.Add(PortName);
            // Standard Baud Rates:
            int[] BaudRates = new int[] { 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 38400, 57600, 115200, 128000, 256000 };
            // Add Port Names:
            foreach (int BaudRate in BaudRates)
                BaudRateComboBox.Items.Add(BaudRate);
            // Set Selected Index:
            BaudRateComboBox.SelectedItem = 115200;
        /// <summary>
        /// Form Load Event.
        /// </summary>
        private void Form1_Load(object sender, EventArgs e)
            // Set the read/write timeouts
            serialPort.ReadTimeout = 500;
            serialPort.WriteTimeout = 500;
        /// <summary>
        /// Calculate the Frequency:
        /// </summary>
        /// <param name="frequency">The desired Frequency: 3.73Hz</param>
        /// <returns>int representing the resolution on the Register (16 bits).</returns>
        int CalculateFrequency(double frequency)
            return fclock / (int)(frequency * Prescaler) - 1;
        /// <summary>
        /// Calculate the Duty Cycle:
        /// </summary>
        /// <param name="period">Period, or 1 / F</param>
        /// <param name="duty">The desired Duty Cycle: 50.0%</param>
        int CalculateDutyCycle(int period, double duty)
        /// <summary>
        /// Calculate Register Resolution:
        /// </summary>
        /// <param name="ocrx">The Register Value, E.G: CalculateFrequency(1024.57)</param>
        /// <returns>double representing the Resolution at the current Register Value.</returns>
        double CalculateResolution(int ocrx)
            return (Math.Log((double)ocrx + 1.0D) / Math.Log(2.0D));
        /// <summary>
        /// Send Button Click Event.
        /// </summary>
        private void SendButton_Click(object sender, EventArgs e)
            // Parse the Values:
            double.TryParse(FrequencyTextBox.Text, out double Frequency);
            double.TryParse(DutyCycleTextBox.Text, out double DutyCycle);
            // Calculate Resolutions:
            int FrequencyResolution = CalculateFrequency(Frequency);
            int DutyCycleResolution = CalculateDutyCycle(FrequencyResolution, DutyCycle);
            // Set Resolution:
            ResolutionLabel.Text = CalculateResolution(FrequencyResolution).ToString();
            // Send the Data:
            serialPort.WriteLine(String.Format("<{0}|{1}>", FrequencyResolution, DutyCycleResolution));
        /// <summary>
        /// Serial Data Received Event.
        /// </summary>
        private void SerialPort_DataReceived(object sender, SerialDataReceivedEventArgs e)
            // Handle Data here...
            string data = ((SerialPort)sender).ReadExisting();
            Invoke(new Action(() => {
                richTextBox1.AppendText(data + Environment.NewLine);
        /// <summary>
        /// Connect Button Click Event.
        /// </summary>
            if (ConnectButton.Text == "Connect")
                // Configure Serial Properties:
                string Port = PortNameComboBox.SelectedItem.ToString();
                int Baud = Convert.ToInt32(BaudRateComboBox.SelectedItem.ToString());
                serialPort = new SerialPort(Port);
                BaudRate = Baud;
                DataBits = 8;
                Handshake = Handshake.None;
                serialPort.RtsEnable = true;
                // Attach Data Reveived Event:
                serialPort.DataReceived += SerialPort_DataReceived;
                // Open the Serial Port:
                serialPort.Open();
                // Change Button Text:
                ConnectButton.Text = "Disconnect";
                // Return:
                return;
            if (ConnectButton.Text == "Disconnect")
                // Close the Serial Port:
                serialPort.Close();
                serialPort.Dispose();
                ConnectButton.Text = "Connect";
                // Return:
                return;
Of course, this is just the  start, much more can be done, lots of stuff to catch errors, smoother handing of Connection and pretty it all up much nicer!
Also, the Prescalar needs to be handled! 1024 is good at low Frequency, but needs to be changed as the Resolution drops and vice versa.
Code in Zip format is attached below:
Chris posted this 02 July 2020
I have got the code to a point now, where it is a very useful project! Utilising a wide range of PWM: 0.001 - 8 MHz or so.
Here is the Arduino Code:
//   0,        //
//   8,        //
//   64,        //
//   256,        //
//   1024        //
long Prescaler = 8;
// Serial Connection Hook:        //
bool Hook = true;
  // Init Serial:
void ConfgureTimer(){///////////////////////////////////////////////////////////////////////////////
  // Mega = Pin 12
  // Pro Micro = Pin 10
  // Reset Timer One:
  TCCR1A = 0;
  TCCR1B = 0;
    case 1:
      TCCR1B |= (1 << CS10);
      break;
    case 8:
      TCCR1B |= (1 << CS11);
      break;
    case 64:
      TCCR1B |= (1 << CS11) | (1 << CS10);
      break;
    case 256:
      TCCR1B |= (1 << CS12);
      break;
    case 1024:
      TCCR1B |= (1 << CS12) | (1 << CS10);
      break;
    default:
      break;
// Set PWM Mode:        //
  TCCR1A |= (1 << WGM11);
  // Look for Serial Connection:
  if(Serial && Hook){
    // Connection Hook:
    Hook = false;
    // Print Welcome Message:
    Serial.println("Welcome to Serial PWM Controller by Chris Sykes!");
    // Check Data and Process: && data.endsWith(">") would be nice...
    // Flush Serial:
    Serial.flush();
  // Get Frequency: <15624|3906|1024> = 1Hz @ 25% Duty Cycle.
  long D = data.substring(data.indexOf('|') + 1, data.lastIndexOf('|')).toInt();
  Prescaler = data.substring(data.lastIndexOf('|') + 1, data.indexOf('>')).toInt();
  // Print Data:
  Serial.print("MCU set Frequency Register to: ");
  Serial.print(F);
  Serial.print(" or F: ");
  Serial.println(ConvertToFrequency(F));
  Serial.print("MCU set Duty Cycle Register to: ");
  Serial.println(D);
  Serial.print("MCU set Prescaler to: ");
  Serial.println(Prescaler);
  Serial.print("MCU Register Resolution: ");
  Serial.println(CalculateResolution(F));
  // Confgure Timer:
  ConfgureTimer();
  // Set the Prescaler:
  // Set PWM Mode:
  SetPWMMode();
  // Set Frequency:
  ICR1 = F;
  // Set Duty Cycle:
  OCR1B = D;
short ConvertToFrequency(long ocrx){////////////////////////////////////////////////////////////////
  return (short)(fclock / (Prescaler * (1 + ocrx)));
  return (short)(fclock / ((frequency * Prescaler) - 1));
double CalculateResolution(long ocrx){//////////////////////////////////////////////////////////////
Here is the Windows Forms Code:
    using System;
    #endregion
        #region Fields:
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
        /// <summary>
        /// <para>
        /// </para>
        /// </summary>
        #endregion
        #region Properties:
        /// <summary>
        /// The System Frequency.
        /// </summary>
        public double Frequency { get; set; } = 1.00;
        /// <summary>
        /// The System Duty Cycle.
        /// </summary>
        public double DutyCycle { get; set; } = 50.00;
        /// <summary>
        /// The Frequency Track Bar Multiplier.
        /// </summary>
        private int Multiplier { get; set; } = 1;
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
        public int BaudRate
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
        public int DataBits
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
        #endregion
        /// <summary>
        /// </summary>
        public Form1()
            // Form Init:
            // Add Port Names:
            // Add Port Names:
            // Attach Frequency TrackBar Value Changed Event Handler:
            this.FrequencyTrackBar.ValueChanged += new System.EventHandler(this.FrequencyTrackBar_ValueChanged);
        /// <summary>
        /// </summary>
            // Set Initial Frequency:
            FrequencyTextBox.Text = "1111.111";
            // Set Initial Duty Cycle:
            DutyCycleTextBox.Text = DutyCycle.ToString();
            // Set Duty Cycle Track Bar:
            DutyCycleTrackBar.Value = (int)(50.0 * 1000.00);
        /// <summary>
        /// </summary>
            return (int)(Convert.ToDouble(fclock) / (frequency * Convert.ToDouble(Prescaler)) - 1.0);
        /// <summary>
        /// </summary>
            return (short)(Convert.ToDouble(period) * (duty / 100.00));
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
            // Parse the Frequency Value:
            if (!double.TryParse(FrequencyTextBox.Text, out double Frequency))
                // Show Error:
                richTextBox1.AppendText("Input Error!" + Environment.NewLine);
                // Return:
                return;
            // Parse the Duty Cycle Value:
            if (!double.TryParse(DutyCycleTextBox.Text, out double DutyCycle))
                // Show Error:
                // Return:
                return;
            // Check Values:
            if (Frequency == 0.00 || DutyCycle == 0.00)
                // Show Error:
                richTextBox1.AppendText("Error!\r\nCant Divide by Zero!" + Environment.NewLine);
                // Return:
                return;
            // Check Values:
            if (Frequency < 0.00 || DutyCycle < 0.00)
                // Show Error:
                richTextBox1.AppendText("Error!\r\nOnly Positive Numbers can be used!" + Environment.NewLine);
                // Return:
                return;
            // Calculate Prescaler:
            Prescaler = CalculatePrescaler(Frequency);
            // Set Resolution:
            try
                // Send the Data:
                serialPort.WriteLine(String.Format("<{0}|{1}|{2}>", FrequencyResolution, DutyCycleResolution, Prescaler));
            catch
                // Show Error:
                richTextBox1.AppendText("Error!\r\nSerial is not Connected, please connect and try again!" + Environment.NewLine);
                // Return:
                return;
        /// <summary>
        /// Calculate the Prescaler.
        /// </summary>
        /// <param name="frequency"></param>
        /// <returns></returns>
        private int CalculatePrescaler(double frequency)
            if (frequency >= 300000.00)
                return 1;
            if (frequency <= 300000.00 && frequency >= 10000.00)
                return 8;
            if (frequency < 10000.00 && frequency >= 3000.00)
                return 64;
            if (frequency < 3000.00 && frequency >= 500.00)
                return 256;
            if (frequency < 500.00 && frequency >= 0.00)
                return 1024;
            return 0;
        /// <summary>
        /// </summary>
                richTextBox1.ScrollToCaret();
        /// <summary>
        /// </summary>
                // RichTextBox Clear:
                richTextBox1.Clear();
                BaudRate = Baud;
                DataBits = 8;
                // Gets or sets a value indicating whether the Request to Send (RTS) signal is enabled during serial communication.
                try
                    serialPort.Open();
                    // Return:
                    return;
                    // Show Error:
                    richTextBox1.AppendText(exc.Message + Environment.NewLine);
                    // Return:
                    return;
                serialPort.Close();
                // Return:
                return;
        /// <summary>
        /// The Frequency TrackBar Value Changed Event.
        /// </summary>
        private void FrequencyTrackBar_ValueChanged(object sender, EventArgs e)
            // Detach Frequency TrackBar Value Changed Event Handler:
            FrequencyTrackBar.ValueChanged -= new System.EventHandler(FrequencyTrackBar_ValueChanged);
            // Get TrackBar Frequency Value:
            int Value = (sender as TrackBar).Value;
            // Check Frequency Values:
            if (Value >= FrequencyTrackBar.Maximum)
                // Increment the Multiplier:
                Multiplier = Multiplier + 100;
                // Check for Ones Value:
                if (Multiplier == 101)
                    Multiplier = 100;
                    Frequency = 1.00;
                // Reset Track Bar after Value Underflow:
                FrequencyTrackBar.Value = FrequencyTrackBar.Minimum + 1;
            else
            if (Value <= FrequencyTrackBar.Minimum)
                // Decrement the Multiplier:
                Multiplier = Multiplier - 100;
                // Reset Multiplier:
                if (Multiplier <= 0)
                    Multiplier = 1;
                    Frequency = 0.001;
                // Check Zero Values:
                if (Frequency >= 1)
                    // Reset Track Bar after Value Overflow:
                    FrequencyTrackBar.Value = FrequencyTrackBar.Maximum - 1;
            // Reattach Frequency TrackBar Value Changed Event Handler:
            FrequencyTrackBar.ValueChanged += new System.EventHandler(FrequencyTrackBar_ValueChanged);
            // Set the Frequency:
            // Track Bar Max Value is: 100000 so / 1000 gives increments of 100, with 3 Decimal places: 100.123
            FrequencyTextBox.Text = ((Frequency * Convert.ToDouble(Multiplier)) + (Convert.ToDouble(Value) / 1000.0D)).ToString();
        /// <summary>
        /// The Duty Cycle TrackBar Value Changed Event.
        /// </summary>
        private void DutyCycleTrackBar_ValueChanged(object sender, EventArgs e)
            // Calculate Duty Cycle:
            DutyCycle = Math.Round(DutyCycleTrackBar.Value / 1000.00D, 3);
            // Set the Duty Cycle Text Box:
            this.DutyCycleTextBox.Text = DutyCycle.ToString();
        /// <summary>
        /// Frequency TextBox Leave Event.
        /// </summary>
        private void FrequencyTextBox_Leave(object sender, EventArgs e)
            // Get the Frequency:
            double.TryParse(FrequencyTextBox.Text, out double FrequencyOut);
            // Get Hundreds:
            int Hundreds = Convert.ToInt32(Math.Floor(FrequencyOut / 100));
            // Check Multiplier:
            if (Hundreds <= 0.00 && FrequencyOut < 100.00)
                // Set Multiplier:
                Multiplier = 1;
            else
                if (Hundreds <= 0.00 && FrequencyOut > 100.00)
                // Set Multiplier:
                Multiplier = 100 * 1;
            else
                // Set Multiplier:
                Multiplier = 100 * Hundreds;
            // Calculate the Frequency Divider, including the 3 Decimal places:
            double FrequencyDivider = Convert.ToInt32(FrequencyOut * 1000);
            // Set the Frequency TrackBar Value:
            if (FrequencyDivider < FrequencyTrackBar.Maximum)
                FrequencyTrackBar.Value = Convert.ToInt32(FrequencyDivider);
            else
                FrequencyTrackBar.Value = Convert.ToInt32(FrequencyDivider % FrequencyTrackBar.Maximum);
A Video:
Guys, this project has been very helpful in my work!
baerndorfer posted this 02 July 2020
this looks very interesting! i will try out thx a lot
meanwhile i try to move one of my arduino projects to the faster ESP32 board - the idea is to get a faster switching and more chanels because the esp32 should provide PWM functionality on mostly all pins.
regards from austria!
Hey Baerndorfer,
Yes exactly! 32 bit boards or at least registers are much faster and have a lot more resolution! I have also used the STM32F405 and this was awesome! Much more programming however. Setting GPIO Ports, then enabling Timers, its a lot different to program than the Arduino's.
Ourbobby posted this 03 August 2020
              The market for electronics and opportunities is getting younger!
Raspberry Pi For Kids (Updated) Mad BOOK NEW
https://www.ebay.com.au/itm/Raspberry-Pi-For-Kids-Updated-Mad-BOOK-NEW/352120949439?epid=237881065&hash=item51fc0b4abf:g:frQAAOSwu~ZZctQf
ourbobby.
Kritischer posted this 22 August 2020
It seems that being able to generate a precise PWM pulse with and duty cycle is going to be a key component in everything I try to do from here on out so this seems like a great place to put in some time to build a portable precision generator. I know this isn't the only way but being able to generate custom pulses is going to help me at work and will save time in the long run I can dedicate to OU projects.
I'm going to try to get this code to run on my 2560 Mega along with a rotary encoder to set pulse width and PRF, and I2C LCD as output. It needs to run using interrupts because I need the main loop() for other functions and it's much cleaner that way.
It's been 15 years since I've programmed a microcontroller and I'll tell you... it's hard work feeling this stupid for as long as I have.
I'm plagued with ambitions that outweigh my abilities and analysis paralysis is a symptom of the disease. Now that I've found this site I feel like I'm at home because at least I don't see people in this community actively DISCOURAGING people...
I went on a Arduino buying spree and now that I have everything I need I need to learn how to make small, incremental, features to work. Small wins are what keep me going and in the past I fail because I'm too ambitious too soon and that's a recipe for failure I've spent too many years repeating.
If I make progress it will all go here.
Chris posted this 22 August 2020
Hey Kritischer,
If I may, best advice I ever heard: "Little Steps for Little Feet" - Sir Richard Feynman
Bite off little chunks and before you know it, you will be very far advanced! I promise you! Ask others here. This code, with some modifications will work on the MEGA.
