The Frequency Conundrum
  • 571 Views
  • Last Post 07 April 2018
Zanzal posted this 06 April 2018
Not all frequencies are created equal. Should I create a device and want it to resonate at a low frequency I must use a large capacitance which must be charged and discharged. If it resonates at a high frequency, I must expend energy to switch and low values for RC time constant timing bleeds energy due the need to use low resistance. The low C component also makes the device more unstable since small changes in capacitance will throw it out of resonance. If my device dictates its own resonant frequency then I must invest time trying to learn to build adjustable frequency circuits which will invariably require changing capacitors or resistances to address component specific variance that changes over frequency.
Let's call this the frequency conundrum. Is there a frequency or range of frequencies which because of natural laws consume less power and require less capacitance for commonly encountered inductance? Assuming that the natural laws of the Universe aren't entirely linear this is the frequency I'd like to target. By standardizing my devices on an efficient frequency I can design circuits that are naturally more efficient.
Thoughts?
  • Enjoykin2118
Marathonman posted this 06 April 2018
Very true, Tesla found that certain frequencies were better for heat production and others better for light production even creating a breeze in your house ect.....
finding the right frequency for your projected outcome would definitely be to ones advantage thus the standardizing of the frequencies would be a good idea.
Here lies the problem, who has the equipment to get the frequencies to the height of the master Tesla and it would seam to me that would be the first hurtle to overcome.
other than that it is a good idea to mimic natures frequencies as Tesla and others did so many times. connecting to the wheel work of nature is the real oyster.
Chris posted this 06 April 2018
Hi my Friends, this is a very good Thread, a topic I have touched upon in other Threads:
A properly designed H Bridge is the most efficient Switching System, MERS (Magnetic Energy Recovery Switch) is designed around the H-Bridge. https://patents.google.com/patent/US8045309
I have found Series Resonant, better than Parallel Resonant, but I have used both and sometimes both at the same time which provides an interesting configuration.
  • Series Resonance
    • Minimum Impedance at Resonance
  • Parallel Resonance
    • Maximum Impedance at Resonance
I urge, do not limit ones self, there are many many configurations that will work, so as Flexible as possible will always be better!
The properties of a Coil can be a hand full to grasp, and the fact that these properties change during operation also a hand full to grasp.
The Coils Impedance, Distributed Capacitance, Inductive Reactance, Capacitive Reactance, DC Resistance, and how all these factors interact together at different times to give different results are a lot to grasp, but this is not really necessary to grasp...
I think, from my understanding, and I am still learning, always will, that we should aim for the least total impedance, which does not mean as few turns as possible! It means aim towards 'generating' or aiming for the maximum Negative Power Factor as possible!
Where the Power Factor is taken at the Terminals of Each Coil individually.
I often look back on my experiences at the 'other' forums and I honestly think that many of the so called, and self proclaimed, 'gurus' were either fake or stupid... I think most all of us would agree!
We have the best bunch here now! All 'real' people will always be welcome here!
Jagau posted this 06 April 2018
Very good question!
Before doing all my practical experiments I often asked myself this question.
Don Smith and many others before him have I believe discovered this frequency usable for our experiments that would make sense on how often would it be most useful for inventors who have discovered this secret before us?
I think I'm on the right track with that makes sense compared to what I found.
North of the hemisphere of our planet earth (Canada), it has two dominant frequencies of space. It may seem a little crazy what I'm going to tell you but these two frequencies are 45 MHz and 408 MHz. I am fortunate to have a monitor service that I use for the radiocommunication service and I can tell you that at these two frequencies when I synthesize one of these two frequencies I get a maximum and very powerful reception. There is no station or network at these 2 frequencies, I check in the databases of my country.
Before going further, I have attached a document as an attached file that you will read and I hope you will give me your comments, For now I use the frequency 45 Mhz which seems to correspond perfectly with the E.E.S. 2 from Don Smith.
Jack
Enjoykin2118 posted this 07 April 2018
Hey Zanzal your post reminded me to John Ernst Worrell Keely's 40 LAWS OF VIBRATION !!
Are you sure you aren't his reincarnation ? ((( )))
Let;s remember the first 10.
   1. Law of Matter and Force: Coextensive and coeternal with space and duration, there exists of all matter: these are in a state of constant vibratory motion, infinite in extent, unchangeable in quantity the initial of all forms of energy.     2. Law of Corporeal Vibrations:   All coherent aggregates when isolated from like bodies, or when immersed of confined in media composed of matter in a different state, vibrate at a given ascertainable pitch.     3. Law of Corporeal Oscillation:   All coherent aggregates not isolated from like bodies, oscillate at a period-frequency varying with the tensions that augment and diminish the state of equilibrium.     4. Law of Harmonic Vibrations:   All coherent aggregates are perpetually vibrating at a period-frequency corresponding to some harmonic ratio of the fundamental pitch of the vibrating body; this pitch is a multiple of the pitch of the atomole.     5. Law of Transmissive Vibraic Energy:   All oscillating and vibrating coherent aggregates create in the media in which they are immersed, outwardly propagated concentric waves of alternate condensation and rarefaction, having a period-frequency identical with the pitch of the aggregate.     6. Law of Sympathetic Oscillation:   Coherent aggregates immersed in a medium pulsating at their natural pitch simultaneously oscillate with the same frequency, whether the pitch of the medium be a unison of any harmonic of the fundamental pitch of the creative aggregate.     7. Law of Attraction:   Juxtaposed coherent aggregates vibrating in unison, of harmonic ratio, are mutually attracted.     8. Law of Repulsion:   Juxtaposed coherent aggregates vibrating in discord are mutually repelled.     9. Law of Cycles:   Coherent aggregates harmonically united constitute centres of vibration bearing relation to the fundamental pitch not multiples of the harmonic pitch, and the production of secondary unions between themselves generate pitches that ate discords, either in their unisons, or overtones with the original pitch; from harmony is generated discord, the inevitable cause of perpetual transformation.     10. Law of Harmonic Pitch:   Any aggregate in a state of vibration develops in addition to its fundamental pitch a series of vibration in symmetrical sub-multiple portions of itself, bearing ratios of one, two, three, of more times its fundamental pitch.
Enjoykin
