HomeBrew - new build started
  • 622 Views
  • Last Post 26 January 2024
HomeBrew posted this 24 January 2024
Hello all. Brand new here, but have a build started. Will post my results soon.
My initial concept of what the coils are doing.
Chris posted this 24 January 2024
Hello and Welcome Homebrew,
Please see: Help with using the Forum.
That will help you adding images and video to your posts.
  • Tinker
KnightOwl posted this 24 January 2024
I think we might have to host the image elsewhere and link to it. I don't think the forum supports animated gifs. I'm reading through tutorial now.
yes, hosting it offsite is the way to do it. Animation is working.  Did you get your core yet?
Hey KnightOwl,
Thanks, a good graphic, nice and a good way to visualize the Coils!
If I may, the sequence is not correct, can you follow this sequence: Input Coil On, POCOne On, POCTwo On, Input Coil off, and then after a bit of time, POCOne and Two Off. You see this here:
Which is Asymmetrical Regauging:
Input Coil is typically around 10% Duty Cycle, Partnered Output Coils are 100% Duty Cycle, although there is a slight delay in Conduction from POCOne to POCTwo, because POCOne "" POCTwo's Voltage.
Please Note: To upload an animated gif, please use our File Manager, make an Images Folder/Directory, and upload the animated gif into your Images directory, then from there it is very easy to add the gif to the page! This is all covered in the link: Help with using the Forum and also here: Aboveunity's File Manager. I have a video in that that thread showing you how to add Animated Gif's.
Our File Manager is a fantastic tool, I am very surprised its not used more often! It is a very High Tech utility, with tons of very cool functions and uses!
The Timing of this machine s very important, because the timing defines the operation and the success! I would be very grateful if you are able to get the Gif showing this timing like I have explained, that'd be awesome!
KnightOwl posted this 25 January 2024
The graphic actually belongs to HomeBrew user, another guy from Utah who lives just an hour or so from me.  He is helping me with my own project and understands this stuff way better than I do.  I'm sure he can get the timing right.  He whipped out the graphic to help me visualize what is happening with the coils. Even though it is not right as you said, just seeing it helped it click in my brain.
I tried uploading the graphic after HomeBrew had issues.  I'm a few weeks ahead of him on watching and reading your videos and posts, but he is picking it up way faster than I am.  He gets off work in a bit and can probably adjust the timing on the image if he is free tonight.  I'm recently retired and pretty excited about working on this project, but my electronic skills are basic. My career was in teaching IT and programming.
To make sure I identify the coils correctly, in the graphic the green coil is input, and orange coil  you are referring to as POCone  with the red coil as POCtwo right?
On another note, I sent you an email a few days ago to see if you recognized a motor gadget a fellow was demonstrating a number of years back that I think possibly worked on the same or similar principle. He said the magnets were the energy source and the bucking coils were pumping the magnets.  Hoping you might recognize the device or know the individual. He was also from Utah.  If any other Utah people are on the forum, I'd love to get together and work on this aboveunity device.  It seems a lot more practical and accessible than machining custom iron parts for a motor.
HomeBrew posted this 25 January 2024
Hey George, Yeah, I actually got 2 glass cores out of China. It was better to buy two for the shipping discount.  If you want one I've got an extra.  I went with the AMC400, so its a bit bigger than most cores people are using on here, but it should still work and we can go with bigger gauge wire.  I've got a roll of 18 and 20 awg that should work.
Chris,
Pleasure to meet you and thank you for putting all this information out here.  I'll work on getting the timing right on the graphic.
That shouldn't be a problem.  10% duty for input.  100% for POC 1 & 2.  DO POC1 and 2 come on simultaneously, or should I put a slight delay between them?
I have a cheap ferrite core I ordered off Amazon for $16.  I'll give that a try first.
https://www.amazon.com/dp/B07PWXYR5F?psc=1&ref=ppx_yo2ov_dt_b_product_details
Coil Sequence Order
Hey Chris, is this closer?
Chris posted this 26 January 2024
Yes Sir, that's perfect!
This is how the coils should work.
