Accelerating Electrons
  • 600 Views
  • Last Post 24 May 2018
Chris posted this 31 March 2018
A subject we have partly covered, and also a subject we have seen mentioned by others before us:
Ah, the devices I have invented, which there are a number of them, they all, ah, actually, accelerate Electrons. They're Electron Accelerators.
Don Smith 1998 Office Interview Part 3 @3: 30
So why is this important?
A Single Copper Atom has 29 Protons, 34 Neutrons and 29 Electrons. A Copper Wire, has many Centillion Electrons, all at rest state at our scale, but at the Electrons scale very busy little fellas!
An Electron, because it carry's a Charge has an associated Magnetic Moment - Making the Electron susceptible to External Magnetic Fields!
Electromagnetic Induction, discovered in 1831 by Michael Faraday, 187 years ago, uses The Lorentz Force, to Strip off outer Orbital Electrons, or Free Electrons and create a Potential Charge Difference on the Terminals of the Insulated Copper Wire.
Each Terminal consisting of an excess of Charged Electrons, where the Charge of one electron is typically in the order of: -1.602 x 10-19 C. If you like, the Insulated Copper Wire has now become a Capacitor, where each Terminal has Opposite Charge and there is an associated Volume of Charge Q. Where Q = C V
Because the Electron has an Associated Magnetic Moment, and it is susceptible to external Magnetic Fields, the very movement of the Electron can be accelerated further, increasing the total flow of Electrons, or Current, by an additional external Magnetic Field, a subject we have seen before also:
The current and potential windings require relatively little power, and are applied in such a manner that rate of flow of moving charges may be accelerated beyond 1 ampere = 6.24 x 1018 electrons / second. Thus the duty factor of the copper changes. I2R Losses diminish and more charges drawn from the now coherent space field flow at a faster rate as current to the load. This means as more current is required by varying loads more feedback magnetomotive forces free more electrons from binding forces complimented by potential magnetic forces of the orientated, coherent space field. Thus a conductor that formerly had a temperature rise above ambient labelled as a factor of 10 would now operate at a temperature of 1.0. Thus the same gauge wire would carry 10 times more current at the same temperature.
 Floyd Sweet - The Space-Flux Coupled Alternator
What Experiment might we see this occur?
The Mr Preva Experiment!
Current is the Flow or Electrons, or Charged Particles. So, what might this acceleration look like? From our friend George:
Electrons are Accelerated down the Insulated Copper Wire, out of the Terminals and through a Load. If the Load is not Connected, e.g: switched off, then no Current can Flow, however, an E.M.F or an Electromotive Force is still present!
Current is equivalent to the M.M.F or Magnetomotive Force, which does not need to be present at the stage of Electromagnetic Induction!
We MUST not confuse the two different processes!
  • Enjoykin2118
The Lorentz Force used to Accelerate Electrons:
From Newtons Force equation: F = ma, the above equation is adapted: FM = qv⃗ sin( θ ) B⃗
The Magnetic Force, the strength, is proportional the the Acceleration. In other words, the stronger the Magnetic Field, the more the Acceleration!
  • Enjoykin2118
Don't be confused - This is very simple:
I stress again, The Mr Preva Experiment is an example of using The Lorentz Force to Accelerate Electrons!
As Floyd Sweet said: Current I = da+/dt + da-/dt which is Charge moving to the Left + Charge moving to the Right = Total Charge Moving!
An External Field, in the Opposite Direction, Poles Opposing, Accelerate Electrons!
The best advice I ever heard:
  • Enjoykin2118
Marathonman posted this 03 April 2018
Meaning the higher the density (Compression) of the opposing magnetic fields lines are the higher the acceleration will be.
just my take on the subject.
  • Enjoykin2118
Chris posted this 03 April 2018
The reason that Above Unity Machines are not only possible, but working in many places already, is easily explained. First lets re-visit the famous quote:
Ere many generations pass, our machinery will be driven by a power obtainable at any point of the universe. This idea is not novel. Men have been led to it long ago by instinct or reason; it has been expressed in many ways, and in many places, in the history of old and new. We find it in the delightful myth of Antaeus, who derives power from the earth; we find it among the subtle speculations of one of your splendid mathematicians and in many hints and statements of thinkers of the present time. Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature.
"Experiments With Alternate Currents Of High Potential And High Frequency" (February 1892)
Examining this quote is a very prosperous task!
  • Voltage can be Amplified, the great Nikola Tesla was a master at this!
  • Current, which is Kinetic Energy, can also be Amplified! Nikola Tesla also gave us a patent showing this: 336,961
Nikola Tesla is very precise in his words! Very meticulous about the words chosen! taking small sections: "a power obtainable at any point of the universe" and "Throughout space there is energy" and "it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature"
Ohms Law, yes it does work, if we step up the Terminal Voltage, the because I = V / R and we are not changing R, only increasing V, then I also increases. E.G:
  • Current (i) = Voltage (V) 10 / Resistance (R) 10 = 1 Ampere.
  • Current (i) = Voltage (V) 100 / Resistance (R) 10 = 10 Amperes.
By stepping the Voltage up from 10 Volts to 100 Volts, we see an increase from 1 Amp to 10 Amps. A 10 fold increase!
Current and Voltage are both amplified by the Coil interactions, Magnetic Fields Opposing, but to make this occur Terminal Voltages up, but not too high, this can be very dangerous, so be careful.
  • Enjoykin2118
Chris posted this 24 May 2018
To spur more thinking on:
We must keep these basic principles in our heads all the time. For our Power Meters measure, Electrons and the Flow of them.
Dont forget,
The Magnet and the Copper Tube Experiment, the falling Magnet Accelerates Electrons:
Gravity does this, but if we have a Magnetic Field in space, then this Magnetic Field wants to collapse back to equilibrium.
It acts like a Spring, like the Gravity does.
