Partnered Magnetic Resonance - PMR above 1 performance certified
  • 829 Views
  • Last Post 15 September 2017
alohalaoha posted this 14 September 2017
Made in Russia. Date 17.06.2013.
Red - Coil L1. Green - Coil L2.
L1 : L2 =  Red /1 : 3/ Green.
Example L1 = 8 w. L2 = 24w - both coils same wire diameter.
Black - Balanced Output Coils - must have same inductance meassured at transformer core. In central transformer's limb must be NdFeB strong magnet with same width and lenght as central limb. height of magnet several mm.Look at aliexpress.com
Обозначение
T1 КТ819А or КТ805
C1 bipolar 0.1 uF
C2 elco 50uF/25V
R1 2.2 кОм
R2 62 Ом
Bat1 12V
Tr1- Ferrite transformer. Make it from two E ferrite cores.Magnetic permeability > 2000. Could be higher Miu. Central limb slot make carefully with fine grinding with respect to magnet dimensions. Good choice of ferrites at aliexpress.com
Wire 1.5mm diameter.
pcb
http://cxem.net/tesla/files/tesla36_pechatnaya-plata(1).lay
Source
http://cxem.net/tesla/tesla36.php
Chris posted this 14 September 2017
Hi Aloha - I am very pleased you bought this device up. This we have seen before, Wistiti and I looked at this some years back now. It is very close to my early experiment that led me to this technology:
It took me some time to properly understand what I had found. Some time to make the connection to other devices that use this same technology!
Zanzal posted this 15 September 2017
Nice work Aloha. You did a very good job describing all aspects of the device. It should be very easy to attempt replication.
