Apparatus and Method for Extracting G-Energy from a Defined Space!
  • 3.2K Views
  • Last Post 21 August 2019
glennmr2018 posted this 19 May 2019
hei guys, the following is my own original writing, and is more practical than you may think at first! You will especially get the idea when you see the illustrations. cool
Apparatus and Method for Extracting Gravitational Energy from a Defined Space.
            According to earlier researchers (e.g. Vallee*) there exists an amount of negative potential gravitational energy in any given volume of space (air) on the earth’s surface, which is not at all dependent on mass, but dependent only on local gravitational acceleration (g) and the volume of defined space in question:
 - “We are thus constrained to admit that the matter vacuum must contain, actually, an important quantity of diffuse energy having a finished density p0 in interstellar space. A simple calculation shows, indeed, that one cubic meter of empty matter space on the surface of the ground contains, in the form of energy diffuses 57.000 Mega joules less than one cubic meter of interstellar space. It is thus well necessary that this energy exists, whether it is in this form or another!...”   (- g2 /8π G)
            Taking this at face value, a volume of 1 cubic centimetre would then contain 5.7 x 1010 x 10-6 or 5.7 K-Joules of such potential energy. It must be emphasized that such energy is inherently in a negative (or possibly inverted) state and to be utilised, would need to be activated, resonated and extracted via a cascading of impedances, keeping in mind that the universal impedance of free space (Z = 377 Ohms) still exists within vacuum or air. If such an amount of energy were to be resonated at (say) 7.83Hz (the earth's Schumann Resonance), then the potential Power Output (in the frequency domain) would be:
            (2.π.f) En =  6.28 x 7.83 x 5.7 x 103  =  280 KiloWatts
(since Power = the instantaneous rate of change in Energy) and if the Impedance (Z) were engineered down to 377Ω as well, and so likewise the available Current and Voltage Output would become:
 I =  √(P/Z) = √[(280/377) x 103 ] = 27.3 Amps and V =√(P.Z) = √[(280x377) x103 ] =  10.3 KVolts,                    if it could be converted as such.
 Lower frequencies are much preferred for practical purposes anyway, and in any case, ELF (aka prof. Fran de Aquino) is recommended as an initial trial input signal, or even step inputs, in order to carefully monitor the output effects.
            Without delving into further technicalities, the proposed excitation pulses could be expected to produce an output at right angles to both the applied E and H fields but in parallel with the solenoids used for said excitation, as the E & H field begins to precess or gyrate under the influence of the applied input signals. Such an output of rotating or gyrating magnetic fields could well be syphoned off via similar solenoids (conical or otherwise) placed orthogonally. See original figures below/attached.
(since improved on!)
written circa 2012, but substantially re-edited in May 2019 A.D.
G.M.R.
Main Reference:  http://jlnlabs.online.fr/vsg/synergetics.pdf
Rene-Louis Vallee - THE ELECTROMAGNETIC ENERGY, MATERIAL AND GRAVITATIONAL (1970)
The basis of Synergic theory - see p. 86 - http://www.rexresearch.com/vallee/vallee.htm
Hagelberg, P. Physics, an Introduction..., Prentice Hall, 1973, page 622
 http://www.zpenergy.com/modules.php?name=News&file=article&sid=117
Visualize the Shape of Things Not Yet Seen with Eyes !! ... .. .
p.s. i had to cut out most of the maths above as there was not sufficient room to paste it all in.
I can share it with anybody who asks.
glennmr2018 posted this 20 May 2019
last part:
            Without delving into further technicalities, the proposed excitation pulses could be expected to produce an output at right angles to both the applied E and H fields but in parallel with the solenoids used for said excitation, as the E & H field begins to precess or gyrate under the influence of the applied input signals. Such an output of rotating or gyrating magnetic fields could well be syphoned off via similar solenoids (conical or otherwise) placed orthogonally.  (at right angles)
Anyone wishing to have a copy of my Corrected TABLES is welcome to ask!
Jagau posted this 21 May 2019
Hi Glenn
This kind of technique is new to me.
It takes a bit of time to study his concept.
At first it seems to be a device that produces energy from a defined space from orthogonal coils using some special concepts of the golden number and E and H pulses. It can take a long time to understand everything.
glennmr2018 posted this 21 May 2019
Yes my friend, it can! and i have taken nearly 24 years to understand and work this out, but now i feel i should share it freely in the spirit of why this forum was founded. Please take it and Run with it!
with my compliments
Glenn
Atti posted this 21 May 2019
Hi Glenn!
Really great work. Is there any experience in practice, visible somewhere? Is there any measurement?
Just what we learn. And most importantly not just the theory.
I assume the practice is because you want so many years (24 years).
Atti posted this 22 May 2019
Glenn.
It's just a blueprint. Is there work done? Is there a measurement?
If there is nothing, it is worth nothing. I'm sorry.
Zanzal posted this 22 May 2019
Glenn.
An idea can still inspire...
glennmr2018 posted this 23 May 2019
dear Atti!
                   and Others!
                                          i will be very brief and to the point:- Is this a blueprint? - Correct!
Is this worth nothing? - Absolutely wrong! - in the spirit of the open source sharing of this fine forum, my policy has always been to design and SHARE FIRST, then if/when i get time and/or equipment, to work on the design for myself.
I know that i know that i know that this design of extreme worth, and you will not find such quality of detail anywhere else on the web, or possibly elsewhere, so you guys don't know how fortunate you are!
In short: - If you are a fool, then stand there and ask what i have done with it,
                  If you are Not a fool, then take this free gift and RUN with it!
                     You will never get such a chance again, rest assured of that!
GMR
Please Note Significant Changes - the Core is No Longer Connected Directly to the Source Outputs!!
  • Marathonman
p.s. but Yes - 'an idea can still inspire" - you are quite right about that! cool
Chris posted this 23 May 2019
I have tried to be patient, this thread is completely off topic.
State relevancy and why this thread should be kept on this forum! It has nothing to do with bucking coils nothing to do with EM Power Generation.
I am getting tired of nonsense and non relevancy!
Marathonman posted this 24 May 2019
It is none of my business but this is along the lines of Walter Russel and Lord knows he was as gifted as Tesla. the core are set up to compress the field lines as they are set up which could result in some impressive output if one is cleave.
Just saying, there are way more useless threads then this one. everyone was against me at one time, then through time the madness drifted out and reasoning drifted in.
glennmr2018 posted this 25 May 2019
Dear Chris!
I am being patient too, but since you have now asked me specific questions, I will give you very specific answers:-
1stly, you wrote “State relevancy” – OK, here we go: - Please do yourself the favour of actually having a close look at the diagram I have copied below – When you do so, you will clearly see that it has EVERYTHING to do with bucking coils! – Can you see how each coil of the coil pairs is directly bucking the other? – Please check again – it may take a while to actually sink in, but it is exactly what I said.
Not only is it 1 pair of bucking coils presented here, but 2 pairs working together, and both pairs in perfect harmony, with the pulse timing shown at the base of the chart. Now please tell me how ‘It has nothing to do with bucking coils’ ! - I will await your specific answer. ... .. .
2ndly, you wrote: “It has nothing to do with bucking coils nothing to do with EM Power Generation.” –  to this, I couldn’t agree less! – Again, if you take the time, just a few minutes, to actually LOOK at the details in my chart, and study them for a little while, you will actually soon realize that this again has EVERYTHING to do with EM power generation! – Why or How? – again, just see the excerpt below -  the problem here may be once of semantics, in that I may be using terms that are not yet very familiar to you and other readers on the forum, however, that does not mean the terms I am using are irrelevant or non-sensical, it just means some people have some catching up to do! If you actually take a few minutes to FOCUS on details in my presentation chart, you will sooner than later see that the process of EM power generation is literally printed all over it! – thus to claim that it has ‘nothing to do with EM power generation’ is frankly, to use your word ‘nonsense’! Maybe your rash conclusion comes from the fact that I am not just using the usual tired old keywords or that most people are yet used to in this field of research, but am using a wider range of terms that provide fresh insights into the same truths we are all (hopefully) striving towards.
OK, if after all this clarification, you still cannot or perhaps will not see the relevance to the forum’s aims, I will simply take it off and share it on a forum with people of more open mindedness, if there is one, or not at all.  I don’t actually care that much if others can’t  or won’t see it for now, or perhaps never will. That’s their business. Yes I know you founded this forum, and I acknowledge you have done a LOT of hard work and shared nearly everything, as I have endeavoured to, but you don’t have all the insight, and neither do I, but you don’t need to label an alternative or unique approach as ‘nonsense’ just because you are not accustomed to it. You must be a pretty open-minded person to have even started off in this field, so all I would ask of you is to just open up your mind a little more, and give this a chance. If not, it will still be your choice. The call is yours.
Let’s still ‘be part of something better’ -    Glenn  MR
  • Marathonman
dear MarathonMan
Well thank you for your inverted compliment! - the fact is that i only briefly looked at Walter Russell's works many years ago, and never properly studied them, so any superficial similarity between his and my work is just that - superficial. He was though as you stated, a very gifted man, and probably far beyond Einstein, who was a bit of a plagiarist.
However, i DO believe we should give credit where it is due, so i can acknowledge some influence from W.Russell, and of course many others. Even Chris's artwork has inspired some ideas for me as well. Just for the record, i have been working on this type of thing on and off for 24 years, and can show records to prove it. That alone is no proof of anything, but as you wrote, i am also trusting that open-minded reasoning will drift in here too and people will get outside of the box in order to look into it afresh! (now that's original too!)
Glenn MR
  • Marathonman
Marathonman posted this 25 May 2019
There is no superficial about it, if you do some research on Walter Russel's set up when he actually changed elements into another form with a set up just like this..
as for your setup. it does have possibilities as compressing the field lines on two different planes so keep on keeping on.
also it is possible to get magnetic and electric sensors placed throughout the center area and record various intensities, directions, field interactions and such. a lot could be learned from this as it is right along Chris's work except your compressing from four different angles not just two.
Chris posted this 25 May 2019
Hi Glen,
I will allow your thread and monitor as I do with all threads. It is Walter Russel Tech and others may gleam the insight as you have.
I must make an apology as I was under the weather and made comments partially out of context, with other interfering problems also.
We have very little time left, we are at a cusp, if we don't get this Technology specifically, we, the Human Race may never get the chance again! Time is short, so I ask you, give it your best shot and please remember, I also am doing the same and trying to be as specific as I can. So if our paths do not align as I hope, then I can not allow outside distractions that I find could be misleading of others wanting to learn.
We must make, as best we can, Specifics, and state when we are not sure.
glennmr2018 posted this 26 May 2019
Hi Glen,
hei Chris!
Well thanks for your positive comments today and of course i accept your apologies as well! Yes i can agree that we don't have much time left - i also share a sense of urgency, but Not panic. Agreed that we need to be as clear and specific as possible and to admit when we're not sure - noted. I appreciate your decision to keep my thread on the forum, and am happy to keep sharing freely. Re: W Russell, ok i can admit that it bears perhaps more than a superficial resemblance, if you say so, but honestly i have not read his works for many years. Now i am getting curious as to how it relates to mine. OK, see u on the forum, and again i regard this forum as one of the best - keep it up. regards Glenn
glennmr2018 posted this 27 May 2019
hei Guys - please see my latest chart revision above! - now much clearer regarding the switching process & timing of both input and output transistors/gates/mosfets (take your pick) + some keys clarified eg. scalar input-> vector output!
BTW - the aerial and earth shown in this scheme are OPTIONAL here, but can be better put to use with an air-cored ground-based system, speaking of which -
This scheme is based on a cubic core made of special composite material, but i have been asked to describe if such a thing could be designed with an AIR CORE - the answer is YES - so my next schematic sketch will show you how! - this will probably illustrate the method and procedure more clearly to many of you.
GMR
  • Marathonman
                                    TUNING the GRLC Core:
B = µ0 H  where µ0 : permeability of free space (Henries/meter)
µ0 = 4π x 10-7 = 1.26 x 10-6 H/m  (μr = 1 for air)    (B: flux/sq.m.)
D = ε0 E  where ε0 : permittivity of free space (Farads/meter)
ε0 = 1/(36&pi x 10-9 = 8.85 x 10-12 F/m  (εr = 1 for air)  (D: webers/sq.m.)
Combined EM Energy Product = [√( µ0 ε0). EH.Ad] = EnEH (Joules)
Note: if A = Area = d2  and   A/d = d = depth   ( if core is a cube)
ideal GYRO Electro-Magnetic applied Frequency = ωg (radians/second)
ωg = 1/(me.c).√[h/2. EH]
and PEH : Potential Output Power = ωg.EnEH (Watts) (in the frequency domain)
where me : mass of electron, c: light speed, h: Plank’s constant
Worked Real-Life Example: (note: 'Voltage' here is Potential Difference!)
Let d = 10cm, thus A = 100 cubic cm = 10-2  so A.d = Volume = 10-3 m3
E = 100 V/m so V = E.d = 100 x 0.1 = 10V but E.d/2 = 100 x 0.5 = 5 V
H  = B/µ0 = 45uT/1.26 u-Henries/m =  [45x10-6 ]/[1.26x10-6] = 36 A/m !
Thus combined EM Pot. En. Product = 1/c. [√ EH].(A.d) since [√( µ0 ε0)] = 1/c
so EnEH = ...  micro-Joules  (not very much!)
Solution: Add Magnetic Potential - eg. magnets to upper and lower plates!
(but don't use ferrous plates so mag. field can penetrate into core)
Typical modern Neodymium magnets have B ~ 1Tesla but H ~ 1KA/m !
So again: combined EM Pot. En. Product = 1/c. [√ EH]. Ad
Now, if ideal GYRO Electro//Magnetic applied Frequency = ωg (rads/s)
i.e. ωg = 1/(me.c). √[h/2. EH]   where me = 9.11x10-31 , h = 6.63x10-34
(a mistake was found by yours truly - to be corrected and filled in sooner or later)
To achieve this power output under the above-mentioned conditions, such a high pulsation frequency of nearly 1GHz would need to be used - not normally practicable, so an air-core is not recommended, and should be substituted with a core of specially prepared composite material as already described! - so that the εr and μr can get multiplied in to the EnEH potential equation in order to increase it, but while at the same time, the E and H inputs can be lowered (eg. 12V/m and/or 1KA/m) to allow a lower input frequency! Lowered frequency and less EH but higher εr . μr would then tend to then cancel each other out but still allow a similar Power Output! -
Motto: Do the Maths!
GMR
Vidura posted this 27 May 2019
Hey glennmr, Respectfully, as math's is not my strong side , if I may ask if you have build such a device, are there some experimental results to show the expected effect? Regards Vidura.
Simplified (Non-Maths) Version:
Believe me, real models are coming, and i now have contact with my old coworker-associate in NZ, who is an electronics technician. The foundation via mathematics must first be laid in order to know how to proceed properly!
In order to obtain real electrical power output from pulsing into a defined cubic space via 2 pairs of bucking coils at right angles, it is better to not use an air core!
What about gravitational (g) energy? - how does it relate to this?
ANY space on the earth's surface contains g-energy due to its volume! In order to make use of some of it, it is required to counteract it with applied EM energy and to thereby resonate it via vector-zero pulsation at right angles, however it is NOT necessary to activate ALL of the available g-energy as it usually more than required, so the amount of EM Potential energy applied is used to calculate the amount of useable electrical energy to be extracted and converted to power.
Can a cubic air-core be used for this purpose?  - Yes, but the frequencies required for air-cores is too high for the practical purposes of home-based handymen. Therefore it is much more recommended to construct a core of special composite material that is high in magnetic permeability (μr ) as well as       electrostatic permittivity (εr )! -
What do these 2 terms mean? - μr is the ability of a material to absorb or transmit magnetic potential energy, while εr is the ability of a material to transmit or absorb electrostatic potential energy.
 These types of materials are not difficult to find and may well include: - welding rod coatings, certain ferrous sands, ferrite powders, ceramic and cermet type materials etc - once mixed though, they will need to be compacted and set hard by the use of resins etc. Don't forget to insert the central plate first!
I trust this helps!
GMR
Chris posted this 28 May 2019
Glen, please stop bolding everything.
Use the [Ix] Button to clear any unwanted Copy Paste formatting you need to remove.
Thank You.
glennmr2018 posted this 28 May 2019
loads and their equivalent impedances
Jagau posted this 28 May 2019
Just a suggestion Glenn.
The images are difficult to read, could you put it in attached file
there is a button for that
so that we can enlarge it ??
glennmr2018 posted this 29 May 2019
hei Jagau - that is exactly what i have been doing!
glennmr2018 posted this 31 May 2019
first cube incubating - May/June 2019!
glennmr2018 posted this 24 June 2019
btw, i now have an expert ex-associate in NZ working on assembling these models out of pyrothene and magnetite etc,
and will be able to show real pictures soon! .. Meanwhile, take a look at this mini-lesson in simplified format! - cool
simplified G-Pot-Energy lesson
Marathonman posted this 27 June 2019
I see the the pace between the cones and the upper and lower magnets  a very highly compressed state and the possible output could literally melt wire like no tomorrow so it seams to warrant thick wired coil. compressing from three different plans is very interesting and i can not wait to see the reaction of highly compressed space. even switch like Graham's step switching you should hit well over 1000 volts possibly.
glennmr2018 posted this 28 June 2019
hei Marathon Man! Thanks for your sensible comment~but rest assured.... I've already prepared the circuitry to cope with excess heat outbreaks!.. See how the second load below is a Counter Load..designed to Absorb heat instead of Disipating it! 🌝
Marathonman posted this 04 July 2019
If anyone would like to see where this thread,  along the lines of Water Russel,  is leading PLEASE!  read this link thanks to Jahau that got me searching.
http://www.resonantfractals.org/PCC/Dual_Cones.html
this material is literally the cutting edge Physics of human understanding as we know it. i think it will simply blow you away.
i can not stop reading and have printed in  PDF form from Bull Zip Printer on my computer for safe keeping and further study.
amazing Glen at the possibilities to come. KEEP ON TRUCKIN !
  • glennmr2018
glennmr2018 posted this 04 July 2019
Thanks again Marathonman for your informative and intriguing comment and link! - we have since made some considerable progress on this GRLC device, and 2 cores have been poured and set, with a quad set of pancake coils on each!
The truncated conical windings are still to be made, but i can show you some basic pics soon! cool
poured GRLC CUBEs  first-fruits !
When you spoke a few posts ago referring to materials to use were you referring to Fe304 and such which can be used at extreme high frequencies and retain zero magnetization.? i also have 10 lbs of high purity iron powder @ 99.5 % purity. saving that for a  possible Robbert Adams build pending results of the core.
just curious.
marathonman
glennmr2018 posted this 05 July 2019
hei MM - another good question - The whole point about this is that the core material should be a COMPOSITE material with both its Magnetic and Electric properties pretty much balanced out, or as much as possible! - so for this kind of material, pure iron powder would Not necessarily be very suitable, as it doesn't have much Permittivity to Electric Fields! - a better choice is Magnetite powder and/or welding-rod coating powder! - the latter is easy to get and to crush up, and exhibits both properties pretty much! - i hope that helps!
glennmr2018 posted this 06 July 2019
first cores
Here are the first proper GRLC cores prepared and poured by David Ball, NZ - good On ya, David, ol' mate!
first cores 2
and just before pouring - (after pouring, the weight came to almost 630g)  - dimensions are 4x4 (sq.cm.)
glennmr2018 posted this 11 July 2019
testing of properties
Testing for mag. permeability and dielectric permittivity !!..
testing for mu & epsilon
testing for mu & epsilon again ..
glennmr2018 posted this 26 July 2019
(this was published on the AboveUnity Forum back on 28th May,
but needed correcting, which has now been done)
Since this example uses an AIR CORE, then  µr = 1 =  εr (!)
Let d = 10cm = 10-1, thus A = 100 cubic cm = 10-2  so A.d = Volume = 10-3 m3
E = 100 V/m so V = E.d = 100 x 0.1 = 10V but E.d/2 = 100 x 0.5 = 50 V
Thus combined EM Pot. En. Product = 1/c. [√EH].Ad since [√( µ0 ε0)] = 1/c
so EnEH = [1/3 x 10-8 x [100x36x10-3]0.5 ]= 20 micro Joules  (not very much!)
CORRECTION: combined EM Pot. En. Product = 1/c. [√ EH].(Ad)    (NB)
so EnEH = (1/3 x 10-8) x [100x36]0.5 x 10-3 = 0.33 x 60 x 10-11 = 200 pico Joules
Typical modern Neodymium magnets have B ~ 1Tesla but H ~ 1MA/m !
So again: combined EM Pot. En. Product = 1/c. [√ EH]. (A.d)
so EnEH = [3x108]-1 x [100 x 106]0.5 x 10-3 =   0.333 x 10-7  = 33.3  nano Joules (!)
   µr (still) = 1 =  εr  (result is a bit better!) so … .. .
Now, if ideal GYRO Electro-Magnetic applied Frequency = ωg (rads/s)
i.e. ωg = 1/(me.c).√[h/2. EH]   where me = 9.11x10-31 , h = 6.63x10-34
then ωg => [9.11x10-31x 3x108]-1 x [6.63x10-34 x 0.5 x 100x106]0.5
               =  [9.11x3x10-23]-1 x [6.63x0.5x 10-26]0.5 => 979 Mega rads/sec !
                                                Which over 2.pi  =  155,892 Mega Herz
Now for potential power output, since PEH = ωg.EnEH ,   µr (still) = 1 =  εr
P => [1/(mc2).√(h/2).√[( µr.εr).(EH)].(Ad)]   =  22.2 x10-5 x √[( µr.εr).(EH)].(Ad)]
PEH => 2πf. EnEH = 979x106 x 33.3 x 10-9  = 32,601 x 10-3 = 32.6 Watts !
(However low this result is, the EH values can be regarded as Gateways) ! !
(just in case anyone is interested in my derivations above)
glennmr2018 posted this 28 July 2019
p.s. - the centre plates you can see here can also be regarded as an artificial BLOCH WALL !! cool
Main Equations//Algorithms Used Here Are as Follows: )
Since Speed of Light (c)  =  inverse of √ (μ0 ε0 ) = ( μ0 ε0 ) -0.5 (m/s), then
 (1/me).√[(h/2).(µ00.µr.εr).EH] = ωg = (1/mec).√[(h/2).(µr.εr).(EH)]
 so then ωg  = (1/ me c). [√(h/2)] . [√ (µr.εr).(EH)]
so laughing ωg = [20100] x [√ (µr.εr).(EH)] laughing
 where me = 9.11x10-31 , h = 6.63x10-34 , c = light speed  = 300,000,000 m/s
then Power = PEH = ωg.EnEH => [1/(mc2).√(h/2). √[( µr.εr).(EH)].(Ad)]
= [9.11 x 10-31 x 9 x 1016]-1 x [6.63 x 0.5 x 10-34]0.5 x √[( µr.εr).(EH)].(Ad)]
= 0.0122 x 1015 x 1.82 x 10-17 x √[( µr.εr).(EH)].(Ad)]
so cool PEH = [22.2 x 10-5] x √[( µr.εr).(EH)].(Ad)] cool
Chris posted this 10 August 2019
Hi GlenMR,
Bold Text Posts and images that you are posting, that only the odd component here and there are made out, is just a distraction to all readers!
When you started this thread I asked you to keep the posts on topic and to loose the Bold Texting of the entire posts.
I have been patient, I have read your posts, please:
  1. Please un-bold every post!
  2. Please post images that are clear and easy to follow!
  3. Please fix every post that you have posted!
Currently I see this thread as a distraction and not relevant to anything we are doing, if you can change my mind then it stays.
glennmr2018 posted this 11 August 2019
Hei Chris! surprised
                        OK then, but 1stly, let me remind you of a few basic facts about some of your readers and/or contributors (including ME) – Some of us are over 60 years of age, and therefore NEED bold print to read for at least 2 reasons! – 1. to make it clear enough to read, and/or 2. to type as we go, as well as 3. presenting clarity!      Go Figure Man! (that is, it’s a physical necessity for some)
2ndly, I have not, and do not plagiarize off Anyone, including your beloved Walter Russell (hard as it may be for you to comprehend or accept the fact) but 99% of my work is Original, but with admixtures of ideas and design from various people, including artwork from yourself, as you should know by now! I have briefly looked at W.Russell’s works in the past, but found them quite incomplete, in my view.
3rdly, as to Relevancy – Again, you are totally blind to the fact that my presentations are Totally Relevant to your main theme, which is Partnered Output Coils (POC) and if you actually LOOK into my diagrams you will see them presented clearly all over the place (except that I present them as partnered Input/Output Coils, with a double or mutual function). I mean it couldn’t be any more relevant if it were to rise up behind you and bit you on the A*** !
What I think you Really mean is that you cannot comprehend the deeper meaning or application(s) behind these designs, but which as I again remind you, is clearly outlined step by step in my comments and descriptions!! – If you cannot get your head around this, then it’s not My problem! Last time you admitted:
‘’Hi Glen(n),     25 May 2019 ‘’I will allow your thread and monitor as I do with all threads. …I must make an apology as I was under the weather and made comments partially out of context, with other interfering problems also. ‘’ -  so what’s wrong this time? Having other problems? (btw, I don’t drink or smoke, if that’s relevant)
4thly, You are still stuck in your squarish box which is really a 4-D environment, but you can’t see this – All you can see is the plain 2-D square of the floor you are staring at, because you have forgotten to open your windows to enlighten your brain a little more !! You can’t or you won’t see that the 8 points of your box represent 3D progressing to 4-D, let alone being willing or able to step out of the box, which is surrounded by the circle of familiar concepts you have built up around you!          (Go figure again, if you will) There is always a world outside of your world, but you don’t want to see it, because ‘nothing is as painful as a new idea!’!(for you, anyway)
5th, re formatting in general, why does it seem SO much more important to you than the actual CONTENT of the posts?? – Surely the Content is the main thing, isn’t it?
Since you are blind to new (or rather ancient) truths being presented by me in new ways, I suppose there is no other option than to leave this forum behind and not waste my time with it any more! A few have seen the light from time to time though, ‘as in a night mirror, dimly’. I don’t need anybody’s approval anyway, when I know what I’m doing, and am steadily progressing towards it, week by week … .. .
Since you don’t give me any credit for fresh and new ideas etc, except just once back on another forum, where you once described my post as ‘’brilliant’’, I now know that I don’t have to give you any more credit either – fair is fair, mate! I have always stated my known sources of ideas including you, in my published designs, as you should have noticed! From now on, I won’t bother, not that I really need others’ ideas anyway, even less de-constructive criticism! Thus I think I will give you a day or 2 to think about my remarks, and if you don’t like them, just delete my thread. I thought that this was the best forum around for FE research and also because it’s local or at least Aussie-based, we could be proud of it! Now I just wonder if I was wrong. I will just go to find people who are truly open-minded to new truth(s)!
Farewell. Adieu. Godspeed. All the Best, but there is no such thing as ‘good luck’. coolfrown
patrick1 posted this 11 August 2019
haha yous passion is cool,  but much like formatting and punctuation in general,  if it isnt bucking coils, it dosnt float my boat, let alone propel it,  or mankind in general.
thankyou however is very much in order, and good job !!.  i hope you actually build this thing and take some measurements, - however i suspect it will be very difficult too get any accurate readings at those power level,s because of chris;s intense third eye burning out your meters.
girly giggles  **
but seriously love peace and unity.
im on abit of a high after my best results yet with bucking coils....  COP 2...   hmm... i have some catching up too do
merry chrismas all.
Chris posted this 12 August 2019
Hi Glen,
1: If you have a problem with my site formation then please bring it to my attention. A PM would be good.
2: I see where you are trying to link your ideas with mine.
3: What you describe in your posts is nothing like my work!
4: If you feel the need to leave, then that's up to you.
5: My forum is my responsibility, all I am asking is that you make an effort to not make a mess of it. Bolt Posts, and images that have no clarity are just no good for anyone. If you made just a little more effort here, then others would no doubt find your effort more readable.
6: You're  some 50 posts in and have shown no progress.
7: I warned you and you persisted in bolding, you asked for no help. You only ignored my request!
8: What I am showing and what you are showing is not the same.
Glen, let me be straight, I have a responsibility. A responsibility to not let our Forum become like the others!
What sets us apart? We have direction! We have meaning, we have a specific dedicated proven technology!
We are not here showing a bunch of Guess work!
We are not showing Equations of something that might work one day!
We are not showing anything that might be confusing and or illegitimate or irrelevant!
My responsibility is, that every post on my forum has meaning, for years to come, for other readers to know they can read and gain something from it, in a specific direction with context to one single goal! A Working Energy Machine.
Glen, I am sorry, but I have given you a good chance! For the sake of keeping my forum on topic and also credible, I am going to have to delete your thread.
I have no room for anything that may create confusion!
patrick1 posted this 12 August 2019
well said chris.
although if there is any amazing results, i would absolutely love too see them... but the whole thing looks abit Dr who
