Ruslan/Akula Generator Copy from Azerbaijan?
  • 1.6K Views
  • Last Post 08 February 2023
DoofusNugget posted this 03 October 2021
I found this interesting video about a week ago. At some points in this video you will see a "blue-tray device", which apparently is powering an LED bulb with no other input other than a single ground connection. There are obvious similarities to the devices of Akula and Ruslan. According to some people in the comments of this video, there was direct connections historically to Ruslan. I will leave other members to discuss this video and its worthiness, as I don't have an interest investigating this video in depth at the moment.
Chris posted this 04 October 2021
Hey DN,
It seems more and more people are reaching the goal. This is great to see!
This Grenade configuration of Energy Machine started with Tariel Kapanadze, I believe, circa 1998, and a long list of successes from there, well before Ruslan and Akula!
Not in any specific order, and not complete:
and no doubt many others before Akula had his Replication Successes, and then Ruslan and others.
The General Public is showing How Corrupt the Science Institution really is! How many people need to come forward before Science is FORCED to catch up? Isn't this totally ridiculous! Its so blatantly obvious that the System is Rigged and Corrupted by a small group of Bottom Dwelling Scum Bags! These Parasites have been running the show for a very long time, we should have had this very simple and very cheap technology well over 100 Years ago!
GITMO and Military Tribunals are currently underway, most of these Parasites are going to PAY a very heavy price for their Roles, and they should be absolutely terrified, as some will loose their lives over their part. Treason is punishable by Death in many countries! Flee they will, but they can not escape! The Worlds Population has had enough, we all want Justice for what they have done, and Justice is happening NOW!
DN, if you are able to do the smallest experiments, we will help you, you can see some extremely interesting, Eye Opening, Pages here on this Forum and our Back Up Forum.
Its simple, and very Cheap!
Mitza84 posted this 19 January 2023
Guys i hope this help i put a link for download the documentation for this device it was hard to find and is from the author so this is the link for download i hope it make some light is in russian but you can translate it .        https://we.tl/t-y5q1zryRpG
Mitza
The link will stay for about few days so save the files and publish it here cose i can not i dont know why  . and i hope the senior members here will have a beter understanding than i have of the device.  below is a photo with the principle of operation and you will see high voltage and modulation with low voltage and grounding.
Mitza
donovan posted this 19 January 2023
OK, That link takes me no where......
Donovan
azerbajian
Mitza
The link is working is from we transfer in the left side of the page you will find the download option is imposible it has to work .  If you can not download it i ca share it via watsup or telegram .
Mitza
Chris posted this 19 January 2023
Mitza is 100% correct, the Image says all you need:
  1. Separation comes from the Asymmetrical Electromagnetic Induction, Bucking Magnetic Fields, of the Output Coils.
  2. Yes Two coils is enough, but not necessarily ideal! That's why this is stated!
  3. Yes, sometimes an Earthed Ground is required.
  4. Absolutely, the Principle of Current Addition means Magnetic Field Opposition! Bucking Magnetic Fields:
    • Yes, Voltage is critical!
    • It is critical to have Currents In Phase on the Output, Phase Locked, this is important!
This is all really simple, once one thinks about it the right way!
Mitza84 posted this 20 January 2023
 This is the autor own words
Ask yourself why many have failed to recreate the installation with an increase in output power? Whatever you do, grenades, kachers, Tesla, etc. A lot of schemes and stories in forums and YouTubes will never give anything.
You need to think in volume, look at the Kapanadze generators, does he use the complex circuits that we collected? Of course not. There is an inverter of 220 volts, there is a high-voltage transformer with a voltage of no more than 1 kV, and that's all.
What gives us power? Is that the current in the circuit right? So. And now turn on the logic of how he does it and the same installation that was demonstrated in Baku. There is a voltage of 270 volts sine modified 50 hertz. There is a coil to which it is fed, and there is a spark gap. There is high voltage. Further, the arrester is set to 25 hertz and clicks on 0 when a positive sinusoid occurs, in this case a meander. Well, that's all.
Hello everyone on the forum. Now I'll tell you everything. Yes, the circuit is almost correct, in no case should you use the output to the diode bridge from a copper tube with a cut, there should be a capacitance between the tube and the winding, it will be 20 + 20 turns of wire wound in antiphase and the central wire should be connected to the diode bridge. The second winding of 18 meters 9 + 9 is also in antiphase, and only the third 30 meters is wound in two bifilar wires to obtain inductance and the effect of the discharge on both coils.
Greetings to you all, why is the topic swollen? Just need a little respect for each other and everything will be fine.
Many of the people who conduct or have conducted experiments want to immediately see the output above unity, without creating the conditions for it.
For example, we have a car weighing 1 ton, which needs to be moved, for example, at a speed of 100 km per hour.
The car is our load, which we take as a basis.
There is an elephant that can move at a speed of 10 km per hour, this is a current.
There is a cheetah that can run at a speed of 100 km per hour - this is our stress.
If conditions are not created, then the elephant will push the car at a speed of 10 km per hour, no matter how hard the cheetah pushes it, while having speed.
Whatever you do, if you do not create conditions in the conductor in such a way that the current and voltages add up, power will not be possible to obtain.
But how to get it? How many times I tried to convey to you, you never saw the essence. Although one of the publications outlined a clear principle of operation of the generator. It was only necessary to put a capacitor with a capacity of 0.4 microfarads and the issue was closed.
Whoever guessed what was at stake, he understood where the secret of the device was hidden. In order for your current to start moving with high voltage in a conductor with low resistance, you, using TVS or TT Kacher, begin to increase the resistance in the conductor, creating phase addition conditions.
Now I'm collecting at 1 kilowatt, and maybe the power will come out higher. The voltage that the kacher gives out on the receiving removable coil is above 250 volts. The buildup current of the circuit is 2 Amperes, yesterday you assembled a low-frequency high-voltage coil, this is so that the current in the circuit can increase.   Now I'm collecting at 1 kilowatt, and maybe the power will come out higher. The voltage that the kacher gives out on the receiving removable coil is above 250 volts. The buildup current of the circuit is 2 Amperes, yesterday you assembled a low-frequency high-voltage coil, this is so that the current in the circuit can increase.
On the receiving coil you get truss voltages of about 250 volts. But already she has the usual tension. Its essence is a decoupling between magnetic fields so that the first coil affects the second and the second does not affect the first in any way. The cap patent clearly shows this
There is cc, there is a receiving coil. One part of the reception sits on the ground, the output is loaded with a lamp. From the second century I already apply a discharge to obtain current
Well, sorry, if you can’t get it, it doesn’t mean that it doesn’t work at all.
The specialists who tested the device saw it with their own eyes, held it in their hands and practically informed everyone inside whether there were hidden batteries. It was turned on for several hours, and charged a laptop beech and a couple of phones. After the test, they also asked questions, but where did the increase come from?
I actually have the unit in stock right now in working order. Even if someone wants to come to see with their own eyes, to feel it, check it out, but for God's sake.
Yes, you don’t think what will happen, you came to see it, and then it somehow miraculously stopped working. It will still work and give energy.
Of course, I don’t need gifts from you, I myself will make gifts for you so that you can make sure that there is a working device, but then after the show, I won’t give a diagram if you think that I will draw and show on a piece of paper.
Without land, it is unlikely to work, because without it there is no potential and gain. Unless you hook onto the car body. Or on a large metal sheet. Then yes, you can do without land. And so everything will start to bite, and one more thing, but the metal sheet itself will also start to bite if you touch it. Best grounding.
And look, here you have voltage potential right? You got 250 volts on the secondary circuit, now you need to increase the current in it. The same primary processing must work with the second oscillator and the voltage of the second oscillator must be at least 5 kilovolts. Everything must be galvanically isolated. Capacitor Capacitor Capacitor again Capacitor.
Nothing ever happens with a grounding pin, especially with an ordinary kacher or TT, this is a myth of those who deceive and deceive, like a novel, etc. Mystical frequencies and hydrogens, the earth does not work here, but transferred somewhere and suddenly does not work.
A regular pin to the ground and will work for many years without problems.
The general principle of adding additional power is the addition of current with voltage.
1) the principle and it is the foundation of this installation, it is necessary to separate the influence of the first circuit of the high-voltage generator from the second circuit of the low-frequency generator
2) there are 2 coils in total and this is completely enough, the first coil is the operating voltage from the VV, and the second is the output load coil. We must apply both BB and LF to the first one.
But at the same time, the generators themselves do not affect each other in any way and should not influence
3) it really should be the earth, it doesn’t work without it, but it just starts flashing everywhere to bite BB.
4) current and voltage the principle of addition
A) on the circuit of the removal of cv we get voltages
B) the circuit is the same LF we get the current in phase
Now according to the scheme.
You can assemble on a ferm rod with any generator for 200-250 kilohertz (I'm assembling it myself at the moment)
One end is soldered to a matching capacitor, the second is planted on the ground through a removable coil
On the circuit + on the ground and minus is connected to the first end of the generator BB
Mitza
And this is the word document that helped the inventor to build the device and he explain also the function of the device .And most important why and from where the enegry come from and acumulates. i hope i made some light in all this kapanadze type of devices.at least from the author perspective and i can say the device seem legit he was with big comision when he presented from government and elctricians that measure the device fow many hours .
you have a word and a pdf the pdf shows beter the order of the files i dont know why .   peace guys.
Mitza
Jacek05 posted this 21 January 2023
Mitza84 - thank you for your work ! I'v downloaded all. I can help with Russian language hand written schematic if you want.
When Mehran Keshe publicised his magrav plans, someone written step-by-step technology how to build this device. Some people stated it is very easy and you can do it in your kitchen but it wasn't. I tried to do it, but when found out from other builders it doesn't work (errors or deliberately done changes), I gave up. I'v spent few years to look for a working schematic of even 100 W device.
Guys, I have a big request to you. Because I am not electronic engineer (just a metal processing mechanic that can assemble electric parts), I'd be happy if someone would publish here step-by-step plan how to build it, how to make it working.
Chris posted this 21 January 2023
Hello Jacek05,
What steps would you take to Replicate machines like this or similar?
Jacek05 posted this 25 January 2023
I understand, you defend your rules in your forum. That was only my kind request for those who can help, share like Mehran Keshe to give people some power to defend from the very, very bad system that wants us to ley on our knees to take the number of the beast. I know how much effort like time, money one have to input to develope even a simple device. I'v spent thousands of hours learning how to burn in my central heating stove and now I am going to use less than a one tone of coal, before it was 4 tones. If somebody answers my apeal, my steps will be assembling it and sharing (if agreeded). If inventors can't patent, don't want patent, are affraid to patent to manufacture, it is no time to hide such goods in our more and more dark times. Look what happens in Ukraine. It will be in my country Poland, then in your countries. Everywhere. Russia has weapons to destroy everything by many ways.
Best regards, Jacek
Chris posted this 25 January 2023
Hello Jacek05,
Plastered all over My Forum and YouTube:
Captainloz and Tinman only had half of this:
But, they learned what I have shared and made it work!
Tinman was the first:
All Talk and no Action makes Jack a ? You know the Quote I am talking about?
donovan posted this 29 January 2023
I like your idea, of doing this as a team.......I see so many people that talk about having free energy device, but are afraid to use it or talk about......and time keep passing....and we still depend on century old technology for day to day life......I am so tired of it.......
Century old.....may not be the best choice of words.....the stuff that is happening on this site also has roots back that far.....
Donovan
Chris posted this 29 January 2023
Hi Donovan,
I agree, and yes, I am so tired of the Stupid that some humans carry on with, look at all the trouble I have had with Trolls for so long!
Trolls Suck! They only accomplish one thing, that's destruction, that's their goal! They are Satanists, and Satanists have nothing good to share!
I am at the point where I see the Troll Attacks not reducing, but in fact getting worse, but I think we just need to observe their Dumb Ass Idiocy and try to laugh at it, they are just children, fighting in a playground, adolescents that need a smack bottom!
Its old, and its dumb! You're right!
What I have given works, it does! One just needs to apply it!
Working on "applying" it!!!
I have a small electronics repair business, and a lot of my customers know, I do have always some sort of "strange" project on the go......and when the conversation turns to perpetual motion machines.....I like that comparison for average people......because they instantly know what I am talking about, even though it is somewhat misleading....I always ask a question like, "Ok, tell me, what day is the sun going to stop shining, since, there are no perpetual motion machines?"
You are right, though, after a while, the trolls are almost entertaining.......
It is actually sad, that these people have such a closed mind......
Have a good day!
Donovan
Chris posted this 30 January 2023
Hey Donovan,
Yes, there are a lot of people out there that choose to be as Dumb as possible! We know them as Trolls! As Dumb as a Pig in Mud!
Those wanting to improve, and to gain knowledge, seem to be somewhat of a rare breed, I can say Members here have this quality! I ban the rest!
Mitza84 posted this 08 February 2023
this is supose to be the right schematic for the device in azerbaijan  . i translate it in english you have the wire lenght 10m for the 3 coils and 2.5m for the last one wich goes to positive . i hope it helps hope this makes things easier .
Mitza
Mitza
Mitza
