STRUCTURE OF DYNAMIC ELECTRON - SECRET OF 2nd MAGNETIC FIELD
  • 551 Views
  • Last Post 28 April 2018
Enjoykin2118 posted this 05 April 2018
This new physics concept, has been prepared to explain the theory of the EH Antennas and the HZ antennas. Document presented here, in layman’s terms, present a new form of radiation - 2nd Magnetic field or Hz field.
All members of CHRIS SYKES >>1 forum are encouraged to read “STRUCTURE OF ELECTROMAGNETIC FIELDS (WAVES) , OF THE DYNAMIC ELECTRON (mass - charge)” by Vladimir.I.Korobejnikov.
Several years of practical operation of EH Antennas have demonstrated very unusual properties of these antennas compared to the properties of conventional Hertz antennas. In particular, experiments have proven much greater penetrating abilities (less attenuation) of signals between EH Antennas compared to those of Hertz antennas in various media including water. The full explanation as to why this has taken place is due to the unusual electromagnetic field created by the ЕН-antenna.
The mathematical explanation for this is defined by enhanced Maxwell’s equations, which are detailed in the document referenced in the first paragraph.
The outstanding feature of Vladimir’s mathematical work is the realization that the electric charge in dynamic electrons always has two components - forward and rotary. As a result, the electromagnetic field of this dynamic charge consists of two complex components: two (2) separate and distinct electromagnetic fields. The properties of these two electromagnetic fields are very different in space. Conventional Hertz antennas work on the forward progress of electric charges (current) in the conductors.
A feature of the EH Antenna is that the cylinders have some conventional forward electron progress (current) but the ROTARY movement of the electrons is dominant. This sets up a condition to create magnetic streams counter to those of the tuning coil of the EH Antenna. The magnetic field from the tuning coil penetrates the non-ferrous cylinders in phase opposition (anti-phase) to the magnetic field caused by currents in the antenna phasing coil. Figure 1 exhibits the full structure of an electromagnetic field of a dynamic electric charge. The six (6) equations presented
in Figure 1 presented bellow are a results of taking Maxwell’s first two equations (defining the electric and magnetic fields) and enhancing them by applying them in three dimensions, as compared to the planer rectilinear motion of an electron used by Maxwell.
Enjoykin
Whole concept in a simple word is a TWIST. Electrons twist in the same place, while creating powerful longitudinal field reaction on boundary of the Aetheric filed/s. This HZ field under some special circumstances (boundary conditions) depending mainly from the coils parameters, correct phasing and Aetheric reaction become infinite in wavelenght or simply said open door Aetheric energies to get in your system..
One of many known methods to achieve this are critical tuning at critical frquency and making input/putput ports (entrance points) to powerful Aetheric forces. One good way to make it work is well known Chris Sykes Partnered Coils Configuration with proper phasing (timing).
Thats all for now.
Thank you
Enjoykin
Thanks Bob, you are righ 100%.
Old fashion REAL SCIENTISTS, like Tesla, Morray and many always used the ancient term Ether or Aether, nothing else, nothing more.
I also think that all answers we are looking for are hidden in ETHER,
Enjoykin
Antimony posted this 06 April 2018
This is sort of related to the subject, so I wanted to Share this link to see what you think about it.
https://www.everythingselectric.com/atoms/
Edwin Kaal: The Proton-Electron Atom — A Proposal
https://www.thunderbolts.info/wp/2018/03/11/edwin-kaal-the-proton-electron-atom-a-proposal-for-a-structured-atomic-model-eu2017/
I dont know what to think about it yet, but I trust Thunderbolts project enough to Share this link with you.
Enjoykin2118 posted this 06 April 2018
Thanks Antimony. This info should be studied.
Enjoykin
Marathonman posted this 08 April 2018
The Electromagnetism and Dark matter connection - A new theory
"We all know the electric monopole charge particle responsible from the Electric force, thus the electron.
However, we can not find the magnetic monopole charge particle anywhere in nature to complete that what we call Electromagnetism.
What if i told you that this particle is hiding in a domain aka eather all around us which has not electrons and therefore we can not observe it and it passes right through us but it is all around us namely 95% of the total mass of the universe!
You guessed correct..namely dark matter dark energy the modern version of aether. The elusive medium which binds everything around us.
Magnetism originates and is generated at the domain wall the only spatial region in the Universe were electric charge is balanced and E field is zeroed.
Therefore because in any two points in the universe from the macroscale down to the quantum level, the electric charge is unbalanced there is always a midpoint (domain wall) between them, where E=0, this is the exact spatial string where magnetism emanates out of the dark matter domain as a unknown yet magnetic charge particle or its quanta...is it the superluminal neutrino?...I don't know.
So yes on a magnet for example, which is may add is not just a magnetic device as wrongly mistaken but an electromagnetic device since electric charge unbalance inside a permanent magnet (induced during the magnetization process) will trigger its magnetic field, all magnetism i submit originates from its middle Bloch domain wall there where E field is zeroed.
This is a beautiful theory because it binds electromagnetism with dark matter domain proving that what we call electromagnetism (including unified strong and weak force) is an effect caused by the interaction of ordinary monopole electric charged matter with dark monopole magnetic charged matter everywhere in the universe and in any scale.
Also the stronger the electric charge unbalance between two spatial regions aka dipole magnet, the more the domain wall (tear into dark matter domain) between these two regions opens up and more magnetic charge emanates from the domain wall out of the dark matter to the ordinary matter thus more electromagnetism.
If the above theory proves theoretical or/and experimental true, and we consequently then get rid of the "action at a distance" dogma and accept dark matter as the elusive till now medium for energy and information transfer then we have also opened the gates and made the breakthrough for explaining gravity I submit.
Until then gates are closed.
In order to understand gravity we must first master Electromagnetism cause and effect.
The truth of Gravity passes through Electromagnetism..."
  This was posted by a member of EF by the name Markoul and was one of the best layman term description i have ever heard on the structure of our universe.
Marathonman posted this 16 April 2018
Here is some VERY good reading in the cause of electromagnetism. rather mind blowing to say the least.
 it also discusses the very reason we have EMF in the first place.
Marathonman posted this 28 April 2018
Aurther Kip and professor J.W. Duffin of the university of Hull states there are glaring mistakes in the very foundation of conventional theory of elctric currant. their work ended with verrying degrees of conflict and their end results totally invalidate the coventional theory.
electrostatic field is a charge partical that causes no currant flow and no curl. electromagnetic induction has EMF and has curl therefore the charge partical plays no roll in the EMF production.
they state that electromagnetic induction veries quite differently from  the electrostatic fields and that one can produce EMF and the other can not. thus the description that they give of electric currant produced by electromagnetic induction is completely non-electrostatic. an EMF of non-Electrostatic origin causes currant I to flow through a resistance R. electric charges play no part in the process. thus they realize that non-electrostatic force EMF must act on the carriers of the charges rather than the charge it's self.
this tells me that even though we have charge particals it is the charge carriers of non electrostatic origin (Ether) that causes the currant to flow.
this makes the charge superfluous.
just my two cents worth and i am not trying to make enemies as i have to mant of those already.
Chris posted this 28 April 2018
Hey MM,
A static Charge, stationary in Space with no Force acting on it whatsoever, is not a Current and as a result has no surrounding Magnetic Field.
Electrostatics is dealing with all Space at an absolute stand still. A snapshot in Time.
Of course, this is why so many questions lay unanswered, because this is not Nature, not our Reality, not how Space works!
Time, when this critical component is introduced, we see everything come back to life, Currents, Fields, interactions throughout Space...
The Atom can not exist without Time, the continual exchange of Energy Transformations would cease to exist!
To see how wrong Electrostatics is, take the following Equation:
Motion:
  • Position ( x )
  • Velocity ( V = δx / δt )
  • Acceleration ( a = δV / δt )
What happens if δt = Zero?
It does make me laugh how so many hold Electrostatics with such high regard, considering it is merely a small and incomplete image of Reality!
Scientists should know better!
After reading most in the series with a ton more to go it seams it is the closest to reality i have heard yet to the actual cause of current flow. a two dimensional magnetic field cancelling two of the three dimensional gravitation leaving the one dimension that allows currant to flow.
Very interesting reading at least for me anyways.
Hey MM,
I appreciate your honesty MM, I respect that! Everyone is different and has different Views
I to the same with you. i am just a student of life like yourself thus i remain open to other possibilities as our perception of reality is quite distorted and locked into place by elite in the form to control.
the present government control system hides the realities of thing and shackles the hands of professors and teachers. we should be taught my masters in their fields thus hitting adult hood will be masters ourselves.
since we are just the students of nature it is up to us to to wade through the muddy reality handed to us discerning what is right from wrong and pass that information to enlighten others.
i am still wading through the mud.
