Let's Sparking ...
  • 1.2K Views
  • Last Post 19 February 2019
alohalaoha posted this 08 December 2018
Ok folks
Let's sparking...
But what ?
Let's sparking partnered coils
But what are in fact partnered coils ?
Transmission line, Short circuited transmission line, shortly SCTL.
Why ?
Because there are hidden under the 7 locks aboveunity current and voltage amplifications.
As in Russia said: "All new is long time forgotten old".
Same Anomaly Pulse exist when you used mosfet instead spark gap. This should work also with bipolar transistor, tyristor or igbt.
Next step is organising smart way power extraction, using λ/4 voltage amplification or λ/2 current amplification or both in the same time using additional pair of partnered coils, each with their own respective lenght.
Let's think about the most smartest way to take all Ether power for our needs.
Count-1
When the transmission line in shorted from the load end, it's known as short circuited transmission line.
Here is one SCTL.
At the short circuited end the current I is maximum and voltage V is minimum. At each λ/2 interval.
This behavior is repeated if we move away form the load end towards the source.
At λ/4 from from the shorted end the behavior of current and voltage is vice versa to previous case.
It means that at λ/4 from shorted end the voltage is maximum and the current is minimum.
This behavior is also repeated at each λ/2 interval from the same point or at the odd multiples of λ/4 on the transmission line.
As the current at the shorted end of the transmission line is maximum, therefore the impedance at this point will be minimum.
At λ/4 away from the shorted end the impedance will be maximum because at this point the current is minimum.
Count-2
The short circuited transmission line behaves as series resonant circuit at the short circuited end because the maximum flow of current take place at the short circuited end.
At λ/8 away from the shorted end, towards the source, the behavior at this point will be inductive.
This behavior will repeat at 5λ/8 from the short circuited end.
At λ/4 from the short circuited point of transmission line, the circuit will behave as parallel resonant circuit.
It is due to the reason that at point the current is maximum possible.
At 3λ/8 form the shorting end the behavior will be capacitve.
This behavior will repeat at 7λ/8 and so on.
The behavior of short circuited transmission line as a series resonant circuit or parallel resonant circuit or inductive or capacitive circuit will repeat it self in the same manner toward the source at each λ/2 intervals if the transmission line is long enough.
Count-3
These are main characteristics of short circuited transmission line.
Voltage standing wave ratio or VSWR of the short circuited transmission line is infinity.
Magnitude of voltage reflection coefficient is 1.
Phase angle of voltage reflection coeffinient is 180 degree out of phase.
First current maximum node is λ/2 away from the shorted end towards the source.
First voltage maximum node is at λ/4 away from the shorted end towards the source.
Current is minimum and voltage is maximum at λ/4 distance from the short circuited end.
Current is maximum and voltage is minimum at the short circuited end.
Count-4
Why this is needed ?
Because we need to find exact wire lenght of sort circuited transmission line including velocity factor of our impulse or we need exact wire lenght of partnered coils where the magic will start on.
It means if we want current amplification effect while sparking, we need to make partnered coils lenght exactly at λ/2 or even multiple of λ/2.
If we want voltage amplification effect while sparking, we need to make partnered coils lenght exactly at λ/4 or odd multiple of λ/4.
For maximum power extraction from partnered bifilar at his resonant point, load resistance MUST be the same as partnered bifilar impendance (wave resistance).
Anomaly Effect is a strictly wire lenght dependent so we must care attention for each mm lenght error.
The most precise way to measure wire lenght and characteristic bifilar impendance is using an oscillograph and TDR or Time Domain Reflecometry. Who has vector signal analyser can do it on most easiest way. Simply tune S21 parameter to active resistance value canceling imaginary part of S21 coefficient (tunning line lenght), so the coefficient remain matched with load only with real part.
Light Up the Mind Darkness !!!!
POWER TO THE PEOPLE !!!!
Best wishes
ALOHA
RUSSIA
Jagau posted this 08 December 2018
The best use I could make with a coaxial line is a pancake coil.
Easy to wind and we already know its characteristic impedance Z. Even better is a triaxial line.
P.S. I use the TDR only when I'm trying to match a line with different Zo.
Yes Jagau, you sure know, that Kapanadze used coaxial line in all his BTG generators. Once i think 2004 , he have been very upset, because he coudn't find proper coaxial for his 2004 FE generator.
We are know that he had short-circuited his coaxials. My estimation, about 90% probability is partnered coaxial configuration.
This partnered coaxial setup is very easy to check for all who has 1GHz wideband oscillographs like LeCroy or Tektroniks. Only need to fire some single pulses and analyse transients. I am sure he used here concept of short circuited transmission line, with one end short circuited (central point connection) and connected to the independent ground, while sparking other end.
I am interseting to know about electrostatic induction induced by partnered shorted coaxial line. This is because he used heavy coopper bar with several windings around inner coils, where he was connected HV spark gap. So question is why he has used static field ? What for ?
Best regards
Chris posted this 08 December 2018
Hey Aloha, Jagau,
Great Thread! I must admit, some of this stuff I am yet to learn. I know the basics. I do not yet know how to apply some of this stuff. Floyd Sweet observed Cycloids, its seen here:
It appears Google's censorship algorithm has been hard at work again.
What I do know, is the Kapanadze Grenade Coil is exactly the same as Partnered Output Coils. If you take Turn for Turn, lay the Turns side by side rather than on top of each other, then you have exactly the same thing:
We know about the required Magnetic Resonance, The MrPreva Experiment has shown us this, we have a quote from Ruslan:
The first rule: Wind the coil 40 meters. 2. Find out its resonant frequency (1/4 wave) Inductor 1/4 = 10 meters of the same wire (for example, 2.5mm) Connect the generator to a 10 meter coil, drive the rectangles at a frequency of 1 MHz and crawl higher until 40 meters do not appear sinusoid. The maximum amplitude. The generator is desirable to take a normal, laboratory! With output adjustment from 0 to 20 volts. We achieve maximum amplitude and move tenths of a kilohertz until it starts to dance. This is your wave resonance !!! We fix the frequency and voltage. It is for this all have to do the generators. Further ... Tesla we shake under this frequency that the effect has turned out. Then we do everything as I did or the Shark. In this case, everyone wants to repeat this device. Forward! We fix everything beautifully and stiffly, without forgetting that the resonance and effect can escape in the case of fastenings on the snot. We need to get the effect itself and work, and not a ready device. Once you begin to understand what to do next, you can already move. So .... Tesla, as we know, also wets the sinusoid. Suppose your frequency is 1.821MHz. The frequency, but alas. It is necessary to adjust Tesla on it. The shark used a critic between Tesla and the toroid (Antenna) over the inductor. This is just an accurate adjustment. It is needed before launching. Then the system holds and no matter what has slipped in not large limits. But! Again ... What where? On the Inductor we feed the signal of rectangles with a frequency of 1/50. Consider: 1820: 50 = 36.4 kHz pumping a rectangle through the junction (Pot) with 23-29 turns of wire 2.5 squares. I repeat, you need to make the voltage on this harmonic not 10-20 volts, but higher by an order of magnitude. Approximately up to 50-60 volts and get the same dancing effect at the output.
The Resonance required is also seen in other machines! Look at the tuning required here:
The short sharp pulse, the Harmonics associated with this pulse as Ruslan has pointed out allow for the excitation for the Required Magnetic Resonance.
In the "Effects" is where one will find the right conditions to bring about Magnetic Resonance. After all, Akula also used the fundamental concepts of the Kapanadze Grenade Coil.
One layer, then two layers, the ends connected with Diodes, closest to Ground, makes the Coil CW CCW with 1 : 2 Turns Offset.
  • alohalaoha
Jagau posted this 09 December 2018
Hi Aliha
indeed the cable in blue looks like rg59 it seems the same size.
Tell me what is the definition of BTG?
When he speaks assymetric linear inductance does he mean the physical length of the cable or assymetric in his inductance (I have my little idea on it)
  • alohalaoha
alohalaoha posted this 09 December 2018
Spectral response for single HV pulse is between 100KHz till couple of MHz.
Look at this Zeut machine diagram from his thread on OU. forum and tell me what do you think ?
We need to find exact point where we should with the help of HV impulse/s (unipolar or bipolar) from the Brovin's katcher or Tesla's transformer, make short circuited partnered bifilar coil. Or simple where is best spot on partnered coil to attract charges from the ground using high intensity E-field, and once captured charges (both signs) join them to take part in magnetic resonance of partnered coil. Thinik about boost of current or voltage if we inject huge ammount of charges in the partnered coil while they enter in zone of magnetic resonance. If we repeat whole process in precisely controlled timing, we can easy made infinite energy boost.
  • solarlab
A coil in a ferromagnetic core is linear as long as it does not reach either end of the B-H curve
It becomes non-linear beyond the hysterisis point caused by the ferromagnetic core. An air core is almost always linear.
It is asymmetrical with respect to another cable either by its physical length, or by its inductance.
  • alohalaoha
ps: Nano pulser transformer must work in saturation, so we need here as small as possible ferrite core with highest magnetic permeability and we must put him on radiator and cool him with air fan to avoid heating problems.
Reg.
  • solarlab
Hey aloha
you quote:
These are main characteristics of short circuited transmission line. Voltage standing wave ratio or VSWR of the short circuited transmission line is infinity. Magnitude of voltage reflection coefficient is 1.
We can not have infinity with the coefficient of 1 this is the minimum??
Chris posted this 09 December 2018
I agree with Aloha,
I must say, this is not new, Aloha has already pointed this out. See the following video for information on similar ideas, but used in a different way:
We have to remember, we have two Signals, if you want to call them that. We are literally, bringing about: "Balanced Conditions". This is shown in the Video above. Normally in a Transformer, this Balance would be from Input to Output. However, all our Input does is brings up the Voltage on the Coils. Current is produced by the Opposition of the Partnered Output Coils.
Aloha, Jagau asked, what's the definition of BTG, I would also like to know?
  • alohalaoha
Chris and Jagay , there is only one question ?
Does Electrostatic induction works with short-cirtuited partnered coils or not? If yes we have a KEY to infinite FREE ENERGY. !!
Remain one small stuff. Kind of Magnetic trap for the charges. And i have idea how to make it. One special coil arrangement, in fact infinite moebius coil loop using again partnered coils this time for power extraction.
Jagau i am slow at typing, so i will answer here on your question. I think he is talking about assymetric of his inductance due to special kind of winding.
ps: I think it should be worth that sombody test Zeut's last picture with the hot spot - place where the spark hit the coil, not on the ground conductor, because ground will take out all charges to the earth, but on the center side of partnered coils (or their main connection point). In that way we would have two closed paths - from right to left and vice versa. To say simplest we have splitting either the positive pulse or either the negative pulse, for the both half wave cycle of magnetic field of power transformer.
ps: BTG or Bez Toplivni Generator is Fuellees generator or FE generator.
Reg.
I just have remembered something i think it's very important. Maybe you could remember Ruslan's schematic from one of his vids with power extraction from his grenade coil where he had used high curent diode placed on one end of grenade coil with cathode to the groud-earth and anode to the granade coil. On this way, we was cutting negative half wave of current in his grenade. This is due to only one reason. He had used only positive unipolar HV pulse from his katcher.
Well i think Kapanadze had used both half waves not only one. I conclude this watching behaviour of his spark in his tiny spark gap.
I think power of his spark is very low, almost pure potential with very weak current ( no arc over the spark gap ), and the only reason why he had done this is for initialisation process of Electrosatic induction, triggered only by low power, high potential HV sparks.
Those who want to try this experiment must take in account to avoid generation of powerful electrostatic repuslion force if they attract from the ground charges with the same plarity (sign), with the currently presented charges into rotating magnetic field in the given moment of time. That case will be no good for the device. Everything will be burnt.
Whole trick is to attrack opposite polarity charges so currently presented charges in primary coil could attract opposite ones and join them into magnetic resonance process. All of this should be done 50 cycles in second, while HV spark generator and spark gap must cycling 100 times per second - 50 cycles for each half wave cycle of rotating magnetic field 50 Hz in the primary coil.
Maybe some of you have any different idea ? I am listenng.
Best regards
OK people.
Chris just gave me a right words for explanation whole process of Electrostatic Induction and Magnetic Trapping.
MULTIPLEXING !!
We do have two, forward and reverse currents. We need both because 2 processes take part in excesive energy generation:
1.- ElectroStatic
2.- ElectroMagnetic
Good luck to all
We must realise, Don Smiths Output Circuit holds some similarity's:
This basic Circuit design is not that uncommon:
Ref: Sine Wave from a Square Wave
  • alohalaoha
Thank you Chris
Yes very similar concept. I know Don Smith had knew about interaction between magnetic fields (stationary and dynamic) and stationary and dynamic charges.
If you charge two light bodies suspended on insulating silk threads, touching them with a glass rod rubbed against silk, then both bodies repel each other. The same is observed if both bodies are charged with the help of an ebonite stick, worn on fur.
But if you charge one of the bodies from a glass rod, and the other from ebony, then both bodies attract each other !!
This is a fact which anybody can check !!
This means that the charges of glass and charges of the ebonite differ in quality. Despite the abundance of various substances in nature, there exist are only two kinds of electric charges:
  1. charges similar to those that appear on glass, worn out on silk, and
  2. charges, similar to those that appear on ebonite, worn out on fur.
The first of them are (wrongly) called positive charges, and the second - (wrongly) called negative charges.
Consequently, like charges repel each other, while opposite charges attract each other. This phenomenon of electrostatic  repulsion had been used by Russian academicians M. V. Lomonosov and G. V. Richman for making their device - an electroscope.
So when you bring a charged body to an uncharged electroscope, you can see that the electroscope's leaflets are deflected even before the body touches the electroscope. This is a 1st fact
If the electroscope is precharged, then when the body of the same charged body is presented by it, the leaflets are deflected more strongly. This is a 2nd fact.
If the body has a charge of the opposite sign (wrong formulation), then the deviation of the leaflets decreases as the body approaches, and then, after passing through zero, it increases again. This is 3rd fact.
But how to explain this facts. There is no full or partial anihilation of charges, no sparks, no arcs or anything similar but in my oppinion only charge's balance instability. This bring me to concluion that there exist not two charges, but one substance - one charge in different saturation phases.
Deviation of charges means balance of fully saturated charges and unsatuarted chares. In some moment of time, in some special position where the both charges balance their quality, we have full charged electrostatic balance - full electrostatic quilibrium, but we have no charge anihilation. Further when we bring charges in the much closest proximity, leaflets are again deflected but this time more strongly. It means we have over saturated electroscope rod with same kind of charges.
This is a simple logical explanation i could contemplate.
All of these show us that charges appear on the conductor (an electroscope rod) already when a charged body is present nearby, under the influence of this body.
Therefore, the described phenomenon has received the name of electrification by means of influence or electrostatic induction, and the resulting charges are called induced. The phenomenon of electrostatic induction was studied in detail in the 18 century by Russian academician Epinus.
Stationary magnetic field (magnetic N-S dipole) from ordinary neodymium magnet has ability to ATTRACT charges of both electrostatic phases (satuarted and unsaturated) while we bring him in the close proximity eiher with N or either with his S pole. So there exist electrostatic force when you bring magnet near precharged bodies suspended on insulating therad.
If all of these facts worth for stationary charges and stationary mag.field (magnet), there is no reason why this shoud not work with dynamic charges (charges in motion) and dynamic magnetic field (magnet or solenoid in motion).
Now remain to use explanied concept in design of free energy generator.
Regads
As I have seen nobody isn't interested about presented concept except me, Chris, Jagau and Vidura.
Maybe there is no need to make a new posts except for thouse who steal our ideas ?
ps: Chris your video is old and excellent, but this concept spinning around electrostatic induction and dynamic magnetic trapping.
There is no dc current and transformer primary isnt short circuited.
Best Reg.
Lets go Aloha
We must not wait for the others to get involved but I invite them to share their ideas that's our strenght,
In this site nobody will laugh at you, all the ideas are important.
Continue aloha it's give me ideas for other experiences thank you
Show More Posts
Support Our Effort
Support Us (PayPal)
Support Us (Patreon)
