Wistiti's POC Toroid
  • 1.9K Views
  • Last Post 10 May 2022
Chris posted this 28 March 2017
We have researched the Partnered Output Coils for some time! We have learnt a lot! POC is based on all the Ideas we have researched from other Inventors before Us.
Input Configurations:
Possible Output Configurations:
Our Member, Wistiti, has invented the POC Toriod:
Several of us have replicated the Wistiti POC Toriod! Thaelin has had good results! I replicated, and also another Independent build by Юрий Лиховид (Yury Likhavid)
Important: Turns Ratio seems to be important: 4 : 1 or there abouts. See the Timing Thread and the Parametric Excitations of Electric Oscillations Thread for more information.
Please remember, this is one of many configurations, many configurations can work!
Chris posted this 08 February 2018
Wistiti's POC Toroid - Again Geometry
This works a slightly different way, Sine Wave from the input must be Timed in a different way - Wire Length is much more important.
This device works on the 1/4 Wavelength Principle!
The Geometry again, Three Coils: One Input, Two Output Coils
P.S: For the record, I did struggle with this for a long time - Thus my research into Antenna's
baerndorfer posted this 29 April 2022
i think this is the most overlooked post on this forum. the examples in the two videos are excellent! very easy proof of concept
thank you very much
baerndorfer posted this 01 May 2022
like to add a link to patent 1702771 from 1927
baerndorfer posted this 06 May 2022
i did a test on such a transformer today and monitor the consumption from main grid.
transformer idle: 0.8W / 0.8VAR / 1.2VA / 0.005A / PF: 0.710
then i took a light bulp and connect it to secondary. again i monitor the consumption from grid.
transfomer 10W load: 10.4W / 24.6VAR / 26.7VA / 0.117A / PF: 0.388
let that sink for a moment....
when we connect a resistive load to the secondary of a transformer this type, the powerfactor went down )
baerndorfer posted this 09 May 2022
maybe more should build wistitis toroid 😎
https://gab.com/tankcircuit/posts/108271849802357381
Jagau posted this 09 May 2022
Excellent Presentation Bearn
so the power drops when you plug in the Fan?
the power drops, when i use secondary (POC) from transformer.
in idle condition it consumes lot of reactive power - under load it does not.
this is something special.
leonel posted this 10 May 2022
Thank you Baerndorfer! check it. 😊. By the way, I cannot see the video.
