I want to make it perfectly clear, that Excess Electrical Energy, Above Unity, comes in through massive holes in Science, specifically in Faradays Law and Maxwell Equations, that were manipulated to exclude some fundamental concepts.
Electrical Energy is Generated, Charge is Pumped from source, the Atom, via the Subatomic realm! It is all done through the Magnetic Field Changing in Time!
Free Energy is no fantasy!
I have covered this many times in many places, The Magnetic Field of a Coil.
Every single Coil that has a Potential Difference between Terminal T1 and T2, a Voltage V, and is Loaded with Impedance Z, containing a Resistance R, will therefore carry a Current I, and therefore have an associated Magnetic Field B.
Magnetic Field Density: B = μ0 μr NI / l
  • B is the magnetic field density in Teslas ( T ).
  • μ0 is the magnetic permeability of the vacuum, with a value of 4π × 10−7 T m/A.
  • μr the relative permeability of the material.
  • N is the number of turns per unit area, or Turn Density.
  • I is the electric current in amperes ( A ).
  • l is the length of the Coil in meters ( m ).
Magnetic Field Strength H = I / 2π r at a distance r from the wire, and the relationship to the Magnetic Field B, H = B / μr = B / μ0 - M Where, μ0 being the magnetic permeability of space and μr the relative permeability of the material.
The Grunt of M.M.F
Magnetomotive Force is the Horsepower, always Bucking the Source, thus Opposing Forces, that change the Atomic Structure of the Atom, and forcing Charge Carriers to be Accelerated down the Wire as Current! Where the net Charge can become more than one Ampere equaling 6.241509 x 1018 electrons per second past point P.
The Pressure P that M.M.F exerts on the Atom, in the Insulated Conductor, pushes the Electrons up to higher orbitals, making more Charge Carriers free to move, this is a feedback mechanism, because as the Load increases, the more Current Flows, and thus the more Magnetomotive Forces Free more Charge to flow as Current. Floyd Sweet told us this:
The current and potential windings require relatively little power, and are applied in such a manner that rate of flow of moving charges may be accelerated beyond 1 ampere = 6.2418 electrons⁄second. Thus the duty factor of the copper changes. I2R Losses diminish and more charges drawn from the now coherent space field flow at a faster rate as current to the load. This means as more current is required by varying loads more feedback magnetomotive forces free more electrons from binding forces complimented by potential magnetic forces of the orientated, coherent space field. Thus a conductor that formerly had a temperature rise above ambient labelled as a factor of 10 would now operate at a temperature of 1.0. Thus the same gauge wire would carry 10 times more current at the same temperature.
This is such a beautiful, elegant, fact, that is so completely obvious to the Researcher doing Experiments!
Voltage is Generated
Voltage is the key, and each Coil, arranged in an Asymmetrical arrangement, is the key to making this work, but the Generation of a Voltage takes some understanding, takes some work to build upon!
Because each and every Coil that has an associated Magnetic Field Changing in Time t, the Voltage Generated must be sufficient to do Work on the machine, Bucking, or Pumping more Charge on the Output. A Load Regulated Machine! This is why Walt Rosenthal gave us these Gems:
The VTA "likes" to always see a minimum load of 25 watts.
And:
The VTA can be started by momentary connection of a 9 volt battery to the drive coils when the machine is operated in the self-powered mode. The operation is stopped by momentary interruption of power to the power coils.
Floyd Sweet was a Genius, his ways of thinking were beyond their time and he will always be my Hero!
Asymmetrical Arrangement
It is a fact, all Electromagnetic machines today all follow, specifically, the Symmetry that is enforced by the establishment, when there is a much smarter way!
Two Coils, one Input, one Output, each Force is arranged in a fashion to force the machine to perform in a Below Unity state, simply because: Output = Input - Losses, thus never ever an opportunity to be an Above Unity Machine! This is a very Dumb way to approach Electrodynamics!
Arranging the Machine so we force Asymmetry is the key, fundamental approach to gain Above Unity Machines:
I have given you all the details you need, here on this forum, with experiments to get to the point of building machines that show results that no one else has ever achieved in the Public Domain! Ever before.
Having a combination of Coils, essentially, two Output Coils, that must Oppose, or Buck each other, we can use some very simple Vector Math to point our the Asymmetry: 1 + -1 + 1 = 1, where in a Symmetrical situation we get: 1 + -1 = 0, so we have a different arrangement, and introducing Asymmetry frees us from the age old and very poorly understood Conservation of Energy Laws that only hold under very stringent situations that so many science gurus do not properly understand!
My Thread: Chris's Non-Inductive Coil Experiment, with 11 videos showing you how to build these machines, gives you all, freely, in the Public Domain, all the answers you need! Yet, the Trolls deliberately ignore the Truth, the Facts, hoping this will just go away... Isn't that Criminal! They expose themselves, showing how they have become Traitors of the Human Race!
We have this technology working, and we are still working to further understand some aspects of this technology, but we have it working! You are the only ones that can make this become mainstream, and force it out into the Public Domain! You and you and you and all of us together!
It is very clearly obvious who the Brain Dead Trolls, the useless shills, the CIA Spoofs, are! We can all see them! We all know who they are! They are exposed! The shame they must feel! The Guilt for what they have done must be over whelming and too much to bear! Or maybe they are not Human and do not feel normal natural feelings like we do?
Freedom is only a few steps in the right direction: Builders Guide to Aboveunity Machines. Only you can do this for yourselves!
