Impulse Pressure Wave
  • 1.3K Views
  • Last Post 24 January 2019
Chris posted this 05 August 2018
Some are progressing very nicely. Your progress is immensely exciting. Many readers, not many doers? Where are all the Doers?
These electrical irritations expanded out of the wire in all directions and filled the room in a mystifying manner. He had never before observed such an effect. He thought that the hot metal vapor might be acting as a "carrier"  for the electrical charges. This would explain the strong pressure wave accompanied by the sensation of electrical shock. He utilized longer wires. When the discharge wire was resistive enough, no explosion could occur.
Wire in place, the dynamo whirred at a slower speed. He threw the switch for a brief instant, and was again caught off guard by the stinging pressure wave! The effect persisted despite the absence of an explosive conductor. Here was a genuine mystery. Hot vapor was not available to "carry" high voltage charges throughout the room. No charge carriers could be cited in this instance to explain the stinging nature of the pressure wave. So what was happening here?
The pressure wave was sharp and strong, like a miniature thunderclap. It felt strangely "electrical" when the dynamo voltage was sufficiently high. In fact, it was uncomfortably penetrating when the dynamo voltage was raised beyond certain thresholds. It became clear that these pressure waves might be electrified. Electrified soundwaves. Such a phenomenon would not be unexpected when high voltages were used. Perhaps he was fortunate enough to observe the rare phenomenon for the first time.
Ref: Gerry Vassilatos Secrets of Cold War Technology: Project Haarp and Beyond
I want you to think in terms of a Spark Gap, an Electrical Impulse. E.M.P Weapons use a very high Voltage, stored in Capacitors. The Capacitors are discharged through a very low Resistance Shunt. Turning all the Stored Charge into a high pressure Wave of Energy.
Think, What happens when a Coil is exposed to a short sharp impulse?
Electrons are pushed into a higher Energy Level, they jump to a Higher Orbital level and more Electrons become available to become so called Free Electrons.
A short sharp impulse induces a much Higher Voltage on the Terminals. You need to increase your Output Voltage, start in small steps.
Related Threads:
  1. The Input Coil
  2. Nano Second Pulses
Vidura posted this 05 August 2018
Hello Team
A very important Topic indeed!
a couple of years ago i have found a note about some early experiments of tesla in Patrick Kellys book, and i was thinking about the relationship to the phenomena of acoustic shockwaves, produced by very strong explosions, they propagate at a much faster speed than the transversal soundwaves thru the air. Therefore i also beleave that certain effects in EM are only produced beyond certain energy levels.
here a quote of Teslas observations:
Tesla’s Experiments.
In 1889 Tesla began experimenting with capacitors charged to high voltages and discharged in very short time
intervals. These very short pulses produced very sharp shockwaves which he felt across the front of his whole
body. He was aware that closing a switch on a high-voltage dynamo often produced a stinging shock. This was
believed to be static electricity and it occurred only at switch-on and only for a few milliseconds. However, in
those few milliseconds, bluish needles of energy stand out from the electrical cables and they leak to ground,
often through the bodies of any people standing nearby, causing immediate death if the installation is large.
While the generators of that time were rated at some thousands of volts, these discharges were millions of volts in
intensity. The generator problem was eliminated by the used of highly insulated switches which were provided
with a very large ground connection.
Tesla was intrigued by this phenomenon which appeared to match the effect of his capacitor discharges. He
calculated that the voltages produced were hundreds of times greater than could be supplied by the capacitor or
generator. It was clear that the power supplied was being amplified or augmented in some way, but the question
was, from where was the extra energy coming?
Tesla continued to investigate through experiments, taking precautions against the high voltages being produced.
He was soon able to produce these shockwaves whenever he wanted to. The shockwaves produced a stinging
sensation no matter where he stood in his laboratory, and hands and face were particularly sensitive to the wave.
These waves radiated out and penetrated metal, glass and every other kind of material. This was clearly not an
electromagnetic wave, so he called the new wave ‘Radiant Electricity’.
Tesla searched the literature to find references to this radiant energy but he could not find much. In 1842, Dr.
Joseph Henry had observed that steel needles were magnetised by a Leyden Jar spark discharge located on a
different floor of the building. The magnetising wave had passed through brick walls, oak doors, heavy stone and
iron flooring and tin ceilings to reach the needles located in a vault in the cellar.
In 1872, Elihu Thomson took a large Ruhmkorrf Spark Coil, attached one pole of the coil to a cold-water pipe and
the other pole to a metal table top. This resulted in a series of massive sparks which electrified the metal door
knob of the room and produced the stinging shockwaves which Tesla was investigating. He found that any
insulated metal object anywhere in the building would produce long continuous white sparks discharging to
ground. This discovery was written up briefly in the Scientific American journal later that year.
Tesla concluded that all of the phenomena which he had observed, implied the presence of “a medium of
gaseous structure, that is, one consisting of independent carriers capable of free motion - besides the air, another
medium is present”. This invisible medium is capable of carrying waves of energy through all substances, which
suggests that, if physical, its basic structure is much smaller than the atoms which make up commonplace
materials, allowing the stream of matter to pass freely through all solids. It appears that all of space is filled with
this matter.
Awesome My Friends,
An impulse can be created many ways:
Look at the sharp impulse in there, 700 odd Volts. Lets look again:
How? Well listen carefully:
An Impulse  Wave can be created by allowing the Coils to snap together, switched, or by a Spark Gap, DC Capacitor Discharge into a very low impedance Coil  one example is Dally:
This Nanosecond Generator, very short Impulse, a Non Inductive Coil was used, Coaxial cable, ends tied to ensure the Coils Inductance would not slow the Impulse Wave.
Remember, these impulses make the Electrons Jump to a higher Orbital, they then can be freed, allowing them to become Free Electrons ready for movement as a Current.
Vidura posted this 06 August 2018
==He was aware that closing a switch on a high-voltage dynamo often produced a stinging shock.==
The quote, in Vidura's comment, is incorrect. Closing, turning on, a substation voltage, only produces a small spark, seen in the second half of this video. Opening the switch, turning the electricity off, produces a tremendous arc. This is thought to be caused by the "hammer" effect, the same as the bang heard when a water faucet is turned off quickly. The water, or flowing electricity, has momentum, in the whole pipe, which cannot be stopped suddenly.
?v=VrY_k_pdlCs
Idea1man, When I was thinking again about the swich open or closed question, I am in doubt that it is opening the swith that produces shockwaves, in terms of inductance and BEMF spikes you would be correct , they always occurs when opening the switch. But shockwaves are produced by disruptive discharge of capacitors into inductive elements(about the inductive element I am not sure, Leyden jar discharge dont have), it is not at all clear if the dynamo machine in question was dc, or had contained any capacitors(or the parasitic capacitance of windings and transmission lines) in this case the shockwaves could have occurred when closing the switch. Note that a spark gap do not produce large arcs, but a short disruptive discharge with a huge potential change x time.
Marathonman posted this 08 August 2018
Are you sure about that, Spark or quick discharge is Ether movement or Ether under pressure. one is the fact of Ether and the other is Ether movement. ?
Chris posted this 08 August 2018
Hey Bob, Marathonman, agreed!
I think this is a case of Chicken or the Egg, one and all is reliant on the Aether, the Quintessence, permeating all Space.
Vidura posted this 08 August 2018
Some food for thoughts: In order to get a better understanding of the impuls pressure waves we should try to look for available information, and ask what's the difference between a common EM waves and shockwaves. I agree with MM. that the ether is the medium of propagation(for both). In my opinion the difference is in the power density . Think about the analogy with acoustic shockwaves, how are they produced? In difference with common acoustic waves, which are produced by nearly every vibrating matter in a gaseous medium, the latter is caused by a very powerful explosion only(to my knowledge they need to have a equivalent energy of many tons of TNT, and can be nuclear or chemical as well).Also the effects on objects and the propagation velocities are distinct of sound waves. According to the available information about impulse pressure waves they are caused by a very powerful electric discharge of a capacitor, and there has to be a certain amount of energy released in a very short time.(if someone has different information about it please post). It seems to me as at a certain amount of energy the rules are changing, things behave different. Similar when at certain temperatures the state of matter change to another level, Ice becomes water and then steam...
What is the source of this info from tesla,what setup he used? i didn't know about. Regarding the radiation the ∝ and ß  radiations dont have much penetration to shieldings, for the first a cardboard is enough and the latter is shielded by a brickwall, anyway they could be involved in the nearfield effect and fisical perception.
I have been thinking about why a very sharp pulse when collapsing is so much higher in voltage than the original voltage.
when the instant a pulse is fired the Ether is expanded out in all directions at that instant, well it could be that  the Ether rushes in to fill the void caused by the pulse and when the pulse is collapsing it has twice  or more  Ether than from the beginning.
just something that was bouncing around in my head.
Hopeful1 posted this 09 August 2018
MM
This is what I have been led to believe through reading as much as I can find on this subject. When a large positive spike is put out, because nature abhors imbalance, she responds by sending a equalizing charge of negative polarity and this is what we harvest.Maybe I've been misled but it makes sense to me.
Tony
Marathonman posted this 09 August 2018
For every action there is a reaction so what ever amount is pushed out the same or more rushes in to take it's place as the pressure of the stream rushing in will not stop the moment it has filled the empty space. this will cause a higher pressure in that space until it can equalize.
Fluid Dynamics in action with a non compressible fluid. (Ether)
and yes you are correct as counter space is negative (Pressure) and will flow into space that is positive.(non Pressure) when two of the three dimensions of gravity are cancelled out from two dimensional magnetism leaving one dimensional current flow from counter space into space. all electrical systems are a pressure regulated systems of Ether flow but this might be beyond the scope of this thread so i will leave it at that.
Chris posted this 25 August 2018
Nature is truly awesome!
A shock-wave can produce tremendous power. We have been exposed to this power many times perhaps without knowing it!
A shock-wave can be seen emanating from this Volcano:
The force is felt only seconds later by the camera many miles away! Did you hear it?
Watch out for the shock, its coming...
The poor guy behind the camera man released enough energy to... well we should not go there...
 Another one:
The area around the Volcano is disrupted, shaken up, dust rises from this wave, for miles around! The shock-wave, the disruptive discharge breaks the Speed of Sound, a Sonic Boom...
Some data on Sonic Boom's:
The Point
Nikola Tesla did this with Coils and Disruptive Discharges into the Coils! Remember how I said, Coils and Current through these Coils need to be thought of as Electromagnetic Waves? We have many pages here on Electromagnetic Waves!
Nature has shown us something amazing, we know already that Electrons, the basis of, or building block of all matter, is susceptible to a Shock-Wave! They get stirred up, they get excited, then move into a higher Energy State!
Shock Drift Acceleration (SDA)
The Drift of Electron's accelerate if the have been shocked. This is SDA, or Shock Drift Acceleration. Also: NASA Finds Unusual Origins of High-Energy Electrons
“This is a puzzling case because we’re seeing energetic electrons where we don’t think they should be, and no model fits them,” said David Sibeck, co-author and THEMIS project scientist at NASA Goddard. “There is a gap in our knowledge, something basic is missing.”
Remember, the E.M.P:
The entire focus is to get the Electron's moving, to make as many Electrons move as possible! Free as many Electrons from the Binding Forces as possible! This is the Binding Force inside the Copper Wire, as this is where the Electrons are situated, no where else, the Electrons of the Copper Atom!
Marathonman posted this 04 September 2018
Tesla's secret to massive power at great distances.
Chris posted this 04 September 2018
MM nice find!
Similarly, a Chain Reaction can be created by an Impulse Pressure Wave:
Watching vary careful, a large spark, or lightning, causes this Chain Reaction:
This sharp Impulse Wave starts a cascading after effect, you could say SDA, Shock Drift Acceleration, almost entirely destroying the entire River Mouth!
An amazing display of Power!
Marathonman posted this 05 September 2018
Wow!, talk about oxygen and hydrogen separation to the max. i am surprised their wasn't a massive explosion but the lightning bolt was already gone when the separation occurred.
this is another example of man ignoring the awesome power of mother nature unlike Victor S.
and you wonder why the powers that control everything were so scared of Nicola Tesla. we only use 10% of the wave right now but Tesla was getting 90 Plus %.
mind boggling to say the least.
regards,
Chris posted this 22 January 2019
As already pointed out above, a Spark Gap can also be the catalyst for an Impulse Pressure Wave:
Also pointed out above, Dally's Generator of Nano Second Impulse ( GNSI ). Switching with a Transistor / Mosfet with some small off set can sometimes be enough also. There is an Electric Field that is setup that can be very strong in these sharp fields!
I don't know why, but its a requirement in Energy Machines, its like it charges the surrounding space around the Coils. Thing is, you need a little Shock Wave, or Impulse Pleasure Wave to get the Electrons in the Coils up into a higher state. It sort of dazes then I guess.
Ruslan and Akula used Brovin Kacher Circuit to do the same thing:
You can see the Wave, Pulses at Sine Peak:
Sometimes even using Diodes with different turn on times may even be enough.
So, I urge you all, count the number of machines that have shown these characteristics, this is a requirement, and one needs to figure the best way to do it. Like I pointed out in my thread: How to build your own Above Unity Machine
Circuitry can also be employed to delay Conduction on the second Partnered Output Coil.
This is a method of doing the same thing, some turns are exposed to a Higher Voltage than others, this creates a slight delay of sorts. Many ways exist to achieve this goal.
  • Atti
This is really important, please take special note!
I would like to point out, here, we have covered this else where, but this thread needs some insight on this topic!
Ferroresonance in electricity networks
Ferroresonance or nonlinear resonance is a type of resonance in electric circuits which occurs when a circuit containing a nonlinear inductance is fed from a source that has series capacitance, and the circuit is subjected to a disturbance such as opening of a switch. It can cause overvoltages and overcurrents in an electrical power system and can pose a risk to transmission and distribution equipment and to operational personnel.
Ferroresonance should not be confused with linear resonance that occurs when inductive and capacitive reactances of a circuit are equal. In linear resonance the current and voltage are linearly related in a manner which is frequency dependent. In the case of ferroresonance it is characterised by a sudden jump of voltage or current from one stable operating state to another one. The relationship between voltage and current is dependent not only on frequency but also on a number of other factors such as the system voltage magnitude, initial magnetic flux condition of transformer iron core, the total loss in the ferroresonant circuit and the point on wave of initial switching.
Ferroresonant effects were first described in a 1907 paper by Joseph Bethenod. The term "ferroresonance" was apparently coined by French engineer Paul Boucherot in a paper from 1920, where he analysed the phenomenon of two stable fundamental frequency operating points coexisting in a series circuit containing a resistor, nonlinear inductor and a capacitor.
Conditions
Ferroresonance can occur when an unloaded 3-phase system consisting mainly of inductive and capacitive components is interrupted by single phase means. In the electrical distribution field this typically occurs on a medium voltage electrical distribution network of transformers (inductive component) and power cables (capacitive component). If such a network has little or no resistive load connected and one phase of the applied voltage is then interrupted, ferroresonance can occur. If the remaining phases are not quickly interrupted and the phenomenon continues, overvoltage can lead to the breakdown of insulation in the connected components resulting in their failure.
The phenomenon can be avoided by connecting a minimal resistive load on the transformer secondaries or by interrupting the applied voltage by a 3-phase interrupting device such as a ganged (3 pole) circuit breaker.
Ref: Wikipedia Ferroresonance
I am guilty, I dismiss inferred Magic and the term ferro-resonance does not sit right with me. However, its true, we do need an Interruption, a delay in the Conduction, this has desired effects - One can equate this to two waves slapping together fast, creating an increase of Voltage on one branch.
Jagau posted this 23 January 2019
HI Chris
Last year I realized this experiment in Fig: 2 of the pdf file attached.
This has yielded impressive results as described
but I do not advice it to those who are less help with the very high power systems
Ferroresonance is a strongly nonlinear phenomenon whose origin lies in the saturation of an iron core coil in association with a capacitor. The manifestation of the phenomenon leads to abrupt, and very important, evolutions of the voltages and currents of the circuit, and proves particularly formidable when powering industrial transformers under high voltage.
This pdf explain for mono and 3 phases systems
Chris posted this 23 January 2019
Thanks for sharing! Yes, we have covered some of this before, but it is important and a requirement.
I stumbled across this in one of my H-Bridges I build. I did not have it switching properly and it had spikes in the switching. You can see this here:
Posted more than 4 years ago, at the time the video was already old. To get the effects was easy, but when I changed the H-Bridge, did you think I could figure out what I was doing wrong? Took some time.
There is a region where High Tension build up, High Voltage, its a result of Magnetic Fields Slapping together hard. Faradays Law of Electromagnetic Induction. The difference of Voltage requires a Balance.
I want to point out again, if one looks, its in all genuine above unity machines! Somewhere. Without it, these machines don't work.
One must create a delay in Conduction, between the two Partnered Output Coils, this must be at or close to the Peak Wave or Peak Magnetic Field.
Above I have outlined some ways to make this work.
P.S: By releasing a little bit at a time we can make sure thieves do not come, take the time to learn and patent something that is not theirs to patent. Its Public Domain, thus Prior Art, and unpatentable!
P.P.S: Gee whiz the Term Ferroresonance is horrible as a term, still I need to stick to convention.
Aetherholic posted this 23 January 2019
The waveforms in figure 2 in the pdf can be found in the figuerra device under certain conditions, thats why I was blowing up 100A diode bridges before I figured out what was going on.
Hi aetherholic
Having used to work on power systems when I realize this experience I was very very surprised by the resulting
I did not expect in time I almost broke my scope and I still remember the sound that the transformer did (my wife came to see what was happening)
I got kilovolts on high voltage mulmiter.
As I said, be very careful with this experiment.
alohalaoha posted this 24 January 2019
MM nice find!
Thanks Chris
Excellent post. This video event is excellent example of famous Yutkin's electrohydraulic effect or hydro shock. Water preassure is well above 100 000 atmosphere and depend mainly from nanoimpulse peak power. As you can see this is longitudinal reaction - thrue hydro shock wave.
Similar Yutkin's effect with bowl of water.
Reg.
Another Maestro of hydro shock waves - a pistol shrimp.
Same unipolar pulse - but this time his mechanical variant
Nice little animal !
Recomended Protocol:
