Start Here - Simplicity and basic Facts to step forward.
  • 1.7K Views
  • Last Post 06 January 2024
Chris posted this 17 May 2020
I received a PM from a Member, saying that there is too much to learn to get a basic start.
There is, we have many hundreds of pages, many hundreds of hours of study, an over whelming number of hours reading and studding. For the average person, working and keeping a family fed and looked after, this seems far to much! A task that because of its complexity, and depth, is just too much for the average person to take on.
I want to give Advice, on steps forward.
We must always think about Energy and Energy "Generation"! Our Partnered Output Coils Pump Energy:
My Advice:
If you follow the following three steps, then fit the Cheap Simple Experiment in with the rest of the data as you learn more about the experiment.
Step One:
Review the Thread and Video Series: Non-Inductive Coil Experiment.
Step Two:
Focus on and replicate Video Seven. Focus on the Effects! Focus on improving the effects!
Step Three:
The Sawtooth Waveform is the defining waveform for Energy "Generation"! Focus on Energy "Generation"!
Keep things simple, you may remember my attempt to focus on simplicity, this video I have shared:
The Magnetic Fields and the Action, Reaction and Counter-Reaction is the path forward! Don Smith told us the same thing! Focus on the magnetic Fields, getting the Interactions working the best way!
Chris posted this 20 May 2020
For those that are struggling to make a Start, a certain amount of required Study is essential before you can work in this arena.
The Electron is a critical Subatomic Particle, a Charge Carrier, requiring a basic understanding.
Electrons radiate or absorb energy in the form of photons when they are accelerated.
Quantum mechanical properties of the electron include an intrinsic angular momentum (spin) of a half-integer value, expressed in units of the reduced Planck constantħ.
De Broglie's prediction of a wave nature for electrons led Erwin Schrödinger to postulate a wave equation for electrons moving under the influence of the nucleus in the atom. In 1926, this equation, the Schrödinger equation, successfully described how electron waves propagated.
There are two recognized types of charge carriers in semiconductors. One is electrons, which carry a negative electric charge. In addition, it is convenient to treat the traveling vacancies in the valence band electron population ( holes ) as a second type of charge carrier, which carry a positive charge equal in magnitude to that of an electron.
All Electrical "Generators" do two things:
  1. Separate Charge ( Positive to one Terminal and Negative Charge to the other Terminal )
  2. Pump Charge in the form of Current, 6.24 x 1018 electrons per second past point P = 1 Ampere.
Photon energy is the energy carried by a single photon. The amount of energy is directly proportional to the photon's electromagnetic frequency and thus, equivalently, is inversely proportional to the wavelength. The higher the photon's frequency, the higher its energy. Equivalently, the longer the photon's wavelength, the lower its energy.
Photon energy can be expressed using any unit of energy. Among the units commonly used to denote photon energy are the electronvolt (eV) and the joule (as well as its multiples, such as the microjoule). As one joule equals 6.24 × 1018 eV, the larger units may be more useful in denoting the energy of photons with higher frequency and higher energy, such as gamma rays, as opposed to lower energy photons, such as those in the radio frequency region of the electromagnetic spectrum.
Again, we must focus on Energy, the "Generation" of Energy and the Action of Pumping Energy. This is very simple stuff, all stuff that can be learned if required in a few hours or so. It is important, the way we think, it must be along the lines of Energy "Generation", focus on the Facts!
This very simple Post should give you an indication why we are so far advanced of the other Forums! We are Light Years Ahead!
Chris posted this 06 January 2024
There is NO MAGIC! Please, stop believing in Non-Sense that the Idiot Club want you to believe! There is no such thing as Magic! There is ONLY Understanding!
I want to make a point of "Focus" and "Attention" today!
Focus
In every single bit of Research I have done on the greats before us, I have noticed one basic fact!
All the Greats focused on one thing:
Powering a Load
Every single Load ever powered requires a Voltage and thus a Current! Every single person before us, all focused on the Generation of Voltage and Current to Power the Load!
Attention
The greats before us, all of them, all paid very special Attention to Electromagnetic Induction! An infatuation grew on Powering the Load, and they paid Attention to how this was done, and I quote:
CLEMENTE FIGUERA
This is just one example of many! Many times, we can see, the greats before us, they paid Attention to the "Generation" of a Voltage and supply of a Current, Charge at Velocity, Kinetic Energy, to a Load!
If you have not studied the area of Electromagnetic induction, I personally believe, you are wasting your time and everyone else around you! I can say 100% Majority of the community, over on the other forums, have no idea whatsoever, How Energy is Generated and Supplied to the load, they all think in terms of Battery and not Generator, or Storage and not Production!
It is true, the Dumb Dumb Club, will have you believe all sorts of Lies and Deception, they are just too damn Dumb to be taken seriously in todays world! We all know who they are! Filled with Parasitic-Ignorance, the Dumb Idiots, you know, the Mongoloids that continuously fail in the face of Evidence, in the Community, they are so very embarrassing! Idiots!
