Researching info at Russian
https://drive.google.com/file/d/0B-MmD2EU7WEbOXgxMWZWQ2FSaUk/view?usp=sharing
Cutted at half soft-iron core in form of toroidal cylinder. Boyh parts joined together with very strong force made by very high current impulse via axial thick copper wire connected to both poles of automobile accumulator for a moment. An strong current impulse was introduced. As result Vector magnetic filed H = rot A, was created, joined both halfs of cores and trapped insinde cylindrical toroidal core. So system is H-field free but another Scalar part of magnetic filed was introduced Hs= - div A in whole toroidal axial direction. At one side of toroidal core Scalar field has plus sign and other minus sign. So total field was composed of those two. Main difference is in interaction at free charges and also non electrical masses. in one case we have acceleration of charges in other deceleration. it means in one case we have current rise while in other current decay. Problem is to find correct geometry ot exclude one of signs according to our needs.
LONG EXPLANATION HERE - FOR THOSE WHO NEED IT.
Potential is the cornerstone of any force field. Potential exist only in two types – scalar and vectorial. Spatial derivative of potential form a field vector. At the same time non vectorial force fields does not exist. Force fields exist at only two types – solenoidal ( Q) and potential (P).
Solenoidal is that field at which the divergence (div Q =0 ), and potential at what the rotor (rot P = 0). There are no other possible options as vectorial derivatives are only two.
Respectively, stationary force field from potentials φ and A form only two spatial derivative grad φ and rot A. At the same time in a stationary case of divA=0. In a nonstationary case fact of existence of the second spatial derivative of vectorial potential div A ≠ 0, does not changes nothing.
Value of div A is a scalar and to form vectorial value with dimensionality of force in relation to a moving particle may only by means of e·(v/c)· div A. But here the the most important fact is that such combination is extremely important because changes energy of a particle regardless of the direction of its movement. While vector fields – as the method of the description of interaction of particles – change energy of interacting particles only in case of central interactions.
Here, unfortunately, the deviation from an essence of the classical field theory also begins. The classical field theory considers physical fields as perturbations of a certain environment with the given physical properties, distributed as appropriate in the free space.
The speech in it goes about own physical properties of physical fields as independent physical entity. The main objective of the classical field theory is determination of distribution of physical fields in space on the given distribution of sources (exciters) fields in this space.
As you can see here interaction of a field with charges and currents does not figure anywhere. For example expression -q · ∂A / ∂t is not an independent physical field, but it is expression of force of interaction of a dynamic vectorial potential A field with the based electrical charge, which in set with Lorentz force condition for moving electrical charge in a static magnetic field -q · (rot A x v ) form one uniform general expression of forces of interaction of arbitrary magnetic field with arbitrary electrical charges of Fm.
I.e. Fm = - q · (rot A x v) -q · ∂A / ∂t ≡ -q · dA / dt.
The magnetic field is unambiguity characterized by the vectorial potential of a magnetic field A and rot A = B. Also div A ≡ div B ≡ 0.
The dynamic magnetic field also is strictly vortex since calculates from the equation on partial derivatives.
rot rot A - 1 / c² · ∂ ² A / ∂ t ² = 0 integration on closed loops.
So people, all talks about so-called «Lorentz invariance and four vector spaces» are farfetched illiterate rubbish nonsenses pursuing two aims of Main stream official Jewish Cabbal «science».
1st is to fill up very big "empty jewish holes" in an official main stream electromagnetism hypothesis.
2nd is to hide the electrical longitudinal dielectric fields predicted by Helmholtz and experimentally proved with a success of Nikolai Tesla, by allegedly «jewish Einstain Morgan Cabal creation» of the uniform theory of electromagnetism.
