Pulse Charger with opposing coils
  • 586 Views
  • Last Post 4 days ago
baerndorfer posted this 28 May 2020
While trying to understand more of this opposing coils thing i build a pulse charger.
this is how the circuit looks actually..
i build many of these small coils from stuff laying around - they all work but the frequency is different.
when i have 2 toroids with same dimensions and properties i will do one with the ordinary winding and the other with opposing coils (same wire mass). think then i should be able to measure a difference.
btw this charging circuit works brillant on lead acid or other 'loads'.
regards!
Chris posted this 28 May 2020
@Baerndorfer - Nice work! Beautiful Build! Thank You for sharing!
@All members, I would ask your input to help Baerndorfer with his Opposing Coils. He and I have had a few private messages, and he asked for input, to guide his Coil Project, to where is can be seen to do things not described in the average textbook. Baerndorfer please correct me if I am wrong! And I got the wrong end of the stick.
@CD, what are your thoughts, I would be extremely happy for the community to be seen coming together to help other members along!
Initially, the circuit is ideal as a start, perhaps a few more diodes? Think of, and treat each Coil as a Source, a Battery. Each having polarity, a source of Voltage and also Current, where Magnetic Fields can make your Coils come to life!
Looking forward to see what our Number One Community can share and do to help Baerndorfer.
Vidura posted this 29 May 2020
Hey   baerndorfer, some suggestions if I may. Looking for excess energy we have to be aware that it is mandatory to interact with the Aether environment, a disturbance in the latter can cause an inflow of energy exceeding the input. We know that bringing the core material in the non linear region near saturation during a part of the cycle can cause such interaction. For example a very simple way is adding a static magnetic field offset with a permanent magnet, seeking the best working point by changing the distance to the core.
Another way is working with asymmetric inductance between input and output as Jagau has explained lately.
Hopefully this helps some.
Wistiti posted this 29 May 2020
Hi Baerndorfer! Welcome aboard! Great nice build of the Re-emf charger you done.
I have build many of these charger and I also have to say they work really well!
In my experiment I have see that collecting the bemf of the primary coil lower the power output and effect of the poc. Try with and without the diode on the collector of your transistor while monitoring the output of you poc.
Also the polarity of the diode at the output of your poc is crucial. Try flipping the diode to seek the better output with a reduced input power.
Thanks for sharing your works!
L0stf0x posted this 29 May 2020
Baerndorfer, very nice setup!! Thank you for sharing!
It reminds me a similar setup...
I can suggest one thing that worked in my setup, I maybe wrong, but it may help..
Static magnet on a closed toroid core I think will not give any profit. Its a fully close flux system.
Toroid is good to get and the last drop of flux back for use. But as Vidura suggests in a way its needed to trigger aether directly somehow. To make a "window" of communication with aether grid.
I would try that... Do not use toroid.. Use a core from a flyback transformer, which is two equal peaces and makes easier to wind the coils. Then keep the one connection point of the two peaces in touch, the other to have an open (small) gap. Place an extra coil at the one exact end of the core. Connect the earth at the one side of the coil and leave completely open the other side.
(To make a good contact at the other side of the core connection, and not be inclined, you can add a thin iron washer at the one closed side and at the other side place a same height paper or plastic so to get the core straight)
Like that..
If you have time and want to test it try it. I had tested a similar setup before few years and I was getting very good results. I don't put my hand on fire for that but you can try it and see.. With this small gap you may open a window to aether, then I guess the static magnet can play a roll as well. So the gap leaves you with more options to try different things. Again I am not sure it will work, it is something I would try. I hope it will help you!
This is the video of my setup.. I used a combination of 3 cores... look the changes of the input current when I connect the earth to the open coil at the edge of the core (the other side of the coil is not connected anywhere), then when I disconnected it and then when I disconnect the load.
cd_sharp posted this 29 May 2020
Hey, baerndorfer,
Very nice, professional build. By looking at the schema you posted I don't understand how you start it as there are 2 reverse biased diodes blocking current from the DC supply.
baerndorfer posted this 29 May 2020
hey cd_sharp!
i came across this ReEMF circuit - the guy in the video did a very good explanation on this.
thx for all of your tips!
Atti posted this 29 May 2020
Welcome baerndorfer.
I don't know what your intentions are with the layout you drew. I would add a few thoughts to the pulsed charge.
I just re-uploaded an older video
thoughts: https://terszobraszat.hu/2-ingyenenergia/2-4-az-ingyenenergia-titkai/2-4-21-a-neogen-dinamo-bevezeto/2-4-23-bedini-fele-ssg-energizalo-bevezeto/2-4-23-4-ssg-kiserletek/2-4-23-4-1-pastor-kiserletei-a-hatartalan-toltovel/
Use it healthily.
Nagy Attila.
YoElMiCrO posted this 29 May 2020
Hello baerndorfer
Like everyone in this community we can contribute ideas to the experiments,
in order to improve their efficiency, even if possible AU.
From the circuit I can say that the power supply should be higher
voltage that the battery to charge at least in Vbe , approximately 0.7Vdc
for silicon transistors.
Also that it's a self-oscillating core saturation circuit and
like all they have defined all the parameters like frequencies and duty.
As Vidura and L0stf0 say the problem is the window to the energy medium
that maintains matter.
In what we can help we will surely do it.
Thank you in advance.
YoElMiCrO.
cd_sharp posted this 30 May 2020
Hey, baerndorfer, I watched the video and I noticed the schema looks close to one of the Akula circuits. I think this post from YO will help. If I had time for a new project, this is what I would try.
Hello everyone.
@Gravitation.
This example shows that the charge conservation law appears to be violated,
This law was coined by Benjamin Franklin.
The initial charge of C1 is 26.4mC,if we transfer the charge directly to another capacitor of equal
value the load would be divided between two ideally, being this one of 13,2mC in each one of them.
If we now calculate the total voltage in them, it would be Q (initial) / 2 = Edc / 2 = 6Vdc.
However if we use the above circuit we will see that the sum of the charges
will exceed the initial load and as efficiency is (EndQ1+EndQ2)/StartQ1 AU is posible..
This says a lot, everyone start analyzing ...
Q = VcC = It.
Thank you all in advance.
YoElMiCrO.
baerndorfer posted this 2 weeks ago
after hours of reading through this big encyclopedia here i gave my base-circuit a little redesign.
as a result i have a working model where you can see how to extract energy without diminishing the source dipole.
regards and thanks for all your help.
Chris posted this 1 weeks ago
Hi Baerndorfer,
Apologies, some technical problems with My Flux Capacitor. Site has been down for a few hours now.
Fantastic work! Very nice, Thank You for sharing!
At this point, it can feel like there is no further to go, nothing more can be done, but breaking this down to whats going on there is a lot that can be done.
First, you have a huge achievement! As the load is placed on the Machine, the Input Power comes down as it should! So well done, again a huge achievement!
These machines work on the Interactions of Magnetic Fields. This means the more the Magnetic Field and the Faster the Magnetic Field can work together, the better.
From here, things like:
  1. Bigger Core, with a larger Cross Sectional Area CSA.
  2. Wire Gauge which is larger, 14 gauge or something like that.
  3. Sharper Input Pulse, into a lower Impedance.
  4. A Gap in the Core can sometimes help.
  5. Measure Core Saturation, if saturated or not.
Other things also, but these are the main ones. Well done Baerndorfer! You should be very proud!
P.S: I am speculating a little, cant prove it yet, but I believe the Length of the Coils also have something to do with this also. Long Coils are less desirable, at least to a degree.
YoElMiCrO posted this 1 weeks ago
Hi all.
@Chris.
I think like you, it is not a theory of length.
Since what is needed is an intense magnetic field
the inductors should grow in diameter and not in length.
If we look at this equation:
H = NI / Le.
N = Number of turns.
I = Current flowing through it.
Le = Length of the solenoid.
We will see that H increases with the number of turns and decreases
if the length increases.
This is why in electromagnetic cranes the electromagnet
it's almost flat.
That is why the great Nikola Tesla claims that his pancake-coil
it is the best coil there is.
If we go a little further and want to amplify E field
that is formed in said coil, we make it bifilar in inductive mode,
in this way we increase its layering action through
of the dielectric that the conductors that form it possess.
We are talking directly about Tesla's original Pancake Coil.
YoElMiCrO.
baerndorfer posted this 6 days ago
yellow shows collector from transistor / blue is the POC
looks nice but should be improved !
regards and thx for your support
Chris posted this 6 days ago
Hey Baerndorfer,
There must always be room for improvement, we must always think this way, but at the same time, you have a great achievement there! Be proud, many people have not gotten this far!
Well done, congratulations!
Best wishes, stay safe and well my Friend,
YoElMiCrO's logic is sound! As always! Thank You YoElMiCrO!
Magnetic Fields as they interact together, are the catalyst for "Generating" Energy! The Stronger ( H ) and more Dense ( B ), the Magnetic Fields, the more Energy is Pumped! Remember what Floyd Sweet told us:
To free enough electrons to effect conversion would require magnetic forces approaching infinity.
Affecting Conversion, in other words, to change the atomic composition of the Atoms of the Copper, would require Magnetic Fields approaching Infinity, so, the more Magnetic Field, the more the Conversion!
This stuff is handy to know, and to directly experiment on in this manner.
baerndorfer posted this 4 days ago
vidura did some interesting measurements
