POC input circuit
  • 240 Views
  • Last Post 12 March 2019
cd_sharp posted this 11 March 2019
Guys, I tried these configurations in order to produce the positive half of a sinewave trace:
For the first configuration I tried this resonant tank thanks to Vidura's advice:
I am able to produce a nearly sine wave with it, but it's not the desired positive half of a sinewave trace (sine wave half wave rectified). It's an entire sine wave.
Any idea how to obtain this?
Thanks!
Chris posted this 11 March 2019
Good work!
Adding a second Coil, like a Transformer, with a Diode on the secondary, will half wave rectify the AC Signal:
Hope this helps some!
cd_sharp posted this 12 March 2019
Hi, buddy,
yes, but this means there are 2 cores, the one above and another one for the POC setup?
Chris posted this 12 March 2019
It means if you want to use only a half wave, then you need to accommodate for this. Yes, if you want to use the Half Wave, then a second core is a good way to do it.
You could use a SCR Cap Inductor discharge, but this is more work again. Time t = R x C
Sorry, I may have confused you at some stage. Using a half wave, suggested here, is a good way to learn the timing. But we must think 1/4 Wave timing. Breaking the waves into Quarter Wave parts:
This is exactly a timing problem.
If I may suggest CD, keep the information, keep this all fresh in your mind, because it is important, but move on to the new thread: Important: Delayed Conduction in Bucking Coils
This thread incorporates all the last bit of information and goes a little deeper into the way this works. Giving you a better understanding of how the Waves interact together, using Delayed Conduction techniques, which are the same, but easier to work with. A much easier way to see how the timing works!
Timing is a critical aspect to these machines, we need to see the interactions between the Waves for their Value.
Hey, man
Thanks, but it's confusing. Do we need some time off on the input or it's not mandatory?
Yes, the input Frequency and Duty Cycle is important, no matter what method of timing is used. Remember how Graham Gunderson said:
and here I delay that, so its not a perfect sine wave, and there is a reason for that...
Well, he did not give an answer. But, I know the answer, and I will tell you for free!
Look at the Output Current. If Graham did not delay the sine wave, then the "Generation" of Electrical Energy would be cut short. The Output would be greatly reduced! The Output may not reach gains above unity.
So, the Delay, is effectively a method of changing the frequency and duty cycle of the machine. Allowing for a longer Off Time of the Input.
Exactly, it needs time to "breathe", as you said. I guess I have all the pieces to try to replicate the MIT and I don't think I need  expensive MOSFETs. It can all be done cheaply.
My Friend you're much further along than you might think!
I read the other forums from time to time, all I see is fighting and bickering! A select few are picking others to bits. Shooting others down, for having an opinion. Weather the opinion is deemed to be correct due to ones perspective is another debate.
They lack direction!
Like I have said, we are truly Light Years Ahead of the other Forums!
We have Direction! We have Momentum! We have Knowledge!
Look back and see where we were yesterday, and now again today! We are moving forward! We have the technology, the only thing we have to work on is how people understand or perceive it.
Its actually not that hard to make work, its hard to understand what needs to occur to make it work wink
Be proud, we are already a part of History, we have already changed the world! Only 5 years ago, I was battling with Trolls, trying to introduce this technology, today this technology is main stream and we have Eliminated Trolls!
solarlab posted this 12 March 2019
cd sharp - Check out "Little Fuse" (and others) SiC MOSFETS [Silicone Carbide - fast and robust]. A few dollars and they seem quite liberal with samples - pushing their tech; which is good all around...
https://info.littelfuse.com/silicon-carbide-mosfet-and-schottky-diodes
Chris - How correct you are (tell me about it undecided )
Have a good one fellows!
Please Support Us
All Visitors: since Nov 27 2018
Support Us (PayPal)
Support Us (Patreon)
