Romanian ZPM (Zero Point Module) - Enhancements Stage
  • 9.6K Views
  • Last Post 4 days ago
Fighter posted this 27 September 2019
As the ZPM thread has so much content that it started to load slowly especially on mobile devices, I'm creating a new thread continuing the initial thread.
If you want to search for specific information posted in the initial thread you can find it here:
In this initial post I'm also adding the donation section as I did in the initial thread:
If you find ZPM intriguing and the experiments and data I share here with you useful for your own projects and research, you may help the further research by donating:
Your support will be very much appreciated and it will be used ONLY for equipment and building customized electronics for further research and experiments.
If you're working with a ZPM replication please share your findings here like I do so we can enhance this device.
Thank you,
Fighter
Fighter posted this 29 September 2019
Another UA7812 voltage regulator from the MOSFET driver smoked:
So I decided to get rid of this approach with voltage regulator for powering the switch LED, now that LED is powered by the separate power used for cooling fans and switched on or off by the main switch. Those switches have two set of contacts so when switch is turned on it can close two separate circuits.
Another thing I did was to put high-voltage super-fast SF28G diodes on the MOSFETs but I had some problems with this, when exploring with different frequencies few times I had sudden surges of the power drained from the DC source, the source entered in auto-protection and the 12V/55W light-bulbs from ZPM's output became extremely bright and were destroyed. So far I lost 3 light-bulbs of that type, I have only one left which is still functioning (link to larger image here):
For some reason seems ZPM doesn't like those protection diodes and at certain frequencies it suddenly starts draining full power from the DC source and smoking the 12V/55W light-bulbs.
For now I have set optimum frequency and the 12V/55W light-bulb seems to work fine but probably as soon as I will encounter one of those frequencies the same thing will happen again. If it happens probably I'll remove these protection diodes, I don't like this behavior and it's provoking damages, I don't know what's the reason but it's a fact.
cd_sharp posted this 29 September 2019
You need to limit the current using a resistor to 10-20 mA, whatever your LED needs. 12v / R = 0.01A.
It's okay, now I removed that voltage regulator and both LED's are powered by the separate circuit powering the cooling fans. I suppose that voltage regulator didn't liked the pulses present on DC source's input, it expected clear DC voltage there.
Fighter posted this 30 September 2019
Sorry but that's an abnormal situation, not only the light-bulbs are destroyed but the DC source enters in auto-protection mode.
Is nothing to measure in that situation, I intend to avoid it as it could destroy my equipment...
Fighter posted this 01 October 2019
Finally found some time to check the PowerSource, I verified IRFZ46N's drain-source continuity and found they were shorted so the MOSFET was damaged by that malfunctional DC adapter.
After I removed the MOSFET I checked that the circuit where its gate pin was is still receiving square wave signal:
As you can see the square wave was present so I mounted a new IRFZ46N. I must admit I had some big concerns as my soldering tool is not that delicate for this kind of fine/small circuits so few times I was thinking the copper areas where the MOSFET was soldered will be destroyed by the heat of my tool. There was a high risk of damaging the circuits from the MOSFET area...
After I finished I've made a test with the PowerSource module powering up a PowerSwitch module driven by my signal generator. Wanted to make sure the repair succeeded:
So now the PowerSource module is functional again but I don't intend to use again a cheap DC adapter, I bought a 12V/2A AC transformer and a big 4700uF electrolytic capacitor and using one of the bridge rectifiers I already have I'll build a dedicated DC adapter:
Of course I'll build it when I'll find some time again...
Fighter posted this 10 October 2019
Just a short post, a few days ago somebody asked me through email what's under that red tape covering the middle of the Metglas, if there is a gap and if it's something in it which I don't show:
There is no gap or something secret there, I did put that red tape when I first built the ZPM in order to to keep as close as possible the both pieces of the Metglas core together. To have everything crystal-clear I removed that red tape and used a strong plastic zip tie to continue keeping the pieces of the Meglas core together (link to larger image here):
All the information about ZPM is public, complete and published in this forum. And will always be this way.
It will be updated as I continue the research depending on the free time I can find.
Thanks,
Fighter
Zanzal posted this 10 October 2019
Hey Fighter, while it is very nice of you to show that there is no secret sauce hiding under the tape I would urge not to get distracted with changes to convince people. I take you at your word that the device is exactly as you describe it. Do what you think is good, but you don't need to appease or convince the naysayers IMO.
Chris posted this 10 October 2019
Hahahaha Yes, I agree with Zanzal!
"Whats under the tape", hahaha a 26 Plate Lead Acid Battery?
Apologies, they say: "Sarcasm is a metric for potential - Howard Stark"?
I agree, sweep the silly aside!
Hahaha, the joke about the battery made me laugh after a hard day at work, thank you Chris !
I don't know who the guy is but most probably he was thinking about some permanent magnets or God knows what kind of "secret" thing hiding under that red tape.... Well, I think he didn't expected me to reveal the "secret", I may disappointed him, I apologize for this...
patrick1 posted this 11 October 2019
lols yes, although it must be said. i dont see any nay-sayers.  more like kids in a candy store
Fighter posted this 14 October 2019
I've build the customized DC source for the PowerSource from Vidura, I tried to make it as compact as possible (link to larger image here):
I put the bridge rectifier directly on the transformer's core so the core can be used as a radiator if the bridge rectifier becomes warm.
But there are two problems with it:
  • the 4700uF/100V electrolytic capacitor seems it's not doing its job very well, I have a 620mV Vpp, the capacitor is brand-new;
  • the output is not 12V as I expected, it's about 16V.
The transformer is 230V/12V and also brand-new (link to larger image here):
@Vidura, I suppose this is not acceptable for powering up the PowerSource, isn't ?..
About voltage I suppose I could put a resistor on output for lowering those 16V to 12-15V but I'm not sure what electrolytic capacitor I should use in order to have a linear DC.
I need to check on the scope the output of the 12V secondary, maybe the factory put more turns on it and it's actually 16V there...
Vidura posted this 14 October 2019
Hi Fighter, This voltage is normal when it is rectified and a capacitor connected. The rated transformer voltage is RMS , and so the output rectified and filtered will unloaded output the peak voltage. Anyway 16 volt should be ok, the driver IC is rated up to 18v if the resistors of the snubber circuit becomes hot you can lower the duty cycle on the preset of the module. Regards Vidura.
I suppose that the scope trace is the ripple, 620mv is no problem at all , it is filtered again in the module , and the final stage, the power switch modules have a filtered voltage regulator, there will be pure DC always.
So this output is acceptable for PowerSource. Then next when I find some time I will start tests with ZPM.
Thanks for clarifications Vidura, I really appreciate your help...
patrick1 posted this 14 October 2019
Hello Fighter. im liking your work. very much similar too mine, although your desk is in much nicer state ;=).
i wonder how your machine will respond,  if you try too add a bridge rectifier across the output in addition too the light globe,  and put a second light globe at the bridge output,   ....
i am also curious if you were too use ONLY an output bridge , with a series globe on the bridge input, - and perhaps an additional globe on the output again,  i dont remember this being mentioned by our members as yet.
Hi Patrick, thanks but you don't want to see the mess on my desk when I'm soldering something or repairing or building something new
About bridge rectifier on output, I had an attempt at the beginning, with a bridge-rectifier I've made with two channels and Schottky diodes (you can see images of it here: https://imgur.com/a/bn9gj).
It didn't worked, ZPM destroyed one of those electrolytic capacitors, the capacitor became that hot that I wasn't able to touch it for few minutes after I stopped the experiment. I suppose normal electrolytic capacitors are not made to withstand thousands of KHz frequency and considering these spikes of 100-200V I see on scope on output sometimes that poor capacitor had no chance because it was 10000uF at just 50V. Right now I don't intend to try that but I may try again in the future if I find electrolytic capacitors capable to work at ZPM's frequency. That was a failed attempt and I will need to find the cause of the failure before trying again.
Today I found about one free hour so I've experimented with ZPM and Vidura's PowerTool.
I recorded this video:
Sorry I'm not that good at presenting, while i was talking I tried to not miss anything relevant therefore the pauses/delays - while talking I was always thinking what to talk about next.
Here are some images taken with this configuration.
In these images I have the oscilloscope's probe connected directly on ZPM's output (link to larger image here):
And in these images I have the oscilloscope's probe connected on the light-bulb's pins (link to larger image here):
The ZPM's specific waveform pattern is present on output, maybe a bit different than what I saw with my MOSFET driver but the cause could be that my driver is using one of those Cree MOSFETs, I intend to use one of those on the PowerSwitch in the near future.
A difference I noticed is the light emitted by the light-bulb on output seems to be pulsing at high frequency but it's noticeable, this is not something bad it's just something different.
As it happened with my MOSFET driver too, the MOSFET's radiator on the PowerSwitch is becoming very hot in 20-30 seconds so in order to be able to have longer experiments I'll need to build a active cooling system for the PowerSwitch like I did for my MOSFET driver.
And another (short) update: I definitely need to remove these diodes because while setting back my MOSFET driver and finding optimal frequency I encountered again one of those frequencies, this time the light-bulb survived, the DC source entered in auto-protection mode but one of the Cree MOSFETs from the driver (from the channel which was in use) is dead. Definitely ZPM don't like those diodes there and they are provoking too much damage, I will remove them as soon as I find some time to take care of this...
patrick1 posted this 15 October 2019
Thiis strange flashing effect, is also present on my ZPM build. - however i think its due too the output on the signal generator. - which i do not believe is damaged.  it only happens as specific frequencies, - that i have noticed. - around 100-200khz. but critially it seems tied too the output voltage of the signal generator. -
i am using IRFP N250's ,  which taper off between about 100khz and 800khz., and they seem too appreciate about 8-11v from my identical signal generator.  - and will not operate directly from the signal generator without at least 5volts. -    but i seem too recall when you were using the identical transistors, you had your signal generator voltage turned right up.  - which is also what i have been doing....  - this prevents the flashing phenomenon so far as i can tell .yet.
Fighter posted this 15 October 2019
Yes that is correct, I'm using minimum AMP (5V),I'll try to go up with the AMP value of my signal generator. I don't know how much I should go, I don't want to damage the PowerSwitch but this could be the cause.
Also recently I removed that red tape keeping together both pieces of the Metglas and I'm using a zip tie now, that could be a cause too, maybe that zip tie is not keeping the Metglas pieces together tight enough and there is a small gap in the center of the Metglas.
I'll investigate, thanks Patrick.
I also had some private messages exchange with Vidura so it seems for avoiding that light-bulb flickering I should go up with the AMP on my signal generator while monitoring the voltage on PowerSwitch's MOSFET gate. I will take care of that when I find some time, sorry about this but I still have things to learn and to accommodate myself with Vidura's PowerTool.
Edit: One of Vidura's PowerTool tutorials is about this calibration step for the signal generator, I saw this video but I didn't do this step:
I'll need to do this one-time calibration step for AMP on signal generator in order to have it working well with PowerTool and avoid that light-bulb flickering.
Fighter posted this 17 October 2019
I replaced the dead Cree MOSFET from my MOSFET driver and removed the diodes which caused problems and provoked damages:
Unfortunately this new MOSFET had a short life, I had an experiment where I tried to use a choke-coil to smooth the voltage produced by a 10A/75mV (0.0075 Ohm) current-sensing shunt on the input.
I learned a lesson, choke-coils provoke damages if they are placed anywhere in the circuit. The choke-coil made the DC source enter in auto-protection, burned the new Cree MOSFET and also destroyed the last 12V/55W light-bulb I had:
I remember I had similar damages before when i tried to use choke-coil put on DC source's output trying to smooth the noise/spikes coming back from ZPM.
So right now I'll need to order some new 12V/55W light-bulbs and as the last Cree MOSFET is already placed in the MOSFET driver probably I should order some new Cree MOSFETs too.
Until then I still have some halogen light-bulbs, I'm gonna use 2 x 12V/35W on output.
The goal of the choke-coil experiment was a first step in the process of building a real-time current and voltage sensor on input and output without oscilloscope, using just some 10A/75mV current-sensing shunts.
As this one experiment failed I changed the approach: what about using (for the beginning) some LEDs as visual indicators of the current passing through the shunts ? Of course that's not a precise measurement but the LEDs could provide at least a clue of what's going on with the current on input and output in real-time while experimenting with different parameters on the signal generator. A next step would be, if I succeed in rectifying the voltage provided by those shunts, to place digital voltmeters measuring in real-time the voltage provided by the shunts so actually providing in real-time the accurate current measurements on input and output.
So for this first step (LEDs as visual indicators for current) I took two identical LEDs from two identical Chinese lighters where those LEDs are powered by 3 x SR626SW (1.55V) batteries (link to larger image here):
So this is the result (link to larger image here):
So for now I have some real-time visual indications on current values on input and output.
From now on I can experiment not only with frequency but also with AMP and duty-cycle on my signal generator and see what's going on with the current on input and output. In the following photos I tried changing these parameters. In reality the luminosity difference between the two LEDs is easy to observe but seems my phone is amplifying low luminosity sources and dime high luminosity sources when taking photos in dark. But still you can see these differences (link to larger image here):
Just as a note: the current-sensing shunts are identical and the LEDs are identical in luminosity, I verified that by switching the shunts and LEDs between input and output and having the same results (in terms of LEDs luminosity). So I checked that both shunts and LEDs have the same characteristics.
And I took one photo which I think is very significant, I played with parameters in order to see if I can have the LED on input off while still having the LED on output on. In this photo you can see the current on input is clearly not enough to light that LED while on output you see the LED still on and also on the left 2 x 12V/35W halogen light-bulbs still on (link to larger image here):
I am aware about the voltage differences between input and output but considering on input we have 25V and on output we have spikes between 100V and 200V in my opinion this image gives an additional clue about ZPM's over-unity.
The next goal in building this real-time measurement system is finding a way to smooth the voltage provided by the shunts so that voltage becomes DC (link to larger image here):
If I can have clean DC voltage provided by the shunts then I can use it it with some digital voltmeters I just bought so I can have accurate real-time digital display of currents on input and output.
So for now the problem is how I find a way to get DC from this but without choking-coils (link to larger image here):
I'm thinking of building bridge-rectifiers using these SF28G super-fast diodes then maybe some capacitor(s) for smoothing the voltage. I'll see how it works.
I'll post updates as I find time to continue the experiments...
Vidura posted this 17 October 2019
Hey Fighter,
Sorry about the losses of the Mosfets, they are kind expensive. If I may make a couple suggestions to avoid this damages on your custom made switch:
use MOV as surge protectors on the drain - source terminals, the max. value K420 which clamps around 1100V maybe better a K400 for more safety margin. Do not attach other components as the Mosfet on the heat dissipator, although you use insulation pads, the high frequency currents will pass thru. Be careful when placing a grounded scope probe on the center tap of the coils, as this will shift the hot end (longitudinal high potencial) to the other terminals, where the switch and Power supply are placed , and may cause interferences and failure.
I wanted to say that I love the idea with the LEDs on the current shunts, this visual indicators really make our work easier, maybe you could add a second led with oposite polarity to the shunt, which will give indication on the direction of the currents also. keep up your good work, VIDURA.
Yes they are really expensive and unfortunately they die so fast on every failed experiment. What can I say, I expected them to be more resilient but this is the cost of researching this kind of devices we're working with...
Right now I don't know what exactly changed in device's behavior when I placed those SF28G diodes between drain and source but after that I saw appearing these dangerous frequencies which killed MOSFETs and light-bulbs, that's why I removed the diodes. They were supposed to do exactly this - protect the MOSFETs, but it was exactly the opposite.
Right now I kind of hesitate to try with MOVs between source and drain of the MOSFET as this is the last Cree MOSFET I have until I can order another batch, I'll try when I'll have some backup MOSFETs.
About attaching other components on the radiator inside the MOSFET driver, I will not, I had that voltage regulator attached before but I found a solution to power that LED on the front panel without the voltage regulator. So right now I have only one MOSFET attached to the radiator, for the other channel of the MOSFET driver the MOSFET is missing, didn't mounted one there anymore.
About the center tap of the coil, I've made measurements there with oscilloscope probes some time ago, didn't had any problems or failures, are you saying that could destroy my equipment ?..
Thanks, necessity force us to build the tools we need for this kind of devices... These LED indicators are just the beginning, I will try to get pure DC voltage from those pulses you see on the scope in my previous post, if I succeed then I'll be able to use that DC voltage with digital (and maybe analog) voltmeters which will actually show accurate real-time current measurements on input and output, I hope I'll find a way to accomplish that.
Yes, having a second LED with opposite polarity is also a nice idea and very useful, that way we can "see" the currents going in both directions through the shunts, I will try that, let's see how it works
Vidura, I tried putting a LED with inverse polarity on both shunts (from input and output), the LED doesn't light up at all.
But I found something on output, when connecting LED's positive (green connector) to the negative of the other LED while the negative of the LED (white connector) is in air we have some kind of one-wire transmission, the LED light up just as powerful as the one from the shunt (link to larger image here):
This makes me think of something, should I be concerned about the electromagnetic radiation around this thing ?...
Maybe I should make a box covered with aluminum foil like a full Faraday cage to cover ZPM while it's active ? I was thinking about this sometimes before but I didn't noticed any negative effects while or after making experiments. Maybe I should reconsider this.
Zanzal posted this 17 October 2019
When searching for a mosfet - I recommend this approach - Sort by rdson - look for as low as possible - find mosfet with appropriate voltage rating and lowest gate charge (Qg), pref around 50 nC or less. Check the price per unit and if it is reasonable then it may be worth using. You may need to compromise a bit, for this reason you may find that adapting your circuit to a lower voltage mosfet may offer an advantage.
A quick explanation of my perspective:
Thermal failure is a universal failure so low rdson is typically the most important characteristic, especially if the power is greater than a couple watts.
Voltage rating at first glance may seem important, but I've found that some circuits can easily exceed the voltage rating for a mosfet and the mosfet may clamp voltage at its avalanche voltage. So a mosfet rated at 60V may not fail immediately but could just avalanche (causing losses and extra heating). You can try to design a snubber circuit to clamp the voltage spikes to avoid needing to use a high voltage mosfet. So while operating voltage is an important consideration, there might be better ways to handle spikes than just using a HV mosfet. You can experiment with adding snubbing circuits and see if it negatively impacts AU device performance. I can't tell you if this is appropriate for your device.
Frequency range will determine if the gate charge along with the on/off and rise/fall characteristics are deal killers. For low frequencies, these details may be relatively unimportant, but once you start to go above a couple kHz these things may begin to make huge differences. Keep in mind, high rdson compounds any problems you will have here as the mosfet may spend less time fully on or fully off and rdson only tells you the lowest nominal resistance in the fully on state.
Anyway, these are just opinions from a non-expert. I am curious to know if you find mosfets that work well for your application. When you do, please share the part number.
Hi Zanzal, I'm also a non-expert but I find it's a lot to learn from your post.
C2M0160120D made by Cree/WolfSpeed seems to be the fastest HV MOSFETs on the market for now and, even if they are expensive, during my research (after Vidura told me about them) I didn't found information/opinions about more performant ones.
But using your criteria of selecting who knows, maybe I'll find others better in terms of matching ZPM's circuit, I'll keep these criteria in mind and I'll search.
Of course, if I'm gonna change the MOSFETs model I'll post updates here.
Thanks.
Hey Fighter, I am using the Cree MOSFET s in all my latest experiences, and have not lost one till the moment, the performance is really excellent and the RDS on the lowest in that voltage range. But I always use MOV , it's a must, also the zener diodes for gate protection are strongly recommended, and I didn't note any negative side effects for using this protections. Regarding the effect of single wire transfer it is obvious, you have high frequency longitudinal oscillations, this is why the current not always behave like expected, and the reversal LEDs on the shunts might be off most of the time, but they will indicate when a reversal current flows, which might occur only with very specific parameters. I hope this helps and explain some things. Vidura
Jagau posted this 18 October 2019
Yes Vidura
 zener diodes for gate protection are strongly recommended and a totem pole activation for the gate is also a must to preserve the shape waveform that activates the gate.
Hi fighter
I just received my metglass and I notice they have a very high saturation chest 1.56 Tesla compared a ferrite it is well better.
Nice experiment to do.
It is a hitachi amcc320
Fighter posted this 18 October 2019
@Vidura I know about their performance, the only issue I had was about those dangerous frequencies after I put these protection diodes, I don't know why it happens but seems ZPM don't like having these diodes on MOSFETs.
For sure I intend to give MOVs a try when I'll have some backup MOSFETs for replacement just in case MOVs create the same behavior.
About the single-wire transmission that was fun to see but still after I saw that phenomenon I wonder how strong and how extended is the electromagnetic field around ZPM and if I should take measures to shield it during experiments. What would be your advice about this, what would you do ?
About the additional LED indicators, I understand they may become active in certain situations so I'll certainly add them to the shunts, even if they don't light up all the time as I kind of expected your idea is neat and very helpful, thanks !
@Jagau That's a very nice core ! I suppose you will try a ZPM replication ? If so welcome to the club, I'm glad and I'm curious to see how your experiments work, please share them...
Yes, saturating that core would be kind of difficult, that's one of the special characteristics about Metglas. Being made by Hitachi make me sure your core have exactly the same physical characteristics (related to alloy composition and production process) just like mine because those guys have a strict production and quality control process.
I gathered two quotes from the old ZPM thread which I think could be useful in understanding more about Metglas:
I'm putting links about AMCC-200 technical specs here:
Hitachi - AMCC Cores Technical
Hitachi - AMCC Cores Presentation.
I recommend checking how Metglas cores are produced and read about their special characteristics so you know what you're dealing with; remember Metglas was something produced in 70s for military and space technologies.
Actually this is Metglas - a iron core. Its composition is 85-95% iron, 1-5% boron and 5-10% silicon as specified here. But what's special about this core is it's made of foils created by melting the compositions under high heat then cooling it down so fast (almost instantly) that the Metglas alloy don't have time to form a crystalline atomic structure when it become solid again like any metal does when being melt then being cool down normally. That's why the metals obtained this way are also called amorphous (their atomic structure is not crystalline like the usual metals).
You'll notice the differences about AMCC compared to other cores, enjoy your experiments and can't wait to see it at work !
Vidura posted this 18 October 2019
Hey Fighter, Note that the SF28 diodes are not TVS devices, and thus can not be considered as protection, if connected in parallel they would only bypass the internal body diode of the MOSFET. But as the internal diode of the cree devices is already very fast, it don't make much sense to place it in that way. I think there was a suggestion to put a diode in SERIES with the MOSFET , to prevent the effect of bus pumping, or current being sent to the supply, which would make more sense. But maybe it is better to test this things with a cheaper MOSFET first, or an IGBT, for a short time would be okay. Regarding the radiation (longitudinal) , there are several reports of being beneficial for health, but this might depend on the frequency also, actually there exists a device based on Tesla oscillators used for cure several diseases, development of a Russian investigator. I have many years worked with Tesla coils and i think i didn't note any negative side effects. But if you like you can anyway use a shielding, or keep some distance for any case. The only thing you should take care is that at the hot end of the coils you might get rf burning if you touch with bare fingers, this effect is stronger with lower frequency, so the core devices can make smoke your fingers in an instant 馃榾. Vidura.
Fighter posted this 20 October 2019
@Vidura, you mean to put the SF28 between DC source and MOSFET driver on the positive wire ? I remember I tried that with another diode, I admit it was not a super-fast diode. I can try this scenario too, thanks.
About touching the ends of the coils, I was thinking to get some protection gloves for electricity, for safety I'll buy some. Considering there are spikes of 100-200Vpp, at what frequency could that become dangerous ? Right now I don't go below 80 KHz, usually I'm in 100-1770 KHz range.
Posting updates...
I've build a new version of current indicators, this time I added a second LED with inverted polarity so they will show currents going in both directions through the shunts (link to larger image here):
This is a test with normal polarity (link to larger image here):
And this is a test with inverted polarity (link to larger image here):
For some reason the LEDs for inverted polarity (positioned lower) don't have the same luminosity even if the current should be the same like with normal polarity. All circuit is made using normal 0.8mm wire (just like the one ZPM's coils are built with) enclosed in plastic. I verified the solderings and found no issue.
But for now it's not that important, I'm interested more in what the upper LEDs are showing.
As a note, the fact that a LED indicator is off doesn't mean there is no current, it means there is not enough current to produce enough voltage to power-up the LED.
When I find some time again I will try to rectify the pulsed voltage produced by the shunts, meaning this:
I intend to build a bridge-rectifier using some super-fast SF28 diodes and then some electrolytic capacitor maybe (choosing the right one to smooth that waveform will be difficult, I'll need to do a lot of tests).
If I'll succeed then having pure DC produced by the shunts would mean I can use digital voltmeters to get real-time accurate reads for currents passing through shunts.
Zanzal posted this 20 October 2019
There is a certain frequency threshold above which your heart muscles cannot respond quickly enough and so alternating currents above that frequency won't stop your heart. Not sure where this frequency is exactly, but I vaguely recall it is between 2k and 4k. Above that frequency you should be fine. Below that, and you are at risk any time you are grounded as your blood vessels may act like conductors and your finger tips would be capacitively connecting you to the circuit. High currents should cause burns at any frequency but these would likely be over your skin at very high frequencies. Not sure what the current threshold is for that.
I worry more about my family when I am doing these experiments. Little ones especially have a way of getting into trouble grabbing things they shouldn't. A family member checking on you after you make a mistake may suffer the same. Precautions are good. Take note if any family member or guest has a pacemaker. Stay safe.
Vidura posted this 20 October 2019
@ Fighter
The Fast diode would be placed between the ZPM and the mosfet better, I am not sure if the current capability of the SF 28 is enough.
About the led indicators of course there is a threshold voltage , it will only lite with considerable current spikes, I have thought about this.
@ Zanzal
regarding the current, generally it is dangerous at low frequency or DC specially, above 30Khz it is considered RF , and the skin effect begins to predominate, so the current will flow on the surface, the RF burning is superficial normally , anyway for safty keep the kids at distance when experimenting with this kind of devices.
VIDURA.
Jagau posted this 24 October 2019
Hi fighter
My C core mestglass is progressing well.
I build the insulators in acetate and I prepare to mount the 2 coils.
I have a little technical question to ask you, so with about 150 laps for the primary you have an inductance of 101.4 mh and for the secondary 300 laps with 365 mh on an AMCC200.
What I do not understand if i check inductance factor and with the specifications of the manufacturer (photo below) we have 1.26 uh / N2 for ungap of 0.5 mm.
If I remove the gap we could say that it is about 2 uh / n2
so with 101 mh it would take 200 laps for the primary.
This is the question I am asking.
JL Naudin used an AMCC320 which is like mine and is a little bigger than the 220 and with 24mh he had 100 laps.
Could you tell me if I have the right number of turns?
It does not matter if you do not know I will find.
thank you
Fighter posted this 24 October 2019
Hi Jagau,
This is what my LCR meter shown after I built the coils:
It has two bucking coils (marked the with "L" and "R") winded in a way that when they're connected in series and powered on, their magnetic fields are opposing.
L coil has 101.4mH inductance and approx. 150 turns made of 0.8mm standard copper wire for coils. These are the complete characteristics I measured with my LCR meter (link to larger image here):
R coil has 365.5mH inductance and approx. 300 turns made of 0.8mm standard copper wire for coils. These are the complete characteristics I measured with my LCR meter (link to larger image here):
I ran auto-calibration before making measurements just to make sure. About the number of turns, the counting error is maximum +/- 10 turns (because I've made the coils manually), so yes it's 150/300 turns ratio with maximum +/-10 turns counting error. The gap is displayed in the latest photos, it should be 0mm because I stretched as much as possible that zip tie keeping the pieces together. I would say to follow one of the coil ratios reccomended by YoElMiCrO, ignoring the turns counting error mentioned I consider my ZPM configuration with 150/200 ratio is matching one of them. It's possible that the inductances shown by my LCR meter are because I've made the coils manually and the turns are not ordered as they would be if using a coiling machine, I'm sure the inductance is different between coils made manually and coils made with a mchine.
Hi fighter
thank you for answering,
I will do my 2 coils and see how they behave
Chris posted this 24 October 2019
If I may interject here for a minute.
Fighters Coils are: 1 : 2 basically, as YoElMiCrO kindly pointed out:
N2 = sqrt(n) * N1 = sqrt(0.25) * 300 = 150
Which is Fighters Coil Combination!
We have a situation here, where Fighter is using 25% Duty Cycle on the Input:
What occurs during all that Off Time?
No one is looking at this???
This 25% Duty Cycle is the same as the 0.25, the Quarter Wave. 25% Duty Cycle is a Quarter Wave, they are the same thing! This is important, please, something people need to start thinking about.
cd_sharp posted this 25 October 2019
The sqrt(0.25) is a measure of the time constants ( t ) difference between the coils. 5 time constants is a number which defines the time needed for the current to reach max value which is equivalent to max magnetic field.
Chris posted this 25 October 2019
The Coils reach maximum Current ( I ) when five time constants have passed.
The equation is: T = L / R
  • T is five Time Constants and is measured in seconds
  • L is the Inductance and is measured in Henrys
  • R is the total circuit Resistance and is measured in Ohms.
So no, not really correct, as the coils become resonant, yes we do get maximum Amplitude, but this cant always be assumed this is maximum Current ( I ) for the applied Voltage ( V ).
Resonance, especially this type of Resonance, is quite different. Magnetic Resonance.
Hey, man
During the off-time, assuming both coils are charged, they will decay. L2 will try to decay twice faster than L1. That is a changing magnetic field ahead of the changing magnetic field of L1. This results in delayed EM induction in L1, as we named it counter-reaction and it's adding up to the decaying field of L1.
Please correct me if I'm wrong.
Ah ha, yes you're right!
The Interactions between the Coils:
In Fighters ZPM we see a very interesting Spike:
Marked in Red is the process I describe above in the video. The Coils are like a spring, and Act and React together in Magnetic Resonance. This is an Electromagnetic Induction dance, or disco. Electrons are getting some moves on and the Disco is going off...
This is excess Electromagnetic Induction after the fact! After the Input has excited the Coils into this Resonance.
I wish to go further with my imagination. While L1 is discharging slowly, the voltage over L1 is not what it's supposed to be if L1 was discharging alone. The voltage induced by the L2 collapsing adds up to the voltage over the ends of L1 and it causes a much faster discharge (almost instant) than normally. We have increased V, we obtained increased I.
This almost instant collapsing of L1 causes EM induction in L2 and so they start to dance as you said. This device uses the Reduced Impedance Effect so visibly. I look forward to playing, I'm waiting for some hardware..
Fighter posted this 25 October 2019
Talking about hardware, some updates on my side, I just received the shipment with 6x12V/55W light-bulbs:
... and I have a shipment with 6 x Cree MOSFETs which is still on the way. This time I bought the MOSFETs from TME, they are more expensive comparing to Digi-Key but as TME is in EU I'll avoid the tax for shipments coming from outside of EU which is signifiant.
So my backup stock will be restored soon and I'll have replacements available again for experimenting.
Jagau posted this 31 October 2019
hey fighter
slowly but surely
My acrylic supports are made
and I found (maybe a way to make coils more symmetrical)
I tried to make this coil winder
Fighter posted this 01 November 2019
Hi guys, unfortunately I need to take a break from researching because I need to relocate. I will find another place to rent (the owner of this one wants to sell it), pack all my stuff and transport it there. As you can imagine this will take a while and during this process I will not be able to do experiments. I will resume the research as soon as it's possible. Sorry about this but this is how life is sometimes.
Please continue your research, I'll still be here but I will not be able to present anything new until I resolve this problem.
Chris posted this 01 November 2019
@Fighter
Good luck with your move, I hope it all goes smoothly!
Fighter posted this 20 December 2019
Hi guys, sorry, moving to the new place and setting things up took much longer than I expected.
I just received a shipment from China and I'm currently working on a custom DC source where I can have real-time and (hopefully) accurate readings of input. The real-time measurement module is this one. For calibration I'm using a PeakTech 9035 energy meter which is using power factor for very precise readings and calculation. The measurement module seems pretty accurate and it's consuming about 0.6 - 0.7 watts. Few images without load (link to larger image here):
And few images with a light bulb as load (link to larger image here):
As a custom DC source I'm gonna use a 24V/1.5A transformer, a bridge rectifier and a 10000uF/50V electrolytic capacitor (link to larger image here):
What I hope is by using the new measurement module I will get accurate real-time readings when powering up the ZPM as I actually measure the power before going into the transformer so the readings will not be affected by the signal sent back by ZPM.
By using this simple customized DC source I avoid having in readings the power consumed by the more complex DC source I used until now.
I'll see if this plan works.
The only concern I have is how to protect the transformer, its maximum current is 1.5A and while sweeping ZPM frequencies it's possible to find ranges where the current drawn by ZPM to go to 1.5A or higher. Also having that big electrolytic capacitor it's possible to have 1.5A or higher inrush current when powering up this custom DC source. I'm looking for a 1.5A current limiter so I avoid burning up the transformer, is there a simple solution for protecting it ?
Vidura posted this 20 December 2019
Hey Fighter, Good to have you back on the bench. Really a good approach your new supply module. For the transformer you don't have to worry , it is not likely to damage it, unless it would be short-circuit for a considerable time. It will not output much more than the rated current. You can put a 2.5 or 3A fuse slow type, that's all needed to protect it. The current peaks will be drawn from the capacitor. Good luck with the experiments. Vidura.
Thank you Vidura, it's good to be back
So the transformer will not be damaged if I don't short-circuit it ? It simply will not provide more than 1.5A even if ZPM temporary tries to get more ? That's a relief, I was thinking I will damage it during the experiments.
I really appreciate and I'll follow your advice.
YoElMiCrO posted this 20 December 2019
Hola a todos. Disculpen por postear en Espa帽ol. No estoy frente a un PC para utilizar GoogleTraslator. Actualmente la hip贸tesis sobre la regi贸n negativa de la permeabilidad magn茅tica poco a poco se ha convertido en teor铆a mediante muchos experimentos. La cuesti贸n es que necesitamos de las dos entidades para producir trabajo 煤til. Los n煤cleos de tipo Amorfo, Nanoperm, Nanocristalinos y los utilizados en el control del duty magn茅tico ser铆an los ideales.
La cuesti贸n es que la relaci贸n entre Br/Bs sea lo m谩s pr贸ximo a la unidad. De esa forma aseguramos que que la energ铆a almacenada en el inductor sea m铆nima y podemos comparar la extra铆da del medio.
Postdata. Este segundo post pertenece al anterior, solo que no se como desde el m贸vil se public贸 y no tiene la pesta帽a de editar.
@Fighter, publicar茅 mi r茅plica de tu ZPM al menor tiempo posible, pues he estado s煤per liado en otros proyectos. De nuevo, disculpen.
Hola YoElMiCrO, no se preocupe, podemos usar Google Translator. Entonces, otros experimentos confirmaron la teoría de la región negativa de la permeabilidad magnética? Eso es interesante. Siéntase libre de publicar en cualquier momento aquí.
Cuando tienes tiempo, está bien. Tengo mucha curiosidad acerca de su replicación de ZPM y los resultados de las pruebas.
Zanzal posted this 20 December 2019
Resettable polyfuses can be helpful for some situations. They can stop large surges or sustained currents over a long period of time. The cost is added resistance which will waste power. That can be a good trade off in some cases.
Fighter posted this 21 December 2019
Thank you Zanzal, I'll check for polyfuses.
cd_sharp posted this 21 December 2019
Hey, Fighter, very good to have you back, my friend. I remind you that there is no need to measure the input. I'm convinced the ZPM is very much AU. I would put effort into making it power bigger loads. Just my opinion, I hope you don't mind.
Fighter posted this 22 December 2019
Hey CDd_Sharp, thanks. No worries about your opinion, the idea is I think it should be a required step in this stage of enhancing ZPM having real-time input and output accurate readings, else I would go in blind during enhancement experiments and I wouldn't know if I'm going in the right direction or in the wrong direction.
Unfortunately after the last testings I'm not sure about the accuracy of this method of measuring input as it doesn't match the measurements made on oscilloscope, I'm adding the previously made oscilloscope measurements here for reference:
Hey Fighter,
You have my Vote!
Purely Resistive Load, no phase angle to worry about! Figures look good!
Input:
Output:
Well done! Good work Fighter!
You have "Generated" a full: 鈥3.574784鈥 Watts above your Input for a COP: 鈥1.09396
Calculator is attached in zip format below if you want to use it.
and also because this customized DC source I made seems to modify the behavior of the ZPM.
I'll present the data of the latest experiments.
The customized DC source plus the measurements module are consuming about 5.3 watts.
Basically the customized DC source is consuming about 4.1 W and the measurement module about 1.2 W.
Sorry but the PeakTech energy-meter don't have display light but in the next photos is shows 227.4 V, 0.042 A, 5.2 W.
Photos (link to larger images here):
In the next photos I show ZPM powered by the customized DC source where the probe of the oscilloscope is put directly on ZPM's output (link to larger images here):
As you can see the measurement module shows 62.7 W, much more than the 38.04 W previously measured using the oscilloscope. Also you may notice the ZPM's specific waveform is not present, I don't recognize this waveform and it means ZPM's behavior is changed.
In the next photos I'm using exactly the same parameters I just switched to my usual DC source (link to larger images here):
You may see the ZPM specific waveform is present again now.
In the next image you may see the different behavior when using both DC sources, on the left is the waveform when using my usual DC source (ZPM pattern is present) and on the right when using the customized DC source (link to larger image here):
Then I placed oscilloscope's probe directly on the light bulb pins and searched for another optimum frequency and repeated the tests (with the customized DC source then with the usual DC source).
These are the images made while using the customized DC source (link to larger image here):
And these are the images made while using the usual DC source (link to larger image here):
As you may see it's the same changed behavior, the ZPM's specific waveform is present when using the usual DC source and it's not present when using the customized DC source.
For curiosity I wanted to see what's between the transformer and the bridge rectifier, this is what I see on oscilloscope (link to larger image here):
As a conclusion I consider this way of real-time measuring of input a failure as it's far away from what the oscilloscope shown and also the customized DC source is modifying ZPM's behavior. Seems there is something in the usual DC source and that something is missing from my customized DC source.
Also I was thinking of other possible reasons for failure. The bridge rectifier is made for 50Hz and as we know ZPM is sending high-frequency pulsed power back which for sure rectifier's diodes are unable to block/handle. Probably that power is reaching transformer's secondary and creating magnetic field which is fighting the magnetic field of the transformer's primary. That would be a possible explanation for what the extra-watts shown by the meters.
This hypothesis may be confirmed by the fact that the bridge rectifier and transformer's core are getting hot in about 10 minutes which is strange because the transformer is rated for 1.5 A but during the tests the current used is just 0.33 A. At 0.33 A both transformer and bridge rectifier should not get that hot and that fast.
I suppose another approach is needed for real-time measurements and also I wonder what exactly is in the usual DC source and is missing in the customized DC source making ZPM to change behavior when using the customized DC source. Many new questions and hypothesis resulted from these new experiments even if they failed, I'll think about them.
As usually any suggestions are welcome...
Chris posted this 22 December 2019
Hey Fighter,
An excellent post!
All AC Energy Meters especially the ones with Toroid, or Current Transformers, are no good for accurately measuring anything but the AC Voltage and Current at the specific Frequency that they are rated for.
Almost all Higher Frequencies are eliminated.
Especially Frequencies that are coming back in a much higher frequency range that the ratings are indicated.
I am sorry to let you know now about this as I see two other posts with this idea, I should have said before.
The same is true of the AC Energy Meters that you have plugged into your power board. They have a very limited bandwidth and are not accurate unless you are using the specific frequency they are rated for.
This is just one video showing how far out they can be:
Now this video does not allow for Phase Angle, being a resistive load, it will be negligible, but this is @Rated Frequency and there is a several watt discrepancy, d, there, even at a phase angle of X.
Vd = 122.7 - 120.4 = 2.3V
Id = 1.28 - 1.279 = 0.001A
Pd = 鈥157.056鈥 - 鈥153.9916鈥 = 鈥3.0644鈥 watts.
This is not including any phase angle there may be in there. Of course phase angle, cos(theta), may be very small due to the resistive load, with very little Capacitive / Inductive component.
@50 Hz or 60Hz they are ok, @600Khz they are hopeless.
P.S: Sorry, I see your edits, I edited also. You have a good point, we should start looking at the Input Power Circuitry also. A Battery might be a good choice for a Source as it contains no Circuitry as such?
P.P.S: The much slower speed of the E I Laminated Silicon Steel Transformer will absorb the Higher Frequencies and not respond to, in time, the Energy coming back. Turning this Energy into extra Heat. Similar to how an Induction Cooker works.
Hi Chris, the meters are put before the custom DC source, they are actually measuring 220V/50Hz input. But I agree there is something wrong with the readings, I'm still organizing and adding data to the previous post, I'll explain and add a conclusion.
I just saw your latest edits, Chris, you're right, there are too many flaws in this approach. Most of the components are made for 50 Hz and can't handle/block high-frequencies. I was hoping that by moving the measurements block before the transformer and measuring 220V/50Hz I will escape from the high-frequency power sent back by ZPM. Seems it's not the case unless I use a bridge rectifier which can handle/block high-frequency power coming against it. Also there seems to be some component in the DC source which is missing in my customized DC source and that missing component is the cause of ZPM's changed behavior. Many things to think about but also some lessons learned...
Edit: A battery could be a good idea, don't know if there are some ~25V batteries, maybe rechargeable so I avoid significant costs for each experiment. But it's possible that a battery could modify ZPM's behavior too if there is "something" in my usual DC source which is actually actively working with ZPM to behave this way. That "something" needs clarification: does it exist and if yes what component is it ?
My Friend, I agree!
A reason a forum, to share our experiences is so important, a documentation archive that will serve humanity for decades to come!
There is always more to learn! We humans think we know everything, in general, but the truth is, there is more to learn than what we have already learnt!
The humans that can memorise entire physics volumes, is nothing compared to a life time of real world experience.
My friend, this is invaluable knowledge for others!
EDIT:
Yes, agreed. However, a Battery will serve as a better reference point as to the Actions / Reactions that occur with the ZPM than a DC Power supply as it has no Circuitry. High Frequency DC Pulses will be absorbed, Charge the Battery, much better than random Circuitry that exists in a DC Power Source. I was thinking about 2x 12V 7Ah or similar Rechargeable Batteries as a possibility?
Best Wishes
Thank you Chris, I'll take into consideration this approach.
Vidura posted this 23 December 2019
Hey Friends, Recently I made some tests related to noise , and found that there is some kind of it which is virtually impossible to filter or screen out. That the high frequency current passes thru a steel core transformer and interfere the digital instruments is not surprising at all. Also it is possible that a lot of power is dissipated in the low frequency rectifier. Regarding the change of the wave form of the ZPM when using the simple transformer, could it be a voltage drop the cause? There might be a threshold voltage for the ZPM to perform properly.As the lab PS is voltage stabilized, it is supposed to maintain the selected voltage, no so a standard transformer, there can be major variation depending on the load conditions. I agree that a battery would give valuable comparison. If it is actually some circuitry inside the PS that is interactive , it should be possible to find which components. Some time ago I had an issue with my PS , the current limiting was damaged, so I opened it to check, it is of the analogue type, a multi tapped steel core transformer, and linear voltage regulation, not switch mode type. I was a bit surprised about the few components on the output line, a single electrolytic capacitor , a precision current shunt, and a few more components. The only digital components are the voltage and current meters. I guess the Switch mode type PS has more filter components , to keep the switching noise low. But if Fighters PS is the analogue type, there are only a few possibilities of interacting components. By the way, I got a notice from costumes about a packet, this could be the metglass core, hopefully, now nearly four months ago was shipped from Europe. So maybe soon I can join the testing of the ZPM. Vidura.
Chris posted this 23 December 2019
Re:
I agree! and this could be assistive of course in our furthering the overall understanding of Input Power and the reasons it can sometimes behave differently.
Four months, wow, that's a slow delivery, sounds like Australia Post! Our postal service is very slow also depending on what country the source is coming from!
I think you will find the Metglas Core very useful!
Fighter posted this 23 December 2019
@Vidura
So filtering the noise sent back by ZPM is impossible...
This seems to be the case, the bridge rectifier and/or the transfomer become hot in about 10 minutes so those extra ~30W consumption shown by energy meters most probably are dissipated in that heat.
This could be the case of voltage drop. I could make a test with the usual DC source by setting the voltage much below 25V and check how the waveform looks like.
I will try this way, I will look for some local supliers for rechargable battery/batteries.
My DC source is switch-type, I remember I chosen it specifically to be this way, that's why is has about 16kg weight. The model is QJ6005E and the manufacturer's page is here:
http://www.nbjiuyuan.cn/Single-output/products_21_en.html
Unfortunately there are no schematics anywhere on internet but I found a image from inside (link to larger image here):
I see that big current-sensing shunt and also I see there are a lot of electronics, some of them could possibly actively working with ZPM but I have no idea which one.
On the manufacturer's site I see this option but it's for measurements when voltage drop occurs, I don't think it will help with high frequency noise:
I would be glad if you could join the ZPM research, having another ZPM in experiments with different power source and measuring instruments will be very helpful in clarifying some aspects and ZPM's behavior !
@Atti
This is just an opinion, not to be accepted but to consider.
In my opinion, the load on the transformer of a single DC source is probably too close to the maximum load. (36 VA)
Therefore, the peak current draws too much down the buffer capacitor voltage. Whirring tension.
Therefore, the input waveform on the secondary side of the individual transformer.
If you could replace it with a larger transformer (maybe 200VA)
waviness would decrease.
Another solution could be to use L-C filters before the ZPM input.
I agree, the voltage drop could be the reason for ZPM's behavior change, I'm taking this into consideration. I could try a test with the usual DC source but setting the voltage much lower than 25V and see how the waveform looks like. About filtering out the high-frequency noise sent back by ZPM, seems it's not a possible solution according to Vidura, seems this is a particular situation where filters don't work. I remember I tried with a choke coil on input and ZPM don't like that, I had extensive damage: DC source entered in auto-protection mode, the light bulbs on output burned and also the MOSFET was destroyed.
If you are using a factory lab power supply, then its wiring diagram would be good to know.
Unfortunately I could not find any schematics on internet for my DC source. You may find more details in my previous replies to Vidura.
Hey Fighter and all following, I don't know if it's really impossible to filter that interference, but I can assure that it's not an easy task, I have tried with common mode choke, differential mode choke, different types of R C L filters, but the interference in the digital instruments continued, specially with the parametric oscillator circuit and HVTesla coils. The analogue meters seems to remain unaffected. And yes it can be very tricky to make accurate measurements with this kind of devices, but anyway we don't need so much accuracy, If we have a reference to work with it will be helpful to make improvements and monitoring the situation, no need for ten digits below the comma. The PS you have is very similar to mine, this is the transformer type with linear voltage regulation. It is not a Switch mode supply, this refers to high frequency converters with small ferrite cores. The components immediately on the output are the rectifier, electrolytic capacitors and the current shunt (a spiral of copper wire) , and the connectors for the sensing electronics. I had an experience when a interference affected the sensing electronics and the voltage regulation failed, the supply delivered 50V instead of the rated maximum of 30v. Regarding the Battery I would suggest the lead acid batteries, they are tougher for withstand transients, high frequency components and so. The lion batteries might fail in this condition.
Hopefully this helps some. Vidura
Fighter posted this 24 December 2019
So the power sent back by ZPM is "seen" by power meters but its considered/calculated as power sent by the DC source. Basically power meters can't detect direction ? Makes sense as the power meters just measure the magnetic field of the current passing through a conductor, not the magnetic field's polarity. Very interesting, thanks for the video Atti.
Chris posted this 24 December 2019
I see a lot more confusion entering at the moment than is necessary! There is no need for any complexity!
I am not going to fill Fighters thread with partially off topic content, instead, I am posting a response here.
Realistically you do not want to use any High pass or Low pass Filters when doing measurements! not unless your'e looking for anything specifically! So this talk of filtering and so on is distracting and confusing.
I think it is only logical to keep this as simple as possible, no point introducing complications when none exist!
Fighter posted this 08 January 2020
Hi Chris, I just want to say I saw again the Non-Inductive Coil Experiment videos and a lot of things became much clearer now.
The fact that before I watched them in the evenings after finishing work didn't helped in really understanding them.
Now using this short vacation I watched them again one after one with fresh mind without being tired from work and everything makes sense and I understood a lot. For example I understand now why the input coil must have fewer turns and the wire must be thick, I understand why the duty cycle must be as lower as possible while the secondary (bucking) coils are still interacting correctly, I also have a fresh perspective on ZPM's behavior, actually (as Cd_Sharp told me in a conversation) the "R" coil of ZPM is composed from two virtual coils even if physically is just one coil: a virtual coil is perfectly equal with the "L" coil and it's opposing perfectly to "L" coil while a second virtual coil is actually the input coil and has 150 turns (too many). But unlike your device my (virtual) input coil is connected to one of the secondary coils. That's the reason why the behavior of ZPM is different from the behavior of your device even if they're actually using the same principle of the bucking coils.
So I recommend to all the members to find time when they have fresh mind, few hours available and when they're not tired (from work) and watch all the videos one by one carefully and they'll understand a lot about the interactions between bucking coils, why they behave like that and how to improve the interactions and where to look at during the improvements.
I intend to join the replication of your device as it can help me in understanding better ZPM and help with the improvements for ZPM. As I don't intend to dismantle ZPM (it's the only prototype, as far as I know there are no replicas yet) I think I will buy another AMCC-200 and start working on a replication of your device. Will take some time to receive the core and to design and order different coil supports to a CNC company but I think it's worth the effort. Who knows, maybe during the research we can make a better device, a hybrid getting the best things from your device and from my device.
EDIT: I definitely need to see the videos again as I'm sure there are still details which I missed. I downloaded the videos with the original resolution and I'm adding them to my archive so just in case if you ever need them just let me know, you have also a backup of the videos here.
Chris posted this 08 January 2020
Hey Fighter,
Your ZPM is extremely important and the entire reason I showed the Experiments I did. Your work is critical in moving forward!
I urge all Members replicate your ZPM!
So please, I urge you to continue your work! And, as you say, a replication may help also!
Yes exactly, they use the same principles! Exactly the same! Just a different way to get to the same ball park!
Soon, a new geometry will come and it wont make sense, especially after these experiments. I have said we can have problems with the Machine choking off the Magnetic Fields, but there is a way around this. So for this reason we need to keep open minds.
The thread: Some Coils Buck and some Coils DONT gave a lot of information, the problem is, because the figures were poor, no one paid any attention. However, massive amounts of information can be gained from this thread. Information that the average EE will say is wrong, but, I have experiments to prove this is true...
I agree, keep your ZPM intact, its an important machine!
It takes time for understanding to be achieved, I have had to repeat myself many times, but people are starting to get it... Its thanks to your machine and others like Graham Gunderson and even Tinman and his RT which was very important for the momentum of what we are doing.
People look for proof, they see scam... Its sad, and its so extremely obvious! With just a little understanding, people can build these machines for a few dollars and an hours work!
Isn't that just crazy!
I would like to quote:
On that “blessed day” when we arrived and witnessed the VTA Device in operation it is a day I shall never forget. To actually see a Device that only would cost approximately $200 dollars and create all the clean energy you would ever need was “awesome”. I know I have been “altered” ever since knowing that such a Device existed.
Ref: ATTACHMENT floyd sweet.pdf - Maurice Campbell Documents.
You can see, Maurice commented on the Cost in the above quote! How cheap it was!
We will see a day, where angry people, angry for being ripped off for so long, will storm the streets! We will never again allow Government govern us! We will never again allow Bankers to be in control of Banks!
The establishment is doomed! They have bought down a mountain of rubble on themselves!
Names of Humanity's Traitors will be published! Some will be punished for their crimes! Many will take their own lives for the guilt they incur on themselves!
I say, isn't it easier to just be Good! Good always wins, eventually!
Jagau posted this 19 January 2020
Hello Fighter
I have tried several configurations with different number of laps without obtaining good results.
I even tried a configuration with 3 coils as in the photo and there I have a better result but not even like you.
I do not give up and will come back later with others try.
Maybe I misunderstood your configuration?
In the meantime I hope your move went well and also say did you do any other tests?
Chris posted this 19 January 2020
@Jagau,
If I may, would you mind sharing more information? Turns, Wire Gauge, Frequency, Output Voltage under Load, Load resistance, Circuit, and other info you think might be relevant?
We know from Experiment and the Math, the Length of the Coil can also play a role: B = μ0N/LI
  • B = the Magnetic Field in Tesla.
  • μ= the magnetic constant.
  • N = the Number of turns.
  • L = the Length of the Solenoid.
  • I = the Current.
It is important that sufficient B Field does sufficient work to produce the required effects. If B is not sufficient, or the Actions of each B Field is not sufficiently interactions, then results will be poor.
I hope this helps some!
Jagau posted this 20 January 2020
Yes indeed Chris,
Ok I tried with 20 gauge wire with coils of 200 and 100 turns each in partnership mode and also in additive mode with different voltages of 9, 12, and 24 volts, and a 12 volts bulb lamp, nothing wanted to do. Working frequency was 325khz, But I know that the metglass core is optimized for a max of 100 kHz.
I would have a theory however.
As the Metglass is a material of high permeability and that it surely has, as Don Smith said, the characteristic of a piezoelectric material. So I think Fighter found exactly the right length of wire and the number of turns it takes to trigger this piezoelectric effect.
  The Metglass becomes at a precise frequency a feedback transformer which provides more energy than it consumes.
I am currently testing this theory through various experiments.
Fighter posted this 20 January 2020
Hi Jagau,
I didn't do additional tests, I just returned from the holidays break. Within 4-5 days I'll have enough funds (this entire moving thing was extremely expensive) to buy a second AMCC-200 so I can begin replication of a second ZPM and experiment with different coils configurations without dismantling the prototype.
Can you post the waveform you have on your ZPM's output ? Is the specific ZPM pattern present there ?
Did you do the frequency sweep to find the optimal frequency for your configuration ? Also, just for double-checking, use a compass to confirm the polarity of the magnetic field for each coil just to make sure the magnetic fields are opposing.
What duty-cycle did you tried ? The optimal frequency range change if duty-cycle is changed.
If possible could you post a video of the frequency-sweep procedure for your ZPM ?
About frequency, 100KHz is not the maximum for Metglas, I remember I was going near 700-800KHz in the initial tests and I still had a 12V/5W light bulb lighting. Right now with the 12V/55W light bulb I'm playing within 90-160KHz range. Remember the optimal frequency changes dramatically when load is changed or duty-cycle is changed, with a 12V/5W light bulb it can go near 700-800KHz but with a 12V/55W light bulb 160KHz is the upper limit. Also what I found since the beginning is that going below 80-90KHz dramatically decreases ZPM's performance, it's starting to get more and more power from the DC source (at least what the DC source's display is showing, I know that's not a precise reading).
About voltage, I always used 25V for ZPM, I tried going much below 25V (like 18V, 15V, 12V) but the results were poor. So if you have 24V stay with that voltage, if possible go to 25V (I don't know if you're using a variable or fixed voltage source).
About the exact length of wire, I doubt I found it from the first try, I'm not even sure about the exact number of turns, they are 150/300 ratio with error rate of +/- 10 turns for each coil. Also, I'm not sure if the positions of the coils on the core matters, probably not.
I'll try to assist as much as possible.
Thank you very much for all this information.
Glad you were able to relocate to experiment, yes the moving and the time of the holidays, are expensive.
Ok one thing that I had not noticed the ratio is coils is 1: 2 is that right?
With this new setup I will redo tests, I used 1: 1 already there is a good difference.
OK thank you
You're welcome. Yes, 1:2. Try with 150/300 turns ratio.
Fighter posted this 21 January 2020
@Jagau, a question, can't tell because the photo is too small but is the wire you use multifilar ? 'Cause I don't use multifilar, I use solid copper wire, that could make a difference, I don't know.
Jagau posted this 21 January 2020
Hi fighter
I use 20 gauge solid copper cable.
In the photo it is a configuration with 3 coils that I had tested.
2 coils at the top and one at the bottom.
Fighter posted this 22 January 2020
Got it, my mistake. Thanks for the clarification.
Jagau posted this 22 January 2020
One thing that I noticed in your configuration is the mounting of the 2 coils in a very specific place.
I think they do not want to be located on the gap as I have mounted them on the central gap, I think it matters, they must be located on each side of the gap.
Checking out this theory.
Did you leave a gap in your config fighter?
Jagau, there are no gaps in my ZPM. My coils are mounted in the middle of each U piece of the Metglas (link to larger images here):
and your coils are mounted over the two places where the Metglas is cut.
I suppose the places where the coils are mounted on core don't matter. But if they matter then there is a difference between my configuration and your configuration.
Just to clarify, this is where my coils are mounted on the core:
And this is where your coils are mounted on the core:
As I said at this moment I have no data showing that the position of the coils on the core matters. Why do you think the positions matters, do you have any data indicating this ?
EDIT: could be a misunderstanding, let me clarify - by gaps I mean air-gaps, the spaces between the two U pieces of the core (the places where the core is cut as indicated by red arrows in the image below):
So yes this is a difference between my configuration and your configuration, If you think it matters then you could try to place the coils in the same positions like I did. I know it is difficult to place coil supports there, I needed to order to CNC pieces which could be put in place and when glued compose the supports.
This is a hand-made design I've made to explain to the CNC guy what exactly I want (link to larger image here):
As a note: I've made these coil supports when I was trying to replicate Bearden's MEG so I wanted to place the coils on the core exactly as it's specified in the MEG schema.
No Gap,
ok thank you
it is very clear
Fighter posted this 31 January 2020
I just received the Metglas core from DACPOL Poland, the company I ordered from the previous cores few years ago. I'm very disappointed, it's not made by Hitachi, it's made by UAML India and it's labeled UMCCC-200:
The characteristics of the core are specified on manufacturer's site here.
I complained to DACPOL and they say even if their site is showing Hitachi AMCC-200 here the site is not updated and they don't have AMCC-200 from Hitachi anymore (since 1-2 years ago) but they guarantee this one have the same characteristics as AMCC-200 from Hitachi. I can't be sure about what they say. They offered to send my money back and to return the core and they will pay for returning shipment costs. I did a quick search and seems there are no providers anymore for Hitachi AMCC-200 in Europe. So I guess unless I order from US (with price & shipment & EU import tax doubling the costs) the only option is to keep this one and give it a try even if I consider their trading practice very unprofessional and misleading. For the future I hope there will be another provider for the original Hitachi cores in Europe as I don't intend to buy from DACPOL anymore.
As I'll find some time I'll prepare the specs for new coil supports to send a order to CNC guys. I intend to make coil supports for ZPM configuration but also additional supports to test the device presented by Cd_Sharp here.
Fighter posted this 01 February 2020
For future reference I'm adding this info here (copied from the AMCC C Cores Suppliers thread), seems there is a provider for Hitachi AMCC cores which I missed during my quick search:
If it could help, i bought mine at' Mouser elctronic
with with their description:
Mouser #: 205-AMCC0320
Mfr. #:
AMCC0320 Desc.: Ferrite Toroids / Ferrite Rings Ferrite Toroids / Ferrite Rings 79x129x50 Amorphous Cut Core
They have AMCC-200 here.
For now I'll use the UMCCC-200 and I'll see what it can do.
Thanks Jagau !
YoElMiCrO posted this 01 February 2020
Hi everyone.
I've been super busy with work, but I'm starting
to vacate, I will have more time from now.
I will catch up.
Thank you all in advance.
YoElMiCrO, I understand, I have a lot to do at work too so the new ZPM replication is progressing slowly.
When you have some time maybe you can publish info about your ZPM replication, I'm interested especially if your device have the specific waveform pattern on output and what's your conclusion about its COP. Thanks.
Fighter posted this 14 February 2020
Finally, after waiting 10 days in the CNC schedule, my redesigned pieces for coil supports entered in production yesterday (link to larger image here):
For making a coil support I made two kind of pieces (link for larger image here):
I ordered enough pieces to build 8 coil supports with variable width.
I redesigned these pieces for full flexibility so I can build coil supports anywhere on the Metglas core, in any configuration (link to larger image here):
Also I can build coil support with variable width.
The only limitation is the height of these supports, I will not be able to wire the same number of layers like I did with the previous supports because I wanted to also be able to have coils on upper side and on the lower side of the core (see the two parallel supports in the previous image).
But it's a limitation I can live with considering the advantage of full flexibility offered by the new design.
Also I bought some 1.4mm wire which I intend to use later in the primary coil (thicker wire, fewer turns) for a non-inductive coil experiment - Chris' device (link to larger image here):
And I replaced the two old 10,000uF/50V electrolytic capacitors (one of them was burned by ZPM) with new 680uF/400V electrolytic capacitors on my old two-channels bridge rectifier using MBR 4045 PT Schottky diodes (link to larger image here):
I intend to give it another try on ZPM's output, I'm sure I'll not get a clean DC output but at least to try to rectify the negative voltage side of the output.
Jagau posted this 14 February 2020
Which model of AMCC received fighter?
Fighter posted this 15 February 2020
It's UMCCC-200. The equivalent of AMC-200 from Hitachi. Just this one is not made by Hitachi, it's made by an Indian manufacturer. I hope it has the same characteristics, we'll see.
YoElMiCrO posted this 28 February 2020
Hi All.
@Fighter.
I have time for the ZPE device, is the best example on the net for AU.
Thank, for sharing.
YoElMiCrO.
Fighter posted this 29 February 2020
Hi YoElMiCrO, thank you. I'd be glad to know how your replication behave and what's the results of your tests.
You're more than welcome to post the details here (it's about the same device) or if you prefer in your own replication thread, you choose.
I'm currently working also on a ZPM replication but unfortunately the progress is very slow because I'm very busy at work and don't have too much time. I'm always telling myself "maybe I'll have some time in the weekend"...
I'm looking forward to see the test results of your ZPM replication, thanks for sharing.
cd_sharp posted this 29 February 2020
Hey, my friend
I watched again your video
I noticed you are using 5V amplitude from the SG. Based on Vidura's recommendations,
If any signal source with a different voltage as 5V default configuration will be used , changing the current limiting resistor of the emitter diode may be required. Choose an adequate value to adjust the emitter current between 10 and 16 mA.
I determined that for FY3200S SG using 10V amplitude is optimal.
If you are using 5V, the MOSFET may not open fully.
Just thought to let you know this detail.
Best wishes
Fighter posted this 01 March 2020
Hi my friend,
Yes, it's true, I used the minimum AMP where I observed the light bulb is on while I was testing the switching functionality at low frequency with a light bulb instead of ZPM. I didn't wanted to go higher with AMP because I was afraid I'm gonna damage the switch.
For the switch made by me (the black box on top of the DC source) I'm using maximum AMP=20V because I observed (based on light bulb's luminosity on ZPM's output) that is the most efficient value.
Thanks, I'll keep in mind this value (AMP=10V) when I'll use Vidura's tool.
Fighter posted this 04 March 2020
Adding a quote from Nikola Tesla I found recently, I want to have it in this thread:
Fighter posted this 07 March 2020
Hi guys, I have multiple updates.
First, I found out why long time ago ZPM destroyed the electrolytic capacitor from one of the channels of my bridge rectifier using MBR 4045 PT Schottky diodes: they are not fast enough to rectify so the capacitor is actually receiving negative voltage on its positive terminal. As you know I replaced the electrolytic capacitors of my rectifier with new 680uF/400V capacitors and tried again.
This is without rectifier just having the oscilloscope's probe on light bulb's terminals (link to larger image here):
And this is with the rectifier on ZPM's ouptut (link to larger image here):
As you can see the diodes in bridge fail to rectify and we have negative voltage on capacitor's positive terminal.
Then I tried with a improvised bridge rectifier using faster diodes (SF 28 G) and the good thing is these diodes rectify but the bad thing is they get hot very fast (within about 5-10 seconds) so they can't be a permanent solution (link to larger image here):
So I should try to find diodes like these but witch don't get hot so fast and so strong (after all it's a lot of energy wasted from ZPM's output). I need to search for those better diodes.
Another really good news is the fact that the ZPM replication is ready and is functioning just like the prototype (link to larger image here):
So the prototype can be replicated and now I have actually two functional ZPMs.
I'll document the building process below.
This is the step where I check the polarity of the magnetic field for each coil so I know how to connect the coils between them so I make sure on the top of the ZPM are two North magnetic polarities opposing each other (link to larger image here):
The coils are exactly 150/300 turns using 0.8mm wire, considering the coil supports are smaller than the ones of the prototype I tried to build the coils tighter.
In the next step I calibrated my LCR and measured the characteristics of the coils.
The characteristics of the bigger coil ("R") are these (link to larger image here):
The characteristics of the smaller coil ("L") are these (link to larger image here):
During the frequency sweep I found that the optimal frequencies of the device are almost identical with the frequencies of the prototype (just few KHz difference).
Below is a test with a 12V/55W light bulb on ZPM-2's output, let's name it this way (link to larger image here):
And two more photos of the output on the oscilloscope (link to larger image here):
So ZPM can be replicated. I placed the prototype in a sealed bag, I hope this will minimize the advancement of the rust on the Metglas core. I'll use it in experiments when it will be necessary, if I find differences in behavior of the new ZPM.
I'll use this new ZPM for enhancements (modifying the coils, additional coils and so on).
Another photo with the desk lamp off to check the luminosity of the 12V/55W light bulb (link to larger image here):
Edit: I just compared the inductance measured for each coil of the prototype long time ago and the inductance measured for each coil of the replica today (link to larger image here):
For the smaller coil ("L") I see 101.4 / 172.9 mH. Let's say this is normal as I made the coils tighter on the replica.
But for the bigger coil ("R") I see 365.5 / 665.5 mH. That's almost double inductance. I have no explanation of this difference so big.
I calibrate my LCR every time I make measurements, I calibrated it in that day and I calibrated it today.
Still, something seems wrong with the measurements of the coils characteristics.
Vidura posted this 07 March 2020
Hey Fighter, At least in theory schottky diodes should be very fast, in my knowledge they don't have reverse recovery time as other fast switching diodes. The reason could also be avalanching due high voltage surges, as this diode is only 45v rated, the voltage setting on the scope is not clearly visible, only 7v peak in this scope shot, I think I remember to see much higher spikes in your experiments? Regards Vidura.
Fighter posted this 08 March 2020
Hi Vidura, SF28G seems to be faster than Schottky and they're doing the job, but I must find something from their class which are not getting so hot so fast. It's a lot of energy lost and it's not a permanent solution, they burn.
About the voltage when I tested rectification I put the scope probe directly on light bulb's pins, remember the voltage is higher when I put the scope directly on ZPM's coils, voltage is going lower on the same wire as it's getting away from ZPM's coils. Standing waves.
And it depends of the load, the highest Vpp (about 160-180 Vpp) is when I measure directly on ZPM's output (on coils) when I use as load one 12V/5W light bulbs. Here I used one 12V/55W light bulb and I had about 98Vpp putting the probe directly on ZPM-s coils.
So this is a previous test with the ZPM prototype having 12V/55W on output and scope probe put directly on ZPM's coils (link to larger image here):
And this is a test made today with the new ZPM having 12V/55W on output and scope probe put directly on ZPM's coils (link to larger image here):
It's the same result just with optimal frequency difference of 16KHz and AMP difference of 3V between the prototype and the new device. The 17V AMP is just something I tried on that previous test, I usually go with AMP=20V.
To be honest, when I tested the new ZPM first time and I saw the ZPM specific pattern on the oscilloscope I knew the replication is successful
Chris posted this 08 March 2020
Fighter, excellent Thank You for sharing.
The first thing that stands out for me, is the Input Duty Cycle, since the start, its Asymmetrical, 25% On time, 75% Off Time and the System is still doing work during the Off Time!
I very much appreciate your work! Thank You for sharing!
Congratulations on your awesome achievements!
Thank you Chris. Yes, it's the ZPM specific pattern showing this behavior
As you know I didn't wanted to dismantle/modify the ZPM prototype as long as didn't had the device replicated (by me ore someone else). Now as I have a second device working, I did put the prototype under conservation and I can use this one for continuing research and enhancements (coils changes, additional coils and so on).
As I can find available time I will start to play with this one.
@Vidura, I think this is what you remember: I ran a test with a single 12V/5W light bulb with the oscilloscope's probe put directly on ZPM coils and there is 254Vpp (link to larger image here):
And here is the same configuration but the oscilloscope's probe is connected now on light bulb's pins and there is 242Vpp (link to larger image here):
Comparing the two measurements as you can see there is a 12Vpp voltage drop on the same wire between ZPM's coils and light bulb's pins.
This voltage drop increases significantly when there are bigger loads like one or two 12V/55W light bulbs.
I consider the presence of different voltages on the same wire in different points of the wire the proof of the presence of standing waves on ZPM's output. The physics I learned in school told me this phenomenon shouldn't be possible (except when the wire is very very long) but still here it is present in a very short wire.
I was searching in the old ZPM thread for the parameters of the test showing on ZPM's output the waveform like Graham Gunderson's device output, just wanted to verify that the new ZPM is also capable of showing that pattern:
And this is the output measurement, it's the same as I posted it last night - looking like Graham Gunderson's device output (link to larger image here):
So the prototype was showing Gunderson's pattern at 115 KHz and 25% duty cycle using one 12V/55W light bulb on output.
And this is the same test using the new ZPM (link to larger image here):
So the new ZPM has the same behavior at 111 KHz (instead of 115KHz) optimal frequency, a difference which I consider insignificant.
The only significant difference I keep thinking about is the big difference of inductance between the prototype and the replication for the bigger coil ("R"):
I still have no explanation about this, I still don't know what's the cause.
In the end of this post I'm adding a image used by a guy named David Monroe in a Facebook group named "Understanding Tesla's Stationary Waves and Scalar Energy" to illustrate the behavior of the standing waves. I don't intend to post inappropriate content but the way he explains the image is like this: imagine the perturbation we make in the zero-point field as this girl jumping on the ground; the perturbation make the zero-point field oscillate in concentric waves around but, instead of propagating indefinitely away from the center, the concentric waves encounter the pressure/energy of the zero-point field and, at a certain distance from the source of the perturbation, instead of continuing to propagate they return back to the source of perturbation. The important thing is when they return to the center they contain the energy/pressure of the zero-point field which made them return to the source of the disturbance. That's the energy which is used by all over-unity devices to provide more energy on their output (link to larger image here):
Ignoring the nice girl in the image I think the image and the explanation sounds like a good description of the standing waves and the way they can transmit energy from the zero-point field to the source of disturbance.
Chris, if you consider the image inappropriate for the forum let me know and I will remove it.
Fighter posted this 10 March 2020
Hi guys,
Cd_Sharp asked me to run some tests for finding out the resonance frequencies for ZPM's coils.
I'm adding the results here for later references.
What I did was to insert a sinusoidal signal with AMP=10V and measure the frequency where coil's resonance is maximum in amplitude (note: the ground connector from the signal generator is not connected). Something like this (link to larger image here):
So I disconnected the connection between coils and all the wires connected to ZPM and started testing.
This is the test for coil "L", the smaller coil (link to larger image here):
This is the test for coil "R", the bigger coil (link to larger image here):
Then I soldered again the connection between coils.
This is the test for coil "L" plus coil "R" together (link to larger image here):
So the preferred resonance frequencies for ZPM's coils are these:
  • coil "L" (smaller coil): 11.9 KHz;
  • coil "R" (bigger coil): 6.4 KHz;
  • coil "L" + "R": 11.3 KHz.
Fighter posted this 22 April 2020
Hi guys,
I hope everyone is okay.
I know the world is in a bad shape right now but we must remember how to laugh again, this is how we Romanians survived over 50 years of communist darkness - we were making jokes and laughing about it.
So a joke about the current situation:
And in a more serious and realistic way:
Now going back on the subject, I'm posting some updates with a promising experiment using a different experimental configuration of ZPM.
I tested many configurations while trying to build a input coil separated from the output coils. Also switched to a 220V light bulb on output.
The results are not spectacular but I consider them a good beginning of the enhancements stage.
As it's difficult to describe the current configuration and behavior of ZPM in words I thought it will be more clear if I make a video presenting it. I know I'm not a good speaker but I don't intend to become one, my intention is just to present my findings.
So this is the video:
The current question is why putting the bigger coil ("R") in short provide more energy on output and also why putting the capacitor in parallel on the same coil is providing more output than shorting the coil. Kind of makes no sense as putting a coil in short should make it "disappear" (so to speak) from the configuration.
I don't have answers to these questions right now but when I find some time I intend to get screenshots of the oscilloscope with the probes on "L", "R" and input coils for each scenario (coil "R" not in short-circuit, then in short-circuit, then with capacitor on parallel on coil "R") and try to see what exactly makes these differences. I'll post the updates here.
Also I'll continue changing the configuration and test, trying to get better results. This was the reason why I created the ZPM replica - to experiment on it without dismantling the ZPM prototype which is stored in a sealed container for now to limit the contact with the air and the rust of its core.
Stay safe everyone.
Fighter posted this 25 April 2020
For later references I'm posting here the analysis of the latest configuration with measurement schemas, oscilloscope probes placements, frequency, oscilloscope screenshots and photos of the 220V light bulb  for each test:
1. Oscilloscope probes are connected to coils "L" and "R" with oscilloscope ground connected on the connection between coils (the yellow channel is bigger the coil "R", the blue channel is the smaller coil "L"):
  • simple configuration (no short-circuit on coil "R", no capacitor in parallel with coil "R"):
  • short-circuit on coil "R":
  • capacitor in parallel with coil "R":
2. Oscilloscope yellow probe is connected to output (coil "L"+"R"):
2. Oscilloscope yellow probe is connected to input coil:
It's a lot to analyze in this data but somewhere in the oscilloscope screenshots is the answer to the question "why short-circuiting coil "R" or putting a capacitor in parallel with it provide more energy on ZPM's output ?" and hopefully some hints on how to amplify this effect further.
If you notice something in the oscilloscope screenshots please let me know.
Also something I find strange is the fact that on the input coil I have more than 300 Vpp and more than 45 Vrms, I should have just 25 Vrms as provided by the DC source, is that back-EMF ? Is it how ZPM as usually is sending power back to the DC source ?
Many questions but finding answers to them will lead to further enhancements of the device.
1. Initial (link to larger image here):
2. Bigger coil "R" short-circuited (link to larger image here):
3. Capacitor put in parallel with the bigger coil "R" (link to larger image here):
Looking at the oscilloscope data I see major changes in coils' behavior between the testing scenarios.
Here should be the key of the effect and hopefully some hints on how to enhance it.
Chris posted this 25 April 2020
Hey Fighter,
My Friend, EXCELLENT WORK! I sent you a Donation to help out! If more donated, then we would be able to do more work, share more! Right now times are tough! But right now we have an opportunity like we have never had before! We can come out of this Virus issue into a Changed World! We will come out of this into a Changed world! Lets make the required changes!
I urge everyone, Fighter has shown excellent results! His first machine was 3 Watts above the Unity Boundary!
If everyone just donated a little, this work could go so much quicker.
Lets Change this world for the better! Lets push for the Advancement of Humanity!
Fighter posted this 26 April 2020
Thank you my friend.
We have some fine builders here but we need more. We should put our experimental data together in order to push forward. On my side I was very curious how @YoElMiCrO's replication of ZPM works and I was looking forward to see some testing data, having a ZPM replica tested with a different setup (DC source etc.) would be very helpful. Sharing is the key, that's why I continue to share my findings but there are too many directions/configurations which should be explored and I can't go to all these directions on my own, I can build just one configuration at a time (as I find some free time) and testing it takes a lot of time. For example I found this effect but learning how it can be enhanced will take some time and experiments. Who knows what other effects are waiting to be discovered in other configurations ? We need data sharing and more experiments.
YoElMiCrO posted this 26 April 2020
Hello fighter.
First apologize for the time you have spent publishing my findings, you have
sense because to understand it I had to carry out many experiments with circuits
to demonstrate the hypotheses that occurred to me along the way.
I tell you that the tests I carried out on your ZPM were on a small scale
for not having large amorphous core, only a few cores used
to measure alternating currents, but enough to understand
partially what was happening, like the magnetization/demagnetization energy phases,
the energy/mass density and stuff like that.
Your system shows that N.E. Zaev is right, only that you went further
using bucking coils and in relation to 0.25.
I'm still a bit complicated to work, but I almost have an article
realized that it talks about your ZPM even though all the systems share
the same phenomenon.
This week I will make a little time to finish it, so I can publish it
here, then I will put an article in Tier II and of a deeper theoretical nature
so we can all debate its veracity with simple experiments
until we finally have at least one working flashlight.
Thank you in advance.
YoElMiCrO.
Chris posted this 26 April 2020
Hey YoElMiCrO,
Who is N.E. Zaev, and what is it you think he is right about? Never heard of this person. Is the following what you are referring to:
History notes
N. E. Zaev’s article about using environmental heat to generate electricity was published
somewhere in 1991. According to some internet resources, N.E. Zaev was researching this
concept since 1960s, probably in cooperation with P.K. Oshepkov, founder of Public Institute of
Energy Inversion. I heard first time about Zaev’s idea of conversion of environmental heat to
electricity about ten years ago. Since that time I made a lot of experiments and attempts to build
such device without any significant progress. In desperation, I started studding everything related
to magnetic properties, BH curves etc. And accidentally, last year a chain of unexpected events
was triggered, which brought me to understanding and some experimental results. Here, in this
short summary, I am trying to document a path which one have to follow in order to be able
understand and build such device.
Interesting!
@YoElMiCrO, no apologies needed, it's okay, I'm really looking forward to read about your findings and your results with ZPM. The thing is the information I'm sharing here and your information you found based on ZPM's behavior could help in enhancing the device, to go further to the final goal of having a self-looping capable device. That's why we all are here, else we would be some lonely wolves experimenting alone and not capable of exchanging information.
@Chris, I heard of N.E. Zaev and his ferro-kessor but my understanding is his device was becoming very cold while functioning which didn't noticed happening with ZPM. It's true its coils are never even warm but the Metglas's temperature is the same while functioning. I'm looking forward to read YoElMiCrO's findings, he is more advanced in electronics and physics. His data could possibly help in significant enhancements of ZPM, that would be great.
Chris posted this 27 April 2020
@Fighter, I have done a little research and see some of N.E. Zaev's work. Yes a Heat Exchanger of sorts, a very confusing exchange of Energy into Coils and Capacitors as we would normally understand it:
Ref: http://jnaudin.online.fr/html/nzaeexp.htm
I remember reading this years ago, I did not recall the name: from Nikolay Zaev.
I have done a lot of research in this area, but can not prove it, and can not find a way to further understand it, however in saying this, I have a feeling, what YoElMiCrO is saying is close and maybe right! I think we need to think of this in another way however.
Quote from my attached pdf above:
As we know, in usual transformer BH loop traversed counter-clockwise and loop’s area corresponds to energy loss in transformer core. But if we manage to create such device where BH curve traversed clockwise, area of the loop will represent an energy gain.
The plot forms an ellipse whose area represents the energy lost per cycle. Note the area is traversed anti-clockwise.
Of interest to OU researchers is the concept of negative resistance, since this represents a source of energy rather than a sink. The next figure shows the Φ v I plot for an inductor shunted by a negative resistor.
Figure 5. Φ v. I plot for negative resistor
Ref: PDF Document 'h2e' Image from 'A New Look at the Bearden MEG © Smudge, May 2014 Smudge', aka Cyril Smith.
Now, some of this makes sense to me, some of it, but not all of it. So I cant say this is how its done! I have researched working at the knee of the BH Curve before, but again, even though knowing about this area where there may be some advantage working, I can not say for sure this is what is required and what is needed.
2. Synthesizing a Clockwise Φ v. I Loop
It is known that, by the use of short-circuited coils, it is possible to divert flux from a magnetic material. Thus it may be possible to synthesize the clockwise loop by stitching together two different characteristics. Consider  the following typical Φ v. I characteristic for a saturating material.
Figure 6. Φ v. I plot for saturating material
If we could arrange for flux within a coil to be positive-going while also going over the positive saturation knee, then when negative-going it does not trace its original steps, but passes over the negative saturation knee, we would get the combined characteristic we desire. The following section is devoted to this possibility. First consider a magnetic core having two coils connected in series aiding, yielding an inductance L.
Ref: A New Look at the Bearden MEG - By Ciryl Smith aka Smudge
I would recommend more research in this area! In my following experiment, perhaps the loop here may have some relevance?
Cyril Smiths document: A New Look at the Bearden MEG, is attached below.
@YoElMiCrO - I also am looking forward to seeing more of your experiments and results! A greater overall understanding is what I strive for! I appreaciate your input here, Thank You! I found this interesting:
One way to cool a gas is as follows. First compress it isothermally. This means compress it in a vessel that isn’t insulated, and wait for the gas to lose any heat that is generated so that it returns to room temperature. Then insulate the vessel and allow the gas to expand adiabatically. We could call this cooling by adiabatic decompression.
You can cool a rubber band as follows. First stretch it isothermally. That means, stretch it slowly, so that it has lots of time to lose any heat that is generated. Then, suddenly destretch it, and before it has time to gain any heat from its surrounding, measure its temperature by immediately holding it up to your lips. You will find that it has cooled by adiabatic de-stretching. (If you stretch the band quickly (i.e. adiabatically) and immediately hold it up to your lips, you will find that it is hot. BUT ... before you try that experiment, close your eyes tightly. You don’t want the stretched elastic band to break and hit you in the eye. Believe me, you do not want that to happen.)
The method of adiabatic demagnetization has been used to obtain extremely low temperatures. A sample of a paramagnetic salt (such as cerium magnesium nitrate), already cooled to low temperatures by other means, is magnetized isothermally. The sample is often suspended in an atmosphere of helium, which can conduct away any heat that is produced, and hence keeps the process isothermal. It is then insulated (by pumping out the helium) and suddenly and adiabatically demagnetized. This process of isothermal magnetization followed by adiabatic demagnetization can be repeated over and over again. Temperatures close to 0 K have been reached in this manner. You could actually reach a temperature of absolute zero if you did this an infinite number of times – but not for any fewer.
In the analysis that follows, I shall have to assume that you are familiar with the concepts of B, H, magnetic moment and magnetization from electricity and magnetism.
In brief, the magnetic dipole moment pm of a sample is the maximum torque it experiences in unit field B. That is, the torque is given by . τ = pm × B The magnetization M of a specimen is defined by ). ( B = µH = µ0 H + M The magnetization is also equal to the magnetic moment per unit volume.
Now consider the following.
If the tension in an elastic string is F, the work done on the string when its length is increased by dx is F dx.
If the pressure of a gas is P, the work done on the gas when its volume is increased by dV is −P dV.
Ref: http://astrowww.phys.uvic.ca/~tatum/thermod/thermod15.pdf
Again, I just want to say, do your own research here, I agree with what YoElMiCrO has said, I am partly in agreeance with some of the above, but not all of it! Come to your own educated conclusions!
Stay safe and well everyone!
Fighter posted this 29 April 2020
For later references I'm quoting YoElMiCrO's analysis about ZPM from here:
Hello everyone.
In order not to distort the Fighter tread, here is this observation.
The Fighter ZPM even though it looks like the document published by N.E. Zaev.,
does not fully share what is published, as it is not exact.
In your case the potential energy is higher by using bucking coils, good
that idea on his part.
In his tread I will talk about what happens from my point of view.
But let's see in practice what Zaev talks about.
This scope image shows what it is based on…
And this is the circuit in question ...
If we look at the mauve stroke, it is Ton's pulse at the gate of the mosfet and the
yellow stroke is the behavior in the drain of the same.
Your system works in the revercible area of 鈥嬧媓ysteresis, not in the
saturation area as we are studying.
That is why your system exchanges heat with the medium.
Let's carry out an analysis by simple inspection ...
The resistor parallel to the primary is powered by the source for
the voltage drop time at the mosfet drain, the latter being
of the order of the ns, after turning off the mosfet the resistor remains
powered during the adiabatic response time of the core.
So in theory TD>>TM and the energy gain is proportional
a TD/Tr> 1.
I hope this post will definitely serve the concept in which
your system is based.
YoElMiCrO.
Note: YoElMiCrO, thank you and you're really welcome to post your thoughts here, it's about ZPM so it's not a problem and no distortion
Chris posted this 29 April 2020
@Fighter, and all,
I agree, this is important! If you think a post by anyone is important to your work, please do as Fighter has, re reference it and quote that post in your thread! This is excellent technique for referencing material that is important to your thread!
Great Work Team! I am so awesomely Proud of our Progress!
Floyd Sweet said:
With regards to over-unity phenomena it is important to note that so long as positive energy is present in a positive / flowing time regime, unity and over-unity power gains are not possible. The summation of the losses due to resistance, impedance, friction, magnetic hysteresis and Eddy currents and windage losses of rotating machinery will always reduce overall efficiency below unity for a closed system.
Floyd told us he did not use Hysteresis as such, reading between the lines that is.
Fighter posted this 30 April 2020
And another piece of information related to ZPM as a quote this time wrote by Vidura here:
If I may add my two cent's regarding yoelmicros post about the effect described by N.Zaev: Time ago I did the experiment and noted that with a puls as short as 200ns applied to a inductor it becomes "spontaneously magnetized" that means before a current is actually flowing thru the inductor. but the following demagnetization is about five times longer, and with active power flowing thru a resistor load. The energy returned in form of the BEMF is clearly greater than that from the applied pulse. Practically it is not very useful, as the gain is very low, and it depending on the mass of the core. But it seems that in the case of the ZPM it is notably magnified by the cancelling coils, which would make the effect strong enough for practical implementations.
Thank you all for the great work.
@Cd_Sharp, this could be a key useful for your research about enhancing the coils for your device: "with a pulse as short as 200ns applied to a inductor it becomes "spontaneously magnetized" that means before a current is actually flowing thru the inductor. but the following demagnetization is about five times longer, and with active power flowing thru a resistor load."
YoElMiCrO posted this 30 April 2020
Hello everyone.
@Fighter.
This is a preliminary analysis that I have done on your ZPM
long ago I think in your case when using Buckuing-Coils
is based more on the nonlinearity of the inductances even than
also uses the phenomenon described by N.E. Zaev. let's say
which is a conglomerate of phenomena not so studied.
Thanks to your ZPM and your observations I began to study
or at least try to understand what the real phenomenon is not
so observable that it transcends the physics we know.
It is this subtle phenomenon that really involves everyone
the devices whose creators claim AU, still under study.
This is my view point…
On your device, during the magnetization cycle the inductance
magnetizing is the difference between them since the fields
magnetics are in the opposite direction, that's logical!
However during the demagnetization cycle the inductance
grows due to their attempt to maintain a sense of
current circulation, this image I think will clarify what I say ...
As the magnetizing current is common, the energy grows by itself
because now the inductance is greater than the initial one and its COP will be proportional
to the difference between them.
This is demonstrated by the time it takes to return to Edc during
the BEMF, since for the core to return to the initial position
within the hysteresis cycle it will have to be fulfilled that (EdcTon)=(BemfToff).
This idea of 鈥嬧媢sing Bucking-Coils started WET, now
parked due to time/work problems, also Vidura's post
here and other experiments related to another phenomenon you notice.
Here I leave you an image with some theoretical approaches in case
It serves you something, if it helps you do not hesitate to ask.
YoElMiCrO.
Thank you YoElMiCrO, I will need some time to process this information. You're welcome anytime to post in this thread.
Atti posted this 30 April 2020
Hi.
I need a little help.
I’ve done a similar test before, so I’m putting it in this thread. Seeing here in this thread the work of Fighter Vidura and Yo. Chris and CD's layout also fits here, I think.
The two tests are measured at the fet gate and at the light bulb load, respectively. Looking at the times entered and withdrawn. As well as the effect of the loosely coupled coil on the primary. (that would have been the essence of the past video)  At 1:40 a slow diode is displayed. So you can actually count on the delay.
  Schematic drawing at the beginning of the video. I'm not sure I'm going in the right direction. What are your opinions?
Hi Atti, the layout looks more like a layout tested by @Cd_Sharp. Is the input coil wrapped over the output coil and they are bucking coils ? I just started to test ZPM with a third coil separated as input so my experience on this kind of configurations is limited. But I see a interesting thing, consumption from source is jumping a bit but then returning to the previous value when you add the second light bulb. And also I see something which I'm very familiar with and it's a part of ZPM's specific pattern, the signal of a coil is looking like a spring.
The quote below is part of a previous post made by Chris in this thread here:
The Interactions between the Coils:
In Fighters ZPM we see a very interesting Spike:
Marked in Red is the process I describe above in the video. The Coils are like a spring, and Act and React together in Magnetic Resonance. This is an Electromagnetic Induction dance, or disco. Electrons are getting some moves on and the Disco is going off...
This is excess Electromagnetic Induction after the fact! After the Input has excited the Coils into this Resonance.
In my opinion you're going in the right direction and you also have another interesting effect: consumption from source is jumping a bit but then returning to the previous value when you add the second light bulb.
I took a screenshot from your video and marked the spring-like pattern and also something else, a additional spike is present even if your input is not changing. That's intriguing...
Guys you may post your opinions here, it's not a problem.
Atti posted this 01 May 2020
Hey Fighter.
The layout, so the coils of the drawing is connected.
-The spring-like pattern is due to the AMCC core.
Other transformers do not have such a spring-like pattern (e.g. hypersil)
-The additional pin is only present if only the loosely coupled coil is connected (according to the drawing there is only a light bulb on the right coil, in which case there is no light bulb on the coil on the left)
However, this is also only with one kind of diode! (This is a very old diode. Tungsram SY100 but unfortunately I can't find a datasheet about it. But I assume it can be very slow)
-I also tried with another transformer at a lower frequency.
The effect is the same.
-This load raises the Fet Drain voltage. If it is very high and of inadequate value then Fet will be ruined!!
Atti.
cd_sharp posted this 02 May 2020
Hey, Atti,
Nice job, I see inrush current in your setup. About the delay conduction I think using a switch instead of the slow diode gives you a lot more control. I also took a shot at TVSs, but I can say that only a part of them are truly able to conduct suddenly.
Thumbs up from me!
YoElMiCrO posted this 03 June 2020
Hello everyone.
@Fighter.
If you want, try this configuration of your ZPM.
As soon as I can I explain how it works.
YoElMiCrO.
Fighter posted this 03 June 2020
Hi YoElMiCrO,
Thanks, I'll give it a try.
So far the tests with a separate coil for primary failed, seems I'm on a wrong way.
That's why I didn't posted anything new.
When you have some time please feel free to post the explanation.
I appreciate,
Fighter
YoElMiCrO posted this 04 June 2020
Hello everyone.
@Fighter.
The best way I've ever seen to get energy from the E-field
is the previous post, testing Floyd Sweet's idea that only E remains
while we cancel H.
This is possible with the following reasoning.
Imagine that the two inductors are exactly the same
and they are in non-inductive mode, in this way the current will move
the magnetic permeability instantaneously to its highest value, this
current value will be defined mainly by the value of the placed load resistance
in the center of the inductors while the turns define the permeability for that current.
Being inductors, Faraday's laws do not apply, but Biot-Savart's laws for a field
defined B for which the magnetic permeability is maximum.
Put another way and excuse the mathematics ...
It turns out that during Ton's time the two fields collide at their center,
if we take the latter as a reference we will see the following ...
Since the two magnetic vectors are at 0, the energy expenditure
the source will only be to supply the current required by the load and only
that in theory we do not store any energy in the system.
But during Toff's time, these vectors revert to natural action
of them, (in their attempt to make the current follow the same direction) away from the center (0),
In other words…
During Ton's time the two beginnings are (+/-) and for Toff (-/+), as the current
it is maximum for the beginning of Toff and the tension increases by the induction of E
the load will see more energy during that half cycle.
You can play with the duty if you want, also with the relationships between the inductors.
Here are some images of the experiments I carry out.
The load in this case is a 6W@12Vac LED lamp.
Note:
Chris is right about using POC, it is related to a fundamental phenomenon
that occurs in nature with or without core, but still under study.
As I commented earlier in the shortest possible time I will deal with it in this post here.
YoElMiCrO.
Chris posted this 04 June 2020
@YoElMiCrO, @Fighter and others,
I wish others reading would Join In and Share their work! We here, have tried for so long, but we can not do it by ourselves! We need everyone to join in, to learn, to build and to share!
This can only be Public Domain if everyone in the Public knows about it, learns it, shares it and suppresses others trying to claim this as their own.
Thank You YoElMiCrO for the acknowledgement! I very much appreciate your effort here to help others along as I do all Members here!
As you point out, there is a very simple critical Base Requirement:
  1. Two Output Coils, Partnered Output Coils, POC.
  2. The POC must have opposing Magnetic Vectors.
Everything beyond this, it is up to the order of many hundreds of ways this can be achieved. The Experiment can be performed many ways to achieve the same end result. Everything else in the experiment is a result or a specification the experimenter unwittingly imposes without knowing the base phenomena.
Thank You all! I appreciate your time, your honesty, your efforts here, and I appreciate that I have the best bunch of people here the world has to offer! Thank You All!
Fighter posted this 15 June 2020
This is as a note for myself but also for everyone who ever tried to reproduce Tom Bearden's MEG.
It also have implications on every device using "special" cores including ZPM.
Recently after I saw one of Chris' post about someone asking in private for Tom Bearden's "Energy from the Vacuum" DVDs Collection I became curious and wanted to see what those DVDs contain.
For now I only saw the first DVD from that collection and I already found out there are hidden gems on those DVDs. Really important stuff !
One of them is what I post here and it's Bearden explanation on how MEG really works. It's a paradigm-shifting video segment and I'd wish I'd saw it few years ago when I was trying to replicate MEG.
This is the video segment I'm talking about:
There are a few paradigm-changing conclusions:
  1. J.L. Naudin's explanation on how MEG works is totally wrong. So this simulation is wrong:
The role of the permanent magnet is not to have his magnetic field switched to left and right core sections by the small command coils.
2. Seems that when a permanent magnet is placed inside of the core without gap so the entire magnetic flux of the permanent magnet is "sucked" inside of the core and become trapped there are two effects:
  • the permanent magnet become almost inert so it stops emitting magnetic field around it or (depending of how close to 0 mm is the gap between it and the core) it's emitting a very small magnetic field compared to its original magnetic field;
  • when the previous conditions are happening and almost all the magnetic field of the permanent magnet is trapped inside the core something new happens: outside of the core a zero-point/quantum/aether (however you call it) field is formed containing additional energy ready to be captured by our device.
3. The practical way of capturing additional energy from that new zero-point/quantum/aether field formed outside of the core is to "shake" that field by pulsing the small command coils on top of the MEG. That will make the output coils capture the additional energy contained in that field therefore zero-point energy is added to the device's output.
4. Tom says MEG's output actually contains multiple and very complex signals which our actual instruments (including the oscilloscopes) are unable or have major difficulties to analyze; he says that because of this there is very difficult to calculate the real energy from the output and expensive specialists and specialized instruments are required for calculating MEG's COP.
5. Seems COP 5 is not the limit for MEG, it can go higher but in the prototype trying to go higher would burn the output coils.
6. He's talking about "nano-crystalline material, there's 2-3 types which would do it"; Metglas AMCC core is actually amorphous metal alloy, not nano-crystalline, so I'm not sure it's one of those 2-3 types Bearden is talking about. What if it's not, what if when placing a permanent magnet inside a AMCC core the magnetic field is not "sucked" and trapped inside the core or what if that zero-point field is not forming around the core ? In my experiments I used AMCC-200 but what if, to really have that zero-point field forming around the core, a nano-crystalline core like Hitachi F3CC0125 is required ? Since seems that zero-point field forming outside of the core cannot be detected directly is difficult to verify if amorphous metal cores are able to have that effect or not. If not then I experimented for years with a wrong core so this is a important question which I have no answer for it right now.
Augenblick posted this 15 June 2020
Fighter,
Looks like that video series has a lot of hidden gems. Tom Bearden has broad shoulders for us to stand upon, with Chris encouraging us to step up.
This is exciting stuff.
A great post! Thanks!
-A-
... in the blink of an eye.
One would imagine that no special materials were created for the MEG project, but rather off-the-shelf cores were utilized.
Looking at the characteristics of Hitachi FINEMET, the saturation/permeability boundary has been exceeded.
Superior
https://www.hitachi-metals.co.jp/e/products/elec/tel/p02_21.html
-A-
Chris posted this 15 June 2020
Hey Fighter,
There is some good data in the Videos mentioned, but also, there is some confusing data.
I think Experimental Results speak for themselves, and you have shown results consistently. One could spend a lifetime searching for the ideal Core Material, and find the first Core that was tested to be the best, that's a possibility.
The Magnetic A Vector Potential left on the Outside of the Core, is an Electric Field with Curl:
  • B = Magnetic Flux Phi or Φ
  • A = Magnetic A Vector Potential
This Magnetic A Vector Potential is only available, if one Changes the Field, if one changes the Coil Position, then this is not available. So the Magnetic Field Phi or Φ, must also be changed, because the Magnetic Field and the Magnetic A Vector Potential are part of the same thing. Magnetic Flux is both: The Magnetic A Vector Potential and Magnetic Flux Phi or Φ.
The Screen shows Flux but no Magnetic A Vector Potential. Above, Magnets in Attraction Mode.
Below, Magnets in Opposition mode:
In this experiment, Magnets are in Opposition Mode. This says a lot here! You know the Poynting Component?
When I started my public Replication, I was wrong in my initial assumptions. You can see here, my replication work.
I failed miserably, you will see comments like: "Lenz's law is a problem"...
On The MEG Thread, I explained how one day I connected the dots, and I saw the Interaction between the Two Partnered Output Coils. I saw how they Interacted, to create excessive Electromagnetic Induction.
The fact that One Partnered Output Coil had a MOV, or a conditioned Carbon Resistor, or a TVS or Transorber on it, not connected to the Output, or the Input speaks volumes:
This means, there was a timed Action Reaction Pair, the Tertiary Coil had to be assisting the Action of the Primary Coil to get a Gain on the Output.
I knew I had it right when I saw the MEG Team release the following:
Because I had seen this already, I knew it was what was necessary. Your waveform is what is necessary for your configuration! You show, clearly, that there is another method to reach the same Magnetic Resonance!
Most of all, what confirms you are on the right direction, is Your Results! So stick with your results, they guide you.
@Augenblick I'm not saying a special core was created for MEG, just maybe I was the one using a wrong core (amorphous) and maybe for that core the field around is not formed in that scenario as it is forming with a nano-crystalline core. About the gap, Bearden says it's not necessary to be perfect, the condition would be to have almost the entire magnetic field of the permanent magnet to be "sucked" and trapped in the core.
@Chris a important correction, Bearden says the field formed around the core is NOT curled:
If that's true and the following phenomenon is also true
then we don't need to use energy to create two opposing magnetic fields in order to create that field surrounding the core.
The only energy we will use is the pulsed energy directed to the small command coils for making that surrounding field to pulsate.
That would be a significant decrease of the energy required on input.
So the only condition to have that surrounding field present permanently (and without any energy required) would be to find a matching permanent magnet and core able to create this phenomenon.
So if what Bearden is saying is true then we have a permanent way to convert the undetectable zero-point energy to a detectable UNCURLED potential surrounding the core without any energy costs for us. We will just just need to pulsate it and that would be the only energy cost for us.
I find this extremely interesting, at least for me it changes the entire concept of how I was thinking the MEG works !
Of course the only way to verify the validity of what Bearden says is through experimenting. I'd wish I had all this information a few years ago when I was experimenting with the MEG concept.
Chris posted this 16 June 2020
Hey Fighter,
Good catch My Friend!
When Two Forces, in our Case, M.M.F's Oppose, the Curl becomes Zero. Each Curl opposes the opposite Curl. At least this is how I understand it.
Floyd Sweet said:
Electromagnetic induction with no measurable magnetic field is not new. It is well known that in the space surrounding a properly wound toroidal coil there is no magnetic field. This is due to the superposition of the fields. However, when alternating current is surging through a transformer an electric field surrounds it. When we apply the principle of superposition to the vacuum triode it becomes more obvious how the device is in fact operating.
Reference: Floyd Sweet Nothing is Something.
So, the Non-Curled Electric Field is from the Cancellation of the Curl. Curl Superposition.
Augenblick posted this 16 June 2020
I understand, Fighter. I was confirming what you said about the Hitachi core(s). Your post had me look into that type material, and I was edified by what I found. It brings much to the imagination. Keep those great thoughts/ideas coming. I am understanding more with every post.
Thanks!
-A-
Fighter posted this 21 June 2020
I have some updates.
As you probably noticed I started working on a secondary project for learning purposes:
Fighter's replication of Andrey Melnichenko's GLED
Also I was so intrigued by the recent finding about how Bearden says he used the Aharonov-Bohm effect for MEG that I decided it's worth investing in a experiment in that direction, if the experiment is successfully it would mean a huge step forward for our devices including ZPM:
Aharonov-Bohm effect as zero-point energy concentrator
The ZPM enhancement project remains my main project and I'm gonna experiment with the configuration posted here by YoElMiCrO.
Also hopefully the Aharonov-Bohm effect experiment could provide a big enhancement: a input-free mechanism for the same effect manifesting not only in ZPM but also in our other devices.
Atti posted this 09 July 2020
Hi.
I haven’t seen this document yet, but the oscilloscope figure is similar to the value presented by Fighter. See pages 104 and 122.  https://ferd041.files.wordpress.com/2016/07/fe_basics.pdf
Fighter posted this 09 July 2020
I didn't knew about this, thank you Atti !
Yes, the waveforms (especially the one from page 122) are very familiar:
Also the device presented there has two opposing coils with 1:2 size ratio.
The difference is that the device has coils one over the other (overlapped) and it has a air core.
Maybe that's the reason why the ZPM waveform (actually Gunderson's waveform because he was the first showing that pattern) has a higher peak before the spring-like section. But the spring-like section is present in both waveforms.
Zanzal posted this 12 July 2020
Hey Fighter, any initial thoughts on the use of Finemet for these experiments? Are you seeing anything to indicate it is worth the price?
Fighter posted this 12 July 2020
Hi Zanzal,
I answered in the Aharonov-Bohm Effect thread here.
Fighter posted this 23 July 2020
I was watching a video from Tom Bearden's "Energy from the Vacuum" DVDs Collection where Bedini explains how Tesla's impulse technology is gathering zero-point energy. There are similarities in the behavior with ZPM and therefore with Chris' bucking coils technologies.
This clarify more ZPM's functionality, basically ZPM have two virtual Bloch walls (on top and on bottom) which are variable in with and which allow the zero-point energy to enter into the system then compress and gather it. This also explains the negative voltage spikes, basically that's the energy gain and that's why, while powering up the light bulbs on the output, ZPM is sending energy back to the DC source, it's seeing it as a load and it's trying to power it up. That's the energy heating up the MOSFETs in my MOSFET driver and it's confusing the readings on my DC source as it's unusual for a DC source to receive energy back from a load.
Basically the negative voltage in the system is our free energy gathered from the zero-point field.
I wanted to share with you guys what I'm learning so I created a video about it:
Chris posted this 24 July 2020
Hey Fighter,
I tend to agree, Bedini uses all the right words. The understanding is there!
I have had trouble in the past, keeping focused on the target:
Magnetic Field Opposition and Charge Pumping!
In point of fact, we know this is the fundamental base concept. Hanging the Image up on ones monitor:
May be of benefit? Always have to make the Fields oppose, in Magnetic Resonance! Simply, there is no other way to "Generate" excess Energy!
Thank You for sharing My Friend, Best wishes,
Atti posted this 4 days ago
Hi.
Analogy of effect A-B. It is well illustrated in this video.
On a suspension connected by an abbreviation with a chopstick. This would replace the pace of control. Then a different resonance, i.e. a different rate of load. The difference between the two different resonances is another excitation stage which affects both coils and loads.
Binaural beat.
Another feature used. If two sounds with only minimal differences in frequency can be heard in isolation in our two ears, the interference between the two sounds is automatically created in our head (the auditory subsystem of the brain) and the effect of sound vibrating at the two frequencies becomes practically perceptible.
You can search for a lot of videos about this. Or you can hear it here and even see the figure. https://hu.qwe.wiki/wiki/Beat_(acoustics)
Atti.
