Challenging Kirchhoff Faraday Maxwell
- 634 Views
- Last Post 22 November 2018
Hey MrBlobby
Great work you have done man. What's next in your experiment ?
ps: my small gift for you MrBlobby !
Best regards
Not my work alohalaoha, I'm just the messenger.
It's from a Youtube channel I've been following for a few years now, by the name of 'Arkiver Unified Energy'.
Thank you mrblobby
Presented experiment is extremely interesting because judge - official msm physics is wrong. Only problem with this civilization is IGNORANCE! And that problem need to be solved as fast as possible.Why ? Because there is only one way out of blind alley - LIGHT OF KNOWLEDGE ! Other is abyss of darkness and non existence.
PS: Those who will try to repeat above radiant experiment, beware of any mistakes. Radiant can't be shielded, or we still don't know how, because playing with radiant is like a pulling the tail of Dracon. We have deal here with Elemental Power which source is in infinite Aether and Essences which exist there. This planet haven't been made by accident, but with the will of infinte consciousness which exist out of space and time.
Or to say with Tesla's words "If you want to discover the TRUTH, you need to become part of her" !
1st it was Nikola Tesla who had discoverd Radiant effect!
Than in 70th years of last cenury in USSR Rimily Fedorovitch Avramenko, had repeated Tesla discovery !
Than Don Smith in USA in 2006 has again repeated Tesla's experiment and make free energy device due to power of Radiant. That is all we need to produce enormous current. By the way Radiant also was released in partnered coils but in small amounts due to use of very low voltages. High voltage is Master Key to free Radiant out of Matter, whatever device configuration you are using !
Same Tesla Radiant process in two devices !
Now you know the Secret of Don Smith - Tesla Radiant at 3,73 KV. This voltage coud be different in some small voltage range but not to much. This is due to geometry and spark gap tuning. For spark gap best is use Tesla's magnetic quenching spark gap, two NdBr magnets with different poles at two different sides of the arc. Magnets must be isilated with thick layer of mica between arc and them.
Radiant fly longitudinaly from Aluminium plate only when the copper plate is grounded. So you can control ammount of released Radiant by periodicaly swith earth-ground conductor with the circuit.Connection of ground-earth conductor should be made only with knife switch. Beware to use grid ground. Make isolated ground with copper tube sticked deep into ground at backyard of your house and use thick welding conductor to make ground link with the device in your room or lab !!
Why nobody have success with Don Smith's board replication ?
Becuase Don had used NST (Neon sign Transformer) redesigned by him to give output of 3,73kV with some voltage offset due to use of PWM duty controlled oscillator. He has shown how to get more cuurent (move primary on the left from center point of partnered coil , over CCT windings, or more voltage (more primary to the right over the CW windings). He had used spark-gap gas dischare tube for fine control HV DC output voltage at 3,73kV.
In Colorado Springs Tesla had used voltage about 14Million volts which could be easy second etheric voltage resonance 3,73kV^2 =13,91 MV. This is the probably only way to get out of his Magnifying Transformer 1 TeraWatt power. Can you imagine how much Radiant he had released, and all of it on strictly controlled way ?
ps: Radiant have direct connection with Electronegativity of metals !
Reg.
- Chris 350
- akoteles 100
- Arya 100
- Gucio_81 92
- FringeIdeas 90
- thaelin 50
- skywatcher 20
- anarsu 20
