Polarity of a Generated E.M.F.
  • 356 Views
  • Last Post 07 December 2023
Chris posted this 06 December 2023
This thread is to clear up a debate on Polarity of a Generated E.M.F.
Over the years, I have seen some Researchers confused with the Polarity of the E.M.F Generated. Some Researchers try to tell you that the Magnetic Fields are Aiding each Other, when the truth is, that's totally Wrong! Its very important, that we get this right in our minds, because becoming confused over such a simple thing is definitely the difference between Success and Failure! Perhaps some use this as a new Tactic, to try to confuse others, and thus stop Progress in the Community? I don't know.
I honestly thought the Community was a lot further ahead and understood this in much better detail than we see sometimes. I have covered much of this many times in different places here on this forum!
Those before us and Electromagnetic Induction
It is very important that you know Electromagnetic Induction in Detail! Floyd Sweet and many others had an excellent background and knowledge of Electromagnetic Induction. For example, one of the greats, Clemente Figuera said:
Floyd Sweet mentions Faradays Law about five times in his writings!
Plain and simple, all of these people before us, had an excellent knowledge of Electromagnetic Induction, remembering it was big in those days, it was all the rage, as we were having patent after patent being issued for all sorts of Electromagnetic Inventions. Inventions we all take for granted today!
The E.M.F Generated, in Units of Volts, or some say a Voltage, is always the result of Faradays Law and Lenz's Law combined, thus we get:
E.M.FVolts = -N δΦB / δt
  • E.M.F is the Potential Charge Difference in units of Volts.
  • The Negative Sign ( - ) represents Lenz's Law and shows the Bucking Nature of the E.M.F.
  • Delta ( δ ) is the Change: Max - Min = Delta, the total Change.
  • Phi ( Φ ) is the Magnetic Field Density B, the Window of total Magnetic Flux.
  • Time t is the total Time Difference. End time - Start Time in seconds.
This Image is one of the best I have found to explain the Lenz's Law Negative Sign
Electromagnetic Induction in a Transformer
In an AC Voltage Source, supplying an AC Voltage across an Input Coil, we have four phases or Quadrants we must consider, however, we only have two Phases in the AC Source.
From a net Zero Field, there is only ever two situations that a Coil is going to experience.
  1. A North Pole changing in Magnitude from BMin to BMax and then back to BMin again.
  2. A South Pole changing in Magnitude from BMin to BMax and then back to BMin again.
This Change in Magnetic Field B, from BMin to BMax and then back to BMin again, constitutes one Half Cycle, a DC Half Cycle:
It does not take much to see, that the Two situations above, gives us Four Quadrants we need to think about:
  • The Red Electric represents the Coil being supplied with a Current until the Magnetic Field builds to BMax, from BMin.
  • The Green Magnetic represents the Coil suppling a Current until the Magnetic Field moves from BMax, to BMin.
NOTE: For this Half Wave DC Cycle, a Diode does NOT change Polarity during this portion of the Cycle, its a specific Polarity and the Diode will only ever conduct in One Polarity for this specific Half Wave!
Also NOTE: The Red Electric Portion is always in a Bucking Form between Primary and Secondary Coils! Always and there is nothing you can do to change this! This Opposition is why the Magnet falls so slowly:
Magnetic Field Opposition
Bucking Magnetic Fields are the norm! We see every time we Generate an E.M.F, we see the Secondary Coil Oppose the Primary Coil! There is, again, two Phases for each Half Cycle, a Magnetisation Phase, and a Demagnetisation Phase.
The following Simulations are from the MIT Courseware, in Electrodynamics. It is very easy to prove this sim correct on the bench!
Primary is on the Bottom Coil, Secondary is on the Top Coil, thus the Conventional Transformer Modeling Standard.
The Magnetisation Phase:
The De-Magnetisation Phase:
Please Note: Every single Coil starts off with a Magnetic Field at Earths Magnetic Field Density, sometimes very small, about 0.5 of a Gauss. So there is no Negative, or a net Equilibrium value of around 0.5 Gauss.
Always the Currents flow in Opposite Directions and always the Voltages are Generated in the Negative of the Source, in a Bucking Nature.
Current Flow
We have two Rules to work out what the Current Flow will be, because in the old days, we assumed Current flowed from Positive to Negative, however, as time went on, we realised we had it wrong, and we corrected the Rules, and swapped hands.
We used to use what's called the Right Hand Grip Rule:
Ref: Transformer Phasing - The Dot Notation
You can see, we have Magnetic Field Opposition occurring here, in a Transformer.
Today we know we have a Current Flow from Negative to Positive, so working out how a Current Flows now requires the Left Hand Grip Rule, using the Left Hand you can grip the Coil and
I use Conventional Current, because everyone knows what it is, and some dorks try to catch me out and try to correct me, which is petty and pathetic, because they should know already, I am referring to Conventional Current. However, the same idea applies, take note of the Voltage Polarity and apply what rule you want, to work out which way the current will flow.
NOTE: A Generated Voltage is in the opposite direction compared to an applied Voltage, so please remember this!
Exceptions
In a Non-Standard situation, we can see what appears to be Exceptions to the above situation. The Mr Preva Experiment does appear as an Exception, but you must remember, once understood, it does follow this standard! This is because, at Resonance, the Coils do actually Generate more E.M.F and thus the Current flows as a result of the Generated E.M.F.
Making proper and accurate observations as to what the Source of the Generated E.M.F is is important and if you want to be taken seriously, a must!
We are dealing with Coils that have a difference in Polarity, and an E.M.F is Generated on all Coils, but the Source of the E.M.F is the key to understanding the Machine! Electromagnetic Induction can and does occur in more than one direction in the same machine! Many will not like that statement, but it is true!
Adam posted this 06 December 2023
I agree with you 100% !
When you look at the magnet moving toward the coil, the coil generates a magnetic field apposing that field N – N or bucking or trying to push away. Just as my drawing shows.
When the magnet moves away from the coil, the coil generates a magnetic field that attracts the magnet trying to hold it from moving away. Or attracting the magnet trying to prevent it from leaving. Just as my drawing shows.
When the magnet and coil are attracting  (when the magnet is moving away) they are in the same polarity meaning Norths on the left side of both and South on the right side of both.
That means to me in the center between the coil and the magnet, you have a south pole on the coil and a North pole on the magnet. Attracting each other.
Just like in a generator when the shaft is turning or trying to pull the magnet away from the coil.
So what I am saying is that any time the magnet is moving away from a coil or the primary is turning OFF the fields are in attraction mode or in my mind not bucking or pushing away from each other. That is why I say they are not bucking in this instance.
So I just state it in another way “that the coil is trying to holding the field on” when the primary turns off the coil attract the magnet which in my mind is not bucking it’s attracting.
When the magnet is moving toward the coil this is the same as the primary turning ON,
and when the magnet is moving away from the coil is the same as the primary turning OFF.
Please let me know if you feel anything I am stating in this post is not correct.
I think we are actually on the same page, my wording is just slightly different.
I agree 100%
Thanks.
Adam
Hi Adam,
A Driven Primary Coil, or Input Coil and a Secondary Coil does not act the same as a "Generator" with a Permanent Magnets Flux sweeping past the Coil. The Permanent Magnet has a stationary Flux, that does not change over time. The Velocity of the Magnet is used, and the Flux Cuts the Coil and also has a Transformer Induction Component. The Permanent Magnet has static Flux Lines!
It may be worth reading George I. Cohn - Electromagnetic Induction.
In a "Generator" the Stator Coil moves through a full sinusoidal wave as the Permanent Magnet moved in and then back out again, past the Stator Coil.
In a Transformer, a Diode blocks one half of the AC Waveform, as it does in a Generator, like I have shown you:
A Diode on the Output Coil is not going to make the Input Coil and Output Coil add in Fluxes! It does not work that way.
A Diode has to have 0.5 of a volt applied across it to conduct in one polarity only. If the Voltage is applied in the other polarity, then it wont conduct. The diode can not change its Conduction State if the applied voltage is not also changed, and it can not change half way through a half Cycle.
Tinman's choice to publish this video:
Four years after being a part of my Partnered Output Coils Thread:
Make the claims he did, and knowing this was after the RT V 3.0:
Tinman gave the whole world the answers I had given, we agreed on every single scientific point, and the rest of the world fell asleep, deeper and deeper into their slumber.
Any and all normal people, would have jumped at this opportunity! The Dumb Bastards that were present at the time, they are nothing but Fake, Bought and paid for Shills, too damn dumb to realise what they had just experienced, and been witness too!
That was 2015, are these hilariously dumb bastards any further ahead since? Have they made a single bit of progress? Do they want to???
Chris posted this 07 December 2023
Currently we understand Electromagnetic Induction as a completely Symmetrical Process: Output = Input - Losses. The Secondary Magnetic Field Mirrors the Primary, thus Symmetrical.
The Secondary Magnetic Field creates a drag, that has the equivalent Mechanical Force in the form of Torque, as the Electrical Energy that is produced, again, not including losses. Again, you see a Symmetry here between Force!
Of course our goal is Asymmetrical Electromagnetic Induction. I have shown you how to do this here:
Electromagnetic Induction can and does occur in multiple directions at the same time!
It is very easy to prove, that POCOne see's the Input Coil and also POCTwo as a Source, and POCTwo see's POCOne as a Source.
I have shown you this since 2015 and even earlier:
In these machines, Asymmetrical Electromagnetic Induction, we have a very small Input, and still have a large Output, an Output that that is governed by Design and not by the Input.
