how long till this guy disappears?
  • 957 Views
  • Last Post 05 January 2019
AHargis75 posted this 15 July 2018
translation?
Vince posted this 17 July 2018
I could only understand what he was saying near the end.  He was using sign language.  "The disk is not the same as these little white flowers stuck here on the ground".  I could not disagree with that.
On a more serious note.  Ouch......
  • Ziggy
This second video is a good find Bob.  Seems the other guy had a lot a extraneous stuff, such as the Tesla coil etc etc to obfuscate the simplicity of this.  That might not be entirely true, however the video you have linked to indicates that it may be.  He doesn't show the magnets in the first one either.  Then again who knows what he is actually saying?  Seeing the magnets rotating is one thing, but why it is levitating is a mystery to me.  I wont to know!  And why are all the clever people Russian?
Something I find curious.  The material of the top rotating disk has a pattern stamped into it that appears to be exactly the same as the one in the previous video.  In fact even the wobble, and the fact that it is somewhat out of round in the same way as the other suggest this is the same guy to me.  Or a very close associate.
  • Ziggy
Vince posted this 19 July 2018
You amaze me at your ability to dig up interesting and relevant information Bob.  So, what is going on in this device?
  • Ziggy
Prometheus posted this 16 September 2018
You can enable Closed Captioning, then go into the settings and set it to auto-translate from Russian to English. It's not an exact translation, but it'll at least give you an idea what he's talking about.
  • Ziggy
romanta posted this 03 January 2019
Unfortunately, this guy in the video shows a fake, he uses fishing wire to hang this device in the air.
Atti posted this 03 January 2019
That is why you should not necessarily believe everything. All information is worth as much as it can be. In other cases. Think, reproduce, weigh. If not reproducible, the whole is false. It applies to everything.
  • Ziggy
alohalaoha posted this 03 January 2019
Hm. Again wrong conclusion Atti !
What about Reproduction Ability - Skill of an replicator. Not account for your mind apparatus !
How many people could reproduce samsung s10 mobile phone at first attepmt ?
I know for myself I can not !
So does samsung s10 mobile is a false suff ?
Think about - and don't project your personal outlook to other people mind process !
Aloha !
Btw in 70th years of last century in USSR has been discovered ultra-sound-magnito-electro-static effect of levitation !
So you need ultra sound source, magnetic fields, and electrostatic fields to successfully replicate Aleksey's levitation effect !
  • Ziggy
Zanzal posted this 03 January 2019
Aloha, Atti, Romanta, I agree with some points, but not wholeheartedly. I see two possibilities 1 it is real, 2 it is fake. I saw no evidence of trickery. Just because the claim is outrageous doesn't make it false. It also doesn't make it true. So unless you have evidence of trickery its just an opinion that it is fake or an opinion that it is real. Why not imagine both possibilities? Why does everything have to have certainty?
One thing is for certain though, for it to be real there needs to be an underlying principle that the device exploits. We have no Unified Field Theory so there is no way to know if an electric device can manipulate gravity. But some things point us in that direction. For example, Lee Hively's patent references Eugene Podkletnov's work implying that scalar potentials may be involved. Two magnets with opposing poles facing each other fall slower than two magnets that are not forced to oppose. Chris' video where his transformer slides around simply by arranging the coils in a certain way. Rumors of government programs to develop anti-gravity technology, etc. EM Drives and more. All these things point to the possibility that electricity and gravity are related.
While that certainly doesn't make the video real, it does give us reason to take it seriously.
Vidura posted this 03 January 2019
Basically I agree with Zanzal, there are two possibilities. Unfortunately the internet is plagued by fake videos, but we have to be aware that many of them are posted with support of the corporations to discredit and ridiculing technology which would be against there interest. We certainly don't know in which category this video is, but unless having a proof that it is fake, we should keep our minds open to the possibility that it could actually work. Better than stating one or the other opinion would be to investigate and do research of precedents. Regards Vidura.
Prometheus posted this 03 January 2019
I saw one of his videos where he takes a long tree branch and waves it over the device as it hovers, then walks around the perimeter of the device with the tree branch held vertically.
So I'm not sure this is the explanation.
At time 23:00, he passes a hoop over the entirety of the hovering device, showing no lines or wires can be holding it up.
Here's a potential explanation:
On The Classical Coupling Between Gravity and Electromagnetism
http://www.mdpi.com/2218-2004/3/3/320/pdf
It will be shown that there is an upward force on an electron positioned at the center of a positively-charged shell in the presence of a uniform gravitational field. This electric force can be made equal in magnitude to the gravitational force on the electron at a shell voltage of approximately 1 MV. Moreover, the electric force is gravitationally induced, and the balance is unaffected by the magnitude of the gravitational force.
In the absence of gravity, the electric field of a point charge is simply a Coulomb field. However, in the presence of a gravitational field, the Coulomb field becomes distorted.
Gravity is an effect of the non-zero expectation value of the Quantum Vacuum. It is, in effect, the Casimir Effect,writ large.
http://article.sciencepublishinggroup.com/pdf/10.11648.j.ijass.s.2014020601.11.pdf
Quantum vacuum energy, gravity manipulation and the force generated by the interaction between high-potential electric fields and zero-point-field
In modern physics the “vacuum” cannot be considered, due to Heisenberg uncertainty principle, as a void but as physical entity manifesting a complex and fundamental background activity in which, even in absence of matter, processes like virtual particle pair creation – annihilation and electromagnetic fields fluctuations, known as zero point fluctuations (ZPF) continuously occur (see Fig.1). The physical reality of ZPF, also known as Quantum Vacuum (QV), has been proved to give measurable effects for the first time by Casimir’s experiment in 1948 [1] and next confirmed by Lamoreux [2], Milonni et al. [3]. From a more theoretical point of view, Russian physicist Andrei Sakharov, in searching for deriving Einstein’s phenomenological equations for general relativity from more fundamental set of assumptions, came to the conclusion that general relativistic phenomena could be seen as induced effects brought about by changes in the quantum-fluctuation energy of the vacuum due to the presence of matter [4].
Based on the Sakharov’s hypothesis, Puthoff [5] explored a conceptually simple, classical model according to which gravitation could be not a fundamental interaction at all, but rather an induced effect due to changes in the quantum-fluctuation energy of the vacuum when matter is present.
So if this device works as he claims, he's apparently generated a large electrostatic field of one polarity which is "bowed" by gravity, and in the center of that electrostatic field he's generated another electrostatic field of opposite polarity, imparting a repulsion to the device. The spin is for gyroscopic stability, although the angular momentum of the electrons on the spinning charged plates may contribute somewhat to the interaction with the gravitational field.
Apparently a single electron's size is so small that it requires 1MV to counteract gravity upon that electron, but the increase in surface area of his device acts to increase lifting surface area.
There is such a thing as gravitoelectromagnetic coupling, but it's been measured to be extremely weak with all experimental setups thus far. Perhaps it's just weak, perhaps the setups weren't optimized... time will tell. It is known that a large inertial change (or a change of reference frame) of a charged particle raises the coupling coefficient, as I explicated in my triboelectric charge-separation motor thread (which didn't seem to survive the transition to the new server).
Here's an explanation of the triboelectric charge-separation motor idea, all that survived the move to the new web server:
Another applicaton is my triboelectric charge-separation motor idea, operating upon the same principle as the Searl device (but much simplified and more direct). It steals bound electron orbital momentum and uses it in attempting to conserve the angular momentum of the permanent magnetic field and the frame-dependent magnetic field, resulting in a unidirectional rotation. The bound electrons regain their usual orbital momentum by absorbing energy from the quantum vacuum. This device should also exhibit gravitoelectromagnetic coupling via a large electron accelerational change... gravitoelectromagnetic coupling is miniscule at low electron velocity, but a large rate of change of electron velocity implies a larger coupling coefficient. My triboelectric charge-separation motor idea utilizes such a large rate of change of electron velocity via a geometrical transform. This change of reference frame makes the electron transition from stationary (in the rotor's frame) / rotating (in the lab frame) to rotating in the opposite direction (in the rotor's frame) / stationary (in the lab frame). Gravity is a uniform acceleration, and it does distort a Coulomb field. Thus the inverse (an electron's acceleration distorting the gravitational field) should also take place.
The above discussion shows that gravity could be considered as a function of QV energy density since both G and gravitational mass can be expressed as QV functions. This means that, from a theoretical point of view, gravity manipulation is possible, provided that we are able to modify the local value of ρQV , for example by altering ZPE.
This is exactly how magnetic attraction and repulsion works. See my thread here.
What does all this mean? Well, eventually we'll learn how to manipulate not only gravity, but inertia. Think of the ramifications of that... Tron bike, anyone?
As with any technology, this has benefits and potential misuses. Imagine negating the inertia of, say, a concrete bunker's wall, thereby allowing a projectile to more easily deeply penetrate.
Chris posted this 04 January 2019
From my findings, if we follow the technology I am sharing, it will also lead to the very same Antigravity Propulsion Systems!
Fake or not, there is little significance to a technology that is enclosed in secrecy. No matter what the technology is capable of! Its insignificant if we are not able to grasp it. It then falls into the realm of Magic.
I would ask all on this forum, if you would focus on what's on our plate, then the future will be so much closer.
Atti posted this 04 January 2019
Aloha !
You are absolutely right, right for you.
  • Ziggy
Zanzal posted this 05 January 2019
A clue from the book Ether-Technology by Rho Sigma:
Aetherholic posted this 05 January 2019
This effect was known in the late 1800's I believe. More mass, more effect. Long heavy multi-plate barium titanate capacitor. The effect occurs with almost zero inertia. Increased effect with asymmetric plates, large positive plate, small negative plate.
