Inductors, how do they work?
  • 742 Views
  • Last Post 18 November 2019
YoElMiCrO posted this 27 May 2019
Hello everyone, as I comment in another post I will try to give my point of view to the
devices that work sparkgap, it should be noted that I have not done tests
of any kind about these devices, I only apply the theory of how they could
operate them using electromagnetism.
First we define what is an inductor, although a common transformer has
primary and secondary inductance, is not the same.
I explain…
We all know that transformers obey long-defined rules
time, as the tensions are proportional to the ratio of turns, that the current is inversely proportional to the relations of turns, things of those.
But they are really just impedance couplers.
The reflected resistance of the secondary to the primary is Rl' and its value is SQR (Np / Ns) Rl.
It should be noted that always in a direct sense, the energy passes from the source to the load
during the magnetization cycle through magnetic induction.
Now, flyback topologies do not work in direct mode, because
there is no current reflected to the primary during the magnetization cycle.
The magnetizing current stores energy equal to the square of the current
for the inductance divided by two, this is E = (Ipk ^ 2Lp) / 2.
More clear…
Imagine a primary of 10 turns and secondary of only 1, let's see what happens ...
Suppose we apply a voltage and time of Ton in such a way that the current remains at 1A.
All good…
It turns out that the secondary current will be 10A, no matter the load!
Since the inductors operate in current, this indicates that 1A * 10Tp = 10A and this
Current ratio should remain constant at all times.
Well and the question that follows ...
What happens with the voltage on the secondary side?
This will obey Ohm's law in every rule.
If we put a load of 1 Ohm on the secondary the voltage will be 10V, if the load is 10 Ohm
the voltage will be 100V and with 100 Ohm of 1000V.
But we can not forget that the output voltage is reflected to the primary in Vds = Vs * (Np / Ns) + Vdc
due to live magnetic induction.
Let's see what happens according to the applied load ...
For the first case, load of 1Ohm, the voltage that would have to support the switch would be
100V plus the voltage that feeds it, in the second case it will be 1000V plus the supply voltage and in the third case of 10000V plus the supply voltage !!!
There is no current technology in the power switches that support such voltages.
But if a Sparkgap.
The previous case would be for the transformer with air core that forms the receiver device within the global circuit that composes it.
What does this mean…
If you look at the devices, they use a transmitter coil and a receiver, the first
in step-up and the second in step-down, but always through sparkgaps.
In the transmitter, a capacitor is charged at such a voltage that just when the medium is ionized
content between the electrodes sparkgap this causes a spark gap that in turn energizes the primary winding of few turns.
The current flowing through said primary is high and short time due to the low primary inductance.
On the secondary side of the same transformer to have a very low ratio (Np / Ns) the current will be reduced in the reciprocal of its ratio of turns 1 / (Np / Ns), but as the impedance of the medium that communicates said secondary with the primary of the receiver is high (another sparkgap), the voltage between the electrodes will be very high, this will reflect a voltage on the primary side extremely high, voltage that the sparkgap can support on the primary side perfectly.
From this study it is deduced that the instantaneous power transmitted from one point to another is high,
(between the two transformers to air core).
Only by adjusting the load value of the receiver side, number of turns of the transformers and looking for the auto-resonant frequency of the two transformers to be the same could be seen
if there really is gain in the system that involves it.
It is essential that the volt-seconds ratio be asymmetric, this is achieved if the system
works in resonant mode, the inductors should remain linear all the time, that's why
they are built to air core, since the permeability of the vacuum is constant.
I think it is the best approach to which these devices could work.
It would be necessary to physically prove the exposed thing here and to verify its operation.
Chris posted this 28 May 2019
Hey YoElMiCrO,
This is a great post! Thanks for sharing! You should put all this into a video series and put a PayPal Button on the top of the page!
This makes sure you paid for your time and at the same time, others can learn from your knowledge! Everybody wins!
YoElMiCrO posted this 28 May 2019
Thanks Chris, but I do not have the time.
It is for this reason that I do not post much and much less in a language that is not maternal.
I will talk to my wife to be my voice and knowledge.
If you agree then we try the videos, because even so
I would have to prepare everything and explain the details to her.
Thank you very much everyone.
Marathonman posted this 28 May 2019
YoElMiCrO .
  While i do agree with most of what i understood and i do agree with the resonate action of the transformer being able to expell more then the excitement as per Tesla. unless this is in resonate action a transformer it can never be ou, here is why.  when a transformer's magnetic field is created so is the electric field just the same as the magnetic field which is all the way around the core NOT just at the secondary. the fields are increased and decreased in strength but yet it is never an emotional electric field because it just increases and decreases  it's intensity not so called cutting the field lines. a motional electric field can not be shielded as such yet a transformer action can.....why????
there is No emotional electric field in a standard transformer and the fact is a transformer is to say self regulating as the lenz law dictates it's self regulation with feed back from the primary to the primary and from the secondary to the primary minus all the loses occurred  from wire, core, Hysteresis and eddies which i might add will never ever be OU unless it is in resonant action.. the generated electric field is created at a finite intensity as per the magnetic field thus output's only a finite amount of EMF no more no less thus can be transformed either up or down in current or voltage.
a  Generator on the other hand has either a notional electric field or  a moving conductor which is NOT the same as a transformer at all. when you physically move either of the two in some way a different mechanism comes into play which leads to an output that is NOT proportional to it's input. the feed back from a standard off the shelf generator is STUPIDLY small compared to it's input which i might add is a pressure regulated system as is all electric devices.
back to the transformer which i might add ONLY transforms up or down NEVER Generates minus losses. without a bucking type of system for which Chris has outlined a transformer can never be Ou unless it is in resonant action for which Tesla was the master which started all that,
Please do not be upset as i am only expressing my observations as a researcher and am quite interested in what you have to say. even though not 100% i still am interested in what you have to say.
MM, YoElMiCrO,
I agree, MM is right, but this depends on the definition of Resonance one chooses. LCR Resonance and Magnetic Resonance are not the same Resonance phenomena.
LCR Resonance never allows for the "Generation" of Excess Energy.
Magnetic Resonance does allow for the "Generation" of Excess Energy.
Every System has Losses!
Energy Gain must over come Losses and Power the Load. This cannot be done in an LCR Resonance System!
P.S: Inductors must become Non-Linear for Excess Energy "Generation". Parametric Pump, where the Combined Ratios of M.M.F is not the same throughout the Cycle of Operation.
MagnaMoRo posted this 16 November 2019
RE: Where do the electrons come from in the secondary circuit on a transformer?
Answer: The electrons are already present in the secondary circuit and only need to be accelerated and decelerated along and around the circuit. The force of the magnetic field across the conductor directly translates to the force of the electrons set in motion and offset by any resistance and losses.
Question 2: How are they accelerated to near the speed of light along the circuit, even if a magnetic field only slowly cuts across a conductor?
Answer 2: The relative cross movement of a magnetic field in relation to the conductor (copper wire) causes a gyroscopic precession of the orbiting electrons of the copper atoms in the magnetic field. [The direction and intensity of the electron precession] is directly related to [the cross angle, polarity, and force (speed and strength) of the magnetic field’s relative motion].
* Contrary to common theory, the electrons of the copper atoms do not jump from atom to atom. Instead, free electrons that are already present in the circuit are affected by the “forced” electron precession in a manner that can be determined using special relativity. It is the free electrons that are accelerated around the circuit.
* Proof: In an open circuit the free electrons will build up on the negative side of the copper conductor without ionizing or otherwise changing the state the copper on the positively charged side of the circuit.
In effect, each affected copper atom is catalyzed to perform like an electron accelerator, the voltage (pressure/force) of which is dependent upon the intensity and direction of the copper atom electron procession, and the resulting current in the circuit is a cumulative result of the atoms so affected.
Jagau posted this 17 November 2019
Hi Yo
I do not think an air core is the best approach, but it depends on the way you want to use it to achieve it.
Chris demonstrated another way with a metglass core as well as the group of Tom Bearden with his MEG patent. One plays on the point Br where there is variation of the inductance.
Don Smith has proven another way to produce energy with an air core but the process is very different, it uses a spark gap, and a very high voltage. I think the process you prefer Yo but there are other means to reach the goal.
MagnaMoRo posted this 18 November 2019
Two spark gaps in series make a BIG difference. Joseph Newman also used spark gap methods (in parallel and series) in his commutator designs to greatly increase the voltage off of which his Energy Machines ran. Newman asserted that the ideal method was to have high voltage that would catalyze as many of the atoms of a massive coil as possible with as little current as possible.
For example: Since the electrons accelerate to near the speed of light along the length of the conductor in a coil, (Approx. 186,000 mps), then for a coil with 1 mile of wire, high voltage should be applied for about 1/186,000th of a second or Just long enough to build up the magnetic field to max strength. A powerful back-spike was used to re-energize the battery and the process was to be repeated until the magnet was torqued 180 Degrees. Then the whole process was repeated under the opposite polarity.
