5KW Generator Teardown
  • 712 Views
  • Last Post 4 weeks ago
Chris posted this 01 January 2023
Power "Generation" Technology has been shrouded in an almost, secrecy, for a long time, it is however, a very simple Technology!
Here are some Images from a Powertec PT6000 5KWh Petrol "Generator":
Separating the Stator housing from the Rotor:
The Two Pole, Lap Wound, Stator Housing:
The Rotor, Magnetized with a DC Current via Carbon Brushes:
The Stator Housing Wiring:
The Output of the "Generator" is 12 Volts and 240 Volts, and as you can see, there are no Permanent Magnets here!
The Rotor is Magnetized by a DC, Current, via the Brushes seen above. This DC Magnetic Field is Rotated at the rated RPM of the "Generator". Thus, the Rotation Magnetic Field represents a Magnetic Field Changing in Time, relative to the Stator Coils.
Thus, the Value of the DC Magnetic Field, in combination with the Rate of Change, in proximity to the Stator Coils, "Generates" the E.M.F measured in Volts above.
NOTE: An Automotive Alternator works the very same way!
A Changing Magnetic Field B is KEY! This is critical in Power "Generation"!
You can see, we have a series of very specific Parameters here to make this "Generator" run at its rated 5000 Watts.
  • The Magnetic Field B ( Rotor Magnetic Field ) Changing in Time t.
  • The Turns N ( Stator Coils are the Output Coils )
  • The Cross Sectional Area ( Total Area that the Magnetic Field and Coils encapsulate )
  • The Energy Density is the Length of the Coils ( Stator Coils - Very narrow, 0.9cm approx. )
These values we have covered many times here on this Forum! Faradays Law! Magnetic Field B is Modulated, by means of Rotation, or as in the above Transformer, AC Current.
Chris posted this 29 April 2023
Energy or Power "Generation" is so very simple, and the other forums have very little to no idea on the fundamentals of this very simple technology!
Have you ever seen another forum do a teardown of a "Generator" like this before? No!
Do other forums even follow the very simple Energy "Generation" principles? No!
Why are they so far from the truth, off chasing nonsense?
CLEMENTE FIGUERA
PRINCIPLE OF THE INVENTION - Watching closely what happens in a Dynamo in motion, is that the turns of the induced circuit approaches and moves away from the magnetic centers of the inductor magnet or electromagnets, and those turns, while spinning, go through sections of the magnetic field of different power, because, while this has its maximum attraction in the center of the core of each electromagnet, this action will weaken as the induced is separated from the center of the electromagnet, to increase again, when the induced is approaching the center of another electromagnet with opposite sign to the first one.
Because we all know that the effects that are manifested when a closed circuit approaches and moves away from a magnetic center are the same as when, this circuit being still and motionless, the magnetic field is increased and reduced in intensity; since any variation , occurring in the flow traversing a circuit is producing electrical induced current .It was considered the possibility of building a machine that would work, not in the principle of movement, as do the current dynamos, but using the principle of increase and decrease, this is the variation of the power of the magnetic field, or the electrical current which produces it.
The voltage from the total current of the current dynamos is the sum of partial induced currents born in each one of the turns of the induced. Therefore it matters little to these induced currents if they were obtained by the turning of the induced, or by the variation of the magnetic flux that runs through them; but in the first case, a greater source of mechanical work than obtained electricity is required, and in the second case, the force necessary to achieve the variation of flux is so insignificant that it can be derived without any inconvenience, from the one supplied by the machine. Until the present no machine based on this principle has been applied yet to the production of large electrical currents, and which among other advantages, has suppressed any necessity for motion and therefore the force needed to produce it.
There is no magic here, its very simple and there is a common theme across the board, a Magnetic Field Changing in Time in the proximity of a conductor, and if the Conductors are arranged Asymmetrically, then there is no Net Negative Force on your Input, your Input see's No Load!
DJOs posted this 4 weeks ago
  • strape
  • Classic
  • Classic
  • Classic
