Earthing your device.Considerations.
Use indepenedent earth ground rod/s, not electrical grid ground.
Empirical data:
Empirical data:
Hi en joykin
I use always 2 different earth 10 feet ground rod by
the drawing you use 3 ??
Jack
Hi ,
when i worked on a teslacoil with a 35khz neondriver i could double the output voltage by using the earth gain potencial point, about the other points i dont have any conclusions.
Hi en joykin
Jack
Hey Jack
No. only one at once. There are 3 points with very different behaviour after connecting Earth ground.
You have right Jack, independent earth ground rods are the best possible way for earthing experiments.
Enjoykin
Enjoykin, earthing must be one of the biggest "hidden" techniques. Do you have any explanation of the earthing types in your diagram?
Hi Idea1man
Yes. you are correct. There are for sure some hidden secrtes how it in fact work. We don't know nothing about the influence of Hartmann's energetic grids and.also Curry grids.
Earthing is standard type, two heavy copper rods at 90 degrees, in the ground. Long and thick welding line as massive ground conductor. For Hv flyback earthing is best at the upper end of HV flyback transformer at anode of HV diode. Also interesting is earthing one plate of HV capacitor. In my oppinion on that way we transform non-polar symmetric capacitor to asymmetric one.
Enjoykin
