Hello,
I want to show you Ken L Wheller researching's about nature of magnetic field. Here is all science videos Videos have around 2 years (2015), but for me its a News, so Im watching and researching it.
https://www.youtube.com/playlist?list=PLTMm2h0hniVKcsU5pMage8lhHSgOIyU63
Here is link for free ebook witch all most imporatnt data and explanation.
https://plus.google.com/110321252195532535450/posts/6fLJoA32Mv1
Hope it helps witch unconvering secrests of VTA. Specially better understand and simulate what happens witch magnetic fields in device.
Its a tons of materials to read, watch and understand. I have downloaded it all and im researching it. So to not waste time im sharing witch you. My first goal "is that "excitior coil" will make perturbance (imbalance) between centripetal and centrifugal vortex. Like self perpetuating swing. Magnetic Forces in VTA need to be re-draw.
Old CRT TV/screen can be used to visualise forces in magnetic field. This example is on the movie, in Ken channel.
Cheers !
PS. By the way, I have lost old Account, so now im using new one.
Uncovering The missing secrets of magnetism - Ebook and movies
- 1.3K Views
- Last Post 08 July 2017
Hi Sneak and Welcome!
I believe, in my journey, which is not complete and never will be, that much of Magnetism is in plain sight. We still have some to learn yes! But what we currently know is sufficient to understand much of the devices we have studied.
What is not well understood is the "Generation" of Energy!
Energy begets Energy! What does this mean? Well in a properly designed system, Energy Flows "Generate" more Energy! It is just a Design Problem!
As an example, Tariel Kapanadze starts his KapaGen with a 9V battery, as did Floyd Sweet in his Generation 4 Device.
Many others have also.
So, the tiny amount of Energy we use, Begets More Energy, it "Generates" more Energy, well in excess of the Energy Used!
How?
186 Years ago Michael Faraday discovered Electromagnetic Induction... Today, we still do not fully understand how it works!
In my opinion we need to understand true nature of magnetic field (and reality by the way). So my idea is that study the geometry plain of the magnetic field vortex, understand of proces "producing elecricity" (induction) and undestand what it is electricity (is electrons real (?), Tesla not belive in electrons)
If the design of VTA is ruraly correct (the circuit, coils position, VTA construction), and data that you have is corrrect/real, so..My early idea was that we need to find geometry design for the device - to find geometry for magnetic fields (following Ken L Wheller). To do what...produce energy.. but how? Following that what Floyd Sweet says.. we need to make perturbation between stable double vortex (N or S pole). It will produce extra energy. It's like a "excited", unbalanced state and self perpetuating (because that is design device constructed).
Following that what Bashar (Alien, channeled by Daryl Anka) says in sessions (i have that records, from torrent ) about energy, energy generation process, it is all a geometrical patterns. And when I focus on that what Ken L Wheller says about magnetic field, atoms (they are 99.9% empty of course) and.. it is like it is.
Look at Bashar space ship enegine, collecting coil is a the same like in magnetic field images from book (phi ratio, sun flower)
http://overunity.com/14029/bashars-spacecraft-engine/#.WV_d32d-Omw
And About Space time Antenna (designed by Bashar to) it is a double vortex to. It will get energy from "templet level reality"
https://basharspacetimeantenna.wordpress.com/
"But before we will be able to construct our space crafts, our higher mind it is in the state that we are able to download all information to construct space crafts- we are connected witch them (its a extension of our mind), so it physical manifestation manifestation of our mind" - Bashar
And about teleportation by Bashar, every object have own frequency that represents position in XYZ Axis, so when you move object you will create "another object". Shortly say;Using strong singal of sound or Electromagnetic wave, you can move object. So you can jump direct from A to Z.
And you remember John Hutkinson effect? www.hutchisoneffect.com/
And mistic peoples says that we are live in "matrix", not (no so solid) world as we know It looks more like a 3D computer game.
Our univerce is realive simply in nature and holographic. But works perfectly and accurate. We must only undestand it fully and drop missunderstandings and complicated theories.
But back to the energy im thinking between two possibilites of creating energy. 1. Drop the ambient energy (using electromagnetic interaction's) and total sum of energy it is contant. or 2. Getting energy from the "Aether" "higher dimentional" witch it means, unlimited source of energy.
Of cource I will research in my own Ken L Wheller book and inform about my ideas.
Hi Sneak - I agree with what you said! Especially this part:
Floyd 'Sparky' Sweet was a true Scientist, studding all he could, making no postulates, and questioning all assumptions made and even going as far to question experiments performed that may have had derivations...
We all have our own path, and I will not persuade anyone, its not my job, but if youre interested, the real Physics of how the VTA Worked is very clearly laid out in Floyd Sweets Writings:
- A Dimensionless Viewpoint of a Four-Dimension Cosmos
- Cosmic Rays, Natural Magnetic Fields, Coherent Quanta Energy and Aurora Borealis
- Flaws in the Ecklin Theory
- Intergalactic Space Travel
- Letter to Mark from Sparky
- Magnetic Resonance by Floyd A. Sweet. PH. D
- Space-Quanta Modulator - Clean-Propulsion Power Now!
- The Energy-Matter Involute
- The Space-Flux Coupled Alternator
- Validating Quantum Electrodynamics' Interaction of Radiation with Matter
I have provided all these documents for many years to all interested. Currently in our Reference Section! I was given these documents by some people that worked with Floyd Sweet in the Early Days. I have verified most of them to be genuine.
Also,
- Floyd Sweet Lab Notes - Property of the Aseop Institute taken by Darryl Roberts
I will make one promise, the documents provided are perhaps the best we will ever have!
Take special note about Floyds writings, in where he talks about Energy, there are more insightful quotes in there than anywhere else I have seen!
If I may, some advise, I did go down many Rabbit Holes in my Research, especially in the early days. If anything deviates too far from real Science, then very likely it is false, Science is mostly correct, some errors, in the form of Postulates and some outright wrong "Theories" have been presented. But the Days of Dirac, Faraday, Lenz, Oersted, and a few others, did bring about a working, real and workable Science today!
It is not wise to throw away Science and leap into the realm of make believe, trust me, I learnt this the hard way!
@Sneak - If I may invite you to read: Electrical Energy
Nikola Tesla gave us some excellent insight:
Ere many generations pass, our machinery will be driven by a power obtainable at any point of the universe. This idea is not novel. Men have been led to it long ago by instinct or reason; it has been expressed in many ways, and in many places, in the history of old and new. We find it in the delightful myth of Antheus, who derives power from the earth; we find it among the subtle speculations of one of your splendid mathematicians and in many hints and statements of thinkers of the present time. Throughout space there is energy. Is this energy static or kinetic? If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature. - Nikola Tesla "Experiments With Alternate Currents Of High Potential And High Frequency" (February 1892)
The very Definition of Kinetic Energy is the answer to all our Questions:
Energy which a body possesses by virtue of being in motion.
I go into these things in some depth on the above thread!
Thank you for the link's. I will research it too. I will write if i get solution or idea.
Cheers !
- Chris 440
- FringeIdeas 370
- Adam 370
- Tinker 320
- CaptnFalcon 240
- Antares 164
- akoteles 120
- Arya Rao 100
- Classic 60
- ZeUs21 20
