Current Observation and Measurement
  • 906 Views
  • Last Post 17 May 2018
Chris posted this 12 April 2018
I know most of you already know, but this post is to help brings others up to speed:
See(Increasing the Rate of Kinetic Energy)
Ohms Law, for electronics, takes Resistance (Ohms), Voltage (Volts), Current (Amps) and Power (watts) and with a set of equations gives a very accurate prediction of each and every quantity, only requiring two input quantity's.
A Current Sensing Resistor (CSR) uses the equation: Current ( I ) = Voltage ( V ) / Resistance ( R
Because the Voltage Drop over a Resistance can be measured very accurately, and using a small resistance so as to not impede the Circuit much, we can get a very good idea of the Current in the Circuit. In the following example, we need to keep in mind the Units, using milliOhms requires a correction as will be shown.
Using Ohms Law, the Current through a 1 Ohm Resistor when 1 Volt is applied across it, is 1 Ampere: I = V / R = 1 / 1 = 1
Ref: http://www.ohmslawcalculator.com/ohms-law-calculator
 In the above example, the Values chosen are:
  • Resistance = 1.1 Ohms
  • Voltage = 1 Volt
So, the equation, again: I = V / R = 1 / 1.1 = 0.90909
In the above simulation we get: 09098
Note: We are measuring a Voltage Drop across a Resistor that is 1/10th of an Ohm! We need to account for this because this resistor is 1/10th of of an Ohm, for the Total Circuit Resistance.
A correction factor of 10 must be applied! We have an easy option however! Setting the Oscilloscope Probe to 10x can automatically account for this correction, giving us:
09098 x 10 = 0.9098
Which is correct up to three decimal places, where the simulation perhaps accounting for trace resistance, 0.0008 of an Amp difference. Also rounding may play a part in this figure.
Calculated Resistance: 1.09914 for the given Current: 0.9098
Measuring, or observing Current is really important! Its a key step in understanding what Coils are doing, an observing how they interact together! We have learnt this in The Mr Preva Experiment!
I have covered some of this before, but, the measurement Blocks I have built, are very valuable little devices!
My Metal Strip Through Hole Current Sensing Resistors are 0.1 Ohms ±1% and have very little Inductance.
The following video is very good, but has a lot of silliness, I don't recommend using high Voltage or Hi Current, please be careful!
Also, watch wire length, no matter weather it is "Non-Inductive" it can still create problems!
  • electrondiger
Jagau posted this 12 April 2018
How to learn electronics with a smile.
Very relaxing video!
Jack
Chris posted this 17 May 2018
For all that are new and wish to learn more, when I build my measurement blocks, I built three, two of the ones above and one with a dual Current Sensing Resistors on it.
This is what I used in my Thread: Some Coils Buck and some Coils DONT
The basic Circuit:
You can see, this is only for Current, I am not taking any voltage measurement here.
I hope this helps some!
Perhaps a Bank Transfer?
  • Bank: Bank of Queensland
  • Name: Christopher R Sykes
  • BSB: 124-001
  • Account: 21580359
