Charge Separation
  • 2.6K Views
  • Last Post 27 September 2023
Chris posted this 06 January 2018
Charge is separated, Positive to one terminal and Negative to the other terminal, or some may say Negative to one Terminal and none to the other. This, nitty gritty is a topic for another day...
The answer lays in the Capacitor, does each plate hold a Charge, and is it equal and opposite?
Any and all processes that separate Charge, function as a "Generator", or I personally prefer, as T. H. Moray termed, this process is a Pump...
Battery's Separate Charge via Chemical imbalance, of course they need to be charged to store charge!
Capacitors also the same...
Solar Cell's the same, Photoelectric Charge Separation...
Electro-Static Charge Separation, an example, again, that all should be familiar with:
An Antenna also works on the Separation of Charge, one end must be Positive, while the other is either neutral or Negative, depending on the wavelength used:
Either 1/4 wavelength:
or 1/2 wavelength:
Alianse77's example, Electricity from ionisation, is yet another excellent example, showing the importance of Charge Separation!
Thanks for sharing!
Chris posted this 07 January 2018
A moving Magnetic Field in the Proximity to a Conductor Separates Charge: Flux Cutting: E.M.F = Bvl
And also: Flux Linking: E.M.F = -NdPhi/dt
We know from The Mr Preva Experiment and Floyd Sweet, and also Clemente Figuera, that Current, the very flow of Charges can be increased, or amplified:
Floyd "Sparky" Sweet
The voltage from the total current of the current dynamos is the sum of partial induced currents born in each one of the turns of the induced. Therefore it matters little to these induced currents if they were obtained by the turning of the induced, or by the variation of the magnetic flux that runs through them; but in the first case, a greater source of mechanical work than obtained electricity is required, and in the second case, the force necessary to achieve the variation of flux is so insignificant that it can be derived without any inconvenience, from the one supplied by the machine.
Clemente Figuera
Steven Mark, listen carefully:
Ruslan Kulabuhov, read the translation:
The very Copper Wire you wind on your Core is the source of Electrical Energy you look for, its static, we must "Pump" the Charges as T. H. Moray said.
Its all in the design and function of your System, I pointed out a long time ago 4+ years ago, the system you need to aim for works almost exactly the same as the Hydraulic Ram Pump:
A self running machine, that works on the Inverse Square Law principles. As shown in The Mr Preva experiment, Current is a function of the Opposing Magnetic Fields, and Voltage is Turns and the rate of Change of the Magnetic Fields.
The Secret is truly revealed:
I may tell a small storey of how I found this soon...
Chris posted this 08 January 2018
So you know, my friends, in the years I have been trying to get this out to people, I have dealt with a lot, a LOT of stupid!
A portion of people researching, or that say they are researching this field, including some of the smartest people out there, have absolutely ZERO knowledge on what we have already covered: How to "Generate" Electrical Energy
A good portion do not even know what Electrical Energy is! EE's of 30+ years, they know how to measure it, they know about Positive and Negative, but have ZERO Idea on how the Positive's and Negative's are produced!
Zero Idea on most all of what we have covered for many years now!
I meet lots of nice people, some not so nice, but must say, in particular, a lot of the YouTube Comments I get are borderline senseless and should be able to be answered by someone that is actively researching this field.
I do try to have patience, and I do realise we are all at different stages of learning.
So, for these reasons, I ask, please understand why I repeat myself a lot. Please understand, other than the names I have mentioned, none have given you Bucking Coils, or Partnered Output Coils! None have taken the time to lay a massive trail, all over the internet on the How's and Why's!
Experiments I have posted to various places over the years, that were not understood then, are now being understood by You, that have done your homework and learnt the importance of Opposing Fields!
I have done the best I can to try to keep all stages of learning satisfied, to present Solid, Hard Data with References, and I also still encourage all to Cross Reference all my References also! Don't take my word on what I say, check for yourself!
It is true, we are Light Years ahead of all other forums!
Chris posted this 09 January 2018
A long time ago, in a galaxy far far away...
Ok, not so far away actually back here on Earth, at my home, I do the Vacuuming around the house. A long time ago I went to press the on button on my Vacuum Cleaner and just tapped it with my foot, fast and not with a solid push, and my Vacuum cleaner popped, a hydraulicing and a arching noise and no more Vacuuming on this particular day...
As a kid I always took everything apart, never got anything cool or expensive for Xmas or birthday because I "destroyed" everything, always interested to see how things worked, so true to nature I explored this popped vacuum cleaner...
I took the Vacuum Cleaner apart. In the housing I found a wire had completely disintegrated, about a centimetre and a half, completely gone, nowhere to be found. It was right on the terminal, off one of the Stator Coils.
I very much wish I have documented this, took pictures and so on, but alas I did not.
Many I have told do not believe me about this.
Anyway, sure enough the Current to achieve such a thing must have been huge, more than the 10 amp fuse could bare to handle, but no fuse popped, in-fact a closer look at the power board showed no sign of anything strange going on. This issue was completely isolated to the Vacuum Cleaner as far as I could see.
That feeling inside, when you see something and seem to have an immediate understanding, I got that, mentally seeing a large Magnetic Field Build, and because I did not switch on properly, a huge collapse, and the Could just happened to be in a configuration that shorted the huge collapse back on itself.
Thus, a huge "Generation" of Electrical Energy...
Many years later, I learned that an Antenna can sometimes see a similar thing under certain circumstances. Very high Currents can occur and then at a particular point, there is a Burn Out...
Over the years learning more and more, connecting the dots, I made progress and understood more.
I hope this gives some insight as it did for me!
Chris posted this 21 February 2019
For Vidura, a Bump.
On charge separation
Vidura posted this 21 February 2019
I was not aware that there was already a thread about charge separation, If you would like to move My last post feel free to do it! Regards Vidura.
Its ok, you carry on my friend.
Vidura posted this 22 February 2019
 Hello Team,
for simplicity i move the posts to this thread:
In this thread I will post some information and experiments performed by Sergei Deyna with his permission.
The topic is related to other threads which are actually developed here on the forum. And hopefully will make our understanding of this phenomena more complete.
the attached doc. is online translated , if somone russian speeking would like to correct , the link for the original is availiable on YT below the video.
her the next video and attached doc below:
"Electrostatic" charge separation
in this experiment Sergei can prove the separation of positive and negative charges by electrostatic influence:
find attached the translated doc.
The electrostatic experiment shows very clearly that the source of charge separation is not affected, not loaded by extract the current from the capacitance or by separating the charges. Also it is not likely that there is a counterforce like the Lenz Effekt in magnetic systems. So there might be a huge potential for AU.The experiment make it easier to imagine how charge separation can be achieved by electrostatic influence, the capacitance could be a coil or capcoil as well, and the source a resonant TC ( katcher, or slayer exiter), at Megacycles frequencys. Although not anymore "electrostatic" in that case.
Vidura posted this 24 February 2019
Here something to consider when we want to achieve charge separation without inductive coupling. you can easyly find out by experiment that it will not be possible to induce voltage- current in a non inductive coil or transformer by the conventional inductive coupling. So what we need to separate the charges in such a coil? As Sergey Deyna pointed out I his experiment a very sharp
magnetic puls is needed like this:
the upper trace shows the magnetic pulse(current)
Sergey also stated that the steeper the edge of the signal the stronger the effect. I can confirm from my own experiments that the noninductive coils and Markov's transformer can only be exited by very short and sharp pulses.
alohalaoha posted this 24 February 2019
High power nanosec generator for charge pulsing.
Kelech posted this 03 March 2020
Homopolar generator also is based on charge separation by static magnetic field. This separation of charge can lead to super efficient or zero drag generator if the Lorenz force felt by flowing electron can cancelled or balanced.
Chris posted this 03 March 2020
Hi Kelech,
I have asked you nicely to post your material in your own thread. You have posted in everyone else's and some of what your'e posting is Off Topic - Something we do not allow on this forum!
Please post your Homopolar material to your own thread and do not post to others thread that is not about the homopolar Generator.
Best wishes
Chris posted this 28 December 2021
Recently, someone I thought was a Friend, and I, had a falling out. This Friend was a Personal Friend and not a part of the Forum! The pressures of life and living, I guess just got too much? Some very serious Threats were made toward me. Later, they were retracted.
I try to forgive and forget, its not always an easy thing to do!
I believe the world is going Crazy! You can see it everywhere now! On the Other Forums, they have totally lost the plot! Not a single iota of Direction at all! Lost in the Winds of Bull Sh*t!
A Majority of people are looking for Direction, they have entirely lost hope in their Elected Leaders and the self proclaimed, NON-Elected Leaders!
My Friends, some Advice, if I may:
Look within! Be your Own Leader and let no one ever lead you!
What should be SIMPLE, is turned into Total Non-Sense by those trying to Spread Disinformation:
Why cant an "Electrical Generator" be Above Unity? Because it is Symmetrical, Force for Force is Equal and Opposite, and when you add Losses, then Unity can never be reached!
But, this is only part of the Truth!
Those that Actively Lie to You, trying to keep the Truth from you, do not tell you about Asymmetry and how Electrodynamics is: ENTIRELY MISSING Asymmetry and because of this SIMPLE FACT, you can "Generate" Electricity with a much greater Gain than the Electricity that you need to Input! Aboveunity is not only possible, it is Extremely Easy and Extremely Cheap!
Voltage is "Generated", this means Charge is Separated, Positive to one Terminal and Negative to the other Terminal, thus the Difference in Charge Potential between the two Terminals!
The basic processes are the same for all machines:
Charge is Separated, this creates a Voltage, and a Current requires the continuous Separation of Charge! Current must be Supported! Here is a Quote from Floyd Sweet:
E.M.F's are generated by devices that separate charge. A familiar example is the battery which utilizes chemical forces to separate charge. Other examples include the heating of a thermocouple, exposure of a photovoltaic cell to incident light, or the rubbing together of different materials (electrostatic charge separation). Electric fields are also produced by time varying magnetic fields. This principle is extensively exploited to produce conventional electric power in the utility industry.
We just saw this in the above Video, simple, makes sense, logical!
Other Forums are Light Years Behind, simply because they Ignore the basic Rules of Electrical Energy "Generation", they do this for a Reason! It is to Mislead you, to keep you running off down Rabbit Holes! Chasing Magic and Voo Doo Science with nothing but Bull Shi*t!
My Goodness Me, please see what they are doing, please see the non-sense they keep spreading, the lies they tell, there is a small group that is actively misleading the masses, and its sickening to watch!
We now have small groups all through-out the world, Politics, Medicine, Big Phama, Tech Companies, and more, no wonder people are going Crazy! Biden is the worlds biggest looser and he is only one of many!
electrondiger posted this 27 September 2023
I have found one citation that one guy talked that if you use two homoplar generator disks you get most eficient power generator as we dont have nothing similar on the earth. This guy was from america i think and when i check him. He has a book about how he  was taken from earth in a fling "thing" and so on,... and then he asked what is power sorce for this flying "thing". Ihoped that is more detain in his book, but i didnt find it.
Weird story. I know.
