Opposing Currents, Opposing Magnetic Fields
  • 1.4K Views
  • Last Post 17 December 2017
Chris posted this 08 December 2017
I think we could all agree, The Mr Preva Experiment has taught us a lot!
I have shown, how Coils are wound, does make a massive difference:  Some Coils Buck and some Coils DONT
An article that is a critical part to the understanding of very important information about these devices and how Energy is "Generated" in a System! I also covered some of this 31 Jan 2015 in the following video:
The following video shows a little better how this can work:
Also more information about Opposing Magnetic Fields, I posted in the following Video: 15 May 2015
Turns, within reason, are important, The Impedance is only the DC Resistance of the Coil, and  XL = XC because we are in Magnetic Resonance, equal and opposite Magnetic Fields at the same time.
We know, from The Mr Preva Experiment and also from Floyd Sweet that Currents Opposing create a situation where More Current is Generated:
In other words, we see an Amplification of Current!
We also know this is true, a very simple experiment can confirm this in only a few minutes! There is hours of analysis afterwards however to properly understand.
We truly are:
Light Years Ahead of all other Forums!
Chris posted this 11 December 2017
For me, this all started one afternoon, I had a moment of realisation, out of this realisation, I built this, and some months later, 18 Jul 2011 I published:
I posted the description:
This is of great significance !!!!!
"On rare occasions, Sweet saw this effect, called self-oscillation, occur in electric transformers"
and
"Sweet was also a transformer designer and expert, and he remarked that he had also observed specialized self-oscillation in certain transformers. "
See: http://www.hyiq.org/Updates/Update?Na...
I show the importance of knowing and understanding the A Vector Potential and how simple it is to create a self assisted oscillation. This set of shorted Self Assisted Oscillating Coils. This can be improved hugely and is possible to be made to self run with this technology. Nikola Tesla, Floyd Sweet, Lester Hendershot, Edd Leedskalnin and Daniel McFarland Cook all knew about this technology. They all used it in various ways to improve their devices....
Studied it some more, and carefully observed effects, and documented:
Studding more:
Finding that Coils were showing effects at frequencies, that were a little abnormal:
All the time learning, studding those before me, What they had to say, being the Student in the School of life, I still am even today.
What I have learned is that the Magnetic Field, the Frequency of it, the Coils and the Size, Turns, the Interactions between these coils can "Generate" Excess Energy!
Also some other very cool affects can be seen, call it what you will:
I have my own ideas on how this happens, my ideas correlate to the works of: Ioannis Xydous and also along many other researchers about Mass Displacement.
Chris posted this 15 December 2017
I have posted the following image to my website and else where many times:
The Core, once Magnetised has a Magnetic Direction, Pole Polarity, and a Curl to the Magnetic A Vector Potential. Noting the Magnetic A Vector Potential is only present when there is a Change in the Magnetic Field, If the Magnetic Field is stationary, then the Magnetic A Vector Potential is not present, or not detectable.
Using the Right Hand Grip Rule, you can see there is common-sense, logic, to this diagram.
Another Diagram I have posted give a sense of how the Field around the Changing Core will be interpreted:
A living, breathing beast, Matter in motion, the very requirement for Inertial Displacement.
Chris posted this 17 December 2017
Electrical Energy
In my article Electrical Energy, I state: "Energy begets Energy". A very smart person stated:
Clemente Figuera
Another example:
Electricity is not made by the generator, it is merely pumped. From that standpoint, an electric generator might be referred to as an electric pump and the Moray radiant energy device as a high-speed electron oscillating device.
T. H. Moray - The Sea of Energy in which the Earth Floats.
If you study the Greats, before us, you will see that they all had a good grasp in Electrical Energy, and how Electrical Energy is "Generated", it is very evident! I have covered a small snippet in my Support Section
The Key is the Modulating, or Moving, Magnetic Field, in an asymmetrical geometry, where your Input is only a Magnetic Field Control of Frequency and Intensity, where none of your Input is directly coupled to your Output...
All your Output is a function off the Pumping of your System as already indicated.
An individual's brain is the absolute most powerful thing given, freewill, is the power to use it, determination, is the power to make progress.
