Newest Ruslan Kulabuhov above unity generator -> 200V, 10A at the output.
Date 20 September, code 2020
Hi Aloha,
The video was also published here: ( Jan 13, 2016 )
I think video redistribution is more accurate. Good that people here are watching this! Good its getting public attention.
Hey Friends !
This is one of my favourites. A device which could be made as an affordable home solution.
@ alohalaoha As you are speaking Russian and English, maybe a translation of the soundtrack would reveal some helpful information?
regards Vidura.
The Translation via Google translate:
so hello everyone happy to welcome my
laboratories in general, I decided not
reanimate or reanimate your
the system that I showed everyone on the video
in the woods near the car not right there from
the coil from it is lying there in the corner I
decided to do a little differently and in
principle it turned out it turned out maybe
not be as powerful as
me then in the clearing but it doesn't matter
now, in principle, the very fact that
you can do anything and how much
anything and any power means well for
in order to start yes that is everything
believe that this is not a varnish, oh
yes, that is, this is a battery - we will remove it in
side
so this is a normal load here they are two
wires here they go go go on
light bulbs now i press the button nothing
happens
then under the tables under the chairs we
we are not observing anything, as it were
absolutely no extra wires
no gay yes behind masks nothing
you see everything that is everything is clear and clean
grounding means how will I prove it
grounding is easy, so I take it for
bare wire he and delirium into the ground and
nowhere else earth so
mother does not hit, we all know that well
I will deliberately open the lid and unscrew the bolt
and I will show that this is not a divorce
real land here it is here I take it
here you go
how I want that's nothing at all that is
the computer will work
I forgot about myself here right now I would burn
well, why would I strike it well?
this is an ordinary welding wire 25
squares
we hang it back
yes to achieve someone already with us so now
twist it here so that's it
order we close our resonant
generator so what else means the most
the main thing is the frequency multiplicity and understand
what happens in this system that is
current pushing occurs in other words
we do what we generate strong
magnetic field then just simply this
push the magnetic field with
high voltage which is
happens in this place she gets
using tesla coil means system
unfortunately not very stable here
so this is just a smoke version of the deme
the device means nothing more than what and what
here over here diode bridge capacitor
or marine 2 2 control relays
buttons and no left connections here
in general, it’s just that
for glass I wanted to make glass
did not become a regular power supply 24
volts and 220 volts means we supply
that we supply 12 volts to the system
power the system with 12 volts it
starts now we press start system
has risen disconnect the battery
we won't need it anymore
the system works how to prove that
the system works up to easy it is with us
earth is our load press the button
bulbs are on here total power 2
kilowatts burn very brightly, but maybe
to be two kilowatts, I did not reach here
since the voltage is on the tester
we put a constant current before we connect to
I show the light bulbs what's at the exit
DC will not turn over now
cons of this
on the tester here you are
at 203 202 I then had 198 this
no matter the lamp is on, it will be healthy at all
it’s impossible to even put out the light here
well, all great lighting and no need
on whom to depend and in no way everything
it works, so I lowered the frequencies
here the pot whistles slightly it is possible
hear
but that is what they call this ferrite but
in fact, I would also like to say
that ferries work at such frequencies
really can't, that's why it's not necessary
mock him a little to raise
the frequency here is now 16 kilohertz here
then what concerns under if I will not
close to bring the camera out
means the wire is thin 0 3 mm
dangles with a thick wire comes here
here i have a controlled tesla to
Sorry, she's moody, creepy it in
in principle, the system is crappy here
use couture driven couture
which will turn on in the floor wave and
push current in general, that's such a garbage here
it's impossible to even look at the light
camera in Moscow, well, something like this
the whole thing is up and running, chu can say
well, if it's kind of interesting that is
I honestly told you what Romanov said
about an oscillatory circuit with one
half stable other unstable
think about it and why
what pushes current current push voltage
voltage is high from couture and current u
us
crazy with why because
crazy magnetic field in inductors
coil everything looks like a classic
Tesla for some reason hides Islam here
so makar that is the inductor at the bottom
from above the whole coil that is, 100 beats
coil stability will be on top here
already reflected waves will go and
standing wave here is about the same
the most
well, something is shorter here it works
economy, let's measure it again
the tension there marvel wilds warmed up
probably already
so there will not be 202 volts 201 where there
the tape warmed up a little, I am and be healthy
see constantly
we put natural to 204 volts shorter
how to show nonsense because
on these wires along the way now
moving high treble
stress because all the bulls*it works
that is, if someone is in such miracles
do not believe but sorry to prove anything
I won't be stupid
that is, Nikola Tesla always said if
do you want to make a note back
voltage systems your chances are equal
zero if you want to self-feed
using the magnetic field your chances
are equal
the very success you are now
you will see that is, this is the system it is
this is how it works and in fact there is nothing here
no complicated the only thing for that
so that her
let's say industry use
there either I don't know to put on the stream or
something like that, well, you have to do
normal this very normal
phase-locked loop so as not to run away
frequency well and think about that
of course stable, by the way
now I'm thinking about what to do
kapanadze the Russian system
so most likely 4 bulbs of 500
watt and the system works please all
like a classic, what I already have for you
showed this installation the coil was working
rewound and changed a little frequency but
it doesn’t matter so it’s like
what i wanted to tell you i think that
already told these are shorter
talking pies
I hope you have an idea in your head
how all this is happening now
forget that the oscillating circuit
such a resonance
very good friends with Tesla like this
here is a little tip
why do many people say
shout at us a diagram and there is still such a thing
in fact, a diagram is born in my head
different means well, I wanted to show what else
one interesting thing is that the system
a little light is shining beautifully now
when I put out here the backlight I made here
so well it certainly is so small
blogging my now purely for fun
there the backlight shines there LEDs and
the very tip of the fans is red
this LED is bright white
shorter than 10 glass by it's simple
in order to believe well and
load of 2 kilowatts here already of course
then nothing is visible burns unreal in
my eyes are shining so I hope you like
understandable well, although in principle, many wind
the coils are trying to squeeze out something with it
nothing succeeds
well, this is natural that is, as it should
work a little to understand
how the oscillating circuit works and in
principle, this is the reel that the shark shook
she is not quite right here
to personal reel she is a little better there
three three separate coils which
work
properly separate
oscillating circuit separate removable
the coil is given which it is just stupid on
the diode bridge goes directly without any
generally yaki well inductor which is usual
induction whole shark used
the q wave because
induction he when
here's a crazy magnetic field that's us and
everything must be achieved in short
dare the bulbs are burning impossible here
they are already being fried like this
pies
bye
The two large outer coils are what make up a permanent magnet they are dc powered. Each wound same direction and in series. acting like a large permanent magnet creating a unidirectional field, against which you clap whit sinewave on the bucking coils on the core. the magnets is what you get for free.
half stable part is the magnet the other half is the bucking coil vacuum triode amplifier, with the center tap earth ,beginning and end wires osc on one and load on the other. with here is proof :
in this chamber rf antenna is bucking coil the PMs envelop the coil and tube
this is helicon wave plasma source.they still cant explain the energetic plasma created. google it. just replace the glass tube with ferite, or put water with iron rust and salt hydrogen for small amountsin the glass you get electricity with the sweet floyd method or get crazy hydrogen for little input.
you can increase frequency higher because core wil be stable. acting as block wall.
ill elaborate more i got to go
what floyd sweet and stan meyer didnt have is neodymium magnets. well floyd sweet made his own.
Hi to all.
I am a big enthusiast of Kapandze, many devices have been created which are demonstrated on Youtube .. my favorite is the just mentioned BTG by Ruslan Kulabuhov .. Unfortunately I am very embarrassed at the moment how it is with this device .. While browsing Youtube I came across a video from Sergei Mr. who has the same device. While watching the video, we found out that he bought this device from Ruslan. And this is where my doubts about the functionality of this device begin.
It was found that this device does not work the battery and is fraudulently powered by the phase .. I'm bad about it, if someone knows more about otm or help me clarify .. I have downloaded files from this video .. I do not know if I am here to put a video or downloaded files so that it doesn't conflict with copyright. Perhaps it's not bad when I write my doubts here, I just don't want us to spend hours here on this device and it's a dead end. Sergei Panov sued Ruslan. everything is comprehensive in the video ..
All the best
Hello Strape,
Please post, I will let you know if we get a Copyright Claim.
There are many Rabbit Holes, and we wont know until we get to a certain point before its worth it or not. So don't worry about this.
We have all the answers we need here, Asymmetry mixed with Electromagnetic Induction is the answer and Path forward. If you look for answers, please study our Above-Unity section.
Thank you for onfo and I'm attaching a link to the video, it's worth a look at everything .. Although the gentleman is quite talkative and still in rustine, I still learned a lot ..
This is the ninth last video, it's worth watching everyone .. It can be seen that Sergei Panov is in dispute with Ruslan ..
I have the document file in zip. but unfortunately it's big enough and it can't be inserted .. or we figured out how to insert it here ..
Hi Strape, I have followed this story time ago, when member MrBlobby posted this series of YT videos. I am very confident that the BTG devices from Kapanadze, Akula83 and Ruslan are all authentic and operational. The issue is that they are not plug and play, they need a very thorough tuning and are very sensitive to grounding conditions. I believe that panov made the device work finally, but was intimidated by payed violent trolls and received harassment against himself and his family. His intention was to reveal all the information contained in the construction of the device, which would not be tolerated by the establishment. Therefore he had to retrieve his published information and declare it as a fake. This things had happened more than once in the past. Regards Vidura.
I agree with Vidura,
I would not take one story over many Hundreds. Kapanadze has a very good record, solid 30 years of working machines with hundreds of demonstrations.
NOTE: All those demonstrations and only a hand full of people have been able to replicate the KappaGen!
Some people can be very destructive, anything new is attacked and the person is attacked with many nasty messages/posts and sometimes even threats. That's why I started this forum, to control this. Most here know the trouble we have had in the past on other forums! The Trolls we have faced and now have totally eliminated!
I also followed some of the stories in the videos you mention, to be honest the excuses were truly laughable! Things like the ground wire hiding another cable, which is not true at all.
I am a firm believer, go with your gut feeling, if you believe the videos, then go with that, if not, then go with that also. We all have an intuitive sense and most can pick truth from lies. Most of the time, truth, matches your gut feeling. That's why we have so many good people here, because they can see through the lies and disinformation on Other Forums. We do not allow for the active spread of Disinformation! We despise it!
We protect Truth and Evidence, that's where the real path forward lays!
P.S: Financially, it is in many peoples best interest to Suppress this Technology! The Owner of the world largest Hydro Electric Energy Company, for example, would want this Technology Suppressed!
Hello everyone
Thank you for your contributions, I was immediately relieved ...
Yes, I agree that these devices are very sensitive to tuning, we have seen for ourselves.
Regards strape
Hi guys i hope you had good hollydays for Christmass ,i wass speaking with Delamorto about the melnikenco flashlight and he gave me something that he think is more usefull i will put the photo about it is related to kapanadze and Ruslan devices. i hope is of help .
Best wishes
Mitza
Look, I have one thing to say about Ruslan Kulabuhov. I somehow believed him. He never talked shit, looks like he knows what he is talking about. I don't want to say that everything from him is fake, I won't say YES or NOT. Just think what you want. I just don't like to talk shit mindlessly about other people. Now, I will just talk about his flashlight only. His flashlight (very bad Akula's replication, in reality it is just a blocking generator, had nothing to do with Akula's one), now looks like 100% fake to me. I have some zip archive (I can share if needed), in which you can see the fake. But still I wasn't sure about this fake revelation, it is just a bad quality fake revelation. Ruslan never said that it is self-running device or perpetual. He adviced, that it will work for some time (like 1 day, on a 1000-2200uF capacitor), then the ferrite will self destoy, conveting into dust. So you will need to replace ferrite (pot core in his case).I still don't say that he is a fake maker. To clarify, I don't mean that Sergey Panov is the good/bad guy and Ruslan is bad/good one.
Also, I replicated and analized his circuit. And also Akula's. And yes, I also had the needed oscillogramme, about which Ruslan talked. And yes I also have russian transistors.
Ruslan started to streaming in his Youtube channel "Ruslan K", he doesn't like to make videos, he wants only streams, I could to save his streams (yes, I can share if needed).Well, in one of his streams, at some moments, he shows his flashlight. BUT accidentally (I think), on the upper side (looks like shelf to me) he had a reflected his desktop table in it, you can see a bit what he does with flashlight before to show it to the camera (he wants just to show that it is still lighting), and he did it like 3-4 times. Well, in the reflection you can see this flashlight, and it is clearly not lighting, every time he tooks it, he activates some switch (not by putting 9v battery) and instantly the flashlight starts to light, he does it before to show it to the camera. After showing it, he puts it back at the desktop table, you see it in the reflection of the shelf, and before to remove the hand from the flashlight, he clearly turns it off. Then, someone asks him if the flashlight is still lighting, and he (Ruslan) says yes, and brightly (you see no light on it). When he shows it again to the camera, he does the same, he puts the hand on it and turns it on with some switch (not by putting 9v battery) (you see it in the reflection of the shelf), and again, when he puts it back at the table, you see that he turns it off. It looks like some hidden circuit with battery inside the flashlight (not some hidden supercapacitor).
Here is link, I uploaded this stream, read the text above before watch the video:
https://lbry.tv/@%D1%87%D0%B5%D1%88%D0%B8%D1%80%D1%81%D0%BA%D0%B8%D0%B9_%D0%B7%D0%B0%D0%BB%D1%83%D0%BF%D0%B8%D1%81%D1%82%D0%BE%D1%80:1/Ruslan-Kulabuhov-flashlight-on-batteries-%D0%A0%D1%83%D1%81%D0%BB%D0%B0%D0%BD-%D0%9A%D1%83%D0%BB%D0%B0%D0%B1%D1%83%D1%85%D0%BE%D0%B2-%D1%84%D0%BE%D0%BD%D0%B0%D1%80%D0%B8%D0%BA-%D0%BD%D0%B0-%D0%B1%D0%B0%D1%82%D0%B0%D1%80%D0%B5%D0%B9%D0%BA%D0%B0%D1%85:b
If you have problem playing this video, please disable your adblocker.
See how he turns on and off the flashlight:
2:03:54 to 2:05:15
2:14:43 to 2:15:00
2:53:14 to 2:53:25
3:29: 35 to 3:29:47 (damn emoji 3:295)
3:51:22 to 3:51:55
Look here, another video, it is not clear, but:
See from 0:53 to 1:23, here he starts it directly from 9v battery, because 6.8 ohm resistor is burnt (he says). On 14:19 flashlight is dead LOL.
Ruslan's flashlight is just a bad blocking generator, with additional not needed components, some of them are connected to the air (not connected), do not replicate it. If you want a solid blocking generator, build LaserSaber's one.
I really, very disappointed about Ruslan. I believed him like a brother.
Hi Vita i am speaking about the Ruslan flashlight i saw the circuit and is like a simple joule thief made with pot core and just the transistor is functional as joule thief the ic signal generator is not even conected corectly and some pins in the air . i spoke with him few times but he dose not explain clearly and he sad is very dificult to set up the device if i dont know what i am looking for , he sad i need to learn more about quantum fizics and what is energy and stuff like that . nothing specific. lasersaber is beter choice to follow for pot core devices .
Mitza
Yes, it looks like some joule thief (because of coil connections), but it is looks more like blocking generator to me. 74HC14 it is not connected, even if somehow VCC is connected, here is clearly no connections for frequency or duty tuning. Aaaaand, some pins are just shorted, which is not supported by this IC. Clearly IC is not working. He says that he helps, but he never releases his circuits.
Read my message above, I will add things soon.
LaserSaber he is 100% not faker. I reaplicated something from him, and his circuits are working.
I wait for updates from you Vita good job. And about the photo i posted above from Delamorto Vadik he told me about what he think is happening in kapanadze coil
Mitza
