Towards a more complete understanding of EM.
  • 4.4K Views
  • Last Post 26 April 2020
Vidura posted this 11 March 2019
Hello All
in this thread we try to give answers to the aspects of physics which can not or only partially explained with conventional EM, and textbook physics.
If you find this information useful please consider a donation , which will be used for supplies and equipment for more interesting research. You can do it HERE:
your support is really appreciated.
Regards Vidura.
Chris posted this 18 November 2019
Hey Vidura,
You are very wise and your experiments are first class!
For every Action there is an equal and opposite Reaction and for every Reaction there is an equal and opposite Counter-Reaction:
Action, Reaction and Counter-Reaction
If Science only accepted it has thrown away half of all Magnetics since at least Heavyside. We ignore the Reaction of the Secondary, because in a Symmetrical system, the Secondary Reaction must be Countered by the Primary Action, a very inefficient way to deal with Force or MMF.
Ref: P.23 Resonant_Energy_Systems_by_Don_Smith
Vidura, I believe I have more than explained in the Threads I have posted, the exact, very detailed explanations of what we see.
Vidura posted this 28 December 2019
Hey Friends
i always have been puzzling how the input waveform- voltage  in Graham Gundersons MIT was generated. lately I found in an experiment from Sergei Deyna the answer. here is the replication, with some additional testing:
here the schematic of the setup:
and a scopeshot :
Regards VIDURA.
Here I will share another experience, related to the topic of the resonant parallel LC circuit. It was a bit obvious that a similar effect could be achieved by manipulating the capacitor branch of the circuit.
Regards Vidura
chocolate blanco posted this 11 February 2020
bobinas bucking, efecto casimir al reves, hacia arriba, panqueque de tesla, la cosa es tener dielectrico y magnetico, cargando y descargandose, con giros iguales y opuestos al mismo tiempo, circuito resonante LC, la onda escalar de tesla, el orgon de reich, si somos el reflejo, entonces esa energia es la proyeccion, mosfet canal N y armonicos puros parece que es lo mejor, el universo resuena en armonicos puros, hay que ver cual melodia va mejor con nuestro dispositivo resonante, en los exp de chris y los demas tambien sucede esto, y se ve ese efecto en todos los dispositivos que abren el muro de bloch, la onda es 180° es auto cancelante, es como acostarse a dormir y tener un viaje astral, ese tipo de dimension se usa, atemporal, infinita, ahi la energia es infinita, aca el espacio, alla el tiempo, por eso la vibracion y todo lo demas, resistencia negativa, pulso radiante, lo magnetico es radiante y lo radiante es magnetico, todo es igual, abrazo
Chris posted this 11 February 2020
Hey Chocolate Blanco,
¡estás en lo correcto! Estoy de acuerdo con tus declaraciones!
  • chocolate blanco
chris, leyendo una revista de radio del 1900 sale lo que vos decis de la energia, que va del negativo al positivo, ahora se entiende ja, todo lo que hablamos sobre la energia ahora, se lee en las revistas de radio amateur, hablan de retro alimentacion negativa, bobinas auto oscilantes, de todo, abrazo
Mira esa patente de Henry T. Moray, bajando una señal y trabajando con bobinas bucking
y miren eso de Russell como la onda va subiendo y el pulso sube su frecuencia y se hace mas corto, mas rápido, menos espacio, mas tiempo, pienso en las pirámides
Mira esas bobinas de Russell, en conos, como las de Tesla, como en la patente de tesla, que habla que tiene que ser igual y contraria al mismo tiempo, bucking coils, miren esas bobinas de conos en serie y miren los armónicos de los números, todos con 3 6 9, 3 en la tierra, el pulso mas bajo, 9 en el aire el pulso mas alto, y en el medio el 6, el equilibrio de los dos, la naturaleza
¡sí, la vieja escuela estaba más adelantada que la actual en muchas áreas! Es una vergüenza!
Vidura posted this 20 April 2020
Hello Friends, I have made some experiments on magnetic interaction with spinning metals, and found that there might be inconsistencies in textbook physics. Here is the link of the video:
Some comments about the observed phenomenons: First the mild steel cylinder, there is no side drag on the magnet, because the magnetic field is bent in parallel to the moving cylinder cause of the high permeability of the material. In the virtually non magnetic stainless steel disc the side drag is present, and the magnetic field passed across it. Not surprising at all the produced strong drag on the magnet when  the Aluminium disc is spinning, but the behaviour of the magnetic field is not what we might have expected. If I remember correctly, textbook physics tells us that the cause of the drag is that the induced current in the metal produces a magnetic field which oppose the field of the magnet. But the compass is showing that this is not what's happening. We can't detect any reverse field, and the field deflection in the case of the aluminium disc is relatively small in relation to the strong force appearing on the magnet. I have tried to hold it in my hand, which is not recorded in the video. The drag is the strongest when the magnetic axis is in right angle to the metal, and diminishes gradually if inclined in any direction and disappeared completely when the axis is parallel to the disc surface. Also a repelling force away from the disc can be felt. In one occasion the magnet slipped of my hand and was smashed violently at the wall of my workshop, leaving a cm deep mould. I do not believe that such an acceleration in the short length of interaction with the disc would be possible by magnetic repulsion .
My tests have been inspired by experiments performed by David Lowrance which can be found here : http://www.resonantfractals.org/Magnetism/SpinningCylinder.htm
Soon a hypothesis will be presented regarding this effects,as I believe it is important for understanding what is going on in our coils also.
Vidura.
Chris posted this 20 April 2020
Hey Vidura and all,
Not sure I should post this? I will delete if you like?
You will note: The value of Conduction affects the Drag!
Magnetic Field distortion is well known. Of course Drag or Eddy Currents have been quite well explained here on this forum and in many Videos online.
One of our main Videos, I have shared on this forum for many years, is this one:
Recently, the following Video was shown in some of my Videos, as Clips:
Of course, the defining Drag effect was shown in the above video.
In the above Video, is is shown a few times that the Magnetic Field is distorted depending on Load an Rotor Drag.
It is great to see you have an expanded thinking on the Drag of the Magnetic Field!
  • This is not a Voltage effect!
  • This is a Current effect!
  • Current being the same thing as the Magnetic Field!
  • Current Creating the Magnetic Field!
  • No Current, no Magnetic Field!
If you look, then you can see, if you choose not to look, then one can not see, we must have an open mind and accept the actions and results we see in Experiment! The textbook is not your teacher, experiment is!
M.M.F to M.M.F, the Action Reaction Pairs are important, and it is important to understand properly! That's why I have said in the past, Lenz's Law is not technically right, there is a gaping hole in Electromagnetism! The Negative Sign in Faraday's Law if not enough to explain the Drag on the "Generator" Shaft alone! The Drag on the "Generator" Shaft is a Magnetic Field Effect, currently not explained by Science! Lenz's Law only Predicts the direction of the Voltage, none of the Equations predict the Current, except Ohms Law! Even then, Ohms Law does not predict the Direction of the Current!
"Generator" Shaft Drag, is an Effect, it is not the Cause, of the "Generation" of Electrical Energy! It comes after the fact! "Generator" Shaft Drag is a By Product of Energy "Generation"!
Thank You for sharing! It is good to see you have this important Understanding!
Vidura, I hope I have not offended you, by showing that what you are now seeing is something we have presented here for a long time!
I merely want others to see, that all this comes down to, is an Understanding!
Hey Chris, Of course there are involved some well known effects, no doubt that a current flows in the discs, which will produce an associated magnetic field, but the point I wanted to remark is the coupling between the different perpendicular fields. IMO the small deflection and polarity of the magnetic field is not consistent with the explanation of a counter magnetic field causing such a strong drag in the case of aluminium or copper. There is likely a third field component involved, which is perpendicular to the B and E. I will try to get more clarity on this. Regards Vidura
dale morgan posted this 20 April 2020
Hello,
Hey Vidura. I hope this is in the spirit you intend for this thread. Or at least close to it. The term 'radiant' seems to be a bump in the road.
It was Tesla... He coined the term 'radiant'. Bedini used the term 'radiant' because he was a solid fan of Tesla. Terminology.
The equation   dĀ/dT = -E.  E has a negative term as it is inbound instead of 'radiating' away. Bedini made the statement Once, as far as I've seen or read or heard, as to where the Radiant comes from. He said, "it comes in when the magnetic field collapses". A  straight forward statement with no ambiguity.
The easiest way to visualize this is by using a sponge as a stand in for the magnetic field. When a dry sponge, (man made type), is placed into water it expands. This is the magnetic field growing, expanding. Water is standing in for the Virtual Particle Flux, (Magnetic Vector Potentials à and Ā). After expanding as much as it's physically able, the sponge is full. Squeezing the sponge releases the water, the magnetic field collapsing. Easier to see if the sponge is removed from the water. So we want to see it of course but we need something to collect it. We use a bowl to keep it from dispersing into the ground, keeping it from being wasted. The bowl will stand in as an output coil.
Bedini used a magnet(s) to activate his coils, to 'expand' them. As we know his units worked solidly but didn't have the high output that is ultimately desired here, and everywhere actually. The thing he didn't do, as far as I know, was separate the two Magnetic Vector Potentials, Ã and Ā, from each other. Ā is magnitudes greater than Ã and is being missed by almost everyone. Paradigm's are strong. Especially when incorrect ones are shoved down our throats from the beginnings of our education.
So yeah, the term Radiant is misleading but as long as it means the same thing to everybody it really doesn't matter.
It's my opinion that everyone wants to build a unit that doesn't have the need of batteries,(maybe a 9 volt to fire it up). Less cost, no hydrogen gas, no dangerous acids for the children to come into contact with. No potential explosions should the batteries become shorted out. Not to mention the space they take up.
Have a good day everyone,
Dale
Hey Dale
Participation on the thread is welcome as always. Let's try to  keep things simple, simple experiments, and pay attention to small details.  We know that there are three vectors in three dimensionas space associated to EM phenomenon's., all ortogonal to each others. This is represented in Flemings Right and Left hand rule for motors or generators:
The three vectors are related to each other, but  each have different qualities. A force is applied to a generator shaft, a magnetic dipole established , resulting in a current flowing thru a conductive loop. Now this interactions are happening in an invisible medium, the Aether(or however you like to call it). We dont need to postulate such a thing as action at distance, it is thru the medium where the interactions are linked together. Non of the above shown fields or qualities are perceptible in steady state, in equilibrium. When this equilibrium is disturbed, a dipole is created, and the other two ortogonal vector forces are also affected. We know pretty much about the qualities of magnetism and electric currents, but the third force? It seems to be so obvious, that we leave it aside , not paying attention to it's qualities. We usually threat the electric and magnetic vectors as if they would exist  separated , only interacting between each other, and as if the involved third force would be something separate, something linear only altered from the first two forces. In a holistic view we should consider this force as a third field, inseparable linked to the others, with different qualities. Only a few researchers have payed attention to this aspect, and coined it the T-field , a torsion field or tempic field, which is neither electric nor magnetic.  It seems to be directly related to inertia, gravity and motion, and is always present in electromagnetic phenomenon's , although in different gradients. As we dont have the means to detect it directly, it is most commonly ignored by science, much the same as the Aether. I think it could be a principal component in the operation of motors, generators and other machines, and that the piezoelectric and the magnetostrictive effects are points of interaction between this forces. Well, have some food for thought's here. Of course this is for the moment hypothetic, could we elaborate a model where this three forces can be linked together as functions of standing waves in the Aether?
Your Feedback is apreceated.
Hey Vidura, excellent post and I agree 100%
I am extremely pleased that you have come to this understanding, and that you have come so far in such a short time! At least it appears from where I stand! Your recent experiments, on other things, have obviously given you great insight into the area of interest that we have looked at for so long.
I have tried to stay away from terms that may lead to scientific controversy as you know! Things like Radiant, I mean all energy Radiates, so I have made an effort to stand in the middle, so I don't sound like a Cook and people actually take what I am sharing seriously. This does not mean that there is not more there! I have said there are gaping holes in Electromagnetism and that we have a lot more to learn!
The fact that the Magnets falls many times slower in the Copper Tube is significant, it shows effects not explained by Science!
The following table will give you some idea on how the Elements will behave:
Ref: Elements Electrical Conductivity Reference Table
Starting at the bottom, we can see why Copper and Aluminium are much more affected by this phenomena! Conductivity, the phenomena we take for granted so often, over looking the basic properties and effects.
I am so pleased you can see the great importance of this, these effects, and how important observing the small effects in the most simple experiments are, that are normally ignored!
A proper Understanding is Key!
Chris posted this 21 April 2020
Some may not understand what it is, we are attempting to clarify, to further understand... This is super Important!
Conduction ( G )  is equivalent to the inverse of the Resistance: 1 / Resistance ( R ). Ohms Law gives us, I = V  / R, thus we can rewrite: I = V / ( 1 / G ). Current I is the Key, Current is directly related to the Conduction! As we have shown.
Is there another, new, unknown Field, the Torsion Field existing here? What is the definition of the Torsion Field?
A torsion field is a feature of pseudoscientific proposals that the quantum spin of particles can be used to cause emanations to carry information through vacuum orders of magnitude faster than the speed of light. This theory is the basis of a number of unfounded claims and scams.
Ref: Wikipedia - Torsion field (pseudoscience)
You may now see why I do not talk about these things?
Whats the difference between the Current and the Torsion Field? Is there any difference? Or are we looking at the same thing from another point of view? E and B are the angles of observation of the same phenomena, its a convenience to view each thing with difference, but E and B can be one and the same things.
What if, honestly, what if the Current we see as standard well known Science, is simply the Path of Current, Charged Particles moving in a Magnetic Field:
Look, I really don't want to get into pseudo science that is viewed upon as fake nonsense, I only want others to think of things a little more broadly than we have in the past. It only makes sense to open our minds a little more so we can accept new things currently undiscovered in Science.
The Current we see, regardless of its real vs speculated path, is critical to making these machines work. With no Current Flows, these machines do not work! The Machines must be loaded, therefore Current Flows, therefore the Interactions of the Currents, thus the Magnetic Fields, make these machines work as we have laid out, heading towards a decade now.
The Current Flows, and the Change of Currents in these Machines are very Important Phenomena to Understand!
All of this has been covered here, on my forum, before. All here following, paying attention, will already understand all this already!
dale morgan posted this 21 April 2020
Hello All,
I really don't want to be negative here. However incorrect graphics muddy the waters.
Right hand for generators, Left hand for motors. The difference between them is whether the conductor is receiving the force, (generator), or the conductor is supplying the force, (motor). From Wikipedia of course. The problem is that once a graphic gets into your perception it guides your thoughts. Basically these rules were for determining the direction a motor would turn. We have to remember that all motors were DC until Tesla came along... The left and right hand rules made it easy to correctly hook up the motor to the power supply so it would rotate in the desired direction right off.
Force is not a field it is an effect of fields. There are no piezoelectric effects in a motor or generator. Unless of course you add a piezoelectric device to the shaft so as to know the RPM's of said motor. A Hall sensor is more effective.
Turning the shaft of a generator does not create a dipole. The first generators were called magneto's. Magnets make up the stator and a coil(s) are the rotor. It also works in the opposite arrangement but why spin a heavy mass of magnets when it's easier to spin the coil(s)? So the dipole already exists in the generator whether the shaft is being turned or not. Resistance to the shaft is merely the Lenz Law doing it's part. The Lenz effect is the same thing that is happening when the magnet is dropped through the copper sleeve as Chris has demonstrated for years. (It's still fun to watch that no matter how many times I see it.) The very first generator output AC but was rectified to match up with batteries which until then was the primary source of electricity. The Egyptian's had batteries so the paradigm had centuries to set in.
Sometime around 1964 magnetos were phased out and replaced by alternators. In this case the dipole is supplied by the field coils and is powered by a battery of course. Field meaning magnetic field since the magnet's had been removed. (The powers that be must have been afraid people would generate their own electricity!) When using a magneto there is no need for a battery. Give your vehicle a push start and it will continue to run until you run out of gas. Over the past few years magnets have been re-introduced to starter motors on cars. More reliable and smaller. Alternators are rectified to output DC to match up with the battery. Dipoles are either magnets or electromagnets. Each has a positive and negative end and AC will not make a dipole as the orientation is constantly being changed.
While I'm at it lets take a look at electrons travelling down the wire. They don't move as has been taught for years. Should the electrons actually move down the wire it would decompose as the atom would be de-stabilized and the friction would melt the substance almost instantly. It would cease to be copper or whatever element was being used as the conductor.
This part of a bigger graphic from Bearden which didn't want to upload or I just messed it up. Either way here is the link:
http://cheniere.org/images/EMfndns1/sm%20CktColleff.jpg
What goes on is that the Drude electrons move towards the surface of the conductor after the conductor has been potentialized. Charge behaves like a fluid, (This is what Tesla believed and so do I), and skims over the surface of the conductor. The Drude electrons basically act like ball bearings to aide the flow of the charge, give it a smooth path. If anyone has seen the Corona Effect demonstrated on transmission lines you saw the over potentialization of a conductor. A capacitor can only hold so much charge and overvoltage will make it explode as we all have seen I bet. Pressure blows it up like a water balloon. Charge occupies physical space and has volume.
Current cannot flow until the Drude electrons have moved close to the surface. If we really want to understand what is happening we have to dump the old paradigms. Using CEM and the Standard Model to try to describe what it does not allow within those models is getting us nowhere.
I read a tremendous amount of technical papers and I know how easy it is to accidentally merge different topics mentally. I constantly re-check myself to keep the picture clear. Much of the data is so similar, small differences at times make a large change to results. I am very sorry to those that may have been offended. That is not my wish. Just clear understanding is my goal and I have learned to not dance around the point and to just get to it. Most of my information is from, Bearden, Bedini, Sweet, Whittaker and Evans plus some others along the way.
So I'm done here until I have my stuff unpacked and set up. As I've said previously, humans are visual beings.
Have a glorious day All,
Dale
Edit: A generator only separates the charge collected by the dipole.
  • YoElMiCrO
Vidura posted this 21 April 2020
Hey Friends, Nice discussion, At this stage I would like to clarify a few things: I am well aware about the concepts of Induction and Lenz law. And for the moment I have presented this as hypothetical , this means I am not sure that the presented Ideas are correct, this will need more experiments to be performed. Regarding the observed effects, I do believe that a current is induced in the moving metal, but I do not believe that this is sufficient to produce the strong side drag on the magnet. If you hold the magnet in your hand you will feel two forces, one weaker repelling from the moving metal, and another, by orders stronger parallel to the surface. The former one is likely produced by the mentioned Lenz law effect. But for the latter this explanation is not consistent, as there should be observable a reversal magnetic polarity on the opposite side of the metal disc. @Chris, thanks for the table of conductivity, I was of course thinking about if the effect is directly related to conductivity, more tests will be needed to proof or disprove. I will see if I can get some more samples of other metals. @ Dale: thanks for the completed grafics. Regarding to term of field: These terms are used by convention. I am convinced that the Aether or space is the medium in which all forms of energy, forces and vibrations propagate, but it is likely labeled as pseudoscience in Wikipedia, so I will try to stick to the terms of convention. The magnetostrictive and piezoelectric effect could be present in all kinds of matter, in different graduands. Some experiments of Sergei Deyna points towards it, also one performed by Atti shows how a mechanical vibration on a ferrite rod induced a current in an attached coil. The torque on the shaft of the generator do not create a dipole, but is likely produced by one, as high pressure on one side of a piston , or the plates of s turbine, and low pressure on the other side. A mechanical dipole in that case, most kinds of mechanical force is caused by pressure (difference). In the case of gravity we have to be sincere that we know very little about, so it is postulated as field. Thank you all for sharing your thoughts. Vidura.
Vidura, Dale, excellent discussion! I agree.
I hope I have not offended anyone! Offending anyone was not my intention, I more so wanted to explain why I do some of the things I do, I have to be so careful, I really don't want to become the laughing stock, that's why I have tried so hard to stay away from pseudo science terms.
This is a very serious topic and we have discovered holes in this topic, not addressed anywhere in Science, thus the discussion.
Best wishes, and thank you for your participation on this topic!
  • YoElMiCrO
Zanzal posted this 22 April 2020
Good stuff Vidura. You've given me much to think about the last day or so. I think it is worth investigating why the steel disc doesn't generate any apparent deflection. It is worth challenging the idea that the higher resistance of steel is enough to explain the effect. Looking forward to seeing more.
Chris posted this 22 April 2020
Zanzal, Vidura, Dale and others following,
For sure! I agree!
Plotting the Conduction vs the Deflection Measured is well worth a full set of experiments. 1 / Resistance per CM, vs the Deflection, say the Magnet attached to a weight meter, is worth investigating!
I am more than happy to be wrong! It would be great to see experiments proving my experiments wrong for sure! Lets challenge each other to make our way to the Truth!
Atti posted this 22 April 2020
If you allow me, I would add a few thoughts to it. Related to Vidurra's work (video).
I'm not saying, I'd rather show. The Neodymium magnet induced eddy current or induction.
The copper tube experiment does not surprise anyone. Acquaintance. However, in a lengthwise section, I haven't seen a presentation anywhere. It is also used in measurement techniques.
I thought I'd do it. As you can see, there is a slowdown. But not to the extent. Understandable.
If I wind a copper wire on a plastic pipe and short-circuit the wire, there is not as much deceleration as with the copper pipe alone. So I divide the tube not only lengthwise but also crosswise. We can understand it that way. However, it cannot induce such a current because the number of turns is low. (although the parameters are the same as the copper pipe. Copper pipe thickness 0.8mm length 300mm diameter 22mm. Winding wire diameter 1.2mm.)
I = V / R
If I use more speeds, the deceleration of the magnet is already understandable.
To connect different fields.
Voltage change due to current induction. That is, the more current, the more induced voltage. But only if the fields are properly interconnected. In the ferrite rod experiment, it can be seen (or audible) that the Led does not light up at all frequencies.
It can also be removed in this arrangement. When the two fields meet, the small light bulb lights up. Yet in the basic case it should not be. The "making music" of the sound is also interesting.
Vidura posted this 22 April 2020
Good experiment Atti, The slotted copper pipe shows the drag where there should not be any eddy currents according to theory. Thanks for your contribution. Vidura.
In my opinion, the Cut in the tube shows what we should see:
Eddy current
Eddy currents are loops of electrical current induced within conductors by a changing magnetic field in the conductor according to Faraday's law of induction. Eddy currents flow in closed loops within conductors, in planes perpendicular to the magnetic field.
The Magnets falls faster, because the area where Eddy Currents can form are reduced. The Area around the Cut, the Currents can not form, but where there is no cut they can still form, so we have some Eddy Currents, but not as much as we had with no Cut.
Eddy Currents are a Localised Phenomena, forming in Circles around the Flux Lines, when able.
The Definition of Eddy:
a circular movement of water causing a small whirlpool.
I guess it depends on who one listens to and what definition that person has interpreted, as to what the end result should be.
The Valence Band, specifically, the Conduction Band gives us the answers we need to solve this problem.
Hey Chris, This is certainly an aspect to be considered, the thing which is most puzzling to me , how do the repelling force away from the disc or cylinder fit into this theory, and why we can't detect the inverse magnetic polarity on the other side of the spinning disc? It might well be that the Eddy's pattern is actually there, but it seems to be relatively week compared with the field of the magnet. My Aluminium disc was spinning at about 2500RPM when I could not sustain the magnet with my hand, with such a force, if produced by contrary magnetic fields those should be in the same magnitude than the field of the magnet and clearly detectable on the other side of the disc. Of course it would be great to have more results testing some other metals and make exact measurements of the appearing forces, and compare to conductivity and atomic weight etc. Vidura.
Chris posted this 23 April 2020
Hey Vidura,
First, I would like to say, we should not rule anything out! So I believe in your investigation! Nothing should be over looked!
As I understand it, the Conduction Band is a very narrow region where the 'Fermi energy', the energy of the highest occupied state at absolute zero temperature, lies within an energy band. This is the Conduction Band, which is specifically related to Conduction and also Resistance.
This means, we can change the properties of the material, the Conductor, with an External magnetic Field or Fields. It is true, we take Conduction for granted! Don't forget, we have many different types of Magnetic Properties:
In an external magnetic field, the potential energy of those states whose magnetic moments are aligned with the field is reduced by the magnetic interaction energy, and those aligned against the field have a correspondingly higher potential energy. Therefore, the parallel aligned states are nearer the bottom edge of the band. This means that only magnetic moments within a range of kBT either side of EF can flip their orientation according to the magnetic field.
Floyd Sweet said:
Of all the known fields- electric, magnetic, gravitational and motional E-field, the only ones incapable of being shielded are the induced motional E-field and the gravitational field. The nature of the motionally induced electric field is quite unique; in order to understand it more fully we must start by parting with a few misleading paradigms. When magnetic flux is moved perpendicularly across a conductor an electromotive force (E.M.F) is electromagnetically induced "within" the conductor. "Within" is an artefact of the commonly used analogy comparing the flow of electric current within a wire to the flow of water within a pipe. This is a most misleading model theoretically. The true phenomenon taking place has little been thought of as involving the production of a spatially distributed electric field.
Conductor "Magnetisation" or the Electromagnetic Field emanation from a Conductor depends on the Parallel Aligned States of the Electrons. Each Electron having its own Magnetic Moment. Unfortunately, when we see Currents, this has the same properties, we see the same things occur. Parallel or Anti-Parallel Alignments.
The Electromagnetic Field emanation from a Conductor could be seen as the Shielding, Floyd Sweet was talking about.
Yes, I believe Star Trek Shields are possible, and I believe we already can make Shields today!
EDIT: I should point out, exactly what is occurring in the Metal, is the requirement for Electromagnetic Induction: This very Change in Alignment, Parallel or Anti-Parallel is the Magnetic Field Drag we observe. This can be the Source for Electromagnetic Induction after the initial creation, conventionally this is completely Ignored and your Input fights this M.M.F throughout the Cycle. What we see in the following image is directly related:
   Ref: The Lorentz Force
It may be worth reading up a little about Valance Bands if you wish to learn more about Conduction:
In solid-state physics, the valence band and conduction band are the bands closest to the Fermi level and thus determine the electrical conductivity of the solid. In non-metals, the valence band is the highest range of electron energies in which electrons are normally present at absolute zero temperature, while the conduction band is the lowest range of vacant electronic states. On a graph of the electronic band structure of a material, the valence band is located below the Fermi level, while the conduction band is located above it.
The distinction between the valence and conduction bands is meaningless in metals, because conduction occurs in one or more partially filled bands that take on the properties of both the valence and conduction bands.
Zanzal posted this 23 April 2020
The opposing field can only be as strong as the amount of charge moved through the field. Thinking about your problem has really helped me understand the implications of the Lorentz force equation and how it describes the forces the electrons experience in your experiment. Its still unclear why the steel didn't seem to produce the same effect. My only suggestion might be to try positioning the compass and the magnets a little further away so the magnet doesn't dominate so much. That or double the speed of the disc...
Vidura posted this 24 April 2020
Hello All.
Some updates as I did some more tests with the rotating discs. I made one more of copper and one of pure zinc metal. In the latter the effect is much weaker, similar to the stainless steel. Copper seems to be strongest, although not too much difference with the aluminium. I didn't record a video as I performed the tests with both hands, scanning the magnetic field with a compass on the other side of the disc. So I made this graphics to illustrate the observations:
This configuration produces the strongest sidedrag
In config 3 when the magnetic axis is exactly aligned to the center and parallel to the disc surface the side drag disappears , while the repelling force is still present, a little bit weaker.
Scanning the field with a compass on the oposite side of the disc showed the usual patterns as if the disc would not be present. I tried different distance of magnet and of the compass, but no alteration could be detected. The discs are 200mm diameter and 1mm copper and zinc  1.5mm aluminium in thickness. I would like to make some measurements of the resulting forces, but I dont have an appropriated scale available.
Regards VIDURA.
Chris posted this 24 April 2020
Hey Vidura,
I had a similar idea.
Using a Drill, Circular Plates with a hole in the middle, a Tachometer, make sure the drill is doing the same RPM's spinning the Disks, put a Magnet on a Weight Meter, hang from a table, measure the weight of the Magnet, then of the drag, subtract the weight from the drag, then one has the drag on the Magnet.
Another problem is getting disks cut the same size and of lots of different types of Metals.
Of course, the magnet would need to stay on the same circumference to make this work.
Its a reasonable detailed set of experiments! I would be happy to donate to help out financially for this if you want?
Vidura posted this 25 April 2020
Yes i thought about some possible test setups also, I think a lever arm with the magnet attached would be the most convenient, ti sustain it in the required position and angle, and measuring the force appearing on the lever. The difficulty at the moment is the delay of delivering of orders, as nearly the entire population is locked in their homes, roads are blocked and all this stuff. Smells a bit like a worldwide government strike all this, sorry the off topicwink. But I will place an order for a tachometer and a hook scale, for the moment i have 6 different metals to test, although not all the same thickness, but it could be compensated with math's.
Another thing, thinking in math's. I would like to calculate approximately how much current would have to flow in eddy currents in the part of the disc, which is exposed to the magnet, to aproximate the field strength of the neomagnet? I think with the law of Biot-Savart it could be calculated, although it is a bit complex(at least for me), as in a solid conductive plate two vortex shaped currents are supposed to be induced. But an approximation would give a hint already I believe. Hey Yoelmicro, if you could give a helping hand with the correct formula , would be much appreciated. Chris, thank you very much for offering a donation, but you have a lot of obligations already to keep the Forum running, It would be much better if others, who might have more than they need would contribute in that way. Thanks' a lot!
Vidura.
Chris posted this 25 April 2020
Hey Vidura,
We, this forum, we have something that is no where else! I do wish more would join in and share! Those not sharing, I wish would help all here out more, $10.00 is not a lot, but if every second reader donated, a lot more work could be on going!
I have donated $10.00.
Our forum is unique! We have zero Trolling, all here are safe, and every single page here has useful accurate information!
Please, if your'e reading this, please consider a small Donation to Help Vidura out in this very important set of Experiments.
The Math aspect is important, many wont understand the math aspect, I was one that used to over look the Math, because I didn't understand it. As time has gone on, I am grasping more of it. Others will also.
   Chris Sykes
Fighter posted this 25 April 2020
@Vidura, I have this video in my personal collection. You may want to see this, I think the effects you're seeing in your experiments are called "the magnetic river" by professor Laithwaite:
Edit: I've also donated $10 for helping with the experiments.
Vidura posted this 26 April 2020
Hey Friends, Thanks so much for your donations, I have ordered a tachometer and a digital scale to perform a comparison with measurement of the latest experiments. Hopefully it will bring some more insight what exactly is going on. Best wishes, Vidura.
