Hi, all.
Ok, I'm getting frustrated. My flux-switching transformer experiment is predicated upon utilizing the unique magnetic properties of a 48% Nickel, 52% Iron wire with specific annealing.
I've tried pretty much every wire manufacturer I can find on Google... either they don't manufacture the wire in the alloy I need, or they only make round wire, or they can't anneal it properly, or they can only supply bare wire, or they want me to buy production-scale quantities.
How do other researchers get wire with custom properties manufactured? Does anyone know of a manufacturer that can help me?
The wire is Ni48Fe (binary alloy of 48% Nickel and 52% Iron, sized 0.5mm x 4.0mm, with the annealing process as follows: Dry-hydrogen annealed (4 hours at 1175 C, cooled for 9.5 hours in the furnace at a rate of 50 C/hr, hold at 700 C for 1 hour, then cooled at 1500 C / minute).
This imparts specific magnetic properties to the wire which is needed for this experiment.
The wire must have insulation with high dielectric strength. PTFE should fill the bill.
I'm looking for a 25 kg spool, although if need be, I can go as high as 50 kg.
