alohalaoha
posted this
13 November 2018
Knowing the secret about the two sorts of Etheric charges and their respective movement, we could easy make correct transformer and correct coil. Direction of Etheric charges at any particular potential in transformer or coil depend of winding way.
Winding a coil against clock hours will create Etheric charges flow (or current rush) from + to - terminal. While clockwise winding will drive current from - to + terminal.
It means that in 1st case transformer, coil or switching element will be cold while setup normal working temperature while in the second case, there will be overheating and thermal breakdown.
So powering and switching coil or transformer is strictly winding way dependent , especially when we start working with very low impendance power sources, high currents and high voltages.
